root/radiance/ray/src/hd/rhd_qtree.c
Revision: 3.29
Committed: Fri Oct 5 19:19:16 2018 UTC (6 years, 7 months ago) by greg
Changes since 3.28: +23 -23 lines
2 static const char RCSid[] = "$Id: rhd_qtree.c,v 3.28 2018/01/24 04:39:52 greg Exp $";
5 * Quadtree driver support routines.
6 */
7
8 #include <string.h>
9
10 #include "standard.h"
11 #include "rhd_qtree.h"
12 /* quantity of leaves to free at a time */
13 #ifndef LFREEPCT
14 #define LFREEPCT 25
15 #endif
16 /* maximum allowed angle difference (deg.) */
17 #ifndef MAXANG
18 #define MAXANG 20
19 #endif
20 #if MAXANG>0
21 #define MAXDIFF2 ( MAXANG*MAXANG * (PI*PI/180./180.))
22 #endif
23
24 #define abs(i) ((i) < 0 ? -(i) : (i))
25
26 RTREE qtrunk; /* our quadtree trunk */
27 double qtDepthEps = .05; /* epsilon to compare depths (z fraction) */
28 int qtMinNodesiz = 2; /* minimum node dimension (pixels) */
29 struct rleaves qtL; /* our pile of leaves */
30
31 int rayqleft = 0; /* rays left to queue before flush */
32
33 static int32 falleaves; /* our list of fallen leaves */
34
35 #define composted(li) (qtL.bl <= qtL.tl ? \
36 ((li) < qtL.bl || (li) >= qtL.tl) : \
37 ((li) < qtL.bl && (li) >= qtL.tl))
38
39 #define TBUNDLESIZ 409 /* number of twigs in a bundle */
40
41 static RTREE **twigbundle; /* free twig blocks (NULL term.) */
42 static int nexttwig; /* next free twig */
43
44 static RTREE *newtwig(void);
45 static void qtFreeTree(int really);
46 static void shaketree(RTREE *tp);
47 static int putleaf(int li, int drop);
48
49
50 static RTREE *
51 newtwig(void) /* allocate a twig */
52 {
53 int bi;
54
55 if (twigbundle == NULL) { /* initialize */
56 twigbundle = (RTREE **)malloc(sizeof(RTREE *));
57 if (twigbundle == NULL)
58 goto memerr;
59 twigbundle[0] = NULL;
60 }
61 bi = nexttwig / TBUNDLESIZ;
62 if (twigbundle[bi] == NULL) { /* new block */
63 twigbundle = (RTREE **)realloc((void *)twigbundle,
64 (bi+2)*sizeof(RTREE *));
65 if (twigbundle == NULL)
66 goto memerr;
67 twigbundle[bi] = (RTREE *)calloc(TBUNDLESIZ, sizeof(RTREE));
68 if (twigbundle[bi] == NULL)
69 goto memerr;
70 twigbundle[bi+1] = NULL;
71 }
72 /* nexttwig++ % TBUNDLESIZ */
73 return(twigbundle[bi] + (nexttwig++ - bi*TBUNDLESIZ));
74 memerr:
75 error(SYSTEM, "out of memory in newtwig");
76 return NULL; /* pro forma return */
77 }
78
79
80 static void
81 qtFreeTree( /* free allocated twigs */
82 int really
83 )
84 {
85 int i;
86
87 qtrunk.flgs = CH_ANY; /* chop down tree */
88 if (twigbundle == NULL)
89 return;
90 i = (TBUNDLESIZ-1+nexttwig)/TBUNDLESIZ;
91 nexttwig = 0;
92 if (!really) { /* just clear allocated blocks */
93 while (i--)
94 memset((char *)twigbundle[i], '\0', TBUNDLESIZ*sizeof(RTREE));
95 return;
96 }
97 /* else "really" means free up memory */
98 for (i = 0; twigbundle[i] != NULL; i++)
99 free((void *)twigbundle[i]);
100 free((void *)twigbundle);
101 twigbundle = NULL;
102 }
103
104
105 #define LEAFSIZ (3*sizeof(float)+sizeof(int32)+\
106 sizeof(TMbright)+6*sizeof(uby8))
107
108 int
109 qtAllocLeaves( /* allocate space for n leaves */
110 int n
111 )
112 {
113 unsigned nbytes;
114 unsigned i;
