root/radiance/ray/src/hd/rhd_qtree.h
Revision: 3.11
Committed: Mon Aug 17 17:59:59 1998 UTC (26 years, 11 months ago) by gwlarson
removed "color.h" include from tonemap.h
1 /* Copyright (c) 1998 Silicon Graphics, Inc. */
2
3 /* SCCSid "$SunId$ SGI" */
4
5 /*
6 * Quadtree data structures for holodeck display drivers.
7 */
8
9 #include "color.h"
10 #include "tonemap.h"
11 #include "rhdriver.h"
12
13 #define DL 0 /* down left */
14 #define DR 1 /* down right */
15 #define UL 2 /* up left */
16 #define UR 3 /* up right */
17
18 #define BRF(i) (0x1<<(i)) /* branch flag bit */
19 #define LFF(i) (0x10<<(i)) /* leaf flag bit */
20 #define CHF(i) (0x100<<(i)) /* change flag bit */
21 #define CHBRF(i) (0x101<<(i)) /* changed branch bit */
22 #define CHLFF(i) (0x110<<(i)) /* changed leaf bit */
23 #define BR_ANY 0xf /* flags for any branches */
24 #define LF_ANY 0xf0 /* flags for any leaves */
25 #define CH_ANY 0xf00 /* flags for any change */
26
27 typedef struct rtree {
28 short flgs; /* content flags (defined above) */
29 union {
30 struct rtree *b; /* if branch */
31 int li; /* if leaf */
32 } k[4]; /* children */
33 } RTREE;
34
35 extern struct rleaves {
36 float (*wp)[3]; /* world intersection point array */
37 int4 *wd; /* world direction array */
38 TMbright *brt; /* encoded brightness array */
39 BYTE (*chr)[3]; /* encoded chrominance array */
40 BYTE (*rgb)[3]; /* tone-mapped color array */
41 int nl; /* count of leaves in our pile */
42 int bl, tl; /* bottom and top (next) leaf index */
43 int tml; /* next leaf needing tone-mapping */
44 char *base; /* base of allocated memory */
45 } qtL; /* our pile of leaves */
46
47 #define is_stump(t) (!((t)->flgs & (BR_ANY|LF_ANY)))
48
49 extern RTREE qtrunk; /* trunk of quadtree */
50 extern double qtDepthEps; /* epsilon to compare depths (z fraction) */
51 extern int qtMinNodesiz; /* minimum node dimension (pixels) */
52
53 extern int rayqleft; /* number of rays to queue before flush */
54
55 extern int4 encodedir();
56 extern double fdir2diff(), dir2diff();
