root/radiance/ray/src/hd/rhd_qtree.c
Revision: 3.15
Committed: Tue Dec 30 17:08:37 1997 UTC (26 years, 3 months ago) by gregl
Changes since 3.14: +56 -25 lines
allow unused leaves to fall into free list for greater efficiency
1 /* Copyright (c) 1997 Silicon Graphics, Inc. */
2
3 #ifndef lint
4 static char SCCSid[] = "$SunId$ SGI";
5 #endif
6
7 /*
8 * Quadtree driver support routines.
9 */
10
11 #include "standard.h"
12 #include "rhd_qtree.h"
13 /* quantity of leaves to free at a time */
14 #ifndef LFREEPCT
15 #define LFREEPCT 25
16 #endif
17 /* maximum allowed angle difference (deg.) */
18 #ifndef MAXANG
19 #define MAXANG 20
20 #endif
21 #if MAXANG>0
22 #define MAXDIFF2 ( MAXANG*MAXANG * (PI*PI/180./180.))
23 #endif
24
25 #define abs(i) ((i) < 0 ? -(i) : (i))
26
27 RTREE qtrunk; /* our quadtree trunk */
28 double qtDepthEps = .05; /* epsilon to compare depths (z fraction) */
29 int qtMinNodesiz = 2; /* minimum node dimension (pixels) */
30 struct rleaves qtL; /* our pile of leaves */
31
32 static int4 falleaves; /* our list of fallen leaves */
33
34 #define composted(li) (qtL.bl <= qtL.tl ? \
35 ((li) < qtL.bl || (li) >= qtL.tl) : \
36 ((li) < qtL.bl && (li) >= qtL.tl))
37
38 #define TBUNDLESIZ 409 /* number of twigs in a bundle */
39
40 static RTREE **twigbundle; /* free twig blocks (NULL term.) */
41 static int nexttwig; /* next free twig */
42
43
44 static RTREE *
45 newtwig() /* allocate a twig */
46 {
47 register int bi;
48
49 if (twigbundle == NULL) { /* initialize */
50 twigbundle = (RTREE **)malloc(sizeof(RTREE *));
51 if (twigbundle == NULL)
52 goto memerr;
53 twigbundle[0] = NULL;
54 }
55 bi = nexttwig / TBUNDLESIZ;
56 if (twigbundle[bi] == NULL) { /* new block */
57 twigbundle = (RTREE **)realloc((char *)twigbundle,
58 (bi+2)*sizeof(RTREE *));
59 if (twigbundle == NULL)
60 goto memerr;
61 twigbundle[bi] = (RTREE *)calloc(TBUNDLESIZ, sizeof(RTREE));
62 if (twigbundle[bi] == NULL)
63 goto memerr;
64 twigbundle[bi+1] = NULL;
65 }
66 /* nexttwig++ % TBUNDLESIZ */
67 return(twigbundle[bi] + (nexttwig++ - bi*TBUNDLESIZ));
68 memerr:
69 error(SYSTEM, "out of memory in newtwig");
70 }
71
72
73 qtFreeTree(really) /* free allocated twigs */
74 int really;
75 {
76 register int i;
77
78 qtrunk.flgs = CH_ANY; /* chop down tree */
79 if (twigbundle == NULL)
80 return;
81 i = (TBUNDLESIZ-1+nexttwig)/TBUNDLESIZ;
82 nexttwig = 0;
83 if (!really) { /* just clear allocated blocks */
84 while (i--)
85 bzero((char *)twigbundle[i], TBUNDLESIZ*sizeof(RTREE));
86 return;
87 }
88 /* else "really" means free up memory */
89 for (i = 0; twigbundle[i] != NULL; i++)
90 free((char *)twigbundle[i]);
91 free((char *)twigbundle);
92 twigbundle = NULL;
93 }
94
95
96 #define LEAFSIZ (3*sizeof(float)+sizeof(int4)+\
