root/radiance/ray/src/hd/rhd_qtree.c
Revision: 3.23
Committed: Mon Jun 30 14:59:11 2003 UTC (21 years, 10 months ago) by schorsch
Changes since 3.22: +4 -2 lines
2 static const char RCSid[] = "$Id: rhd_qtree.c,v 3.22 2003/06/20 00:25:49 greg Exp $";
5 * Quadtree driver support routines.
6 */
7
8 #include <string.h>
9
10 #include "standard.h"
11 #include "rhd_qtree.h"
12 /* quantity of leaves to free at a time */
13 #ifndef LFREEPCT
14 #define LFREEPCT 25
15 #endif
16 /* maximum allowed angle difference (deg.) */
17 #ifndef MAXANG
18 #define MAXANG 20
19 #endif
20 #if MAXANG>0
21 #define MAXDIFF2 ( MAXANG*MAXANG * (PI*PI/180./180.))
22 #endif
23
24 #define abs(i) ((i) < 0 ? -(i) : (i))
25
26 RTREE qtrunk; /* our quadtree trunk */
27 double qtDepthEps = .05; /* epsilon to compare depths (z fraction) */
28 int qtMinNodesiz = 2; /* minimum node dimension (pixels) */
29 struct rleaves qtL; /* our pile of leaves */
30
31 int rayqleft = 0; /* rays left to queue before flush */
32
33 static int32 falleaves; /* our list of fallen leaves */
34
35 #define composted(li) (qtL.bl <= qtL.tl ? \
36 ((li) < qtL.bl || (li) >= qtL.tl) : \
37 ((li) < qtL.bl && (li) >= qtL.tl))
38
39 #define TBUNDLESIZ 409 /* number of twigs in a bundle */
40
41 static RTREE **twigbundle; /* free twig blocks (NULL term.) */
42 static int nexttwig; /* next free twig */
43
44
45 static RTREE *
46 newtwig() /* allocate a twig */
47 {
48 register int bi;
49
50 if (twigbundle == NULL) { /* initialize */
51 twigbundle = (RTREE **)malloc(sizeof(RTREE *));
52 if (twigbundle == NULL)
53 goto memerr;
54 twigbundle[0] = NULL;
55 }
56 bi = nexttwig / TBUNDLESIZ;
57 if (twigbundle[bi] == NULL) { /* new block */
58 twigbundle = (RTREE **)realloc((void *)twigbundle,
59 (bi+2)*sizeof(RTREE *));
60 if (twigbundle == NULL)
61 goto memerr;
62 twigbundle[bi] = (RTREE *)calloc(TBUNDLESIZ, sizeof(RTREE));
63 if (twigbundle[bi] == NULL)
64 goto memerr;
65 twigbundle[bi+1] = NULL;
66 }
67 /* nexttwig++ % TBUNDLESIZ */
68 return(twigbundle[bi] + (nexttwig++ - bi*TBUNDLESIZ));
69 memerr:
70 error(SYSTEM, "out of memory in newtwig");
71 }
72
73
74 qtFreeTree(really) /* free allocated twigs */
75 int really;
76 {
77 register int i;
78
79 qtrunk.flgs = CH_ANY; /* chop down tree */
80 if (twigbundle == NULL)
81 return;
82 i = (TBUNDLESIZ-1+nexttwig)/TBUNDLESIZ;
83 nexttwig = 0;
84 if (!really) { /* just clear allocated blocks */
85 while (i--)
86 memset((char *)twigbundle[i], '\0', TBUNDLESIZ*sizeof(RTREE));
87 return;
88 }
89 /* else "really" means free up memory */
90 for (i = 0; twigbundle[i] != NULL; i++)
91 free((void *)twigbundle[i]);
92 free((void *)twigbundle);
93 twigbundle = NULL;
94 }
95
96
97 #define LEAFSIZ (3*sizeof(float)+sizeof(int32)+\
98 sizeof(TMbright)+6*sizeof(BYTE))
99
100 int
101 qtAllocLeaves(n) /* allocate space for n leaves */
102 register int n;
103 {
104 unsigned nbytes;
105 register unsigned i;
106
107 qtFreeTree(0); /* make sure tree is empty */
108 if (n <= 0)
109 return(0);
110 if (qtL.nl >= n)
111 return(qtL.nl);
112 else if (qtL.nl > 0)
