root/radiance/ray/src/hd/rhd_qtree.c
Revision: 3.6
Committed: Mon Nov 24 15:16:10 1997 UTC (26 years, 7 months ago) by gregl
Changes since 3.5: +8 -3 lines
moved LFREEPCT to rhd_qtree.c and changed from 15% to 25%
fixed bug in trunk flag settings in qtFreeTree()
fixed bug in tone remapping routine
1 /* Copyright (c) 1997 Silicon Graphics, Inc. */
2
3 #ifndef lint
4 static char SCCSid[] = "$SunId$ SGI";
5 #endif
6
7 /*
8 * Quadtree driver support routines.
9 */
10
11 #include "standard.h"
12 #include "rhd_qtree.h"
13 /* quantity of leaves to free at a time */
14 #ifndef LFREEPCT
15 #define LFREEPCT 25
16 #endif
17
18 RTREE qtrunk; /* our quadtree trunk */
19 double qtDepthEps = .02; /* epsilon to compare depths (z fraction) */
20 int qtMinNodesiz = 2; /* minimum node dimension (pixels) */
21 struct rleaves qtL; /* our pile of leaves */
22
23 #define TBUNDLESIZ 409 /* number of twigs in a bundle */
24
25 static RTREE **twigbundle; /* free twig blocks (NULL term.) */
26 static int nexttwig; /* next free twig */
27
28 #define is_stump(t) (!((t)->flgs & (BR_ANY|LF_ANY)))
29
30
31 static RTREE *
32 newtwig() /* allocate a twig */
33 {
34 register int bi;
35
36 if (twigbundle == NULL) { /* initialize */
37 twigbundle = (RTREE **)malloc(sizeof(RTREE *));
38 if (twigbundle == NULL)
39 goto memerr;
40 twigbundle[0] = NULL;
41 }
42 bi = nexttwig / TBUNDLESIZ;
43 if (twigbundle[bi] == NULL) { /* new block */
44 twigbundle = (RTREE **)realloc((char *)twigbundle,
45 (bi+2)*sizeof(RTREE *));
46 if (twigbundle == NULL)
47 goto memerr;
48 twigbundle[bi] = (RTREE *)calloc(TBUNDLESIZ, sizeof(RTREE));
49 if (twigbundle[bi] == NULL)
50 goto memerr;
51 twigbundle[bi+1] = NULL;
52 }
53 /* nexttwig++ % TBUNDLESIZ */
54 return(twigbundle[bi] + (nexttwig++ - bi*TBUNDLESIZ));
55 memerr:
56 error(SYSTEM, "out of memory in newtwig");
57 }
58
59
60 qtFreeTree(really) /* free allocated twigs */
61 int really;
62 {
63 register int i;
64
65 qtrunk.flgs = CH_ANY;
66 nexttwig = 0;
67 if (twigbundle == NULL)
68 return;
69 if (!really) { /* just clear allocated blocks */
70 for (i = 0; twigbundle[i] != NULL; i++)
71 bzero((char *)twigbundle[i], TBUNDLESIZ*sizeof(RTREE));
72 return;
73 }
74 /* else "really" means free up memory */
75 for (i = 0; twigbundle[i] != NULL; i++)
76 free((char *)twigbundle[i]);
77 free((char *)twigbundle);
78 twigbundle = NULL;
79 }
80
81
82 static int
83 newleaf() /* allocate a leaf from our pile */
84 {
85 int li;
86
87 li = qtL.tl++;
88 if (qtL.tl >= qtL.nl) /* get next leaf in ring */
89 qtL.tl = 0;
90 if (qtL.tl == qtL.bl) /* need to shake some free */
