root/Development/ray/src/hd/rhd_qtree.h
Revision: 3.8
Committed: Wed Dec 24 10:52:50 1997 UTC (28 years ago) by gregl
Changes since 3.7: +4 -1 lines
1 /* Copyright (c) 1997 Silicon Graphics, Inc. */
2
3 /* SCCSid "$SunId$ SGI" */
4
5 /*
6 * Quadtree data structures for holodeck display drivers.
7 */
8
9 #include "tonemap.h"
10 #include "rhdriver.h"
11
12 #ifndef int2
13 #define int2 short
14 #endif
15 #ifndef int4
16 #define int4 int
17 #endif
18 /* child ordering */
19 #define DL 0 /* down left */
20 #define DR 1 /* down right */
21 #define UL 2 /* up left */
22 #define UR 3 /* up right */
23
24 #define BRF(i) (0x1<<(i)) /* branch flag bit */
25 #define LFF(i) (0x10<<(i)) /* leaf flag bit */
26 #define CHF(i) (0x100<<(i)) /* change flag bit */
27 #define CHBRF(i) (0x101<<(i)) /* changed branch bit */
28 #define CHLFF(i) (0x110<<(i)) /* changed leaf bit */
29 #define BR_ANY 0xf /* flags for any branches */
30 #define LF_ANY 0xf0 /* flags for any leaves */
31 #define CH_ANY 0xf00 /* flags for any change */
32
33 typedef struct rtree {
34 short flgs; /* content flags (defined above) */
35 union {
36 struct rtree *b; /* if branch */
37 int li; /* if leaf */
38 } k[4]; /* children */
39 } RTREE;
40
41 extern struct rleaves {
42 float (*wp)[3]; /* world intersection point array */
43 int4 *wd; /* world direction array */
44 TMbright *brt; /* encoded brightness array */
45 BYTE (*chr)[3]; /* encoded chrominance array */
46 BYTE (*rgb)[3]; /* tone-mapped color array */
47 int nl; /* count of leaves in our pile */
48 int bl, tl; /* bottom and top (next) leaf index */
49 int tml; /* next leaf needing tone-mapping */
50 char *base; /* base of allocated memory */
51 } qtL; /* our pile of leaves */
52
53 #define is_stump(t) (!((t)->flgs & (BR_ANY|LF_ANY)))
54
55 extern RTREE qtrunk; /* trunk of quadtree */
56 extern double qtDepthEps; /* epsilon to compare depths (z fraction) */
57 extern int qtMinNodesiz; /* minimum node dimension (pixels) */
58
59 extern int4 encodedir();
60 extern double fdir2diff(), dir2diff();