97 sizeof(TMbright)+6*sizeof(BYTE))
98
99 int
100 qtAllocLeaves(n) /* allocate space for n leaves */
101 register int n;
102 {
103 unsigned nbytes;
104 register unsigned i;
105
106 qtFreeTree(0); /* make sure tree is empty */
107 if (n <= 0)
108 return(0);
109 if (qtL.nl >= n)
110 return(qtL.nl);
111 else if (qtL.nl > 0)
112 free(qtL.base);
113 /* round space up to nearest power of 2 */
114 nbytes = n*LEAFSIZ + 8;
115 for (i = 1024; nbytes > i; i <<= 1)
116 ;
117 n = (i - 8) / LEAFSIZ; /* should we make sure n is even? */
118 qtL.base = (char *)malloc(n*LEAFSIZ);
119 if (qtL.base == NULL)
120 return(0);
121 /* assign larger alignment types earlier */
122 qtL.wp = (float (*)[3])qtL.base;
123 qtL.wd = (int4 *)(qtL.wp + n);
124 qtL.brt = (TMbright *)(qtL.wd + n);
125 qtL.chr = (BYTE (*)[3])(qtL.brt + n);
126 qtL.rgb = (BYTE (*)[3])(qtL.chr + n);
127 qtL.nl = n;
128 qtL.tml = qtL.bl = qtL.tl = 0;
129 falleaves = -1;
130 return(n);
131 }
132
133 #undef LEAFSIZ
134
135
136 qtFreeLeaves() /* free our allocated leaves and twigs */
137 {
138 qtFreeTree(1); /* free tree also */
139 if (qtL.nl <= 0)
140 return;
141 free(qtL.base);
142 qtL.base = NULL;
143 qtL.nl = 0;
144 }
145
146
147 static
148 shaketree(tp) /* shake dead leaves from tree */
149 register RTREE *tp;
150 {
151 register int i, li;
152
153 for (i = 0; i < 4; i++)
154 if (tp->flgs & BRF(i)) {
155 shaketree(tp->k[i].b);
156 if (is_stump(tp->k[i].b))
157 tp->flgs &= ~BRF(i);
158 } else if (tp->flgs & LFF(i)) {
159 li = tp->k[i].li;
160 if (composted(li))
161 tp->flgs &= ~LFF(i);
162 }
163 }
164
165
166 int
167 qtCompost(pct) /* free up some leaves */
168 int pct;
169 {
170 register int4 *fl;
171 int nused, nclear, nmapped;
172 /* figure out how many leaves to clear */
173 nclear = qtL.nl * pct / 100;
174 nused = qtL.tl - qtL.bl;
175 if (nused <= 0) nused += qtL.nl;
176 nclear -= qtL.nl - nused;
177 if (nclear <= 0)
178 return(0);
179 if (nclear >= nused) { /* clear them all */
180 qtFreeTree(0);
181 qtL.tml = qtL.bl = qtL.tl = 0;
182 falleaves = -1;
183 return(nused);
184 }
185 /* else clear leaves from bottom */
186 nmapped = qtL.tml - qtL.bl;
187 if (nmapped < 0) nmapped += qtL.nl;
188 qtL.bl += nclear;
189 if (qtL.bl >= qtL.nl) qtL.bl -= qtL.nl;
190 if (nmapped <= nclear) qtL.tml = qtL.bl;
191 shaketree(&qtrunk); /* dereference composted leaves */
192 for (fl = &falleaves; *fl >= 0; fl = qtL.wd + *fl)
193 while (composted(*fl))
194 if ((*fl = qtL.wd[*fl]) < 0)
195 return(nclear);
196 return(nclear);
197 }
198
199
200 int
201 qtFindLeaf(x, y) /* find closest leaf to (x,y) */
202 int x, y;
203 {
204 register RTREE *tp = &qtrunk;
205 int li = -1;
206 int x0=0, y0=0, x1=odev.hres, y1=odev.vres;
