--- ray/src/hd/rhd_qtree.c 1997/11/21 13:35:57 3.5 +++ ray/src/hd/rhd_qtree.c 1997/12/05 16:22:49 3.12 @@ -10,9 +10,22 @@ static char SCCSid[] = "$SunId$ SGI"; #include "standard.h" #include "rhd_qtree.h" + /* quantity of leaves to free at a time */ +#ifndef LFREEPCT +#define LFREEPCT 25 +#endif + /* maximum allowed angle difference (deg.) */ +#ifndef MAXANG +#define MAXANG 20 +#endif +#if MAXANG>0 +#define MAXDIFF2 ( MAXANG*MAXANG * (PI*PI/180./180.)) +#endif +#define abs(i) ((i) < 0 ? -(i) : (i)) + RTREE qtrunk; /* our quadtree trunk */ -double qtDepthEps = .02; /* epsilon to compare depths (z fraction) */ +double qtDepthEps = .05; /* epsilon to compare depths (z fraction) */ int qtMinNodesiz = 2; /* minimum node dimension (pixels) */ struct rleaves qtL; /* our pile of leaves */ @@ -21,7 +34,7 @@ struct rleaves qtL; /* our pile of leaves */ static RTREE **twigbundle; /* free twig blocks (NULL term.) */ static int nexttwig; /* next free twig */ -#define is_stump(t) (!((t)->flgs & (BR_ANY|LF_ANY))) +#define ungetleaf(li) (qtL.tl=(li)) /* dangerous if used improperly */ static RTREE * @@ -58,12 +71,13 @@ int really; { register int i; - qtrunk.flgs = 0; - nexttwig = 0; + qtrunk.flgs = CH_ANY; /* chop down tree */ if (twigbundle == NULL) return; + i = (TBUNDLESIZ-1+nexttwig)/TBUNDLESIZ; + nexttwig = 0; if (!really) { /* just clear allocated blocks */ - for (i = 0; twigbundle[i] != NULL; i++) + while (i--) bzero((char *)twigbundle[i], TBUNDLESIZ*sizeof(RTREE)); return; } @@ -89,7 +103,8 @@ newleaf() /* allocate a leaf from our pile */ } -#define LEAFSIZ (3*sizeof(float)+sizeof(TMbright)+6*sizeof(BYTE)) +#define LEAFSIZ (3*sizeof(float)+sizeof(int4)+\ + sizeof(TMbright)+6*sizeof(BYTE)) int qtAllocLeaves(n) /* allocate space for n leaves */ @@ -115,7 +130,8 @@ register int n; return(0); /* assign larger alignment types earlier */ qtL.wp = (float (*)[3])qtL.base; - qtL.brt = (TMbright *)(qtL.wp + n); + qtL.wd = (int4 *)(qtL.wp + n); + qtL.brt = (TMbright *)(qtL.wd + n); qtL.chr = (BYTE (*)[3])(qtL.brt + n); qtL.rgb = (BYTE (*)[3])(qtL.chr + n); qtL.nl = n; @@ -187,6 +203,96 @@ int pct; } +#define DCSCALE 11585.2 /* (1<<13)*sqrt(2) */ +#define FXNEG 01 +#define FYNEG 02 +#define FZNEG 04 +#define F1X 010 +#define F2Z 020 +#define F1SFT 5 +#define F2SFT 18 +#define FMASK 0x1fff + +static int4 +encodedir(dv) /* encode a normalized direction vector */ +FVECT dv; +{ + register int4 dc = 0; + int cd[3], cm; + register int i; + + for (i = 0; i < 3; i++) + if (dv[i] < 0.) { + cd[i] = dv[i] * -DCSCALE; + dc |= 1<>F1SFT & FMASK)+.5)/DCSCALE; + d2 = ((dc>>F2SFT & FMASK)+.5)/DCSCALE; + der = sqrt(1. - d1*d1 - d2*d2); + if (dc & F1X) { + dv[0] = d1; + if (dc & F2Z) { dv[1] = der; dv[2] = d2; } + else { dv[1] = d2; dv[2] = der; } + } else { + dv[1] = d1; + if (dc & F2Z) { dv[0] = der; dv[2] = d2; } + else { dv[0] = d2; dv[2] = der; } + } + if (dc & FXNEG) dv[0] = -dv[0]; + if (dc & FYNEG) dv[1] = -dv[1]; + if (dc & FZNEG) dv[2] = -dv[2]; +} + + +static double +dir2diff(dc1, dc2) /* relative radians^2 between directions */ +int4 dc1, dc2; +{ + FVECT v1, v2; + + decodedir(v1, dc1); + decodedir(v2, dc2); + + return(2. - 2.