root/radiance/ray/src/hd/rhd_qtree.c
Revision: 3.5
Committed: Fri Nov 21 13:35:57 1997 UTC (26 years, 7 months ago) by gregl
Changes since 3.4: +152 -111 lines
changed definition of global leaf pile to make tone mapping work better
1 /* Copyright (c) 1997 Silicon Graphics, Inc. */
2
3 #ifndef lint
4 static char SCCSid[] = "$SunId$ SGI";
5 #endif
6
7 /*
8 * Quadtree driver support routines.
9 */
10
11 #include "standard.h"
12 #include "rhd_qtree.h"
13
14 RTREE qtrunk; /* our quadtree trunk */
15 double qtDepthEps = .02; /* epsilon to compare depths (z fraction) */
16 int qtMinNodesiz = 2; /* minimum node dimension (pixels) */
17 struct rleaves qtL; /* our pile of leaves */
18
19 #define TBUNDLESIZ 409 /* number of twigs in a bundle */
20
21 static RTREE **twigbundle; /* free twig blocks (NULL term.) */
22 static int nexttwig; /* next free twig */
23
24 #define is_stump(t) (!((t)->flgs & (BR_ANY|LF_ANY)))
25
26
27 static RTREE *
28 newtwig() /* allocate a twig */
29 {
30 register int bi;
31
32 if (twigbundle == NULL) { /* initialize */
33 twigbundle = (RTREE **)malloc(sizeof(RTREE *));
34 if (twigbundle == NULL)
35 goto memerr;
36 twigbundle[0] = NULL;
37 }
38 bi = nexttwig / TBUNDLESIZ;
39 if (twigbundle[bi] == NULL) { /* new block */
40 twigbundle = (RTREE **)realloc((char *)twigbundle,
41 (bi+2)*sizeof(RTREE *));
42 if (twigbundle == NULL)
43 goto memerr;
44 twigbundle[bi] = (RTREE *)calloc(TBUNDLESIZ, sizeof(RTREE));
45 if (twigbundle[bi] == NULL)
46 goto memerr;
47 twigbundle[bi+1] = NULL;
48 }
49 /* nexttwig++ % TBUNDLESIZ */
50 return(twigbundle[bi] + (nexttwig++ - bi*TBUNDLESIZ));
51 memerr:
52 error(SYSTEM, "out of memory in newtwig");
53 }
54
55
56 qtFreeTree(really) /* free allocated twigs */
57 int really;
58 {
59 register int i;
60
61 qtrunk.flgs = 0;
62 nexttwig = 0;
63 if (twigbundle == NULL)
64 return;
65 if (!really) { /* just clear allocated blocks */
66 for (i = 0; twigbundle[i] != NULL; i++)
67 bzero((char *)twigbundle[i], TBUNDLESIZ*sizeof(RTREE));
68 return;
69 }
70 /* else "really" means free up memory */
71 for (i = 0; twigbundle[i] != NULL; i++)
72 free((char *)twigbundle[i]);
73 free((char *)twigbundle);
74 twigbundle = NULL;
75 }
76
77
78 static int
79 newleaf() /* allocate a leaf from our pile */
80 {
81 int li;
82
83 li = qtL.tl++;
84 if (qtL.tl >= qtL.nl) /* get next leaf in ring */
85 qtL.tl = 0;
86 if (qtL.tl == qtL.bl) /* need to shake some free */
87 qtCompost(LFREEPCT);
88 return(li);
89 }
90
91
92 #define LEAFSIZ (3*sizeof(float)+sizeof(TMbright)+6*sizeof(BYTE))
93
94 int
95 qtAllocLeaves(n) /* allocate space for n leaves */
96 register int n;
97 {
98 unsigned nbytes;
99 register unsigned i;
100
101 qtFreeTree(0); /* make sure tree is empty */
102 if (n <= 0)
103 return(0);
104 if (qtL.nl >= n)
105 return(qtL.nl);
106 else if (qtL.nl > 0)
107 free(qtL.base);
108 /* round space up to nearest power of 2 */
109 nbytes = n*LEAFSIZ + 8;
110 for (i = 1024; nbytes > i; i <<= 1)
111 ;
112 n = (i - 8) / LEAFSIZ; /* should we make sure n is even? */
113 qtL.base = (char *)malloc(n*LEAFSIZ);
114 if (qtL.base == NULL)
115 return(0);
116 /* assign larger alignment types earlier */
117 qtL.wp = (float (*)[3])qtL.base;
118 qtL.brt = (TMbright *)(qtL.wp + n);
119 qtL.chr = (BYTE (*)[3])(qtL.brt + n);
120 qtL.rgb = (BYTE (*)[3])(qtL.chr + n);
121 qtL.nl = n;
122 qtL.tml = qtL.bl = qtL.tl = 0;
123 return(n);
124 }
125
126 #undef LEAFSIZ
127
128
129 qtFreeLeaves() /* free our allocated leaves and twigs */
130 {
131 qtFreeTree(1); /* free tree also */
132 if (qtL.nl <= 0)
133 return;
134 free(qtL.base);
135 qtL.base = NULL;
136 qtL.nl = 0;
137 }
138
139
140 static
141 shaketree(tp) /* shake dead leaves from tree */
142 register RTREE *tp;
143 {
144 register int i, li;
145
146 for (i = 0; i < 4; i++)
147 if (tp->flgs & BRF(i)) {
148 shaketree(tp->k[i].b);
149 if (is_stump(tp->k[i].b))
150 tp->flgs &= ~BRF(i);
151 } else if (tp->flgs & LFF(i)) {
152 li = tp->k[i].li;
153 if (qtL.bl < qtL.tl ?