207 int mx, my;
208 register int q;
209 /* check limits */
210 if (x < 0 || x >= odev.hres || y < 0 || y >= odev.vres)
211 return(-1);
212 /* find nearby leaf in our tree */
213 for ( ; ; ) {
214 for (q = 0; q < 4; q++) /* find any leaf this level */
215 if (tp->flgs & LFF(q)) {
216 li = tp->k[q].li;
217 break;
218 }
219 q = 0; /* which quadrant are we? */
220 mx = (x0 + x1) >> 1;
221 my = (y0 + y1) >> 1;
222 if (x < mx) x1 = mx;
223 else {x0 = mx; q |= 01;}
224 if (y < my) y1 = my;
225 else {y0 = my; q |= 02;}
226 if (tp->flgs & BRF(q)) { /* branch down if not a leaf */
227 tp = tp->k[q].b;
228 continue;
229 }
230 if (tp->flgs & LFF(q)) /* good shot! */
231 return(tp->k[q].li);
232 return(li); /* else return what we have */
233 }
234 }
235
236
237 static
238 putleaf(li, drop) /* put a leaf in our tree */
239 register int li;
240 int drop;
241 {
242 register RTREE *tp = &qtrunk;
243 int x0=0, y0=0, x1=odev.hres, y1=odev.vres;
244 register int lo = -1;
245 double d2;
246 int x, y, mx, my;
247 double z;
248 FVECT ip, wp, vd;
249 register int q;
250 /* check for dead leaf */
251 if (!qtL.chr[li][1] && !(qtL.chr[li][0] | qtL.chr[li][2]))
252 return(0);
253 /* compute leaf location in view */
254 VCOPY(wp, qtL.wp[li]);
255 viewloc(ip, &odev.v, wp);
256 if (ip[2] <= 0. || ip[0] < 0. || ip[0] >= 1.
257 || ip[1] < 0. || ip[1] >= 1.)
258 goto dropit; /* behind or outside view */
259 #ifdef DEBUG
260 if (odev.v.type == VT_PAR | odev.v.vfore > FTINY)
261 error(INTERNAL, "bad view assumption in putleaf");
262 #endif
263 for (q = 0; q < 3; q++)
264 vd[q] = (wp[q] - odev.v.vp[q])/ip[2];
265 d2 = fdir2diff(qtL.wd[li], vd);
266 #ifdef MAXDIFF2
267 if (d2 > MAXDIFF2)
268 goto dropit; /* leaf dir. too far off */
269 #endif
270 x = ip[0] * odev.hres;
271 y = ip[1] * odev.vres;
272 z = ip[2];
273 /* find the place for it */
274 for ( ; ; ) {
275 q = 0; /* which quadrant? */
276 mx = (x0 + x1) >> 1;
277 my = (y0 + y1) >> 1;
278 if (x < mx) x1 = mx;
279 else {x0 = mx; q |= 01;}
280 if (y < my) y1 = my;
281 else {y0 = my; q |= 02;}
282 if (tp->flgs & BRF(q)) { /* move to next branch */
283 tp->flgs |= CHF(q); /* not sure; guess */
284 tp = tp->k[q].b;
285 continue;
286 }
287 if (!(tp->flgs & LFF(q))) { /* found stem for leaf */
288 tp->k[q].li = li;
289 tp->flgs |= CHLFF(q);
290 return(1);
291 }
292 if (lo != tp->k[q].li) { /* check old leaf */
293 lo = tp->k[q].li;
294 VCOPY(wp, qtL.wp[lo]);
295 viewloc(ip, &odev.v, wp);
296 }
297 /* is node minimum size? */
298 if (y1-y0 <= qtMinNodesiz || x1-x0 <= qtMinNodesiz) {
299 if (z > (1.+qtDepthEps)*ip[2])
300 break; /* old one closer */
301 if (z >= (1.-qtDepthEps)*ip[2] &&
302 fdir2diff(qtL.wd[lo], vd) < d2)
303 break; /* old one better */