115
116 qtFreeTree(0); /* make sure tree is empty */
117 if (n <= 0)
118 return(0);
119 if (qtL.nl >= n)
120 return(qtL.nl);
121 else if (qtL.nl > 0)
122 free(qtL.base);
123 /* round space up to nearest power of 2 */
124 nbytes = n*LEAFSIZ + 8;
125 for (i = 1024; nbytes > i; i <<= 1)
126 ;
127 n = (i - 8) / LEAFSIZ; /* should we make sure n is even? */
128 qtL.base = (char *)malloc(n*LEAFSIZ);
129 if (qtL.base == NULL)
130 return(0);
131 /* assign larger alignment types earlier */
132 qtL.wp = (float (*)[3])qtL.base;
133 qtL.wd = (int32 *)(qtL.wp + n);
134 qtL.brt = (TMbright *)(qtL.wd + n);
135 qtL.chr = (uby8 (*)[3])(qtL.brt + n);
136 qtL.rgb = (uby8 (*)[3])(qtL.chr + n);
137 qtL.nl = n;
138 qtL.tml = qtL.bl = qtL.tl = 0;
139 falleaves = -1;
140 return(n);
141 }
142
143 #undef LEAFSIZ
144
145
146 void
147 qtFreeLeaves(void) /* free our allocated leaves and twigs */
148 {
149 qtFreeTree(1); /* free tree also */
150 if (qtL.nl <= 0)
151 return;
152 free(qtL.base);
153 qtL.base = NULL;
154 qtL.nl = 0;
155 }
156
157
158 static void
159 shaketree( /* shake dead leaves from tree */
160 RTREE *tp
161 )
162 {
163 int i, li;
164
165 for (i = 0; i < 4; i++)
166 if (tp->flgs & BRF(i)) {
167 shaketree(tp->k[i].b);
168 if (is_stump(tp->k[i].b))
169 tp->flgs &= ~BRF(i);
170 } else if (tp->flgs & LFF(i)) {
171 li = tp->k[i].li;
172 if (composted(li))
173 tp->flgs &= ~LFF(i);
174 }
175 }
176
177
178 int
179 qtCompost( /* free up some leaves */
180 int pct
181 )
182 {
183 int32 *fl;
184 int nused, nclear, nmapped;
185 /* figure out how many leaves to clear */
186 nclear = qtL.nl * pct / 100;
187 nused = qtL.tl - qtL.bl;
188 if (nused <= 0) nused += qtL.nl;
189 nclear -= qtL.nl - nused;
190 if (nclear <= 0)
191 return(0);
192 if (nclear >= nused) { /* clear them all */
193 qtFreeTree(0);
194 qtL.tml = qtL.bl = qtL.tl = 0;
195 falleaves = -1;
196 return(nused);
197 }
198 /* else clear leaves from bottom */
199 nmapped = qtL.tml - qtL.bl;
200 if (nmapped < 0) nmapped += qtL.nl;
201 qtL.bl += nclear;
202 if (qtL.bl >= qtL.nl) qtL.bl -= qtL.nl;
203 if (nmapped <= nclear) qtL.tml = qtL.bl;
204 shaketree(&qtrunk); /* dereference composted leaves */
205 for (fl = &falleaves; *fl >= 0; fl = qtL.wd + *fl)
206 while (composted(*fl))
207 if ((*fl = qtL.wd[*fl]) < 0)
208 return(nclear);
209 return(nclear);
210 }
211
212
213 int
214 qtFindLeaf( /* find closest leaf to (x,y) */
215 int x,
216 int y
217 )
218 {
219 RTREE *tp = &qtrunk;
220 int li = -1;
221 int x0=0, y0=0, x1=odev.hres, y1=odev.vres;
222 int mx, my;
223 int q;
224 /* check limits */
225 if (x < 0 || x >= odev.hres || y < 0 || y >= odev.vres)
226 return(-1);
227 /* find nearby leaf in our tree */
228 for ( ; ; ) {
229 for (q = 0; q < 4; q++) /* find any leaf this level */
230 if (tp->flgs & LFF(q)) {
231 li = tp->k[q].li;
232 break;
233 }
234 q = 0; /* which quadrant are we? */
235 mx = (x0 + x1) >> 1;
236 my = (y0 + y1) >> 1;
237 if (x < mx) x1 = mx;
238 else {x0 = mx; q |= 01;}
239 if (y < my) y1 = my;
240 else {y0 = my; q |= 02;}
241 if (tp->flgs & BRF(q)) { /* branch down if not a leaf */
