--- ray/src/hd/rhd_qtree.c 2003/04/23 00:52:33 3.21 +++ ray/src/hd/rhd_qtree.c 2018/10/05 19:19:16 3.29 @@ -1,10 +1,12 @@ #ifndef lint -static const char RCSid[] = "$Id: rhd_qtree.c,v 3.21 2003/04/23 00:52:33 greg Exp $"; +static const char RCSid[] = "$Id: rhd_qtree.c,v 3.29 2018/10/05 19:19:16 greg Exp $"; #endif /* * Quadtree driver support routines. */ +#include + #include "standard.h" #include "rhd_qtree.h" /* quantity of leaves to free at a time */ @@ -28,7 +30,7 @@ struct rleaves qtL; /* our pile of leaves */ int rayqleft = 0; /* rays left to queue before flush */ -static int4 falleaves; /* our list of fallen leaves */ +static int32 falleaves; /* our list of fallen leaves */ #define composted(li) (qtL.bl <= qtL.tl ? \ ((li) < qtL.bl || (li) >= qtL.tl) : \ @@ -39,11 +41,16 @@ static int4 falleaves; /* our list of fallen leaves */ static RTREE **twigbundle; /* free twig blocks (NULL term.) */ static int nexttwig; /* next free twig */ +static RTREE *newtwig(void); +static void qtFreeTree(int really); +static void shaketree(RTREE *tp); +static int putleaf(int li, int drop); + static RTREE * -newtwig() /* allocate a twig */ +newtwig(void) /* allocate a twig */ { - register int bi; + int bi; if (twigbundle == NULL) { /* initialize */ twigbundle = (RTREE **)malloc(sizeof(RTREE *)); @@ -66,13 +73,16 @@ newtwig() /* allocate a twig */ return(twigbundle[bi] + (nexttwig++ - bi*TBUNDLESIZ)); memerr: error(SYSTEM, "out of memory in newtwig"); + return NULL; /* pro forma return */ } -qtFreeTree(really) /* free allocated twigs */ -int really; +static void +qtFreeTree( /* free allocated twigs */ + int really +) { - register int i; + int i; qtrunk.flgs = CH_ANY; /* chop down tree */ if (twigbundle == NULL) @@ -81,7 +91,7 @@ int really; nexttwig = 0; if (!really) { /* just clear allocated blocks */ while (i--) - bzero((char *)twigbundle[i], TBUNDLESIZ*sizeof(RTREE)); + memset((char *)twigbundle[i], '\0', TBUNDLESIZ*sizeof(RTREE)); return; } /* else "really" means free up memory */ @@ -92,15 +102,16 @@ int really; } -#define LEAFSIZ (3*sizeof(float)+sizeof(int4)+\ - sizeof(TMbright)+6*sizeof(BYTE)) +#define LEAFSIZ (3*sizeof(float)+sizeof(int32)+\ + sizeof(TMbright)+6*sizeof(uby8)) int -qtAllocLeaves(n) /* allocate space for n leaves */ -register int n; +qtAllocLeaves( /* allocate space for n leaves */ + int n +) { unsigned nbytes; - register unsigned i; + unsigned i; qtFreeTree(0); /* make sure tree is empty */ if (n <= 0) @@ -119,10 +130,10 @@ register int n; return(0); /* assign larger alignment types earlier */ qtL.wp = (float (*)[3])qtL.base; - qtL.wd = (int4 *)(qtL.wp + n); + qtL.wd = (int32 *)(qtL.wp + n); qtL.brt = (TMbright *)(qtL.wd + n); - qtL.chr = (BYTE (*)[3])(qtL.brt + n); - qtL.rgb = (BYTE (*)[3])(qtL.chr + n); + qtL.chr = (uby8 (*)[3])(qtL.brt + n); + qtL.rgb = (uby8 (*)[3])(qtL.chr + n); qtL.nl = n; qtL.tml = qtL.bl = qtL.tl = 0; falleaves = -1; @@ -132,7 +143,8 @@ register int n; #undef LEAFSIZ -qtFreeLeaves() /* free our allocated leaves and twigs */ +void +qtFreeLeaves(void) /* free our allocated leaves and twigs */ { qtFreeTree(1); /* free tree also */ if (qtL.nl <= 0) @@ -143,11 +155,12 @@ qtFreeLeaves() /* free our allocated leaves and twig } -static -shaketree(tp) /* shake dead leaves from tree */ -register RTREE *tp; +static void +shaketree( /* shake dead leaves from tree */ + RTREE *tp +) { - register int i, li; + int i, li; for (i = 0; i < 4; i++) if (tp->flgs & BRF(i)) { @@ -163,10 +176,11 @@ register RTREE *tp; int -qtCompost(pct) /* free up some leaves */ -int pct; +qtCompost( /* free up some leaves */ + int pct +) { - register int4 *fl; + int32 *fl; int