91 qtCompost(LFREEPCT);
92 return(li);
93 }
94
95
96 #define LEAFSIZ (3*sizeof(float)+sizeof(TMbright)+6*sizeof(BYTE))
97
98 int
99 qtAllocLeaves(n) /* allocate space for n leaves */
100 register int n;
101 {
102 unsigned nbytes;
103 register unsigned i;
104
105 qtFreeTree(0); /* make sure tree is empty */
106 if (n <= 0)
107 return(0);
108 if (qtL.nl >= n)
109 return(qtL.nl);
110 else if (qtL.nl > 0)
111 free(qtL.base);
112 /* round space up to nearest power of 2 */
113 nbytes = n*LEAFSIZ + 8;
114 for (i = 1024; nbytes > i; i <<= 1)
115 ;
116 n = (i - 8) / LEAFSIZ; /* should we make sure n is even? */
117 qtL.base = (char *)malloc(n*LEAFSIZ);
118 if (qtL.base == NULL)
119 return(0);
120 /* assign larger alignment types earlier */
121 qtL.wp = (float (*)[3])qtL.base;
122 qtL.brt = (TMbright *)(qtL.wp + n);
123 qtL.chr = (BYTE (*)[3])(qtL.brt + n);
124 qtL.rgb = (BYTE (*)[3])(qtL.chr + n);
125 qtL.nl = n;
126 qtL.tml = qtL.bl = qtL.tl = 0;
127 return(n);
128 }
129
130 #undef LEAFSIZ
131
132
133 qtFreeLeaves() /* free our allocated leaves and twigs */
134 {
135 qtFreeTree(1); /* free tree also */
136 if (qtL.nl <= 0)
137 return;
138 free(qtL.base);
139 qtL.base = NULL;
140 qtL.nl = 0;
141 }
142
143
144 static
145 shaketree(tp) /* shake dead leaves from tree */
146 register RTREE *tp;
147 {
148 register int i, li;
149
150 for (i = 0; i < 4; i++)
151 if (tp->flgs & BRF(i)) {
152 shaketree(tp->k[i].b);
153 if (is_stump(tp->k[i].b))
154 tp->flgs &= ~BRF(i);
155 } else if (tp->flgs & LFF(i)) {
156 li = tp->k[i].li;
157 if (qtL.bl < qtL.tl ?
158 (li < qtL.bl || li >= qtL.tl) :
159 (li < qtL.bl && li >= qtL.tl))
160 tp->flgs &= ~LFF(i);
161 }
162 }
163
164
165 int
166 qtCompost(pct) /* free up some leaves */
167 int pct;
168 {
169 int nused, nclear, nmapped;
170
171 /* figure out how many leaves to clear */
172 nclear = qtL.nl * pct / 100;
173 nused = qtL.tl - qtL.bl;
174 if (nused <= 0) nused += qtL.nl;
175 nclear -= qtL.nl - nused;
176 if (nclear <= 0)
177 return(0);
178 if (nclear >= nused) { /* clear them all */
179 qtFreeTree(0);
180 qtL.tml = qtL.bl = qtL.tl = 0;
181 return(nused);
182 }
183 /* else clear leaves from bottom */
184 nmapped = qtL.tml - qtL.bl;
185 if (nmapped < 0) nmapped += qtL.nl;
186 qtL.bl += nclear;
187 if (qtL.bl >= qtL.nl) qtL.bl -= qtL.nl;
188 if (nmapped <= nclear) qtL.tml = qtL.bl;
189 shaketree(&qtrunk);
190 return(nclear);
191 }
192
193
194 int
195 qtFindLeaf(x, y) /* find closest leaf to (x,y) */
196 int x, y;
197 {
198 register RTREE *tp = &qtrunk;
199 int li = -1;
200 int x0=0, y0=0, x1=odev.hres, y1=odev.vres;