242 tp = tp->k[q].b;
243 continue;
244 }
245 if (tp->flgs & LFF(q)) /* good shot! */
246 return(tp->k[q].li);
247 return(li); /* else return what we have */
248 }
249 }
250
251
252 static int
253 putleaf( /* put a leaf in our tree */
254 int li,
255 int drop
256 )
257 {
258 RTREE *tp = &qtrunk;
259 int x0=0, y0=0, x1=odev.hres, y1=odev.vres;
260 int lo = -1;
261 double d2;
262 int x, y, mx, my;
263 double z;
264 FVECT ip, wp, vd;
265 int q;
266 /* check for dead leaf */
267 if (!qtL.chr[li][1] && !(qtL.chr[li][0] | qtL.chr[li][2]))
268 return(0);
269 /* compute leaf location in view */
270 VCOPY(wp, qtL.wp[li]);
271 if (viewloc(ip, &odev.v, wp) != 1)
272 goto dropit; /* behind or outside view */
273 #ifdef DEBUG
274 if (odev.v.type == VT_PAR | odev.v.vfore > FTINY)
275 error(INTERNAL, "bad view assumption in putleaf");
276 #endif
277 for (q = 0; q < 3; q++)
278 vd[q] = (wp[q] - odev.v.vp[q])/ip[2];
279 d2 = fdir2diff(qtL.wd[li], vd);
280 #ifdef MAXDIFF2
281 if (d2 > MAXDIFF2)
282 goto dropit; /* leaf dir. too far off */
283 #endif
284 x = ip[0] * odev.hres;
285 y = ip[1] * odev.vres;
286 z = ip[2];
287 /* find the place for it */
288 for ( ; ; ) {
289 q = 0; /* which quadrant? */
290 mx = (x0 + x1) >> 1;
291 my = (y0 + y1) >> 1;
292 if (x < mx) x1 = mx;
293 else {x0 = mx; q |= 01;}
294 if (y < my) y1 = my;
295 else {y0 = my; q |= 02;}
296 if (tp->flgs & BRF(q)) { /* move to next branch */
297 tp->flgs |= CHF(q); /* not sure; guess */
298 tp = tp->k[q].b;
299 continue;
300 }
301 if (!(tp->flgs & LFF(q))) { /* found stem for leaf */
302 tp->k[q].li = li;
303 tp->flgs |= CHLFF(q);
304 return(1);
305 }
306 if (lo != tp->k[q].li) { /* check old leaf */
307 lo = tp->k[q].li;
308 VCOPY(wp, qtL.wp[lo]);
309 viewloc(ip, &odev.v, wp);
310 }
311 /* is node minimum size? */
312 if (y1-y0 <= qtMinNodesiz || x1-x0 <= qtMinNodesiz) {
313 if (z > (1.+qtDepthEps)*ip[2])
314 break; /* old one closer */
315 if (z >= (1.-qtDepthEps)*ip[2] &&
316 fdir2diff(qtL.wd[lo], vd) < d2)
317 break; /* old one better */
318 tp->k[q].li = li; /* attach new */
319 tp->flgs |= CHF(q);
320 li = lo; /* drop old... */
321 break;
322 }
323 tp->flgs &= ~LFF(q); /* else grow tree */
324 tp->flgs |= CHBRF(q);
325 tp = tp->k[q].b = newtwig();
326 q = 0; /* old leaf -> new branch */
327 mx = ip[0] * odev.hres;
328 my = ip[1] * odev.vres;
329 if (mx >= (x0 + x1) >> 1) q |= 01;
330 if (my >= (y0 + y1) >> 1) q |= 02;
331 tp->flgs = CH_ANY|LFF(q); /* all new */
332 tp->k[q].li = lo;
333 }
334 dropit:
335 if (drop) {
336 if (li+1 == (qtL.tl ? qtL.tl : qtL.nl))
337 qtL.tl = li; /* special case */
338 else {
339 qtL.chr[li][0] = qtL.chr[li][1] = qtL.chr[li][2] = 0;
340 qtL.wd[li] = falleaves;
341 falleaves = li;
342 }
343 }
344 return(li == lo);
345 }
346
347
348 void
349 dev_value( /* add a pixel value to our quadtree */
350 COLR c,
351 FVECT d,
352 FVECT p
353 )
354 {
355 int li;
356 int mapit;
357 /* grab a leaf */
358 if (!imm_mode && falleaves >= 0) { /* check for fallen leaves */
359 li = falleaves;
360 falleaves = qtL.wd[li];
361 mapit = qtL.tml <= qtL.tl ?