*DOT(v1,v2)); +} + + +static double +fdir2diff(dc1, v2) /* relative radians^2 between directions */ +int4 dc1; +register FVECT v2; +{ + FVECT v1; + + decodedir(v1, dc1); + + return(2. - 2.*DOT(v1,v2)); +} + + int qtFindLeaf(x, y) /* find closest leaf to (x,y) */ int x, y; @@ -231,16 +337,28 @@ int li; register RTREE *tp = &qtrunk; int x0=0, y0=0, x1=odev.hres, y1=odev.vres; int lo = -1; + double d2; int x, y, mx, my; double z; - FVECT ip, wp; + FVECT ip, wp, vd; register int q; - /* compute leaf location */ + /* compute leaf location in view */ VCOPY(wp, qtL.wp[li]); viewloc(ip, &odev.v, wp); if (ip[2] <= 0. || ip[0] < 0. || ip[0] >= 1. || ip[1] < 0. || ip[1] >= 1.) - return; + return(-1); /* behind or outside view */ +#ifdef DEBUG + if (odev.v.type == VT_PAR | odev.v.vfore > FTINY) + error(INTERNAL, "bad view assumption in addleaf"); +#endif + for (q = 0; q < 3; q++) + vd[q] = (wp[q] - odev.v.vp[q])/ip[2]; + d2 = fdir2diff(qtL.wd[li], vd); +#ifdef MAXDIFF2 + if (d2 > MAXDIFF2) + return(0); /* leaf dir. too far off */ +#endif x = ip[0] * odev.hres; y = ip[1] * odev.vres; z = ip[2]; @@ -263,17 +381,19 @@ int li; tp->flgs |= CHLFF(q); break; } - /* check existing leaf */ - if (lo != tp->k[q].li) { + if (lo != tp->k[q].li) { /* check old leaf */ lo = tp->k[q].li; VCOPY(wp, qtL.wp[lo]); viewloc(ip, &odev.v, wp); } /* is node minimum size? */ - if (x1-x0 <= qtMinNodesiz || y1-y0 <= qtMinNodesiz) { - if (z > (1.-qtDepthEps)*ip[2]) /* who is closer? */ - return; /* old one is */ - tp->k[q].li = li; /* new one is */ + if (y1-y0 <= qtMinNodesiz || x1-x0 <= qtMinNodesiz) { + if (z > (1.+qtDepthEps)*ip[2]) + return(0); /* old one closer */ + if (z >= (1.-qtDepthEps)*ip[2] && + fdir2diff(qtL.wd[lo], vd) < d2) + return(0); /* old one better */ + tp->k[q].li = li; /* else new one is */ tp->flgs |= CHF(q); break; } @@ -285,22 +405,25 @@ int li; my = ip[1] * odev.vres; if (mx >= (x0 + x1) >> 1) q |= 01; if (my >= (y0 + y1) >> 1) q |= 02; + tp->flgs = CH_ANY|LFF(q); /* all new */ tp->k[q].li = lo; - tp->flgs |= LFF(q)|CH_ANY; /* all new */ } + return(1); /* done */ } -dev_value(c, p) /* add a pixel value to our output queue */ +dev_value(c, p, v) /* add a pixel value to our quadtree */ COLR c; -FVECT p; +FVECT p, v; { register int li; li = newleaf(); VCOPY(qtL.wp[li], p); + qtL.wd[li] = encodedir(v); tmCvColrs(&qtL.brt[li], qtL.chr[li], c, 1); - addleaf(li); + if (!addleaf(li)) + ungetleaf(li); } @@ -323,11 +446,12 @@ qtMapLeaves(redo) /* map our leaves to RGB */ int redo; { int aorg, alen, borg, blen; + /* recompute mapping? */ + if (redo) + qtL.tml = qtL.bl; /* already done? */ if (qtL.tml == qtL.tl) return(1); - if (redo) - qtL.tml = qtL.bl; /* compute segments */ aorg = qtL.tml; if (qtL.tl >= aorg) { @@ -355,142 +479,4 @@ int redo; qtL.chr+borg, blen); qtL.tml = qtL.tl; return(1); -} - - -static -redraw(ca, tp, x0, y0, x1, y1, l) /* redraw portion of a tree */ -BYTE ca[3]; /* returned average color */ -register RTREE *tp; -int x0, y0, x1, y1; -int l[2][2]; -{ - int csm[3], nc; - register BYTE *cp; - BYTE rgb[3]; - int quads = CH_ANY; - int