113 free(qtL.base);
114 /* round space up to nearest power of 2 */
115 nbytes = n*LEAFSIZ + 8;
116 for (i = 1024; nbytes > i; i <<= 1)
117 ;
118 n = (i - 8) / LEAFSIZ; /* should we make sure n is even? */
119 qtL.base = (char *)malloc(n*LEAFSIZ);
120 if (qtL.base == NULL)
121 return(0);
122 /* assign larger alignment types earlier */
123 qtL.wp = (float (*)[3])qtL.base;
124 qtL.wd = (int32 *)(qtL.wp + n);
125 qtL.brt = (TMbright *)(qtL.wd + n);
126 qtL.chr = (BYTE (*)[3])(qtL.brt + n);
127 qtL.rgb = (BYTE (*)[3])(qtL.chr + n);
128 qtL.nl = n;
129 qtL.tml = qtL.bl = qtL.tl = 0;
130 falleaves = -1;
131 return(n);
132 }
133
134 #undef LEAFSIZ
135
136
137 qtFreeLeaves() /* free our allocated leaves and twigs */
138 {
139 qtFreeTree(1); /* free tree also */
140 if (qtL.nl <= 0)
141 return;
142 free(qtL.base);
143 qtL.base = NULL;
144 qtL.nl = 0;
145 }
146
147
148 static
149 shaketree(tp) /* shake dead leaves from tree */
150 register RTREE *tp;
151 {
152 register int i, li;
153
154 for (i = 0; i < 4; i++)
155 if (tp->flgs & BRF(i)) {
156 shaketree(tp->k[i].b);
157 if (is_stump(tp->k[i].b))
158 tp->flgs &= ~BRF(i);
159 } else if (tp->flgs & LFF(i)) {
160 li = tp->k[i].li;
161 if (composted(li))
162 tp->flgs &= ~LFF(i);
163 }
164 }
165
166
167 int
168 qtCompost(pct) /* free up some leaves */
169 int pct;
170 {
171 register int32 *fl;
172 int nused, nclear, nmapped;
173 /* figure out how many leaves to clear */
174 nclear = qtL.nl * pct / 100;
175 nused = qtL.tl - qtL.bl;
176 if (nused <= 0) nused += qtL.nl;
177 nclear -= qtL.nl - nused;
178 if (nclear <= 0)
179 return(0);
180 if (nclear >= nused) { /* clear them all */
181 qtFreeTree(0);
182 qtL.tml = qtL.bl = qtL.tl = 0;
183 falleaves = -1;
184 return(nused);
185 }
186 /* else clear leaves from bottom */
187 nmapped = qtL.tml - qtL.bl;
188 if (nmapped < 0) nmapped += qtL.nl;
189 qtL.bl += nclear;
190 if (qtL.bl >= qtL.nl) qtL.bl -= qtL.nl;
191 if (nmapped <= nclear) qtL.tml = qtL.bl;
192 shaketree(&qtrunk); /* dereference composted leaves */
193 for (fl = &falleaves; *fl >= 0; fl = qtL.wd + *fl)
194 while (composted(*fl))
195 if ((*fl = qtL.wd[*fl]) < 0)
196 return(nclear);
197 return(nclear);
198 }
199
200
201 int
202 qtFindLeaf(x, y) /* find closest leaf to (x,y) */
203 int x, y;
204 {
205 register RTREE *tp = &qtrunk;
206 int li = -1;
207 int x0=0, y0=0, x1=odev.hres, y1=odev.vres;
208 int mx, my;
209 register int q;
210 /* check limits */
211 if (x < 0 || x >= odev.hres || y < 0 || y >= odev.vres)
212 return(-1);
213 /* find nearby leaf in our tree */
214 for ( ; ; ) {
215 for (q = 0; q < 4; q++) /* find any leaf this level */
216 if (tp->flgs & LFF(q)) {
217 li = tp->k[q].li;
218 break;
219 }
220 q = 0; /* which quadrant are we? */
221 mx = (x0 + x1) >> 1;
222 my = (y0 + y1) >> 1;
223 if (x < mx) x1 = mx;
224 else {x0 = mx; q |= 01;}
225 if (y < my) y1 = my;
226 else {y0 = my; q |= 02;}
227 if (tp->flgs & BRF(q)) { /* branch down if not a leaf */
228 tp = tp->k[q].b;
229 continue;
230 }
231 if (tp->flgs & LFF(q)) /* good shot! */
232 return(tp->k[q].li);
