1 |
/* Copyright (c) 1997 Silicon Graphics, Inc. */ |
2 |
3 |
#ifndef lint |
4 |
static char SCCSid[] = "$SunId$ SGI"; |
5 |
#endif |
6 |
7 |
8 |
* Quadtree driver support routines. |
9 |
10 |
11 |
#include "standard.h" |
12 |
#include "rhd_qtree.h" |
13 |
/* quantity of leaves to free at a time */ |
14 |
#ifndef LFREEPCT |
15 |
#define LFREEPCT 25 |
16 |
#endif |
17 |
/* maximum allowed angle difference (deg.) */ |
18 |
#ifndef MAXANG |
19 |
#define MAXANG 20 |
20 |
#endif |
21 |
#if MAXANG>0 |
22 |
#define MAXDIFF2 ( MAXANG*MAXANG * (PI*PI/180./180.)) |
23 |
#endif |
24 |
25 |
#define abs(i) ((i) < 0 ? -(i) : (i)) |
26 |
27 |
RTREE qtrunk; /* our quadtree trunk */ |
28 |
double qtDepthEps = .05; /* epsilon to compare depths (z fraction) */ |
29 |
int qtMinNodesiz = 2; /* minimum node dimension (pixels) */ |
30 |
struct rleaves qtL; /* our pile of leaves */ |
31 |
32 |
#define TBUNDLESIZ 409 /* number of twigs in a bundle */ |
33 |
34 |
static RTREE **twigbundle; /* free twig blocks (NULL term.) */ |
35 |
static int nexttwig; /* next free twig */ |
36 |
37 |
38 |
static RTREE * |
39 |
newtwig() /* allocate a twig */ |
40 |
41 |
register int bi; |
42 |
43 |
if (twigbundle == NULL) { /* initialize */ |
44 |
twigbundle = (RTREE **)malloc(sizeof(RTREE *)); |
45 |
if (twigbundle == NULL) |
46 |
goto memerr; |
47 |
twigbundle[0] = NULL; |
48 |
49 |
bi = nexttwig / TBUNDLESIZ; |
50 |
if (twigbundle[bi] == NULL) { /* new block */ |
51 |
twigbundle = (RTREE **)realloc((char *)twigbundle, |
52 |
(bi+2)*sizeof(RTREE *)); |
53 |
54 |
goto memerr; |
55 |
twigbundle[bi] = (RTREE *)calloc(TBUNDLESIZ, sizeof(RTREE)); |
56 |
if (twigbundle[bi] == NULL) |
57 |
goto memerr; |
58 |
twigbundle[bi+1] = NULL; |
59 |
60 |
/* nexttwig++ % TBUNDLESIZ */ |
61 |
return(twigbundle[bi] + (nexttwig++ - bi*TBUNDLESIZ)); |
62 |
memerr: |
63 |
error(SYSTEM, "out of memory in newtwig"); |
64 |
65 |
66 |
67 |
qtFreeTree(really) /* free allocated twigs */ |
68 |
int really; |
69 |
70 |
register int i; |
71 |
72 |
qtrunk.flgs = CH_ANY; /* chop down tree */ |
73 |
74 |
return; |
75 |
i = (TBUNDLESIZ-1+nexttwig)/TBUNDLESIZ; |
76 |
nexttwig = 0; |
77 |
if (!really) { /* just clear allocated blocks */ |
78 |
while (i--) |
79 |
bzero((char *)twigbundle[i], TBUNDLESIZ*sizeof(RTREE)); |
80 |
return; |
81 |
82 |
/* else "really" means free up memory */ |
83 |
for (i = 0; twigbundle[i] != NULL; i++) |
84 |
free((char *)twigbundle[i]); |
85 |
free((char *)twigbundle); |
86 |
twigbundle = NULL; |
87 |
88 |
89 |
90 |
#define LEAFSIZ (3*sizeof(float)+sizeof(int4)+\ |
91 |
sizeof(TMbright)+6*sizeof(BYTE)) |
92 |
93 |
int |
94 |
