root/radiance/ray/src/hd/rhd_qtree.c
Revision: 3.30
Committed: Thu May 14 20:58:03 2020 UTC (4 years, 11 months ago) by greg
CVS Tags: rad5R4, rad5R3, HEAD
Changes since 3.29: +2 -2 lines
# User Rev Content
1 gregl 3.1 #ifndef lint
2 greg 3.30 static const char RCSid[] = "$Id: rhd_qtree.c,v 3.29 2018/10/05 19:19:16 greg Exp $";
3 gregl 3.1 #endif
4     /*
5     * Quadtree driver support routines.
6     */
7
8 schorsch 3.23 #include <string.h>
9
10 gregl 3.1 #include "standard.h"
11     #include "rhd_qtree.h"
12 gregl 3.6 /* quantity of leaves to free at a time */
13     #ifndef LFREEPCT
14     #define LFREEPCT 25
15     #endif
16 gregl 3.10 /* maximum allowed angle difference (deg.) */
17     #ifndef MAXANG
18 gregl 3.12 #define MAXANG 20
19 gregl 3.10 #endif
20 gregl 3.12 #if MAXANG>0
21     #define MAXDIFF2 ( MAXANG*MAXANG * (PI*PI/180./180.))
22     #endif
23 gregl 3.1
24 gregl 3.10 #define abs(i) ((i) < 0 ? -(i) : (i))
25
26 gregl 3.2 RTREE qtrunk; /* our quadtree trunk */
27 gregl 3.10 double qtDepthEps = .05; /* epsilon to compare depths (z fraction) */
28 gregl 3.2 int qtMinNodesiz = 2; /* minimum node dimension (pixels) */
29 gregl 3.5 struct rleaves qtL; /* our pile of leaves */
30 gregl 3.2
31 gregl 3.17 int rayqleft = 0; /* rays left to queue before flush */
32
33 greg 3.22 static int32 falleaves; /* our list of fallen leaves */
34 gregl 3.15
35     #define composted(li) (qtL.bl <= qtL.tl ? \
36     ((li) < qtL.bl || (li) >= qtL.tl) : \
37     ((li) < qtL.bl && (li) >= qtL.tl))
38
39 gregl 3.1 #define TBUNDLESIZ 409 /* number of twigs in a bundle */
40
41     static RTREE **twigbundle; /* free twig blocks (NULL term.) */
42     static int nexttwig; /* next free twig */
43
44 schorsch 3.25 static RTREE *newtwig(void);
45     static void qtFreeTree(int really);
46     static void shaketree(RTREE *tp);
47     static int putleaf(int li, int drop);
48
49 gregl 3.1
50     static RTREE *
51 schorsch 3.25 newtwig(void) /* allocate a twig */
52 gregl 3.1 {
53 greg 3.29 int bi;
54 gregl 3.1
55     if (twigbundle == NULL) { /* initialize */
56     twigbundle = (RTREE **)malloc(sizeof(RTREE *));
57     if (twigbundle == NULL)
58     goto memerr;
59     twigbundle[0] = NULL;
60     }
61     bi = nexttwig / TBUNDLESIZ;
62     if (twigbundle[bi] == NULL) { /* new block */
63 greg 3.21 twigbundle = (RTREE **)realloc((void *)twigbundle,
64 gregl 3.1 (bi+2)*sizeof(RTREE *));
65     if (twigbundle == NULL)
66     goto memerr;
67     twigbundle[bi] = (RTREE *)calloc(TBUNDLESIZ, sizeof(RTREE));
68     if (twigbundle[bi] == NULL)
69     goto memerr;
70     twigbundle[bi+1] = NULL;
71     }
72     /* nexttwig++ % TBUNDLESIZ */
73     return(twigbundle[bi] + (nexttwig++ - bi*TBUNDLESIZ));
74     memerr:
75     error(SYSTEM, "out of memory in newtwig");
76 schorsch 3.25 return NULL; /* pro forma return */
77 gregl 3.1 }
78
79
80 schorsch 3.25 static void
81     qtFreeTree( /* free allocated twigs */
82     int really
83     )