233 return(li); /* else return what we have */
234 }
235 }
236
237
238 static
239 putleaf(li, drop) /* put a leaf in our tree */
240 register int li;
241 int drop;
242 {
243 register RTREE *tp = &qtrunk;
244 int x0=0, y0=0, x1=odev.hres, y1=odev.vres;
245 register int lo = -1;
246 double d2;
247 int x, y, mx, my;
248 double z;
249 FVECT ip, wp, vd;
250 register int q;
251 /* check for dead leaf */
252 if (!qtL.chr[li][1] && !(qtL.chr[li][0] | qtL.chr[li][2]))
253 return(0);
254 /* compute leaf location in view */
255 VCOPY(wp, qtL.wp[li]);
256 viewloc(ip, &odev.v, wp);
257 if (ip[2] <= 0. || ip[0] < 0. || ip[0] >= 1.
258 || ip[1] < 0. || ip[1] >= 1.)
259 goto dropit; /* behind or outside view */
260 #ifdef DEBUG
261 if (odev.v.type == VT_PAR | odev.v.vfore > FTINY)
262 error(INTERNAL, "bad view assumption in putleaf");
263 #endif
264 for (q = 0; q < 3; q++)
265 vd[q] = (wp[q] - odev.v.vp[q])/ip[2];
266 d2 = fdir2diff(qtL.wd[li], vd);
267 #ifdef MAXDIFF2
268 if (d2 > MAXDIFF2)
269 goto dropit; /* leaf dir. too far off */
270 #endif
271 x = ip[0] * odev.hres;
272 y = ip[1] * odev.vres;
273 z = ip[2];
274 /* find the place for it */
275 for ( ; ; ) {
276 q = 0; /* which quadrant? */
277 mx = (x0 + x1) >> 1;
278 my = (y0 + y1) >> 1;
279 if (x < mx) x1 = mx;
280 else {x0 = mx; q |= 01;}
281 if (y < my) y1 = my;
282 else {y0 = my; q |= 02;}
283 if (tp->flgs & BRF(q)) { /* move to next branch */
284 tp->flgs |= CHF(q); /* not sure; guess */
285 tp = tp->k[q].b;
286 continue;
287 }
288 if (!(tp->flgs & LFF(q))) { /* found stem for leaf */
289 tp->k[q].li = li;
290 tp->flgs |= CHLFF(q);
291 return(1);
292 }
293 if (lo != tp->k[q].li) { /* check old leaf */
294 lo = tp->k[q].li;
295 VCOPY(wp, qtL.wp[lo]);
296 viewloc(ip, &odev.v, wp);
297 }
298 /* is node minimum size? */
299 if (y1-y0 <= qtMinNodesiz || x1-x0 <= qtMinNodesiz) {
300 if (z > (1.+qtDepthEps)*ip[2])
301 break; /* old one closer */
302 if (z >= (1.-qtDepthEps)*ip[2] &&
303 fdir2diff(qtL.wd[lo], vd) < d2)
304 break; /* old one better */
305 tp->k[q].li = li; /* attach new */
306 tp->flgs |= CHF(q);
307 li = lo; /* drop old... */
308 break;
309 }
310 tp->flgs &= ~LFF(q); /* else grow tree */
311 tp->flgs |= CHBRF(q);
312 tp = tp->k[q].b = newtwig();
313 q = 0; /* old leaf -> new branch */
314 mx = ip[0] * odev.hres;
315 my = ip[1] * odev.vres;
316 if (mx >= (x0 + x1) >> 1) q |= 01;
317 if (my >= (y0 + y1) >> 1) q |= 02;
318 tp->flgs = CH_ANY|LFF(q); /* all new */
319 tp->k[q].li = lo;
320 }
321 dropit:
322 if (drop)
323 if (li+1 == (qtL.tl ? qtL.tl : qtL.nl))
324 qtL.tl = li; /* special case */
325 else {
326 qtL.chr[li][0] = qtL.chr[li][1] = qtL.chr[li][2] = 0;
327 qtL.wd[li] = falleaves;
328 falleaves = li;
329 }
330 return(li == lo);
331 }
332
333
334 dev_value(c, d, p) /* add a pixel value to our quadtree */
335 COLR c;
336 FVECT d, p;
337 {
338 register int li;
339 int mapit;
340 /* grab a leaf */
341 if (!imm_mode && falleaves >= 0) { /* check for fallen leaves */
342 li = falleaves;
343 falleaves = qtL.wd[li];
344 mapit = qtL.tml <= qtL.tl ?