qtAllocLeaves(n) /* allocate space for n leaves */ |
95 |
register int n; |
96 |
97 |
unsigned nbytes; |
98 |
register unsigned i; |
99 |
100 |
qtFreeTree(0); /* make sure tree is empty */ |
101 |
if (n <= 0) |
102 |
return(0); |
103 |
if (qtL.nl >= n) |
104 |
return(qtL.nl); |
105 |
else if (qtL.nl > 0) |
106 |
free(qtL.base); |
107 |
/* round space up to nearest power of 2 */ |
108 |
nbytes = n*LEAFSIZ + 8; |
109 |
for (i = 1024; nbytes > i; i <<= 1) |
110 |
111 |
n = (i - 8) / LEAFSIZ; /* should we make sure n is even? */ |
112 |
qtL.base = (char *)malloc(n*LEAFSIZ); |
113 |
if (qtL.base == NULL) |
114 |
return(0); |
115 |
/* assign larger alignment types earlier */ |
116 |
qtL.wp = (float (*)[3])qtL.base; |
117 |
qtL.wd = (int4 *)(qtL.wp + n); |
118 |
qtL.brt = (TMbright *)(qtL.wd + n); |
119 |
qtL.chr = (BYTE (*)[3])(qtL.brt + n); |
120 |
qtL.rgb = (BYTE (*)[3])(qtL.chr + n); |
121 |
qtL.nl = n; |
122 |
qtL.tml = qtL.bl = qtL.tl = 0; |
123 |
return(n); |
124 |
125 |
126 |
#undef LEAFSIZ |
127 |
128 |
129 |
qtFreeLeaves() /* free our allocated leaves and twigs */ |
130 |
131 |
qtFreeTree(1); /* free tree also */ |
132 |
if (qtL.nl <= 0) |
133 |
return; |
134 |
free(qtL.base); |
135 |
qtL.base = NULL; |
136 |
qtL.nl = 0; |
137 |
138 |
139 |
140 |
static |
141 |
shaketree(tp) /* shake dead leaves from tree */ |
142 |
register RTREE *tp; |
143 |
144 |
register int i, li; |
145 |
146 |
for (i = 0; i < 4; i++) |
147 |
if (tp->flgs & BRF(i)) { |
148 |
shaketree(tp->k[i].b); |
149 |
if (is_stump(tp->k[i].b)) |
150 |
tp->flgs &= ~BRF(i); |
151 |
} else if (tp->flgs & LFF(i)) { |
152 |
li = tp->k[i].li; |
153 |
if (qtL.bl < qtL.tl ? |
154 |
(li < qtL.bl || li >= qtL.tl) : |
155 |
(li < qtL.bl && li >= qtL.tl)) |
156 |
tp->flgs &= ~LFF(i); |
157 |
158 |
159 |
160 |
161 |
int |
162 |
qtCompost(pct) /* free up some leaves */ |
163 |
int pct; |
164 |
165 |
int nused, nclear, nmapped; |
166 |
167 |
/* figure out how many leaves to clear */ |
168 |
nclear = qtL.nl * pct / 100; |
169 |
nused = qtL.tl - qtL.bl; |
170 |
if (nused <= 0) nused += qtL.nl; |
171 |
nclear -= qtL.nl - nused; |
172 |
if (nclear <= 0) |
173 |
return(0); |
174 |
if (nclear >= nused) { /* clear them all */ |
175 |
qtFreeTree(0); |
176 |
177 |
return(nused); |
178 |
179 |
/* else clear leaves from bottom */ |
180 |
nmapped = qtL.tml - qtL.bl; |
181 |
if (nmapped < 0) nmapped += qtL.nl; |
182 |
qtL.bl += nclear; |
183 |
if (qtL.bl >= qtL.nl) qtL.bl -= qtL.nl; |
184 |
if (nmapped <= nclear) qtL.tml = qtL.bl; |
185 |
shaketree(&qtrunk); |
186 |
return(nclear); |
187 |
188 |
189 |
190 |
int |
191 |
qtFindLeaf(x, y) /* find closest leaf to (x,y) */ |
