--- ray/src/hd/rhd_qtree.c 2018/01/24 04:39:52 3.28 +++ ray/src/hd/rhd_qtree.c 2018/10/05 19:19:16 3.29 @@ -1,5 +1,5 @@ #ifndef lint -static const char RCSid[] = "$Id: rhd_qtree.c,v 3.28 2018/01/24 04:39:52 greg Exp $"; +static const char RCSid[] = "$Id: rhd_qtree.c,v 3.29 2018/10/05 19:19:16 greg Exp $"; #endif /* * Quadtree driver support routines. @@ -50,7 +50,7 @@ static int putleaf(int li, int drop); static RTREE * newtwig(void) /* allocate a twig */ { - register int bi; + int bi; if (twigbundle == NULL) { /* initialize */ twigbundle = (RTREE **)malloc(sizeof(RTREE *)); @@ -82,7 +82,7 @@ qtFreeTree( /* free allocated twigs */ int really ) { - register int i; + int i; qtrunk.flgs = CH_ANY; /* chop down tree */ if (twigbundle == NULL) @@ -105,13 +105,13 @@ qtFreeTree( /* free allocated twigs */ #define LEAFSIZ (3*sizeof(float)+sizeof(int32)+\ sizeof(TMbright)+6*sizeof(uby8)) -extern int +int qtAllocLeaves( /* allocate space for n leaves */ - register int n + int n ) { unsigned nbytes; - register unsigned i; + unsigned i; qtFreeTree(0); /* make sure tree is empty */ if (n <= 0) @@ -143,7 +143,7 @@ qtAllocLeaves( /* allocate space for n leaves */ #undef LEAFSIZ -extern void +void qtFreeLeaves(void) /* free our allocated leaves and twigs */ { qtFreeTree(1); /* free tree also */ @@ -157,10 +157,10 @@ qtFreeLeaves(void) /* free our allocated leaves and static void shaketree( /* shake dead leaves from tree */ - register RTREE *tp + RTREE *tp ) { - register int i, li; + int i, li; for (i = 0; i < 4; i++) if (tp->flgs & BRF(i)) { @@ -175,12 +175,12 @@ shaketree( /* shake dead leaves from tree */ } -extern int +int qtCompost( /* free up some leaves */ int pct ) { - register int32 *fl; + int32 *fl; int nused, nclear, nmapped; /* figure out how many leaves to clear */ nclear = qtL.nl * pct / 100; @@ -210,17 +210,17 @@ qtCompost( /* free up some leaves */ } -extern int +int qtFindLeaf( /* find closest leaf to (x,y) */ int x, int y ) { - register RTREE *tp = &qtrunk; + RTREE *tp = &qtrunk; int li = -1; int x0=0, y0=0, x1=odev.hres, y1=odev.vres; int mx, my; - register int q; + int q; /* check limits */ if (x < 0 || x >= odev.hres || y < 0 || y >= odev.vres) return(-1); @@ -251,18 +251,18 @@ qtFindLeaf( /* find closest leaf to (x,y) */ static int putleaf( /* put a leaf in our tree */ - register int li, + int li, int drop ) { - register RTREE *tp = &qtrunk; + RTREE *tp = &qtrunk; int x0=0, y0=0, x1=odev.hres, y1=odev.vres; - register int lo = -1; + int lo = -1; double d2; int x, y, mx, my; double z; FVECT ip, wp, vd; - register int q; + int q; /* check for dead leaf */ if (!qtL.chr[li][1] && !(qtL.chr[li][0] | qtL.chr[li][2])) return(0); @@ -345,14 +345,14 @@ dropit: } -extern void +void dev_value( /* add a pixel value to our quadtree */ COLR c, FVECT d, FVECT p ) { - register int li; + int li; int mapit; /* grab a leaf */ if (!imm_mode && falleaves >= 0) { /* check for fallen leaves */ @@ -385,10 +385,10 @@ dev_value( /* add a pixel value to our quadtree */ } -extern void +void qtReplant(void) /* replant our tree using new view */ { - register int i; + int i; /* anything to replant? */ if (qtL.bl == qtL.tl) return; @@ -401,7 +401,7 @@ qtReplant(void) /* replant our tree using new view * } -extern int +int qtMapLeaves( /* map our leaves to RGB */ int redo )
