root/radiance/ray/src/hd/rhd_ogl.c
Revision: 3.21
Committed: Mon May 19 16:32:18 2003 UTC (21 years, 1 month ago) by greg
Changes since 3.20: +0 -1 lines
Eliminated unnecessary and problematic external function declarations
5 * OpenGL driver for holodeck display.
6 * Based on GLX driver using T-mesh.
7 *
8 * Define symbol STEREO for stereo viewing.
9 * Define symbol DOBJ for display object viewing.
10 */
11
12 #ifdef NOSTEREO
13 #ifdef STEREO
14 #undef STEREO
15 #else
16 #undef NOSTEREO
17 #endif
18 #endif
19
20 #include "standard.h"
21
22 #include <GL/glx.h>
23 #include <GL/glu.h>
24 #ifdef STEREO
25 #include <X11/extensions/SGIStereo.h>
26 #endif
27 #include <time.h>
28
29 #include "rhd_odraw.h"
30 #ifdef DOBJ
31 #include "rhdobj.h"
32 #endif
33
34 #include "x11icon.h"
35
36 #ifndef RAYQLEN
37 #define RAYQLEN 0 /* max. rays to queue before flush */
38 #endif
39 #ifndef MINWIDTH
40 #define MINWIDTH 480 /* minimum graphics window width */
41 #define MINHEIGHT 400 /* minimum graphics window height */
42 #endif
43 #ifndef VIEWDIST
44 #define VIEWDIST 356 /* assumed viewing distance (mm) */
45 #endif
46 #ifndef BORWIDTH
47 #define BORWIDTH 5 /* border width */
48 #endif
49
50 #ifndef FEQ
51 #define FEQ(a,b) ((a)-(b) <= FTINY && (a)-(b) >= -FTINY)
52 #endif
53
54 #define VWHEADLOCK 01 /* head position is locked flag */
55 #define VWPERSP 02 /* perspective view is set */
56 #define VWORTHO 04 /* orthographic view is set */
57 #define VWCHANGE 010 /* view has changed */
58 #define VWSTEADY 020 /* view is now steady */
59 #define VWMAPPED 040 /* window is mapped */
60
61 #define GAMMA 1.4 /* default gamma correction */
62
63 #define FRAMESTATE(s) (((s)&(ShiftMask|ControlMask))==(ShiftMask|ControlMask))
64
65 #define MOVPCT 7 /* percent distance to move /frame */
66 #define MOVDIR(b) ((b)==Button1 ? 1 : (b)==Button2 ? 0 : -1)
67 #define MOVDEG (-5) /* degrees to orbit CW/down /frame */
68 #define MOVORB(s) ((s)&ShiftMask ? 1 : (s)&ControlMask ? -1 : 0)
69
70 #define setstereobuf(bid) (glXWaitGL(), \
71 XSGISetStereoBuffer(ourdisplay, gwind, bid), \
72 glXWaitX())
73
74 #define ourscreen DefaultScreen(ourdisplay)
75 #define ourroot RootWindow(ourdisplay,ourscreen)
76 #define ourmask (StructureNotifyMask|ExposureMask|KeyPressMask|\
77 ButtonPressMask|ButtonReleaseMask)
78
79 #define levptr(etype) ((etype *)&currentevent)
80
81 struct driver odev; /* global device driver structure */
82
83 char odev_args[64]; /* command arguments */
84
85 static GLfloat *depthbuffer = NULL; /* depth buffer */
86
87 #ifdef STEREO
88 static VIEW vwright; /* right eye view */
89 static GLfloat *depthright = NULL; /* right depth buffer */
90 #endif
91
92 static int rayqleft = 0; /* rays left to queue before flush */
93
94 static XEvent currentevent; /* current event */
95
96 static unsigned long ourblack=0, ourwhite=~0;
97
98 static Display *ourdisplay = NULL; /* our display */
99 static XVisualInfo *ourvinf; /* our visual information */
100 static Window gwind = 0; /* our graphics window */
101 static GLXContext gctx; /* our GLX context */
102
103 static double pwidth, pheight; /* pixel dimensions (mm) */
104
105 static double dev_zmin, dev_zmax; /* fore and aft clipping plane dist. */
106 static double dev_zrat; /* (1. - dev_zmin/dev_zmax) */
107
108 #define setzrat() (dev_zrat = 1. - dev_zmin/dev_zmax)
109 #define mapdepth(d) ((d)>0.9995 ? FHUGE : dev_zmin/(1.-(d)*dev_zrat))
110
111 static int inpresflags; /* input result flags */