192 |
int x, y; |
193 |
194 |
register RTREE *tp = &qtrunk; |
195 |
int li = -1; |
196 |
int x0=0, y0=0, x1=odev.hres, y1=odev.vres; |
197 |
int mx, my; |
198 |
register int q; |
199 |
/* check limits */ |
200 |
if (x < 0 || x >= odev.hres || y < 0 || y >= odev.vres) |
201 |
return(-1); |
202 |
/* find nearby leaf in our tree */ |
203 |
for ( ; ; ) { |
204 |
for (q = 0; q < 4; q++) /* find any leaf this level */ |
205 |
if (tp->flgs & LFF(q)) { |
206 |
li = tp->k[q].li; |
207 |
break; |
208 |
209 |
q = 0; /* which quadrant are we? */ |
210 |
mx = (x0 + x1) >> 1; |
211 |
my = (y0 + y1) >> 1; |
212 |
if (x < mx) x1 = mx; |
213 |
else {x0 = mx; q |= 01;} |
214 |
if (y < my) y1 = my; |
215 |
else {y0 = my; q |= 02;} |
216 |
if (tp->flgs & BRF(q)) { /* branch down if not a leaf */ |
217 |
tp = tp->k[q].b; |
218 |
continue; |
219 |
220 |
if (tp->flgs & LFF(q)) /* good shot! */ |
221 |
return(tp->k[q].li); |
222 |
return(li); /* else return what we have */ |
223 |
224 |
225 |
226 |
227 |
static |
228 |
addleaf(li) /* add a leaf to our tree */ |
229 |
int li; |
230 |
231 |
232 |
233 |
int lo = -1; |
234 |
double d2; |
235 |
int x, y, mx, my; |
236 |
double z; |
237 |
FVECT ip, wp, vd; |
238 |
register int q; |
239 |
/* compute leaf location in view */ |
240 |
VCOPY(wp, qtL.wp[li]); |
241 |
viewloc(ip, &odev.v, wp); |
242 |
if (ip[2] <= 0. || ip[0] < 0. || ip[0] >= 1. |
243 |
|| ip[1] < 0. || ip[1] >= 1.) |
244 |
return(-1); /* behind or outside view */ |
245 |
#ifdef DEBUG |
246 |
if (odev.v.type == VT_PAR | odev.v.vfore > FTINY) |
247 |
error(INTERNAL, "bad view assumption in addleaf"); |
248 |
#endif |
249 |
for (q = 0; q < 3; q++) |
250 |
vd[q] = (wp[q] - odev.v.vp[q])/ip[2]; |
251 |
d2 = fdir2diff(qtL.wd[li], vd); |
252 |
#ifdef MAXDIFF2 |
253 |
if (d2 > MAXDIFF2) |
254 |
return(0); /* leaf dir. too far off */ |
255 |
#endif |
256 |
x = ip[0] * odev.hres; |
257 |
y = ip[1] * odev.vres; |
258 |
z = ip[2]; |
259 |
/* find the place for it */ |
260 |
for ( ; ; ) { |
261 |
q = 0; /* which quadrant? */ |
262 |
263 |
264 |
265 |
266 |
267 |
268 |
if (tp->flgs & BRF(q)) { /* move to next branch */ |
269 |
tp->flgs |= CHF(q); /* not sure; guess */ |
270 |
tp = tp->k[q].b; |
271 |
continue; |
272 |
273 |
if (!(tp->flgs & LFF(q))) { /* found stem for leaf */ |
274 |
tp->k[q].li = li; |
275 |
tp->flgs |= CHLFF(q); |
276 |
break; |
277 |
278 |
if (lo != tp->k[q].li) { /* check old leaf */ |
279 |
lo = tp->k[q].li; |
280 |
VCOPY(wp, qtL.wp[lo]); |
281 |
282 |
283 |
/* is node minimum size? */ |
284 |
if (y1-y0 <= qtMinNodesiz || x1-x0 <= qtMinNodesiz) { |
285 |
if (z > (1.+qtDepthEps)*ip[2]) |
286 |
