--- ray/src/hd/rhd_qtree.h 1997/11/20 18:03:43 3.2 +++ ray/src/hd/rhd_qtree.h 1997/11/21 13:35:58 3.3 @@ -18,30 +18,37 @@ #define UL 2 /* up left */ #define UR 3 /* up right */ -#define BRF(i) (1<<(i)) /* branch flag bit */ -#define CHF(i) (0x10<<(i)) /* change flag bit */ -#define CHBRF(i) (0x11<<(i)) /* changed branch flags */ -#define CH_ANY 0xf0 /* flags for any change */ +#define BRF(i) (0x1<<(i)) /* branch flag bit */ +#define LFF(i) (0x10<<(i)) /* leaf flag bit */ +#define CHF(i) (0x100<<(i)) /* change flag bit */ +#define CHBRF(i) (0x101<<(i)) /* changed branch bit */ +#define CHLFF(i) (0x110<<(i)) /* changed leaf bit */ +#define BR_ANY 0xf /* flags for any branches */ +#define LF_ANY 0xf0 /* flags for any leaves */ +#define CH_ANY 0xf00 /* flags for any change */ -typedef struct { - float wp[3]; /* world intersection point */ - TMbright brt; /* encoded brightness (LogY) */ - BYTE chr[3]; /* encoded chrominance (RGB) */ -} RLEAF; /* recorded ray (leaf) value */ - typedef struct rtree { - short flgs; /* branch flags */ + short flgs; /* content flags (defined above) */ union { struct rtree *b; /* if branch */ - RLEAF *l; /* if leaf */ + int li; /* if leaf */ } k[4]; /* children */ } RTREE; +extern struct rleaves { + float (*wp)[3]; /* world intersection point array */ + TMbright *brt; /* encoded brightness array */ + BYTE (*chr)[3]; /* encoded chrominance array */ + BYTE (*rgb)[3]; /* tone-mapped color array */ + int nl; /* count of leaves in our pile */ + int bl, tl; /* bottom and top (next) leaf index */ + int tml; /* next leaf needing tone-mapping */ + char *base; /* base of allocated memory */ +} qtL; /* our pile of leaves */ + extern RTREE qtrunk; /* trunk of quadtree */ extern double qtDepthEps; /* epsilon to compare depths (z fraction) */ extern int qtMinNodesiz; /* minimum node dimension (pixels) */ - -extern RLEAF *qtFindLeaf(); /************************************************************************
