root/radiance/ray/src/hd/rhd_qtree.h
Revision: 3.17
Committed: Thu Jan 1 11:21:55 2004 UTC (21 years, 4 months ago) by schorsch
Changes since 3.16: +14 -1 lines
Ansification and prototypes.
# User Rev Content
1 schorsch 3.17 /* RCSid $Id: rhd_qtree.h,v 3.16 2003/07/14 22:24:00 schorsch Exp $ */
2 gregl 3.1 /*
3     * Quadtree data structures for holodeck display drivers.
4     */
5 schorsch 3.16 #ifndef _RAD_RHD_QTREE_H_
6     #define _RAD_RHD_QTREE_H_
7 gregl 3.1
8 gwlarson 3.11 #include "color.h"
9 gregl 3.1 #include "tonemap.h"
10     #include "rhdriver.h"
11 gregl 3.7
12 schorsch 3.16 #ifdef __cplusplus
13     extern "C" {
14     #endif
15
16 gregl 3.1 #define DL 0 /* down left */
17     #define DR 1 /* down right */
18     #define UL 2 /* up left */
19     #define UR 3 /* up right */
20
21 gregl 3.3 #define BRF(i) (0x1<<(i)) /* branch flag bit */
22     #define LFF(i) (0x10<<(i)) /* leaf flag bit */
23     #define CHF(i) (0x100<<(i)) /* change flag bit */
24     #define CHBRF(i) (0x101<<(i)) /* changed branch bit */
25     #define CHLFF(i) (0x110<<(i)) /* changed leaf bit */
26     #define BR_ANY 0xf /* flags for any branches */
27     #define LF_ANY 0xf0 /* flags for any leaves */
28     #define CH_ANY 0xf00 /* flags for any change */
29 gregl 3.1
30     typedef struct rtree {
31 gregl 3.3 short flgs; /* content flags (defined above) */
32 gregl 3.1 union {
33     struct rtree *b; /* if branch */
34 gregl 3.3 int li; /* if leaf */
35 gregl 3.1 } k[4]; /* children */
36     } RTREE;
37
38 gregl 3.3 extern struct rleaves {
39     float (*wp)[3]; /* world intersection point array */
40 greg 3.15 int32 *wd; /* world direction array */
41 gregl 3.3 TMbright *brt; /* encoded brightness array */
42     BYTE (*chr)[3]; /* encoded chrominance array */
43     BYTE (*rgb)[3]; /* tone-mapped color array */
44     int nl; /* count of leaves in our pile */
45     int bl, tl; /* bottom and top (next) leaf index */
46     int tml; /* next leaf needing tone-mapping */
47     char *base; /* base of allocated memory */
48     } qtL; /* our pile of leaves */
49
50 gregl 3.5 #define is_stump(t) (!((t)->flgs & (BR_ANY|LF_ANY)))
51
52 gregl 3.1 extern RTREE qtrunk; /* trunk of quadtree */
53     extern double qtDepthEps; /* epsilon to compare depths (z fraction) */
54     extern int qtMinNodesiz; /* minimum node dimension (pixels) */
55 gregl 3.8
56 gregl 3.9 extern int rayqleft; /* number of rays to queue before flush */
57
58 schorsch 3.17 /*
59 greg 3.15 extern int32 encodedir();
60 gregl 3.8 extern double fdir2diff(), dir2diff();
61 schorsch 3.17 */
62
63     /* rhd_qtree.c */
64     extern int qtAllocLeaves(register int n);
65     extern void qtFreeLeaves(void);
66     extern int qtCompost(int pct);
67     extern void qtReplant(void);
68     extern int qtFindLeaf(int x, int y);
69     extern int qtMapLeaves(int redo);
70     /* rhd_qtree2c.c rhd_qtree2r.c */
71     extern void qtRedraw(int x0, int y0, int x1, int y1);
72     extern void qtUpdate(void);
73 schorsch 3.16
74     #ifdef __cplusplus
75     }
76     #endif
77     #endif /* _RAD_RHD_QTREE_H_ */
78