84 gregl 3.1 {
85 greg 3.29 int i;
86 gregl 3.1
87 gregl 3.7 qtrunk.flgs = CH_ANY; /* chop down tree */
88 gregl 3.1 if (twigbundle == NULL)
89     return;
90 gregl 3.7 i = (TBUNDLESIZ-1+nexttwig)/TBUNDLESIZ;
91     nexttwig = 0;
92 gregl 3.1 if (!really) { /* just clear allocated blocks */
93 gregl 3.7 while (i--)
94 schorsch 3.23 memset((char *)twigbundle[i], '\0', TBUNDLESIZ*sizeof(RTREE));
95 gregl 3.1 return;
96     }
97     /* else "really" means free up memory */
98     for (i = 0; twigbundle[i] != NULL; i++)
99 greg 3.19 free((void *)twigbundle[i]);
100     free((void *)twigbundle);
101 gregl 3.1 twigbundle = NULL;
102     }
103
104
105 greg 3.22 #define LEAFSIZ (3*sizeof(float)+sizeof(int32)+\
106 greg 3.27 sizeof(TMbright)+6*sizeof(uby8))
107 gregl 3.5
108 greg 3.29 int
109 schorsch 3.25 qtAllocLeaves( /* allocate space for n leaves */
110 greg 3.29 int n
111 schorsch 3.25 )
112 gregl 3.1 {
113     unsigned nbytes;
114 greg 3.29 unsigned i;
115 gregl 3.1
116 gregl 3.3 qtFreeTree(0); /* make sure tree is empty */
117 gregl 3.1 if (n <= 0)
118     return(0);
119 gregl 3.5 if (qtL.nl >= n)
120     return(qtL.nl);
121     else if (qtL.nl > 0)
122     free(qtL.base);
123 gregl 3.1 /* round space up to nearest power of 2 */
124 gregl 3.5 nbytes = n*LEAFSIZ + 8;
125 gregl 3.1 for (i = 1024; nbytes > i; i <<= 1)
126     ;
127 gregl 3.5 n = (i - 8) / LEAFSIZ; /* should we make sure n is even? */
128     qtL.base = (char *)malloc(n*LEAFSIZ);
129     if (qtL.base == NULL)
130     return(0);
131     /* assign larger alignment types earlier */
132     qtL.wp = (float (*)[3])qtL.base;
133 greg 3.22 qtL.wd = (int32 *)(qtL.wp + n);
134 gregl 3.10 qtL.brt = (TMbright *)(qtL.wd + n);
135 greg 3.27 qtL.chr = (uby8 (*)[3])(qtL.brt + n);
136     qtL.rgb = (uby8 (*)[3])(qtL.chr + n);
137 gregl 3.5 qtL.nl = n;
138     qtL.tml = qtL.bl = qtL.tl = 0;
139 gregl 3.15 falleaves = -1;
140 gregl 3.5 return(n);
141 gregl 3.1 }
142
143 gregl 3.5 #undef LEAFSIZ
144 gregl 3.1
145 gregl 3.5
146 greg 3.29 void
147 schorsch 3.25 qtFreeLeaves(void) /* free our allocated leaves and twigs */
148 gregl 3.1 {
149 gregl 3.3 qtFreeTree(1); /* free tree also */
150 gregl 3.5 if (qtL.nl <= 0)
151 gregl 3.1 return;
152 gregl 3.5 free(qtL.base);
153     qtL.base = NULL;
154     qtL.nl = 0;
155 gregl 3.1 }
156
157
158 schorsch 3.25 static void
159     shaketree( /* shake dead leaves from tree */
160 greg 3.29 RTREE *tp
161 schorsch 3.25 )
162 gregl 3.1 {
163 greg 3.29 int i, li;
164 gregl 3.1
165     for (i = 0; i < 4; i++)
166 gregl 3.5 if (tp->flgs & BRF(i)) {
167 gregl 3.2 shaketree(tp->k[i].b);
168 gregl 3.5 if (is_stump(tp->k[i].b))
169     tp->flgs &= ~BRF(i);
170     } else if (tp->flgs & LFF(i)) {
171     li = tp->k[i].li;
172 gregl 3.15 if (composted(li))
173 gregl 3.5 tp->flgs &= ~LFF(i);
174 gregl 3.1 }
175     }
176
177
178 greg 3.29 int
179 schorsch 3.25 qtCompost( /* free up some leaves */
180     int pct
181     )
182 gregl 3.1 {