201 int mx, my;
202 register int q;
203 /* check limits */
204 if (x < 0 || x >= odev.hres || y < 0 || y >= odev.vres)
205 return(-1);
206 /* find nearby leaf in our tree */
207 for ( ; ; ) {
208 for (q = 0; q < 4; q++) /* find any leaf this level */
209 if (tp->flgs & LFF(q)) {
210 li = tp->k[q].li;
211 break;
212 }
213 q = 0; /* which quadrant are we? */
214 mx = (x0 + x1) >> 1;
215 my = (y0 + y1) >> 1;
216 if (x < mx) x1 = mx;
217 else {x0 = mx; q |= 01;}
218 if (y < my) y1 = my;
219 else {y0 = my; q |= 02;}
220 if (tp->flgs & BRF(q)) { /* branch down if not a leaf */
221 tp = tp->k[q].b;
222 continue;
223 }
224 if (tp->flgs & LFF(q)) /* good shot! */
225 return(tp->k[q].li);
226 return(li); /* else return what we have */
227 }
228 }
229
230
231 static
232 addleaf(li) /* add a leaf to our tree */
233 int li;
234 {
235 register RTREE *tp = &qtrunk;
236 int x0=0, y0=0, x1=odev.hres, y1=odev.vres;
237 int lo = -1;
238 int x, y, mx, my;
239 double z;
240 FVECT ip, wp;
241 register int q;
242 /* compute leaf location */
243 VCOPY(wp, qtL.wp[li]);
244 viewloc(ip, &odev.v, wp);
245 if (ip[2] <= 0. || ip[0] < 0. || ip[0] >= 1.
246 || ip[1] < 0. || ip[1] >= 1.)
247 return;
248 x = ip[0] * odev.hres;
249 y = ip[1] * odev.vres;
250 z = ip[2];
251 /* find the place for it */
252 for ( ; ; ) {
253 q = 0; /* which quadrant? */
254 mx = (x0 + x1) >> 1;
255 my = (y0 + y1) >> 1;
256 if (x < mx) x1 = mx;
257 else {x0 = mx; q |= 01;}
258 if (y < my) y1 = my;
259 else {y0 = my; q |= 02;}
260 if (tp->flgs & BRF(q)) { /* move to next branch */
261 tp->flgs |= CHF(q); /* not sure; guess */
262 tp = tp->k[q].b;
263 continue;
264 }
265 if (!(tp->flgs & LFF(q))) { /* found stem for leaf */
266 tp->k[q].li = li;
267 tp->flgs |= CHLFF(q);
268 break;
269 }
270 /* check existing leaf */
271 if (lo != tp->k[q].li) {
272 lo = tp->k[q].li;
273 VCOPY(wp, qtL.wp[lo]);
274 viewloc(ip, &odev.v, wp);
275 }
276 /* is node minimum size? */
277 if (x1-x0 <= qtMinNodesiz || y1-y0 <= qtMinNodesiz) {
278 if (z > (1.-qtDepthEps)*ip[2]) /* who is closer? */
279 return; /* old one is */
280 tp->k[q].li = li; /* new one is */
281 tp->flgs |= CHF(q);
282 break;
283 }
284 tp->flgs &= ~LFF(q); /* else grow tree */
285 tp->flgs |= CHBRF(q);
286 tp = tp->k[q].b = newtwig();
287 q = 0; /* old leaf -> new branch */
288 mx = ip[0] * odev.hres;
289 my = ip[1] * odev.vres;
290 if (mx >= (x0 + x1) >> 1) q |= 01;
291 if (my >= (y0 + y1) >> 1) q |= 02;
292 tp->k[q].li = lo;
293 tp->flgs |= LFF(q)|CH_ANY; /* all new */
294 }
295 }
296
297
298 dev_value(c, p) /* add a pixel value to our output queue */
