--- ray/src/hd/rhd_ogl.c 1999/06/28 16:30:22 3.17 +++ ray/src/hd/rhd_ogl.c 2003/09/19 18:33:05 3.23 @@ -1,9 +1,6 @@ -/* Copyright (c) 1999 Silicon Graphics, Inc. */ - #ifndef lint -static char SCCSid[] = "$SunId$ SGI"; +static const char RCSid[] = "$Id: rhd_ogl.c,v 3.23 2003/09/19 18:33:05 greg Exp $"; #endif - /* * OpenGL driver for holodeck display. * Based on GLX driver using T-mesh. @@ -27,6 +24,7 @@ static char SCCSid[] = "$SunId$ SGI"; #ifdef STEREO #include #endif +#include #include "rhd_odraw.h" #ifdef DOBJ @@ -245,7 +243,7 @@ char *id; setstereobuf(STEREO_BUFFER_LEFT); #endif checkglerr("setting rendering parameters"); - copystruct(&odev.v, &stdview); + odev.v = stdview; odev.v.type = VT_PER; viewflags = VWSTEADY; /* view starts static */ /* map the window */ @@ -332,11 +330,11 @@ register VIEW *nv; XResizeWindow(ourdisplay, gwind, odev.hres, odev.vres); dev_input(); /* get resize event */ } - copystruct(&odev.v, nv); /* setview() already called */ + odev.v = *nv; /* setview() already called */ viewflags |= VWCHANGE; } #ifdef STEREO - copystruct(&vwright, nv); + vwright = *nv; d = eyesepdist / sqrt(nv->hn2); VSUM(vwright.vp, nv->vp, nv->hvec, d); /* setview(&vwright); -- Unnecessary */ @@ -349,7 +347,6 @@ register VIEW *nv; dev_section(gfn, pfn) /* add octree for geometry rendering */ char *gfn, *pfn; { - extern char *index(); char *cp; if (gfn == NULL) { @@ -557,7 +554,7 @@ xferdepth() /* load and clear depth buffer */ glClear(GL_DEPTH_BUFFER_BIT); /* clear system depth buffer */ odDepthMap(0, depthbuffer); /* transfer depth data */ if (pbuf != NULL) - free((char *)pbuf); /* free our portal buffer */ + free((void *)pbuf); /* free our portal buffer */ } @@ -568,11 +565,11 @@ freedepth() /* free recorded depth buffer */ return; #ifdef STEREO odDepthMap(1, NULL); - free((char *)depthright); + free((void *)depthright); depthright = NULL; #endif odDepthMap(0, NULL); - free((char *)depthbuffer); + free((void *)depthbuffer); depthbuffer = NULL; } @@ -592,6 +589,8 @@ FVECT direc; else { glReadPixels(dx,dy, 1,1, GL_DEPTH_COMPONENT, GL_FLOAT, &gldepth); + if (gldepth <= FTINY) + return (FHUGE); /* call failed */ dist = mapdepth(gldepth); } if (dist >= .99*FHUGE) @@ -722,7 +721,7 @@ int dx, dy, mov, orb; double d, d1; register int li; /* start with old view */ - copystruct(&nv, &odev.v); + nv = odev.v; /* orient our motion */ if (viewray(v1, odir, &odev.v, (dx+.5)/odev.hres, (dy+.5)/odev.vres) < -FTINY) @@ -792,6 +791,16 @@ XButtonPressedEvent *ebut; static +waitabit() /* pause a moment */ +{ + struct timespec ts; + ts.tv_sec = 0; + ts.tv_nsec = 100000000L; + nanosleep(&ts, NULL); +} + + +static getmove(ebut) /* get view change */ XButtonPressedEvent *ebut; { @@ -808,6 +817,8 @@ XButtonPressedEvent *ebut; setglpersp(); /* start us off in perspective */ while (!XCheckMaskEvent(ourdisplay, ButtonReleaseMask, levptr(XEvent))) { + /* pause so as not to move too fast */ + waitabit(); /* get cursor position */ if (!XQueryPointer(ourdisplay, gwind, &rootw, &childw, &rootx, &rooty, &wx, &wy, &statemask)) @@ -867,8 +878,8 @@ setglpersp() /* set perspective view in GL */ dev_zmin = odev.v.vfore; if (odev.v.vaft > FTINY) dev_zmax = odev.v.vaft; - if (dev_zmin < dev_zmax/100.) - dev_zmin = dev_zmax/100.; + if (dev_zmin*500. < dev_zmax) + dev_zmin = dev_zmax/500.; setzrat(); xmax = dev_zmin * tan(PI/180./2. * odev.v.horiz); xmin = -xmax;