183 greg 3.29 int32 *fl;
184 gregl 3.5 int nused, nclear, nmapped;
185 gregl 3.1 /* figure out how many leaves to clear */
186 gregl 3.5 nclear = qtL.nl * pct / 100;
187     nused = qtL.tl - qtL.bl;
188     if (nused <= 0) nused += qtL.nl;
189     nclear -= qtL.nl - nused;
190 gregl 3.1 if (nclear <= 0)
191     return(0);
192     if (nclear >= nused) { /* clear them all */
193 gregl 3.3 qtFreeTree(0);
194 gregl 3.5 qtL.tml = qtL.bl = qtL.tl = 0;
195 gregl 3.15 falleaves = -1;
196 gregl 3.1 return(nused);
197     }
198     /* else clear leaves from bottom */
199 gregl 3.5 nmapped = qtL.tml - qtL.bl;
200     if (nmapped < 0) nmapped += qtL.nl;
201     qtL.bl += nclear;
202     if (qtL.bl >= qtL.nl) qtL.bl -= qtL.nl;
203     if (nmapped <= nclear) qtL.tml = qtL.bl;
204 gregl 3.15 shaketree(&qtrunk); /* dereference composted leaves */
205     for (fl = &falleaves; *fl >= 0; fl = qtL.wd + *fl)
206     while (composted(*fl))
207     if ((*fl = qtL.wd[*fl]) < 0)
208     return(nclear);
209 gregl 3.1 return(nclear);
210     }
211
212
213 greg 3.29 int
214 schorsch 3.25 qtFindLeaf( /* find closest leaf to (x,y) */
215     int x,
216     int y
217     )
218 gregl 3.3 {
219 greg 3.29 RTREE *tp = &qtrunk;
220 gregl 3.5 int li = -1;
221 gregl 3.3 int x0=0, y0=0, x1=odev.hres, y1=odev.vres;
222     int mx, my;
223 greg 3.29 int q;
224 gregl 3.3 /* check limits */
225     if (x < 0 || x >= odev.hres || y < 0 || y >= odev.vres)
226 gregl 3.5 return(-1);
227 gregl 3.3 /* find nearby leaf in our tree */
228     for ( ; ; ) {
229     for (q = 0; q < 4; q++) /* find any leaf this level */
230 gregl 3.5 if (tp->flgs & LFF(q)) {
231     li = tp->k[q].li;
232 gregl 3.3 break;
233     }
234     q = 0; /* which quadrant are we? */
235     mx = (x0 + x1) >> 1;
236     my = (y0 + y1) >> 1;
237     if (x < mx) x1 = mx;
238     else {x0 = mx; q |= 01;}
239     if (y < my) y1 = my;
240     else {y0 = my; q |= 02;}
241     if (tp->flgs & BRF(q)) { /* branch down if not a leaf */
242     tp = tp->k[q].b;
243     continue;
244     }
245 gregl 3.5 if (tp->flgs & LFF(q)) /* good shot! */
246     return(tp->k[q].li);
247     return(li); /* else return what we have */
248 gregl 3.3 }
249     }
250
251
252 schorsch 3.25 static int
253     putleaf( /* put a leaf in our tree */
254 greg 3.29 int li,
255 schorsch 3.25 int drop
256     )
257 gregl 3.1 {
258 greg 3.29 RTREE *tp = &qtrunk;
259 gregl 3.1 int x0=0, y0=0, x1=odev.hres, y1=odev.vres;
260 greg 3.29 int lo = -1;
261 gregl 3.11 double d2;
262 gregl 3.1 int x, y, mx, my;
263     double z;
264 gregl 3.11 FVECT ip, wp, vd;
265 greg 3.29 int q;
266 gregl 3.15 /* check for dead leaf */
267     if (!qtL.chr[li][1] && !(qtL.chr[li][0] | qtL.chr[li][2]))
268     return(0);
269 gregl 3.10 /* compute leaf location in view */
270 gregl 3.5 VCOPY(wp, qtL.wp[li]);
271 greg 3.30 if (viewloc(ip, &odev.v, wp) != VL_GOOD)
272 gregl 3.15 goto dropit; /* behind or outside view */
273 gregl 3.10 #ifdef DEBUG