154 (li < qtL.bl || li >= qtL.tl) :
155 (li < qtL.bl && li >= qtL.tl))
156 tp->flgs &= ~LFF(i);
157 }
158 }
159
160
161 int
162 qtCompost(pct) /* free up some leaves */
163 int pct;
164 {
165 int nused, nclear, nmapped;
166
167 /* figure out how many leaves to clear */
168 nclear = qtL.nl * pct / 100;
169 nused = qtL.tl - qtL.bl;
170 if (nused <= 0) nused += qtL.nl;
171 nclear -= qtL.nl - nused;
172 if (nclear <= 0)
173 return(0);
174 if (nclear >= nused) { /* clear them all */
175 qtFreeTree(0);
176 qtL.tml = qtL.bl = qtL.tl = 0;
177 return(nused);
178 }
179 /* else clear leaves from bottom */
180 nmapped = qtL.tml - qtL.bl;
181 if (nmapped < 0) nmapped += qtL.nl;
182 qtL.bl += nclear;
183 if (qtL.bl >= qtL.nl) qtL.bl -= qtL.nl;
184 if (nmapped <= nclear) qtL.tml = qtL.bl;
185 shaketree(&qtrunk);
186 return(nclear);
187 }
188
189
190 int
191 qtFindLeaf(x, y) /* find closest leaf to (x,y) */
192 int x, y;
193 {
194 register RTREE *tp = &qtrunk;
195 int li = -1;
196 int x0=0, y0=0, x1=odev.hres, y1=odev.vres;
197 int mx, my;
198 register int q;
199 /* check limits */
200 if (x < 0 || x >= odev.hres || y < 0 || y >= odev.vres)
201 return(-1);
202 /* find nearby leaf in our tree */
203 for ( ; ; ) {
204 for (q = 0; q < 4; q++) /* find any leaf this level */
205 if (tp->flgs & LFF(q)) {
206 li = tp->k[q].li;
207 break;
208 }
209 q = 0; /* which quadrant are we? */
210 mx = (x0 + x1) >> 1;
211 my = (y0 + y1) >> 1;
212 if (x < mx) x1 = mx;
213 else {x0 = mx; q |= 01;}
214 if (y < my) y1 = my;
215 else {y0 = my; q |= 02;}
216 if (tp->flgs & BRF(q)) { /* branch down if not a leaf */
217 tp = tp->k[q].b;
218 continue;
219 }
220 if (tp->flgs & LFF(q)) /* good shot! */
221 return(tp->k[q].li);
222 return(li); /* else return what we have */
223 }
224 }
225
226
227 static
228 addleaf(li) /* add a leaf to our tree */
229 int li;
230 {
231 register RTREE *tp = &qtrunk;
232 int x0=0, y0=0, x1=odev.hres, y1=odev.vres;
233 int lo = -1;
234 int x, y, mx, my;
235 double z;
236 FVECT ip, wp;
237 register int q;
238 /* compute leaf location */
239 VCOPY(wp, qtL.wp[li]);
240 viewloc(ip, &odev.v, wp);
241 if (ip[2] <= 0. || ip[0] < 0. || ip[0] >= 1.
242 || ip[1] < 0. || ip[1] >= 1.)