mx, my; - register int i; - /* compute midpoint */ - mx = (x0 + x1) >> 1; - my = (y0 + y1) >> 1; - /* see what to do */ - if (l[0][0] >= mx) - quads &= ~(CHF(2)|CHF(0)); - else if (l[0][1] <= mx) - quads &= ~(CHF(3)|CHF(1)); - if (l[1][0] >= my) - quads &= ~(CHF(1)|CHF(0)); - else if (l[1][1] <= my) - quads &= ~(CHF(3)|CHF(2)); - tp->flgs &= ~quads; /* mark them done */ - csm[0] = csm[1] = csm[2] = nc = 0; - /* do leaves first */ - for (i = 0; i < 4; i++) - if (quads & CHF(i) && tp->flgs & LFF(i)) { - dev_paintr(cp=qtL.rgb[tp->k[i].li], - i&01 ? mx : x0, i&02 ? my : y0, - i&01 ? x1 : mx, i&02 ? y1 : my); - csm[0] += cp[0]; csm[1] += cp[1]; csm[2] += cp[2]; - nc++; - quads &= ~CHF(i); - } - /* now do branches */ - for (i = 0; i < 4; i++) - if (quads & CHF(i) && tp->flgs & BRF(i)) { - redraw(rgb, tp->k[i].b, i&01 ? mx : x0, i&02 ? my : y0, - i&01 ? x1 : mx, i&02 ? y1 : my, l); - csm[0] += rgb[0]; csm[1] += rgb[1]; csm[2] += rgb[2]; - nc++; - quads &= ~CHF(i); - } - if (nc > 1) { - ca[0] = csm[0]/nc; ca[1] = csm[1]/nc; ca[2] = csm[2]/nc; - } else { - ca[0] = csm[0]; ca[1] = csm[1]; ca[2] = csm[2]; - } - if (!quads) return; - /* fill in gaps with average */ - for (i = 0; i < 4; i++) - if (quads & CHF(i)) - dev_paintr(ca, i&01 ? mx : x0, i&02 ? my : y0, - i&01 ? x1 : mx, i&02 ? y1 : my); -} - - -static -update(ca, tp, x0, y0, x1, y1) /* update tree display as needed */ -BYTE ca[3]; /* returned average color */ -register RTREE *tp; -int x0, y0, x1, y1; -{ - int csm[3], nc; - register BYTE *cp; - BYTE rgb[3]; - int gaps = 0; - int mx, my; - register int i; - /* compute midpoint */ - mx = (x0 + x1) >> 1; - my = (y0 + y1) >> 1; - csm[0] = csm[1] = csm[2] = nc = 0; - /* do leaves first */ - for (i = 0; i < 4; i++) { - if (!(tp->flgs & CHF(i))) - continue; - if (tp->flgs & LFF(i)) { - dev_paintr(cp=qtL.rgb[tp->k[i].li], - i&01 ? mx : x0, i&02 ? my : y0, - i&01 ? x1 : mx, i&02 ? y1 : my); - csm[0] += cp[0]; csm[1] += cp[1]; csm[2] += cp[2]; - nc++; - } else if (!(tp->flgs & BRF(i))) - gaps |= 1<flgs & CHBRF(i)) == CHBRF(i)) { - update(rgb, tp->k[i].b, i&01 ? mx : x0, i&02 ? my : y0, - i&01 ? x1 : mx, i&02 ? y1 : my); - csm[0] += rgb[0]; csm[1] += rgb[1]; csm[2] += rgb[2]; - nc++; - } - if (nc > 1) { - ca[0] = csm[0]/nc; ca[1] = csm[1]/nc; ca[2] = csm[2]/nc; - } else { - ca[0] = csm[0]; ca[1] = csm[1]; ca[2] = csm[2]; - } - /* fill in gaps with average */ - for (i = 0; gaps && i < 4; gaps >>= 1, i++) - if (gaps & 01) - dev_paintr(ca, i&01 ? mx : x0, i&02 ? my : y0, - i&01 ? x1 : mx, i&02 ? y1 : my); - tp->flgs &= ~CH_ANY; /* all done */ -} - - -qtRedraw(x0, y0, x1, y1) /* redraw part or all of our screen */ -int x0, y0, x1, y1; -{ - int lim[2][2]; - BYTE ca[3]; - - if (is_stump(&qtrunk)) - return; - if (!qtMapLeaves((lim[0][0]=x0) <= 0 & (lim[1][0]=y0) <= 0 & - (lim[0][1]=x1) >= odev.hres-1 & (lim[1][1]=y1) >= odev.vres-1)) - return; - redraw(ca, &qtrunk, 0, 0, odev.hres, odev.vres, lim); -} - - -qtUpdate() /* update our tree display */ -{ - BYTE ca[3]; - - if (is_stump(&qtrunk)) - return; - if (!qtMapLeaves(0)) - return; - update(ca, &qtrunk, 0, 0, odev.hres, odev.vres); }