299 COLR c;
300 FVECT p;
301 {
302 register int li;
303
304 li = newleaf();
305 VCOPY(qtL.wp[li], p);
306 tmCvColrs(&qtL.brt[li], qtL.chr[li], c, 1);
307 addleaf(li);
308 }
309
310
311 qtReplant() /* replant our tree using new view */
312 {
313 register int i;
314 /* anything to replant? */
315 if (qtL.bl == qtL.tl)
316 return;
317 qtFreeTree(0); /* blow the old tree away */
318 /* regrow it in new place */
319 for (i = qtL.bl; i != qtL.tl; ) {
320 addleaf(i);
321 if (++i >= qtL.nl) i = 0;
322 }
323 }
324
325
326 qtMapLeaves(redo) /* map our leaves to RGB */
327 int redo;
328 {
329 int aorg, alen, borg, blen;
330 /* recompute mapping? */
331 if (redo)
332 qtL.tml = qtL.bl;
333 /* already done? */
334 if (qtL.tml == qtL.tl)
335 return(1);
336 /* compute segments */
337 aorg = qtL.tml;
338 if (qtL.tl >= aorg) {
339 alen = qtL.tl - aorg;
340 blen = 0;
341 } else {
342 alen = qtL.nl - aorg;
343 borg = 0;
344 blen = qtL.tl;
345 }
346 /* (re)compute tone mapping? */
347 if (qtL.tml == qtL.bl) {
348 tmClearHisto();
349 tmAddHisto(qtL.brt+aorg, alen, 1);
350 if (blen > 0)
351 tmAddHisto(qtL.brt+borg, blen, 1);
352 if (tmComputeMapping(0., 0., 0.) != TM_E_OK)
353 return(0);
354 }
355 if (tmMapPixels(qtL.rgb+aorg, qtL.brt+aorg,
356 qtL.chr+aorg, alen) != TM_E_OK)
357 return(0);
358 if (blen > 0)
359 tmMapPixels(qtL.rgb+borg, qtL.brt+borg,
360 qtL.chr+borg, blen);
361 qtL.tml = qtL.tl;
362 return(1);
363 }
364
365
366 static
367 redraw(ca, tp, x0, y0, x1, y1, l) /* redraw portion of a tree */
368 BYTE ca[3]; /* returned average color */
369 register RTREE *tp;
370 int x0, y0, x1, y1;
371 int l[2][2];
372 {
373 int csm[3], nc;
374 register BYTE *cp;
375 BYTE rgb[3];
376 int quads = CH_ANY;
377 int mx, my;
378 register int i;
379 /* compute midpoint */
380 mx = (x0 + x1) >> 1;
381 my = (y0 + y1) >> 1;
382 /* see what to do */
383 if (l[0][0] >= mx)
384 quads &= ~(CHF(2)|CHF(0));
385 else if (l[0][1] <= mx)
386 quads &= ~(CHF(3)|CHF(1));
387 if (l[1][0] >= my)
388 quads &= ~(CHF(1)|CHF(0));
389 else if (l[1][1] <= my)
390 quads &= ~(CHF(3)|CHF(2));
391 tp->flgs &= ~quads; /* mark them done */
392 csm[0] = csm[1] = csm[2] = nc = 0;
393 /* do leaves first */
394 for (i = 0; i < 4; i++)
395 if (quads & CHF(i) && tp->flgs & LFF(i)) {
396 dev_paintr(cp=qtL.rgb[tp->k[i].li],
397 i&01 ? mx : x0, i&02 ? my : y0,
398 i&01 ? x1 : mx, i&02 ? y1 : my);
399 csm[0] += cp[0]; csm[1] += cp[1]; csm[2] += cp[2];
400 nc++;
401 quads &= ~CHF(i);
402 }
403 /* now do branches */
404 for (i = 0; i < 4; i++)
405 if (quads & CHF(i) && tp->flgs & BRF(i)) {