243 return;
244 x = ip[0] * odev.hres;
245 y = ip[1] * odev.vres;
246 z = ip[2];
247 /* find the place for it */
248 for ( ; ; ) {
249 q = 0; /* which quadrant? */
250 mx = (x0 + x1) >> 1;
251 my = (y0 + y1) >> 1;
252 if (x < mx) x1 = mx;
253 else {x0 = mx; q |= 01;}
254 if (y < my) y1 = my;
255 else {y0 = my; q |= 02;}
256 if (tp->flgs & BRF(q)) { /* move to next branch */
257 tp->flgs |= CHF(q); /* not sure; guess */
258 tp = tp->k[q].b;
259 continue;
260 }
261 if (!(tp->flgs & LFF(q))) { /* found stem for leaf */
262 tp->k[q].li = li;
263 tp->flgs |= CHLFF(q);
264 break;
265 }
266 /* check existing leaf */
267 if (lo != tp->k[q].li) {
268 lo = tp->k[q].li;
269 VCOPY(wp, qtL.wp[lo]);
270 viewloc(ip, &odev.v, wp);
271 }
272 /* is node minimum size? */
273 if (x1-x0 <= qtMinNodesiz || y1-y0 <= qtMinNodesiz) {
274 if (z > (1.-qtDepthEps)*ip[2]) /* who is closer? */
275 return; /* old one is */
276 tp->k[q].li = li; /* new one is */
277 tp->flgs |= CHF(q);
278 break;
279 }
280 tp->flgs &= ~LFF(q); /* else grow tree */
281 tp->flgs |= CHBRF(q);
282 tp = tp->k[q].b = newtwig();
283 q = 0; /* old leaf -> new branch */
284 mx = ip[0] * odev.hres;
285 my = ip[1] * odev.vres;
286 if (mx >= (x0 + x1) >> 1) q |= 01;
287 if (my >= (y0 + y1) >> 1) q |= 02;
288 tp->k[q].li = lo;
289 tp->flgs |= LFF(q)|CH_ANY; /* all new */
290 }
291 }
292
293
294 dev_value(c, p) /* add a pixel value to our output queue */
295 COLR c;
296 FVECT p;
297 {
298 register int li;
299
300 li = newleaf();
301 VCOPY(qtL.wp[li], p);
302 tmCvColrs(&qtL.brt[li], qtL.chr[li], c, 1);
303 addleaf(li);
304 }
305
306
307 qtReplant() /* replant our tree using new view */
308 {
309 register int i;
310 /* anything to replant? */
311 if (qtL.bl == qtL.tl)
312 return;
313 qtFreeTree(0); /* blow the old tree away */
314 /* regrow it in new place */
315 for (i = qtL.bl; i != qtL.tl; ) {
316 addleaf(i);
317 if (++i >= qtL.nl) i = 0;
318 }
319 }
320
321
322 qtMapLeaves(redo) /* map our leaves to RGB */
323 int redo;
324 {
325 int aorg, alen, borg, blen;
326 /* already done? */
327 if (qtL.tml == qtL.tl)
328 return(1);
329 if (redo)
330 qtL.tml = qtL.bl;
331 /* compute segments */
332 aorg = qtL.tml;
333 if (qtL.tl >= aorg) {
334 alen = qtL.tl - aorg;
335 blen = 0;
336 } else {
337 alen = qtL.nl - aorg;
338 borg = 0;
339 blen = qtL.tl;
340 }
341 /* (re)compute tone mapping? */
342 if (qtL.tml == qtL.bl) {
343 tmClearHisto();
344 tmAddHisto(qtL.brt+aorg, alen, 1);
345 if (blen > 0)
346 tmAddHisto(qtL.brt+borg, blen, 1);
347 if (tmComputeMapping(0., 0., 0.) != TM_E_OK)
348 return(0);
349 }
350 if (tmMapPixels(qtL.rgb+aorg, qtL.brt+aorg,
351 qtL.chr+aorg, alen) != TM_E_OK)
352 return(0);
353 if (blen > 0)
354 tmMapPixels(qtL.rgb+borg, qtL.brt+borg,
355 qtL.chr+borg, blen);
356 qtL.tml = qtL.tl;
357 return(1);
358 }
359
360
361 static
362 redraw(ca, tp, x0, y0, x1, y1, l) /* redraw portion of a tree */
363 BYTE ca[3]; /* returned average color */
364 register RTREE *tp;
365 int x0, y0, x1, y1;
366 int l[2][2];
367 {
368 int csm[3], nc;
369 register BYTE *cp;
370 BYTE rgb[3];
371 int quads = CH_ANY;
372 int mx, my;
373 register int i;
374 /* compute midpoint */
375 mx = (x0 + x1) >> 1;
376 my = (y0 + y1) >> 1;
377 /* see what to do */
378 if (l[0][0] >= mx)
379 quads &= ~(CHF(2)|CHF(0));
