--- ray/src/hd/rhd_qtree.h 1997/11/24 15:15:21 3.4 +++ ray/src/hd/rhd_qtree.h 1997/11/25 16:52:04 3.5 @@ -42,20 +42,8 @@ extern struct rleaves { char *base; /* base of allocated memory */ } qtL; /* our pile of leaves */ +#define is_stump(t) (!((t)->flgs & (BR_ANY|LF_ANY))) + extern RTREE qtrunk; /* trunk of quadtree */ extern double qtDepthEps; /* epsilon to compare depths (z fraction) */ extern int qtMinNodesiz; /* minimum node dimension (pixels) */ - - -/************************************************************************ - * These driver support routines implement the dev_value() call, but - * require the following callbacks: - -dev_paintr(rgb, x0, y0, x1, y1) : paint a rectangle -BYTE rgb[3]; : rectangle color -int x0, y0, x1, y1; : rectangle boundaries - -Draws an open rectangle between [x0,x1) and [y0,y1) with the color rgb. -This function is called many times by qtUpdate(), qtRedraw() and qtReplant(). - - ************************************************************************/