406 redraw(rgb, tp->k[i].b, i&01 ? mx : x0, i&02 ? my : y0,
407 i&01 ? x1 : mx, i&02 ? y1 : my, l);
408 csm[0] += rgb[0]; csm[1] += rgb[1]; csm[2] += rgb[2];
409 nc++;
410 quads &= ~CHF(i);
411 }
412 if (nc > 1) {
413 ca[0] = csm[0]/nc; ca[1] = csm[1]/nc; ca[2] = csm[2]/nc;
414 } else {
415 ca[0] = csm[0]; ca[1] = csm[1]; ca[2] = csm[2];
416 }
417 if (!quads) return;
418 /* fill in gaps with average */
419 for (i = 0; i < 4; i++)
420 if (quads & CHF(i))
421 dev_paintr(ca, i&01 ? mx : x0, i&02 ? my : y0,
422 i&01 ? x1 : mx, i&02 ? y1 : my);
423 }
424
425
426 static
427 update(ca, tp, x0, y0, x1, y1) /* update tree display as needed */
428 BYTE ca[3]; /* returned average color */
429 register RTREE *tp;
430 int x0, y0, x1, y1;
431 {
432 int csm[3], nc;
433 register BYTE *cp;
434 BYTE rgb[3];
435 int gaps = 0;
436 int mx, my;
437 register int i;
438 /* compute midpoint */
439 mx = (x0 + x1) >> 1;
440 my = (y0 + y1) >> 1;
441 csm[0] = csm[1] = csm[2] = nc = 0;
442 /* do leaves first */
443 for (i = 0; i < 4; i++) {
444 if (!(tp->flgs & CHF(i)))
445 continue;
446 if (tp->flgs & LFF(i)) {
447 dev_paintr(cp=qtL.rgb[tp->k[i].li],
448 i&01 ? mx : x0, i&02 ? my : y0,
449 i&01 ? x1 : mx, i&02 ? y1 : my);
450 csm[0] += cp[0]; csm[1] += cp[1]; csm[2] += cp[2];
451 nc++;
452 } else if (!(tp->flgs & BRF(i)))
453 gaps |= 1<<i; /* empty stem */
454 }
455 /* now do branches */
456 for (i = 0; i < 4; i++)
457 if ((tp->flgs & CHBRF(i)) == CHBRF(i)) {
458 update(rgb, tp->k[i].b, i&01 ? mx : x0, i&02 ? my : y0,
459 i&01 ? x1 : mx, i&02 ? y1 : my);
460 csm[0] += rgb[0]; csm[1] += rgb[1]; csm[2] += rgb[2];
461 nc++;
462 }
463 if (nc > 1) {
464 ca[0] = csm[0]/nc; ca[1] = csm[1]/nc; ca[2] = csm[2]/nc;
465 } else {
466 ca[0] = csm[0]; ca[1] = csm[1]; ca[2] = csm[2];
467 }
468 /* fill in gaps with average */
469 for (i = 0; gaps && i < 4; gaps >>= 1, i++)
470 if (gaps & 01)
471 dev_paintr(ca, i&01 ? mx : x0, i&02 ? my : y0,
472 i&01 ? x1 : mx, i&02 ? y1 : my);
473 tp->flgs &= ~CH_ANY; /* all done */
474 }
475
476
477 qtRedraw(x0, y0, x1, y1) /* redraw part or all of our screen */
478 int x0, y0, x1, y1;
479 {
480 int lim[2][2];
481 BYTE ca[3];
482
483 if (is_stump(&qtrunk))
484 return;
485 if (!qtMapLeaves((lim[0][0]=x0) <= 0 & (lim[1][0]=y0) <= 0 &
486 (lim[0][1]=x1) >= odev.hres-1 & (lim[1][1]=y1) >= odev.vres-1))
487 return;
488 redraw(ca, &qtrunk, 0, 0, odev.hres, odev.vres, lim);
489 }
490
491
492 qtUpdate() /* update our tree display */
493 {
494 BYTE ca[3];
495
496 if (is_stump(&qtrunk))
497 return;
498 if (!qtMapLeaves(0))
499 return;
500 update(ca, &qtrunk, 0, 0, odev.hres, odev.vres);
501 }
