Ansification and prototypes.
Eliminated copystruct() macro, which is unnecessary in ANSI. Reduced ambiguity warnings for nested if/if/else clauses.
Changes and check-in for 3.5 release Includes new source files and modifications not recorded for many years See ray/doc/notes/ReleaseNotes for notes between 3.1 and 3.5 release
changed dev_value() interface so NULL is passed for infinite points
hack so dev_value() doesn't drop leaves in immediate mode
allow unused leaves to fall into free list for greater efficiency
consolidated newleaf() with dev_value()
changed logic so rays just off view are still saved
change to better, faster angle-difference computation
added code for determining closest ray direction in addleaf()
improved tree update in update()
changed redraw function to simply mark branches and leaves for update
moved LFREEPCT to rhd_qtree.c and changed from 15% to 25% fixed bug in trunk flag settings in qtFreeTree() fixed bug in tone remapping routine
changed definition of global leaf pile to make tone mapping work better
fixed bug in newleaf()
added qtFindLeaf() and made qtFreeTree() global (dunno why yet)
changed routine name and made it so shaketree() doesn't affect flags