274     if (odev.v.type == VT_PAR | odev.v.vfore > FTINY)
275 gregl 3.15 error(INTERNAL, "bad view assumption in putleaf");
276 gregl 3.10 #endif
277     for (q = 0; q < 3; q++)
278 gregl 3.11 vd[q] = (wp[q] - odev.v.vp[q])/ip[2];
279     d2 = fdir2diff(qtL.wd[li], vd);
280 gregl 3.12 #ifdef MAXDIFF2
281 gregl 3.10 if (d2 > MAXDIFF2)
282 gregl 3.15 goto dropit; /* leaf dir. too far off */
283 gregl 3.12 #endif
284 gregl 3.1 x = ip[0] * odev.hres;
285     y = ip[1] * odev.vres;
286     z = ip[2];
287     /* find the place for it */
288     for ( ; ; ) {
289     q = 0; /* which quadrant? */
290     mx = (x0 + x1) >> 1;
291     my = (y0 + y1) >> 1;
292     if (x < mx) x1 = mx;
293     else {x0 = mx; q |= 01;}
294     if (y < my) y1 = my;
295     else {y0 = my; q |= 02;}
296     if (tp->flgs & BRF(q)) { /* move to next branch */
297     tp->flgs |= CHF(q); /* not sure; guess */
298     tp = tp->k[q].b;
299     continue;
300     }
301 gregl 3.5 if (!(tp->flgs & LFF(q))) { /* found stem for leaf */
302     tp->k[q].li = li;
303     tp->flgs |= CHLFF(q);
304 gregl 3.15 return(1);
305 gregl 3.1 }
306 gregl 3.10 if (lo != tp->k[q].li) { /* check old leaf */
307 gregl 3.5 lo = tp->k[q].li;
308     VCOPY(wp, qtL.wp[lo]);
309 gregl 3.1 viewloc(ip, &odev.v, wp);
310     }
311     /* is node minimum size? */
312 gregl 3.10 if (y1-y0 <= qtMinNodesiz || x1-x0 <= qtMinNodesiz) {
313     if (z > (1.+qtDepthEps)*ip[2])
314 gregl 3.15 break; /* old one closer */
315 gregl 3.10 if (z >= (1.-qtDepthEps)*ip[2] &&
316 gregl 3.11 fdir2diff(qtL.wd[lo], vd) < d2)
317 gregl 3.15 break; /* old one better */
318     tp->k[q].li = li; /* attach new */
319 gregl 3.1 tp->flgs |= CHF(q);
320 gregl 3.15 li = lo; /* drop old... */
321 gregl 3.1 break;
322     }
323 gregl 3.5 tp->flgs &= ~LFF(q); /* else grow tree */
324     tp->flgs |= CHBRF(q);
325 gregl 3.1 tp = tp->k[q].b = newtwig();
326     q = 0; /* old leaf -> new branch */
327     mx = ip[0] * odev.hres;
328     my = ip[1] * odev.vres;
329     if (mx >= (x0 + x1) >> 1) q |= 01;
330     if (my >= (y0 + y1) >> 1) q |= 02;
331 gregl 3.11 tp->flgs = CH_ANY|LFF(q); /* all new */
332 gregl 3.5 tp->k[q].li = lo;
333 gregl 3.1 }
334 gregl 3.15 dropit:
335 schorsch 3.24 if (drop) {
336 gregl 3.16 if (li+1 == (qtL.tl ? qtL.tl : qtL.nl))
337     qtL.tl = li; /* special case */
338     else {
339     qtL.chr[li][0] = qtL.chr[li][1] = qtL.chr[li][2] = 0;
340     qtL.wd[li] = falleaves;
341     falleaves = li;
342     }
343 schorsch 3.24 }
344 gregl 3.15 return(li == lo);
345 gregl 3.1 }
346
347
348 greg 3.29 void
349 schorsch 3.25 dev_value( /* add a pixel value to our quadtree */
350     COLR c,
351     FVECT d,
352     FVECT p
353     )
354 gregl 3.1 {
355 greg 3.29 int li;
356 gregl 3.15 int mapit;
357     /* grab a leaf */
358 gregl 3.16 if (!imm_mode && falleaves >= 0) { /* check for fallen leaves */
359 gregl 3.15 li = falleaves;
360     falleaves = qtL.wd[li];
361     mapit = qtL.tml <= qtL.tl ?
