root/radiance/ray/src/hd/rhd_qtree.c
Fri Jan 7 20:33:02 2005 UTC (20 years, 4 months ago) by greg
Changes since 3.25: +9 -9 lines
Diff to previous 3.25 , to selected 3.23
Thu Jan 1 11:21:55 2004 UTC (21 years, 4 months ago) by schorsch
Changes since 3.24: +48 -27 lines
Diff to previous 3.24 , to selected 3.23
Ansification and prototypes.
Mon Jul 21 22:30:18 2003 UTC (21 years, 9 months ago) by schorsch
Changes since 3.23: +3 -2 lines
Diff to previous 3.23
Revision 3.23 - (view) (download) (annotate) - [selected]
Mon Jun 30 14:59:11 2003 UTC (21 years, 10 months ago) by schorsch
Changes since 3.22: +4 -2 lines
Diff to previous 3.22
Changes since 3.21: +5 -5 lines
Diff to previous 3.21 , to selected 3.23
Wed Apr 23 00:52:33 2003 UTC (22 years ago) by greg
Changes since 3.20: +1 -1 lines
Diff to previous 3.20 , to selected 3.23
Tue Mar 4 05:49:21 2003 UTC (22 years, 2 months ago) by greg
Changes since 3.19: +7 -6 lines
Diff to previous 3.19 , to selected 3.23
Sat Feb 22 02:07:24 2003 UTC (22 years, 2 months ago) by greg
Changes since 3.18: +3 -6 lines
Diff to previous 3.18 , to selected 3.23
Mon Aug 10 18:39:46 1998 UTC (26 years, 9 months ago) by gwlarson
Changes since 3.17: +8 -5 lines
Diff to previous 3.17 , to selected 3.23
changed dev_value() interface so NULL is passed for infinite points
Thu Jan 1 13:00:15 1998 UTC (27 years, 4 months ago) by gregl
Changes since 3.16: +8 -2 lines
Diff to previous 3.16 , to selected 3.23
Wed Dec 31 09:06:54 1997 UTC (27 years, 4 months ago) by gregl
Changes since 3.15: +13 -10 lines
Diff to previous 3.15 , to selected 3.23
hack so dev_value() doesn't drop leaves in immediate mode
Tue Dec 30 17:08:37 1997 UTC (27 years, 4 months ago) by gregl
Changes since 3.14: +56 -25 lines
Diff to previous 3.14 , to selected 3.23
allow unused leaves to fall into free list for greater efficiency
Mon Dec 29 17:31:45 1997 UTC (27 years, 4 months ago) by gregl
Changes since 3.13: +6 -18 lines
Diff to previous 3.13 , to selected 3.23
consolidated newleaf() with dev_value()
Wed Dec 24 10:50:49 1997 UTC (27 years, 4 months ago) by gregl
Changes since 3.12: +0 -90 lines
Diff to previous 3.12 , to selected 3.23
Fri Dec 5 16:22:49 1997 UTC (27 years, 5 months ago) by gregl
Changes since 3.11: +15 -12 lines
Diff to previous 3.11 , to selected 3.23
changed logic so rays just off view are still saved
Fri Dec 5 15:40:54 1997 UTC (27 years, 5 months ago) by gregl
Changes since 3.10: +82 -54 lines
Diff to previous 3.10 , to selected 3.23
change to better, faster angle-difference computation
Fri Dec 5 09:40:05 1997 UTC (27 years, 5 months ago) by gregl
Changes since 3.9: +103 -14 lines
Diff to previous 3.9 , to selected 3.23
added code for determining closest ray direction in addleaf()
Tue Nov 25 16:52:04 1997 UTC (27 years, 5 months ago) by gregl
Changes since 3.8: +1 -109 lines
Diff to previous 3.8 , to selected 3.23
Tue Nov 25 14:24:39 1997 UTC (27 years, 5 months ago) by gregl
Changes since 3.7: +5 -6 lines
Diff to previous 3.7 , to selected 3.23
improved tree update in update()
Tue Nov 25 11:15:20 1997 UTC (27 years, 5 months ago) by gregl
Changes since 3.6: +12 -42 lines
Diff to previous 3.6 , to selected 3.23
changed redraw function to simply mark branches and leaves for update
Mon Nov 24 15:16:10 1997 UTC (27 years, 5 months ago) by gregl
Changes since 3.5: +8 -3 lines
Diff to previous 3.5 , to selected 3.23
moved LFREEPCT to rhd_qtree.c and changed from 15% to 25%
fixed bug in trunk flag settings in qtFreeTree()
fixed bug in tone remapping routine
Fri Nov 21 13:35:57 1997 UTC (27 years, 5 months ago) by gregl
Changes since 3.4: +152 -111 lines
Diff to previous 3.4 , to selected 3.23
changed definition of global leaf pile to make tone mapping work better
Fri Nov 21 09:52:06 1997 UTC (27 years, 5 months ago) by gregl
Changes since 3.3: +18 -10 lines
Diff to previous 3.3 , to selected 3.23
fixed bug in newleaf()
Thu Nov 20 18:03:43 1997 UTC (27 years, 5 months ago) by gregl
Changes since 3.2: +42 -6 lines
Diff to previous 3.2 , to selected 3.23
added qtFindLeaf() and made qtFreeTree() global (dunno why yet)
Thu Nov 20 11:38:26 1997 UTC (27 years, 5 months ago) by gregl
Changes since 3.1: +12 -15 lines
Diff to previous 3.1 , to selected 3.23
changed routine name and made it so shaketree() doesn't affect flags
Wed Nov 19 18:01:03 1997 UTC (27 years, 5 months ago) by gregl
Diff to selected 3.23