304 tp->k[q].li = li; /* attach new */
305 tp->flgs |= CHF(q);
306 li = lo; /* drop old... */
307 break;
308 }
309 tp->flgs &= ~LFF(q); /* else grow tree */
310 tp->flgs |= CHBRF(q);
311 tp = tp->k[q].b = newtwig();
312 q = 0; /* old leaf -> new branch */
313 mx = ip[0] * odev.hres;
314 my = ip[1] * odev.vres;
315 if (mx >= (x0 + x1) >> 1) q |= 01;
316 if (my >= (y0 + y1) >> 1) q |= 02;
317 tp->flgs = CH_ANY|LFF(q); /* all new */
318 tp->k[q].li = lo;
319 }
320 dropit:
321 if (drop) {
322 qtL.chr[li][0] = qtL.chr[li][1] = qtL.chr[li][2] = 0;
323 qtL.wd[li] = falleaves;
324 falleaves = li;
325 }
326 return(li == lo);
327 }
328
329
330 dev_value(c, p, v) /* add a pixel value to our quadtree */
331 COLR c;
332 FVECT p, v;
333 {
334 register int li;
335 int mapit;
336 /* grab a leaf */
337 if (falleaves >= 0) { /* check for fallen leaves */
338 li = falleaves;
339 falleaves = qtL.wd[li];
340 mapit = qtL.tml <= qtL.tl ?
341 (li < qtL.tml || li >= qtL.tl) :
342 (li < qtL.tml && li >= qtL.tl) ;
343 } else { /* else allocate new one */
344 li = qtL.tl++;
345 if (qtL.tl >= qtL.nl) /* advance to next leaf in ring */
346 qtL.tl = 0;
347 if (qtL.tl == qtL.bl) /* need to shake some free */
348 qtCompost(LFREEPCT);
349 mapit = 0; /* we'll map it later */
350 }
351 VCOPY(qtL.wp[li], p);
352 qtL.wd[li] = encodedir(v);
353 tmCvColrs(&qtL.brt[li], qtL.chr[li], c, 1);
354 if (putleaf(li, 1) && mapit)
355 tmMapPixels(qtL.rgb+li, qtL.brt+li, qtL.chr+li, 1);
356 }
357
358
359 qtReplant() /* replant our tree using new view */
360 {
361 register int i;
362 /* anything to replant? */
363 if (qtL.bl == qtL.tl)
364 return;
365 qtFreeTree(0); /* blow the old tree away */
366 /* regrow it in new place */
367 for (i = qtL.bl; i != qtL.tl; ) {
368 putleaf(i, 0);
369 if (++i >= qtL.nl) i = 0;
370 }
371 }
372
373
374 qtMapLeaves(redo) /* map our leaves to RGB */
375 int redo;
376 {
377 int aorg, alen, borg, blen;
378 /* recompute mapping? */
379 if (redo)
380 qtL.tml = qtL.bl;
381 /* already done? */
382 if (qtL.tml == qtL.tl)
383 return(1);
384 /* compute segments */
385 aorg = qtL.tml;
386 if (qtL.tl >= aorg) {
387 alen = qtL.tl - aorg;
388 blen = 0;
389 } else {
390 alen = qtL.nl - aorg;
391 borg = 0;
392 blen = qtL.tl;
393 }
394 /* (re)compute tone mapping? */
395 if (qtL.tml == qtL.bl) {
396 tmClearHisto();
397 tmAddHisto(qtL.brt+aorg, alen, 1);
398 if (blen > 0)
399 tmAddHisto(qtL.brt+borg, blen, 1);
400 if (tmComputeMapping(0., 0., 0.) != TM_E_OK)
401 return(0);
402 }
403 if (tmMapPixels(qtL.rgb+aorg, qtL.brt+aorg,
404 qtL.chr+aorg, alen) != TM_E_OK)
405 return(0);
406 if (blen > 0)
407 tmMapPixels(qtL.rgb+borg, qtL.brt+borg,
408 qtL.chr+borg, blen);
409 qtL.tml = qtL.tl;
410 return(1);
411 }
