--- ray/src/hd/rhd_qtree.c 1997/12/30 17:08:37 3.15 +++ ray/src/hd/rhd_qtree.c 1998/01/01 13:00:15 3.17 @@ -29,6 +29,8 @@ double qtDepthEps = .05; /* epsilon to compare depths int qtMinNodesiz = 2; /* minimum node dimension (pixels) */ struct rleaves qtL; /* our pile of leaves */ +int rayqleft = 0; /* rays left to queue before flush */ + static int4 falleaves; /* our list of fallen leaves */ #define composted(li) (qtL.bl <= qtL.tl ? \ @@ -318,11 +320,14 @@ int drop; tp->k[q].li = lo; } dropit: - if (drop) { - qtL.chr[li][0] = qtL.chr[li][1] = qtL.chr[li][2] = 0; - qtL.wd[li] = falleaves; - falleaves = li; - } + if (drop) + if (li+1 == (qtL.tl ? qtL.tl : qtL.nl)) + qtL.tl = li; /* special case */ + else { + qtL.chr[li][0] = qtL.chr[li][1] = qtL.chr[li][2] = 0; + qtL.wd[li] = falleaves; + falleaves = li; + } return(li == lo); } @@ -334,25 +339,29 @@ FVECT p, v; register int li; int mapit; /* grab a leaf */ - if (falleaves >= 0) { /* check for fallen leaves */ + if (!imm_mode && falleaves >= 0) { /* check for fallen leaves */ li = falleaves; falleaves = qtL.wd[li]; mapit = qtL.tml <= qtL.tl ? (li < qtL.tml || li >= qtL.tl) : (li < qtL.tml && li >= qtL.tl) ; - } else { /* else allocate new one */ + } else { /* else allocate new one */ li = qtL.tl++; - if (qtL.tl >= qtL.nl) /* advance to next leaf in ring */ + if (qtL.tl >= qtL.nl) /* next leaf in ring */ qtL.tl = 0; - if (qtL.tl == qtL.bl) /* need to shake some free */ + if (qtL.tl == qtL.bl) /* need to shake some free */ qtCompost(LFREEPCT); - mapit = 0; /* we'll map it later */ + mapit = 0; /* we'll map it later */ } VCOPY(qtL.wp[li], p); qtL.wd[li] = encodedir(v); tmCvColrs(&qtL.brt[li], qtL.chr[li], c, 1); - if (putleaf(li, 1) && mapit) - tmMapPixels(qtL.rgb+li, qtL.brt+li, qtL.chr+li, 1); + if (putleaf(li, 1)) { + if (mapit) + tmMapPixels(qtL.rgb+li, qtL.brt+li, qtL.chr+li, 1); + if (--rayqleft == 0) + dev_flush(); /* flush output */ + } }