nused, nclear, nmapped; /* figure out how many leaves to clear */ nclear = qtL.nl * pct / 100; @@ -197,14 +211,16 @@ int pct; int -qtFindLeaf(x, y) /* find closest leaf to (x,y) */ -int x, y; +qtFindLeaf( /* find closest leaf to (x,y) */ + int x, + int y +) { - register RTREE *tp = &qtrunk; + RTREE *tp = &qtrunk; int li = -1; int x0=0, y0=0, x1=odev.hres, y1=odev.vres; int mx, my; - register int q; + int q; /* check limits */ if (x < 0 || x >= odev.hres || y < 0 || y >= odev.vres) return(-1); @@ -233,27 +249,26 @@ int x, y; } -static -putleaf(li, drop) /* put a leaf in our tree */ -register int li; -int drop; +static int +putleaf( /* put a leaf in our tree */ + int li, + int drop +) { - register RTREE *tp = &qtrunk; + RTREE *tp = &qtrunk; int x0=0, y0=0, x1=odev.hres, y1=odev.vres; - register int lo = -1; + int lo = -1; double d2; int x, y, mx, my; double z; FVECT ip, wp, vd; - register int q; + int q; /* check for dead leaf */ if (!qtL.chr[li][1] && !(qtL.chr[li][0] | qtL.chr[li][2])) return(0); /* compute leaf location in view */ VCOPY(wp, qtL.wp[li]); - viewloc(ip, &odev.v, wp); - if (ip[2] <= 0. || ip[0] < 0. || ip[0] >= 1. - || ip[1] < 0. || ip[1] >= 1.) + if (viewloc(ip, &odev.v, wp) != 1) goto dropit; /* behind or outside view */ #ifdef DEBUG if (odev.v.type == VT_PAR | odev.v.vfore > FTINY) @@ -317,7 +332,7 @@ int drop; tp->k[q].li = lo; } dropit: - if (drop) + if (drop) { if (li+1 == (qtL.tl ? qtL.tl : qtL.nl)) qtL.tl = li; /* special case */ else { @@ -325,15 +340,19 @@ dropit: qtL.wd[li] = falleaves; falleaves = li; } + } return(li == lo); } -dev_value(c, d, p) /* add a pixel value to our quadtree */ -COLR c; -FVECT d, p; +void +dev_value( /* add a pixel value to our quadtree */ + COLR c, + FVECT d, + FVECT p +) { - register int li; + int li; int mapit; /* grab a leaf */ if (!imm_mode && falleaves >= 0) { /* check for fallen leaves */ @@ -355,20 +374,21 @@ FVECT d, p; else VCOPY(qtL.wp[li], p); qtL.wd[li] = encodedir(d); - tmCvColrs(&qtL.brt[li], qtL.chr[li], (COLR *)c, 1); + tmCvColrs(tmGlobal, &qtL.brt[li], qtL.chr[li], (COLR *)c, 1); if (putleaf(li, 1)) { if (mapit) - tmMapPixels((BYTE *)(qtL.rgb+li), qtL.brt+li, - (BYTE *)(qtL.chr+li), 1); + tmMapPixels(tmGlobal, (uby8 *)(qtL.rgb+li), qtL.brt+li, + (uby8 *)(qtL.chr+li), 1); if (--rayqleft == 0) dev_flush(); /* flush output */ } } -qtReplant() /* replant our tree using new view */ +void +qtReplant(void) /* replant our tree using new view */ { - register int i; + int i; /* anything to replant? */ if (qtL.bl == qtL.tl) return; @@ -381,8 +401,10 @@ qtReplant() /* replant our tree using new view */ } -qtMapLeaves(redo) /* map our leaves to RGB */ -int redo; +int +qtMapLeaves( /* map our leaves to RGB */ + int redo +) { int aorg, alen, borg, blen; /* recompute mapping? */ @@ -403,19 +425,19 @@ int redo; } /* (re)compute tone mapping? */ if (qtL.tml == qtL.bl) { - tmClearHisto(); - tmAddHisto(qtL.brt+aorg, alen, 1); + tmClearHisto(tmGlobal); + tmAddHisto(tmGlobal, qtL.brt+aorg, alen, 1); if (blen > 0) - tmAddHisto(qtL.brt+borg, blen, 1); - if (tmComputeMapping(0., 0., 0.) != TM_E_OK) + tmAddHisto(tmGlobal, qtL.brt+borg, blen, 1); + if (tmComputeMapping(tmGlobal, 0., 0., 0.) != TM_E_OK) return(0); } - if (tmMapPixels((BYTE *)(qtL.rgb+aorg), qtL.brt+aorg, - (BYTE *)(qtL.chr+aorg), alen) != TM_E_OK) + if (tmMapPixels(tmGlobal, (uby8 *)(qtL.rgb+aorg), qtL.brt+aorg, + (uby8 *)(qtL.chr+aorg), alen) != TM_E_OK) return(0); if (blen > 0) - tmMapPixels((BYTE *)(qtL.rgb+borg), qtL.brt+borg, - (BYTE *)(qtL.chr+borg), blen); + tmMapPixels(tmGlobal, (uby8 *)(qtL.rgb+borg), qtL.brt+borg, + (uby8 *)(qtL.chr+borg), blen); qtL.tml = qtL.tl; return(1); }