362     (li < qtL.tml || li >= qtL.tl) :
363     (li < qtL.tml && li >= qtL.tl) ;
364 gregl 3.16 } else { /* else allocate new one */
365 gregl 3.15 li = qtL.tl++;
366 gregl 3.16 if (qtL.tl >= qtL.nl) /* next leaf in ring */
367 gregl 3.15 qtL.tl = 0;
368 gregl 3.16 if (qtL.tl == qtL.bl) /* need to shake some free */
369 gregl 3.15 qtCompost(LFREEPCT);
370 gregl 3.16 mapit = 0; /* we'll map it later */
371 gregl 3.15 }
372 gwlarson 3.18 if (p == NULL)
373     VSUM(qtL.wp[li], odev.v.vp, d, FHUGE);
374     else
375     VCOPY(qtL.wp[li], p);
376     qtL.wd[li] = encodedir(d);
377 greg 3.26 tmCvColrs(tmGlobal, &qtL.brt[li], qtL.chr[li], (COLR *)c, 1);
378 gregl 3.17 if (putleaf(li, 1)) {
379     if (mapit)
380 greg 3.27 tmMapPixels(tmGlobal, (uby8 *)(qtL.rgb+li), qtL.brt+li,
381     (uby8 *)(qtL.chr+li), 1);
382 gregl 3.17 if (--rayqleft == 0)
383     dev_flush(); /* flush output */
384     }
385 gregl 3.1 }
386
387
388 greg 3.29 void
389 schorsch 3.25 qtReplant(void) /* replant our tree using new view */
390 gregl 3.1 {
391 greg 3.29 int i;
392 gregl 3.5 /* anything to replant? */
393     if (qtL.bl == qtL.tl)
394 gregl 3.1 return;
395 gregl 3.5 qtFreeTree(0); /* blow the old tree away */
396     /* regrow it in new place */
397     for (i = qtL.bl; i != qtL.tl; ) {
398 gregl 3.15 putleaf(i, 0);
399 gregl 3.5 if (++i >= qtL.nl) i = 0;
400 gregl 3.1 }
401     }
402
403
404 greg 3.29 int
405 schorsch 3.25 qtMapLeaves( /* map our leaves to RGB */
406     int redo
407     )
408 gregl 3.5 {
409     int aorg, alen, borg, blen;
410 gregl 3.6 /* recompute mapping? */
411     if (redo)
412     qtL.tml = qtL.bl;
413 gregl 3.5 /* already done? */
414     if (qtL.tml == qtL.tl)
415     return(1);
416     /* compute segments */
417     aorg = qtL.tml;
418     if (qtL.tl >= aorg) {
419     alen = qtL.tl - aorg;
420     blen = 0;
421     } else {
422     alen = qtL.nl - aorg;
423     borg = 0;
424     blen = qtL.tl;
425     }
426     /* (re)compute tone mapping? */
427     if (qtL.tml == qtL.bl) {
428 greg 3.26 tmClearHisto(tmGlobal);
429     tmAddHisto(tmGlobal, qtL.brt+aorg, alen, 1);
430 gregl 3.5 if (blen > 0)
431 greg 3.26 tmAddHisto(tmGlobal, qtL.brt+borg, blen, 1);
432     if (tmComputeMapping(tmGlobal, 0., 0., 0.) != TM_E_OK)
433 gregl 3.5 return(0);
434     }
435 greg 3.27 if (tmMapPixels(tmGlobal, (uby8 *)(qtL.rgb+aorg), qtL.brt+aorg,
436     (uby8 *)(qtL.chr+aorg), alen) != TM_E_OK)
437 gregl 3.5 return(0);
438     if (blen > 0)
439 greg 3.27 tmMapPixels(tmGlobal, (uby8 *)(qtL.rgb+borg), qtL.brt+borg,
440     (uby8 *)(qtL.chr+borg), blen);
441 gregl 3.5 qtL.tml = qtL.tl;
442     return(1);
443 gregl 3.1 }
