root/radiance/ray/src/hd/rhd_qtree.h
Revision 3.20 - (view) (download) (annotate) - [selected]
Fri Oct 5 19:46:26 2018 UTC (5 years, 7 months ago) by greg
Changes since 3.19: +1 -6 lines
Diff to previous 3.19
Removed jetsam (commented out pre-prototype function declarations)
Changes since 3.18: +3 -3 lines
Diff to previous 3.18 , to selected 3.20
Fri Jan 7 20:33:02 2005 UTC (19 years, 4 months ago) by greg
Changes since 3.17: +3 -1 lines
Diff to previous 3.17 , to selected 3.20
Changes since 3.16: +14 -1 lines
Diff to previous 3.16 , to selected 3.20
Ansification and prototypes.
Mon Jul 14 22:24:00 2003 UTC (20 years, 10 months ago) by schorsch
Changes since 3.15: +13 -1 lines
Diff to previous 3.15 , to selected 3.20
Changes since 3.14: +3 -3 lines
Diff to previous 3.14 , to selected 3.20
Tue Mar 4 05:49:21 2003 UTC (21 years, 3 months ago) by greg
Changes since 3.13: +1 -3 lines
Diff to previous 3.13 , to selected 3.20
Changes since 3.12: +1 -4 lines
Diff to previous 3.12 , to selected 3.20
Thu Dec 17 09:46:35 1998 UTC (25 years, 5 months ago) by gwlarson
Changes since 3.11: +2 -0 lines
Diff to previous 3.11 , to selected 3.20
added NOPROTO define before tonemap.h include
Mon Aug 17 17:59:59 1998 UTC (25 years, 9 months ago) by gwlarson
Diff to previous 3.10 , to selected 3.20
removed "color.h" include from tonemap.h
Wed Aug 12 17:56:26 1998 UTC (25 years, 9 months ago) by gwlarson
Changes since 3.9: +1 -8 lines
Diff to previous 3.9 , to selected 3.20
moved int2 and int4 definitions to standard.h
Thu Jan 1 13:00:15 1998 UTC (26 years, 5 months ago) by gregl
Changes since 3.8: +2 -0 lines
Diff to previous 3.8 , to selected 3.20
Wed Dec 24 10:52:50 1997 UTC (26 years, 5 months ago) by gregl
Changes since 3.7: +4 -1 lines
Diff to previous 3.7 , to selected 3.20
Fri Dec 5 15:40:54 1997 UTC (26 years, 6 months ago) by gregl
Changes since 3.6: +8 -1 lines
Diff to previous 3.6 , to selected 3.20
change to better, faster angle-difference computation
Fri Dec 5 09:39:20 1997 UTC (26 years, 6 months ago) by gregl
Diff to previous 3.5 , to selected 3.20
added array for direction to leaf sample
Tue Nov 25 16:52:04 1997 UTC (26 years, 6 months ago) by gregl
Changes since 3.4: +2 -14 lines
Diff to previous 3.4 , to selected 3.20
Mon Nov 24 15:15:21 1997 UTC (26 years, 6 months ago) by gregl
Changes since 3.3: +0 -4 lines
Diff to previous 3.3 , to selected 3.20
moved LFREEPCT to rhd_qtree.c and changed from 15% to 25%
Fri Nov 21 13:35:58 1997 UTC (26 years, 6 months ago) by gregl
Changes since 3.2: +21 -14 lines
Diff to previous 3.2 , to selected 3.20
changed definition of global leaf pile to make tone mapping work better
Thu Nov 20 18:03:43 1997 UTC (26 years, 6 months ago) by gregl
Changes since 3.1: +2 -0 lines
Diff to previous 3.1 , to selected 3.20
added qtFindLeaf() and made qtFreeTree() global (dunno why yet)
Wed Nov 19 18:01:03 1997 UTC (26 years, 6 months ago) by gregl
Diff to selected 3.20
