--- ray/src/hd/rhd_qtree.h 1997/12/24 10:52:50 3.8 +++ ray/src/hd/rhd_qtree.h 2004/01/01 11:21:55 3.17 @@ -1,21 +1,18 @@ -/* Copyright (c) 1997 Silicon Graphics, Inc. */ - -/* SCCSid "$SunId$ SGI" */ - +/* RCSid $Id: rhd_qtree.h,v 3.17 2004/01/01 11:21:55 schorsch Exp $ */ /* * Quadtree data structures for holodeck display drivers. */ +#ifndef _RAD_RHD_QTREE_H_ +#define _RAD_RHD_QTREE_H_ +#include "color.h" #include "tonemap.h" #include "rhdriver.h" -#ifndef int2 -#define int2 short +#ifdef __cplusplus +extern "C" { #endif -#ifndef int4 -#define int4 int -#endif - /* child ordering */ + #define DL 0 /* down left */ #define DR 1 /* down right */ #define UL 2 /* up left */ @@ -40,7 +37,7 @@ typedef struct rtree { extern struct rleaves { float (*wp)[3]; /* world intersection point array */ - int4 *wd; /* world direction array */ + int32 *wd; /* world direction array */ TMbright *brt; /* encoded brightness array */ BYTE (*chr)[3]; /* encoded chrominance array */ BYTE (*rgb)[3]; /* tone-mapped color array */ @@ -56,5 +53,26 @@ extern RTREE qtrunk; /* trunk of quadtree */ extern double qtDepthEps; /* epsilon to compare depths (z fraction) */ extern int qtMinNodesiz; /* minimum node dimension (pixels) */ -extern int4 encodedir(); +extern int rayqleft; /* number of rays to queue before flush */ + +/* +extern int32 encodedir(); extern double fdir2diff(), dir2diff(); +*/ + + /* rhd_qtree.c */ +extern int qtAllocLeaves(register int n); +extern void qtFreeLeaves(void); +extern int qtCompost(int pct); +extern void qtReplant(void); +extern int qtFindLeaf(int x, int y); +extern int qtMapLeaves(int redo); + /* rhd_qtree2c.c rhd_qtree2r.c */ +extern void qtRedraw(int x0, int y0, int x1, int y1); +extern void qtUpdate(void); + +#ifdef __cplusplus +} +#endif +#endif /* _RAD_RHD_QTREE_H_ */ +