return(0); /* old one closer */ |
287 |
if (z >= (1.-qtDepthEps)*ip[2] && |
288 |
fdir2diff(qtL.wd[lo], vd) < d2) |
289 |
return(0); /* old one better */ |
290 |
tp->k[q].li = li; /* else new one is */ |
291 |
tp->flgs |= CHF(q); |
292 |
break; |
293 |
294 |
tp->flgs &= ~LFF(q); /* else grow tree */ |
295 |
tp->flgs |= CHBRF(q); |
296 |
tp = tp->k[q].b = newtwig(); |
297 |
q = 0; /* old leaf -> new branch */ |
298 |
mx = ip[0] * odev.hres; |
299 |
my = ip[1] * odev.vres; |
300 |
if (mx >= (x0 + x1) >> 1) q |= 01; |
301 |
if (my >= (y0 + y1) >> 1) q |= 02; |
302 |
tp->flgs = CH_ANY|LFF(q); /* all new */ |
303 |
tp->k[q].li = lo; |
304 |
305 |
return(1); /* done */ |
306 |
307 |
308 |
309 |
dev_value(c, p, v) /* add a pixel value to our quadtree */ |
310 |
COLR c; |
311 |
FVECT p, v; |
312 |
313 |
register int li; |
314 |
315 |
li = qtL.tl++; |
316 |
if (qtL.tl >= qtL.nl) /* advance to next leaf in ring */ |
317 |
qtL.tl = 0; |
318 |
if (qtL.tl == qtL.bl) /* need to shake some free */ |
319 |
qtCompost(LFREEPCT); |
320 |
VCOPY(qtL.wp[li], p); |
321 |
qtL.wd[li] = encodedir(v); |
322 |
tmCvColrs(&qtL.brt[li], qtL.chr[li], c, 1); |
323 |
if (!addleaf(li)) |
324 |
qtL.tl = li; /* unget this leaf */ |
325 |
326 |
327 |
328 |
qtReplant() /* replant our tree using new view */ |
329 |
330 |
register int i; |
331 |
/* anything to replant? */ |
332 |
if (qtL.bl == qtL.tl) |
333 |
return; |
334 |
qtFreeTree(0); /* blow the old tree away */ |
335 |
/* regrow it in new place */ |
336 |
for (i = qtL.bl; i != qtL.tl; ) { |
337 |
addleaf(i); |
338 |
if (++i >= qtL.nl) i = 0; |
339 |
340 |
341 |
342 |
343 |
qtMapLeaves(redo) /* map our leaves to RGB */ |
344 |
int redo; |
345 |
346 |
int aorg, alen, borg, blen; |
347 |
/* recompute mapping? */ |
348 |
if (redo) |
349 |
qtL.tml = qtL.bl; |
350 |
/* already done? */ |
351 |
if (qtL.tml == qtL.tl) |
352 |
return(1); |
353 |
/* compute segments */ |
354 |
aorg = qtL.tml; |
355 |
if (qtL.tl >= aorg) { |
356 |
alen = qtL.tl - aorg; |
357 |
blen = 0; |
358 |
} else { |
359 |
alen = qtL.nl - aorg; |
360 |
borg = 0; |
361 |
blen = qtL.tl; |
362 |
363 |
/* (re)compute tone mapping? */ |
364 |
if (qtL.tml == qtL.bl) { |
365 |
tmClearHisto(); |
366 |
tmAddHisto(qtL.brt+aorg, alen, 1); |
367 |
if (blen > 0) |
368 |
tmAddHisto(qtL.brt+borg, blen, 1); |
369 |
if (tmComputeMapping(0., 0., 0.) != TM_E_OK) |
370 |
return(0); |
371 |
372 |
if (tmMapPixels(qtL.rgb+aorg, qtL.brt+aorg, |
373 |
qtL.chr+aorg, alen) != TM_E_OK) |
374 |
return(0); |
375 |
if (blen > 0) |
376 |
tmMapPixels(qtL.rgb+borg, qtL.brt+borg, |
377 |
qtL.chr+borg, blen); |
378 |
qtL.tml = qtL.tl; |
379 |
return(1); |
380 |
