--- ray/src/hd/rhd_qtree.h 1997/11/20 18:03:43 3.2 +++ ray/src/hd/rhd_qtree.h 1998/12/17 09:46:35 3.12 @@ -1,4 +1,4 @@ -/* Copyright (c) 1997 Silicon Graphics, Inc. */ +/* Copyright (c) 1998 Silicon Graphics, Inc. */ /* SCCSid "$SunId$ SGI" */ @@ -6,53 +6,53 @@ * Quadtree data structures for holodeck display drivers. */ +#undef NOPROTO +#define NOPROTO 1 +#include "color.h" #include "tonemap.h" #include "rhdriver.h" - /* quantity of leaves to free at a time */ -#ifndef LFREEPCT -#define LFREEPCT 15 -#endif - /* child ordering */ + #define DL 0 /* down left */ #define DR 1 /* down right */ #define UL 2 /* up left */ #define UR 3 /* up right */ -#define BRF(i) (1<<(i)) /* branch flag bit */ -#define CHF(i) (0x10<<(i)) /* change flag bit */ -#define CHBRF(i) (0x11<<(i)) /* changed branch flags */ -#define CH_ANY 0xf0 /* flags for any change */ +#define BRF(i) (0x1<<(i)) /* branch flag bit */ +#define LFF(i) (0x10<<(i)) /* leaf flag bit */ +#define CHF(i) (0x100<<(i)) /* change flag bit */ +#define CHBRF(i) (0x101<<(i)) /* changed branch bit */ +#define CHLFF(i) (0x110<<(i)) /* changed leaf bit */ +#define BR_ANY 0xf /* flags for any branches */ +#define LF_ANY 0xf0 /* flags for any leaves */ +#define CH_ANY 0xf00 /* flags for any change */ -typedef struct { - float wp[3]; /* world intersection point */ - TMbright brt; /* encoded brightness (LogY) */ - BYTE chr[3]; /* encoded chrominance (RGB) */ -} RLEAF; /* recorded ray (leaf) value */ - typedef struct rtree { - short flgs; /* branch flags */ + short flgs; /* content flags (defined above) */ union { struct rtree *b; /* if branch */ - RLEAF *l; /* if leaf */ + int li; /* if leaf */ } k[4]; /* children */ } RTREE; +extern struct rleaves { + float (*wp)[3]; /* world intersection point array */ + int4 *wd; /* world direction array */ + TMbright *brt; /* encoded brightness array */ + BYTE (*chr)[3]; /* encoded chrominance array */ + BYTE (*rgb)[3]; /* tone-mapped color array */ + int nl; /* count of leaves in our pile */ + int bl, tl; /* bottom and top (next) leaf index */ + int tml; /* next leaf needing tone-mapping */ + char *base; /* base of allocated memory */ +} qtL; /* our pile of leaves */ + +#define is_stump(t) (!((t)->flgs & (BR_ANY|LF_ANY))) + extern RTREE qtrunk; /* trunk of quadtree */ extern double qtDepthEps; /* epsilon to compare depths (z fraction) */ extern int qtMinNodesiz; /* minimum node dimension (pixels) */ -extern RLEAF *qtFindLeaf(); +extern int rayqleft; /* number of rays to queue before flush */ - -/************************************************************************ - * These driver support routines implement the dev_value() call, but - * require the following callbacks: - -dev_paintr(rgb, x0, y0, x1, y1) : paint a rectangle -BYTE rgb[3]; : rectangle color -int x0, y0, x1, y1; : rectangle boundaries - -Draws an open rectangle between [x0,x1) and [y0,y1) with the color rgb. -This function is called many times by qtUpdate(), qtRedraw() and qtReplant(). - - ************************************************************************/ +extern int4 encodedir(); +extern double fdir2diff(), dir2diff();