362 (li < qtL.tml || li >= qtL.tl) :
363 (li < qtL.tml && li >= qtL.tl) ;
364 } else { /* else allocate new one */
365 li = qtL.tl++;
366 if (qtL.tl >= qtL.nl) /* next leaf in ring */
367 qtL.tl = 0;
368 if (qtL.tl == qtL.bl) /* need to shake some free */
369 qtCompost(LFREEPCT);
370 mapit = 0; /* we'll map it later */
371 }
372 if (p == NULL)
373 VSUM(qtL.wp[li], odev.v.vp, d, FHUGE);
374 else
375 VCOPY(qtL.wp[li], p);
376 qtL.wd[li] = encodedir(d);
377 tmCvColrs(tmGlobal, &qtL.brt[li], qtL.chr[li], (COLR *)c, 1);
378 if (putleaf(li, 1)) {
379 if (mapit)
380 tmMapPixels(tmGlobal, (uby8 *)(qtL.rgb+li), qtL.brt+li,
381 (uby8 *)(qtL.chr+li), 1);
382 if (--rayqleft == 0)
383 dev_flush(); /* flush output */
384 }
385 }
386
387
388 void
389 qtReplant(void) /* replant our tree using new view */
390 {
391 int i;
392 /* anything to replant? */
393 if (qtL.bl == qtL.tl)
394 return;
395 qtFreeTree(0); /* blow the old tree away */
396 /* regrow it in new place */
397 for (i = qtL.bl; i != qtL.tl; ) {
398 putleaf(i, 0);
399 if (++i >= qtL.nl) i = 0;
400 }
401 }
402
403
404 int
405 qtMapLeaves( /* map our leaves to RGB */
406 int redo
407 )
408 {
409 int aorg, alen, borg, blen;
410 /* recompute mapping? */
411 if (redo)
412 qtL.tml = qtL.bl;
413 /* already done? */
414 if (qtL.tml == qtL.tl)
415 return(1);
416 /* compute segments */
417 aorg = qtL.tml;
418 if (qtL.tl >= aorg) {
419 alen = qtL.tl - aorg;
420 blen = 0;
421 } else {
422 alen = qtL.nl - aorg;
423 borg = 0;
424 blen = qtL.tl;
425 }
426 /* (re)compute tone mapping? */
427 if (qtL.tml == qtL.bl) {
428 tmClearHisto(tmGlobal);
429 tmAddHisto(tmGlobal, qtL.brt+aorg, alen, 1);
430 if (blen > 0)
431 tmAddHisto(tmGlobal, qtL.brt+borg, blen, 1);
432 if (tmComputeMapping(tmGlobal, 0., 0., 0.) != TM_E_OK)
433 return(0);
434 }
435 if (tmMapPixels(tmGlobal, (uby8 *)(qtL.rgb+aorg), qtL.brt+aorg,
436 (uby8 *)(qtL.chr+aorg), alen) != TM_E_OK)
437 return(0);
438 if (blen > 0)
439 tmMapPixels(tmGlobal, (uby8 *)(qtL.rgb+borg), qtL.brt+borg,
440 (uby8 *)(qtL.chr+borg), blen);
441 qtL.tml = qtL.tl;
442 return(1);
443 }