345 (li < qtL.tml || li >= qtL.tl) :
346 (li < qtL.tml && li >= qtL.tl) ;
347 } else { /* else allocate new one */
348 li = qtL.tl++;
349 if (qtL.tl >= qtL.nl) /* next leaf in ring */
350 qtL.tl = 0;
351 if (qtL.tl == qtL.bl) /* need to shake some free */
352 qtCompost(LFREEPCT);
353 mapit = 0; /* we'll map it later */
354 }
355 if (p == NULL)
356 VSUM(qtL.wp[li], odev.v.vp, d, FHUGE);
357 else
358 VCOPY(qtL.wp[li], p);
359 qtL.wd[li] = encodedir(d);
360 tmCvColrs(&qtL.brt[li], qtL.chr[li], (COLR *)c, 1);
361 if (putleaf(li, 1)) {
362 if (mapit)
363 tmMapPixels((BYTE *)(qtL.rgb+li), qtL.brt+li,
364 (BYTE *)(qtL.chr+li), 1);
365 if (--rayqleft == 0)
366 dev_flush(); /* flush output */
367 }
368 }
369
370
371 qtReplant() /* replant our tree using new view */
372 {
373 register int i;
374 /* anything to replant? */
375 if (qtL.bl == qtL.tl)
376 return;
377 qtFreeTree(0); /* blow the old tree away */
378 /* regrow it in new place */
379 for (i = qtL.bl; i != qtL.tl; ) {
380 putleaf(i, 0);
381 if (++i >= qtL.nl) i = 0;
382 }
383 }
384
385
386 qtMapLeaves(redo) /* map our leaves to RGB */
387 int redo;
388 {
389 int aorg, alen, borg, blen;
390 /* recompute mapping? */
391 if (redo)
392 qtL.tml = qtL.bl;
393 /* already done? */
394 if (qtL.tml == qtL.tl)
395 return(1);
396 /* compute segments */
397 aorg = qtL.tml;
398 if (qtL.tl >= aorg) {
399 alen = qtL.tl - aorg;
400 blen = 0;
401 } else {
402 alen = qtL.nl - aorg;
403 borg = 0;
404 blen = qtL.tl;
405 }
406 /* (re)compute tone mapping? */
407 if (qtL.tml == qtL.bl) {
408 tmClearHisto();
409 tmAddHisto(qtL.brt+aorg, alen, 1);
410 if (blen > 0)
411 tmAddHisto(qtL.brt+borg, blen, 1);
412 if (tmComputeMapping(0., 0., 0.) != TM_E_OK)
413 return(0);
414 }
415 if (tmMapPixels((BYTE *)(qtL.rgb+aorg), qtL.brt+aorg,
416 (BYTE *)(qtL.chr+aorg), alen) != TM_E_OK)
417 return(0);
418 if (blen > 0)
419 tmMapPixels((BYTE *)(qtL.rgb+borg), qtL.brt+borg,
420 (BYTE *)(qtL.chr+borg), blen);
421 qtL.tml = qtL.tl;
422 return(1);
423 }