380 else if (l[0][1] <= mx)
381 quads &= ~(CHF(3)|CHF(1));
382 if (l[1][0] >= my)
383 quads &= ~(CHF(1)|CHF(0));
384 else if (l[1][1] <= my)
385 quads &= ~(CHF(3)|CHF(2));
386 tp->flgs &= ~quads; /* mark them done */
387 csm[0] = csm[1] = csm[2] = nc = 0;
388 /* do leaves first */
389 for (i = 0; i < 4; i++)
390 if (quads & CHF(i) && tp->flgs & LFF(i)) {
391 dev_paintr(cp=qtL.rgb[tp->k[i].li],
392 i&01 ? mx : x0, i&02 ? my : y0,
393 i&01 ? x1 : mx, i&02 ? y1 : my);
394 csm[0] += cp[0]; csm[1] += cp[1]; csm[2] += cp[2];
395 nc++;
396 quads &= ~CHF(i);
397 }
398 /* now do branches */
399 for (i = 0; i < 4; i++)
400 if (quads & CHF(i) && tp->flgs & BRF(i)) {
401 redraw(rgb, tp->k[i].b, i&01 ? mx : x0, i&02 ? my : y0,
402 i&01 ? x1 : mx, i&02 ? y1 : my, l);
403 csm[0] += rgb[0]; csm[1] += rgb[1]; csm[2] += rgb[2];
404 nc++;
405 quads &= ~CHF(i);
406 }
407 if (nc > 1) {
408 ca[0] = csm[0]/nc; ca[1] = csm[1]/nc; ca[2] = csm[2]/nc;
409 } else {
410 ca[0] = csm[0]; ca[1] = csm[1]; ca[2] = csm[2];
411 }
412 if (!quads) return;
413 /* fill in gaps with average */
414 for (i = 0; i < 4; i++)
415 if (quads & CHF(i))
416 dev_paintr(ca, i&01 ? mx : x0, i&02 ? my : y0,
417 i&01 ? x1 : mx, i&02 ? y1 : my);
418 }
419
420
421 static
422 update(ca, tp, x0, y0, x1, y1) /* update tree display as needed */
423 BYTE ca[3]; /* returned average color */
424 register RTREE *tp;
425 int x0, y0, x1, y1;
426 {
427 int csm[3], nc;
428 register BYTE *cp;
429 BYTE rgb[3];
430 int gaps = 0;
431 int mx, my;
432 register int i;
433 /* compute midpoint */
434 mx = (x0 + x1) >> 1;
435 my = (y0 + y1) >> 1;
436 csm[0] = csm[1] = csm[2] = nc = 0;
437 /* do leaves first */
438 for (i = 0; i < 4; i++) {
439 if (!(tp->flgs & CHF(i)))
440 continue;
441 if (tp->flgs & LFF(i)) {
442 dev_paintr(cp=qtL.rgb[tp->k[i].li],
443 i&01 ? mx : x0, i&02 ? my : y0,
444 i&01 ? x1 : mx, i&02 ? y1 : my);
445 csm[0] += cp[0]; csm[1] += cp[1]; csm[2] += cp[2];
446 nc++;
447 } else if (!(tp->flgs & BRF(i)))
448 gaps |= 1<<i; /* empty stem */
449 }
450 /* now do branches */
451 for (i = 0; i < 4; i++)
452 if ((tp->flgs & CHBRF(i)) == CHBRF(i)) {
453 update(rgb, tp->k[i].b, i&01 ? mx : x0, i&02 ? my : y0,
454 i&01 ? x1 : mx, i&02 ? y1 : my);
455 csm[0] += rgb[0]; csm[1] += rgb[1]; csm[2] += rgb[2];
456 nc++;
457 }
458 if (nc > 1) {
459 ca[0] = csm[0]/nc; ca[1] = csm[1]/nc; ca[2] = csm[2]/nc;
460 } else {
461 ca[0] = csm[0]; ca[1] = csm[1]; ca[2] = csm[2];
462 }
463 /* fill in gaps with average */
464 for (i = 0; gaps && i < 4; gaps >>= 1, i++)
465 if (gaps & 01)
466 dev_paintr(ca, i&01 ? mx : x0, i&02 ? my : y0,
467 i&01 ? x1 : mx, i&02 ? y1 : my);
468 tp->flgs &= ~CH_ANY; /* all done */
469 }
470
471
472 qtRedraw(x0, y0, x1, y1) /* redraw part or all of our screen */
473 int x0, y0, x1, y1;
474 {
475 int lim[2][2];
476 BYTE ca[3];
477
478 if (is_stump(&qtrunk))
479 return;
480 if (!qtMapLeaves((lim[0][0]=x0) <= 0 & (lim[1][0]=y0) <= 0 &
481 (lim[0][1]=x1) >= odev.hres-1 & (lim[1][1]=y1) >= odev.vres-1))
482 return;
483 redraw(ca, &qtrunk, 0, 0, odev.hres, odev.vres, lim);
484 }
485
486
487 qtUpdate() /* update our tree display */
488 {
489 BYTE ca[3];
490
491 if (is_stump(&qtrunk))
492 return;
493 if (!qtMapLeaves(0))
494 return;
495 update(ca, &qtrunk, 0, 0, odev.hres, odev.vres);
496 }
