--- ray/src/hd/rhd_ogl.c 1998/12/21 19:17:28 3.6 +++ ray/src/hd/rhd_ogl.c 1998/12/22 09:40:32 3.7 @@ -55,6 +55,13 @@ static char SCCSid[] = "$SunId$ SGI"; #define FEQ(a,b) ((a)-(b) <= FTINY && (a)-(b) >= -FTINY) #endif +#define VWHEADLOCK 01 /* head position is locked flag */ +#define VWPERSP 02 /* perspective view is set */ +#define VWORTHO 04 /* orthographic view is set */ +#define VWCHANGE 010 /* view has changed */ +#define VWSTEADY 020 /* view is now steady */ +#define VWMAPPED 040 /* window is mapped */ + #define GAMMA 1.4 /* default gamma correction */ #define FRAMESTATE(s) (((s)&(ShiftMask|ControlMask))==(ShiftMask|ControlMask)) @@ -97,7 +104,6 @@ static int rayqleft = 0; /* rays left to queue before static XEvent currentevent; /* current event */ -static int mapped = 0; /* window is mapped? */ static unsigned long ourblack=0, ourwhite=~0; static Display *ourdisplay = NULL; /* our display */ @@ -115,12 +121,8 @@ static double dev_zrat; /* (1. - dev_zmin/dev_zmax) * static int inpresflags; /* input result flags */ -static int headlocked; /* lock vertical motion */ +static int viewflags; /* what's happening with view */ -static int isperspective; /* perspective/ortho view */ - -static int viewsteady; /* is view steady? */ - static int resizewindow(), getevent(), getkey(), moveview(), wipeclean(), xferdepth(), freedepth(), setglortho(), setglpersp(), getframe(), getmove(), fixwindow(), mytmflags(); @@ -263,9 +265,7 @@ char *id; checkglerr("setting rendering parameters"); copystruct(&odev.v, &stdview); odev.v.type = VT_PER; - headlocked = 0; /* free up head movement */ - viewsteady = 1; /* view starts static */ - isperspective = -1; /* but no view set, yet */ + viewflags = VWSTEADY; /* view starts static */ /* map the window */ XMapWindow(ourdisplay, gwind); dev_input(); /* sets size and view angles */ @@ -355,6 +355,7 @@ register VIEW *nv; VSUM(vwright.vp, nv->vp, nv->hvec, d); /* setview(&vwright); -- Unnecessary */ #endif + viewflags |= VWCHANGE; } wipeclean(); return(1); @@ -451,7 +452,7 @@ dev_flush() /* flush output as appropriate */ { int ndrawn; - if (mapped && isperspective > 0) { + if ((viewflags&(VWMAPPED|VWPERSP)) == (VWMAPPED|VWPERSP)) { #ifdef STEREO pushright(); /* draw right eye */ ndrawn = gmDrawGeom(); @@ -472,20 +473,25 @@ dev_flush() /* flush output as appropriate */ glXSwapBuffers(ourdisplay, gwind); checkglerr("rendering base view"); } - if (mapped && viewsteady) - if (isperspective > 0) { /* first time after steady */ - if (ndrawn) - xferdepth(); /* transfer and clear depth */ - setglortho(); /* set orthographic view */ - } else if (!isperspective) { + if ((viewflags&(VWMAPPED|VWSTEADY|VWPERSP|VWORTHO)) == + (VWMAPPED|VWSTEADY|VWPERSP)) { + /* first time after steady */ + if (ndrawn) + xferdepth(); /* transfer and clear depth */ + setglortho(); /* set orthographic view */ + + } + if ((viewflags&(VWMAPPED|VWSTEADY|VWPERSP|VWORTHO)) == + (VWMAPPED|VWSTEADY|VWORTHO)) { + /* else update cones */ #ifdef STEREO - pushright(); - odUpdate(1); /* draw right eye */ - popright(); + pushright(); + odUpdate(1); /* draw right eye */ + popright(); #endif - odUpdate(0); /* draw left eye */ - glFlush(); /* flush OpenGL */ - } + odUpdate(0); /* draw left eye */ + glFlush(); /* flush OpenGL */ + } rayqleft = RAYQLEN; /* flush X11 and return # pending */ return(odev.inpready = XPending(ourdisplay)); @@ -613,7 +619,7 @@ pushright() /* push on right view & buffer */ double d; setstereobuf(STEREO_BUFFER_RIGHT); - if (isperspective > 0) { + if (viewflags & VWPERSP) { glMatrixMode(GL_MODELVIEW); glPushMatrix(); d = -eyesepdist / sqrt(odev.v.hn2); @@ -627,7 +633,7 @@ pushright() /* push on right view & buffer */ static popright() /* pop off right view & buffer */ { - if (isperspective > 0) { + if (viewflags & VWPERSP) { glMatrixMode(GL_MODELVIEW); glPopMatrix(); } @@ -670,11 +676,11 @@ getevent() /* get next event */ resizewindow(levptr(XConfigureEvent)); break; case UnmapNotify: - mapped = 0; + viewflags &= ~VWMAPPED; break; case MapNotify: odRemap(0); - mapped = 1; + viewflags |= VWMAPPED; break; case Expose: fixwindow(levptr(XExposeEvent)); @@ -761,7 +767,7 @@ int dx, dy, mov, orb; d = MOVPCT/100. * mov; VSUM(nv.vp, nv.vp, odir, d); } - if (!mov ^ !orb && headlocked) { /* restore head height */ + if (!mov ^ !orb && viewflags&VWHEADLOCK) { /* restore height */ VSUM(v1, odev.v.vp, nv.vp, -1.); d = DOT(v1, nv.vup); VSUM(nv.vp, nv.vp, odev.v.vup, d); @@ -810,7 +816,7 @@ XButtonPressedEvent *ebut; XNoOp(ourdisplay); /* makes sure we're not idle */ - viewsteady = 0; /* flag moving view */ + viewflags &= ~VWSTEADY; /* flag moving view */ setglpersp(&odev.v); /* start us off in perspective */ while (!XCheckMaskEvent(ourdisplay, ButtonReleaseMask, levptr(XEvent))) { @@ -852,7 +858,7 @@ XButtonPressedEvent *ebut; wy = levptr(XButtonReleasedEvent)->y; moveview(wx, odev.vres-1-wy, movdir, movorb); } - viewsteady = 1; /* done goofing around */ + viewflags |= VWSTEADY; /* done goofing around */ } @@ -899,7 +905,6 @@ register VIEW *vp; odev.v.vp[2] + odev.v.vdir[2], odev.v.vup[0], odev.v.vup[1], odev.v.vup[2]); checkglerr("setting perspective view"); - isperspective = 1; vec[0] = vec[1] = vec[2] = 0.; vec[3] = 1.; glLightModelfv(GL_LIGHT_MODEL_AMBIENT, vec); vec[0] = -odev.v.vdir[0]; @@ -915,6 +920,8 @@ register VIEW *vp; glEnable(GL_LIGHT0); glEnable(GL_LIGHTING); /* light our GL objects */ glShadeModel(GL_SMOOTH); + viewflags &= ~VWORTHO; + viewflags |= VWPERSP; } @@ -928,9 +935,10 @@ setglortho() /* set up orthographic view for cone dr glOrtho(0., (double)odev.hres, 0., (double)odev.vres, 0.001*OMAXDEPTH, 1.001*(-OMAXDEPTH)); checkglerr("setting orthographic view"); - isperspective = 0; glDisable(GL_LIGHTING); /* cones are constant color */ glShadeModel(GL_FLAT); + viewflags &= ~VWPERSP; + viewflags |= VWORTHO; } @@ -946,8 +954,11 @@ wipeclean() /* prepare for redraw */ #endif glClear(GL_DEPTH_BUFFER_BIT|GL_COLOR_BUFFER_BIT); freedepth(); - if (viewsteady) /* clear samples if steady */ + if ((viewflags&(VWCHANGE|VWSTEADY)) == + (VWCHANGE|VWSTEADY)) { /* clear samples if new */ odClean(); + viewflags &= ~VWCHANGE; /* change noted */ + } setglpersp(&odev.v); /* reset view & clipping planes */ } @@ -967,10 +978,10 @@ register XKeyPressedEvent *ekey; return; switch (buf[0]) { case 'h': /* turn on height motion lock */ - headlocked = 1; + viewflags |= VWHEADLOCK; return; case 'H': /* turn off height motion lock */ - headlocked = 0; + viewflags &= ~VWHEADLOCK; return; case 'l': /* retrieve last view */ inpresflags |= DFL(DC_LASTVIEW); @@ -1091,4 +1102,5 @@ register XConfigureEvent *ersz; odev.v.vert = 2.*180./PI * atan(0.5/VIEWDIST*pheight*odev.vres); inpresflags |= DFL(DC_SETVIEW); + viewflags |= VWCHANGE; }
