root/radiance/ray/src/hd/rhd_qtree.h
Fri May 20 02:06:39 2011 UTC (14 years, 1 month ago) by greg
Changes since 3.18: +3 -3 lines
Diff to previous 3.18 , to selected 3.6
Fri Jan 7 20:33:02 2005 UTC (20 years, 6 months ago) by greg
Changes since 3.17: +3 -1 lines
Diff to previous 3.17 , to selected 3.6
Thu Jan 1 11:21:55 2004 UTC (21 years, 6 months ago) by schorsch
Changes since 3.16: +14 -1 lines
Diff to previous 3.16 , to selected 3.6
Ansification and prototypes.
Mon Jul 14 22:24:00 2003 UTC (22 years ago) by schorsch
Changes since 3.15: +13 -1 lines
Diff to previous 3.15 , to selected 3.6
Fri Jun 20 00:25:49 2003 UTC (22 years ago) by greg
Changes since 3.14: +3 -3 lines
Diff to previous 3.14 , to selected 3.6
Tue Mar 4 05:49:21 2003 UTC (22 years, 4 months ago) by greg
Changes since 3.13: +1 -3 lines
Diff to previous 3.13 , to selected 3.6
Sat Feb 22 02:07:24 2003 UTC (22 years, 4 months ago) by greg
Changes since 3.12: +1 -4 lines
Diff to previous 3.12 , to selected 3.6
Thu Dec 17 09:46:35 1998 UTC (26 years, 7 months ago) by gwlarson
Changes since 3.11: +2 -0 lines
Diff to previous 3.11 , to selected 3.6
added NOPROTO define before tonemap.h include
Mon Aug 17 17:59:59 1998 UTC (26 years, 11 months ago) by gwlarson
Diff to previous 3.10 , to selected 3.6
removed "color.h" include from tonemap.h
Wed Aug 12 17:56:26 1998 UTC (26 years, 11 months ago) by gwlarson
Changes since 3.9: +1 -8 lines
Diff to previous 3.9 , to selected 3.6
moved int2 and int4 definitions to standard.h
Thu Jan 1 13:00:15 1998 UTC (27 years, 6 months ago) by gregl
Changes since 3.8: +2 -0 lines
Diff to previous 3.8 , to selected 3.6
Wed Dec 24 10:52:50 1997 UTC (27 years, 6 months ago) by gregl
Changes since 3.7: +4 -1 lines
Diff to previous 3.7 , to selected 3.6
Fri Dec 5 15:40:54 1997 UTC (27 years, 7 months ago) by gregl
Changes since 3.6: +8 -1 lines
Diff to previous 3.6
change to better, faster angle-difference computation
Revision 3.6 - (view) (download) (annotate) - [selected]
Fri Dec 5 09:39:20 1997 UTC (27 years, 7 months ago) by gregl
Diff to previous 3.5
added array for direction to leaf sample
Tue Nov 25 16:52:04 1997 UTC (27 years, 7 months ago) by gregl
Changes since 3.4: +2 -14 lines
Diff to previous 3.4 , to selected 3.6
Mon Nov 24 15:15:21 1997 UTC (27 years, 7 months ago) by gregl
Changes since 3.3: +0 -4 lines
Diff to previous 3.3 , to selected 3.6
moved LFREEPCT to rhd_qtree.c and changed from 15% to 25%
Fri Nov 21 13:35:58 1997 UTC (27 years, 7 months ago) by gregl
Changes since 3.2: +21 -14 lines
Diff to previous 3.2 , to selected 3.6
changed definition of global leaf pile to make tone mapping work better
Thu Nov 20 18:03:43 1997 UTC (27 years, 7 months ago) by gregl
Changes since 3.1: +2 -0 lines
Diff to previous 3.1 , to selected 3.6
added qtFindLeaf() and made qtFreeTree() global (dunno why yet)
Wed Nov 19 18:01:03 1997 UTC (27 years, 7 months ago) by gregl
Diff to selected 3.6