112
113 static int viewflags; /* what's happening with view */
114
115 static int resizewindow(), getevent(), getkey(), moveview(), wipeclean(),
116 xferdepth(), freedepth(), setglortho(),
117 setglpersp(), getframe(), getmove(), fixwindow(), mytmflags();
118
119 static double getdistance();
120
121 #ifdef STEREO
122 static int pushright(), popright();
123 #endif
124
125 extern int gmPortals; /* GL portal list id */
126
127 extern time_t time();
128
129
130 dev_open(id) /* initialize GLX driver */
131 char *id;
132 {
133 extern char *getenv();
134 static RGBPRIMS myprims = STDPRIMS;
135 static int atlBest[] = {GLX_RGBA, GLX_DOUBLEBUFFER,
136 GLX_RED_SIZE,8, GLX_GREEN_SIZE,8,
137 GLX_BLUE_SIZE,8, GLX_DEPTH_SIZE,15, None};
138 static int atlOK[] = {GLX_RGBA, GLX_DOUBLEBUFFER,
139 GLX_RED_SIZE,4, GLX_GREEN_SIZE,4,
140 GLX_BLUE_SIZE,4, GLX_DEPTH_SIZE,15, None};
141 char *ev;
142 double gamval = GAMMA;
143 RGBPRIMP dpri = stdprims;
144 XSetWindowAttributes ourwinattr;
145 XWMHints ourxwmhints;
146 XSizeHints oursizhints;
147 /* check for unsupported stereo */
148 #ifdef NOSTEREO
149 error(INTERNAL, "stereo display driver unavailable");
150 #endif
151 /* open display server */
152 ourdisplay = XOpenDisplay(NULL);
153 CHECK(ourdisplay==NULL, USER,
154 "cannot open X-windows; DISPLAY variable set?");
155 #ifdef STEREO
156 switch (XSGIQueryStereoMode(ourdisplay, ourroot)) {
157 case STEREO_TOP:
158 case STEREO_BOTTOM:
159 break;
160 case STEREO_OFF:
161 error(USER,
162 "wrong video mode: run \"/usr/gfx/setmon -n STR_TOP\" first");
163 case X_STEREO_UNSUPPORTED:
164 error(USER, "stereo mode not supported on this screen");
165 default:
166 error(INTERNAL, "unknown stereo mode");
167 }
168 #endif
169 /* find a usable visual */
170 ourvinf = glXChooseVisual(ourdisplay, ourscreen, atlBest);
171 if (ourvinf == NULL)
172 ourvinf = glXChooseVisual(ourdisplay, ourscreen, atlOK);
173 CHECK(ourvinf==NULL, USER, "no suitable visuals available");
174 /* get a context */
175 gctx = glXCreateContext(ourdisplay, ourvinf, NULL, GL_TRUE);
176 /* set gamma and tone mapping */
177 if ((ev = XGetDefault(ourdisplay, "radiance", "gamma")) != NULL
178 || (ev = getenv("DISPLAY_GAMMA")) != NULL)
179 gamval = atof(ev);
180 if ((ev = getenv("DISPLAY_PRIMARIES")) != NULL &&
181 sscanf(ev, "%f %f %f %f %f %f %f %f",
182 &myprims[RED][CIEX],&myprims[RED][CIEY],
183 &myprims[GRN][CIEX],&myprims[GRN][CIEY],
184 &myprims[BLU][CIEX],&myprims[BLU][CIEY],
185 &myprims[WHT][CIEX],&myprims[WHT][CIEY]) >= 6)
186 dpri = myprims;
187 if (tmInit(mytmflags(), dpri, gamval) == NULL)
188 error(SYSTEM, "not enough memory in dev_open");
189 /* open window */
190 ourwinattr.background_pixel = ourblack;
191 ourwinattr.border_pixel = ourblack;
192 ourwinattr.event_mask = ourmask;
193 /* this is stupid */
194 ourwinattr.colormap = XCreateColormap(ourdisplay, ourroot,
195 ourvinf->visual, AllocNone);
196 gwind = XCreateWindow(ourdisplay, ourroot, 0, 0,
197 DisplayWidth(ourdisplay,ourscreen)-2*BORWIDTH,
198 #ifdef STEREO
199 (DisplayHeight(ourdisplay,ourscreen)-2*BORWIDTH)/2,
200 #else
201 DisplayHeight(ourdisplay,ourscreen)-2*BORWIDTH,
202 #endif
203 BORWIDTH, ourvinf->depth, InputOutput, ourvinf->visual,
204 CWBackPixel|CWBorderPixel|CWColormap|CWEventMask, &ourwinattr);
205 CHECK(gwind==0, SYSTEM, "cannot create window");
206 XStoreName(ourdisplay, gwind, id);
207 /* set window manager hints */
208 ourxwmhints.flags = InputHint|IconPixmapHint;
209 ourxwmhints.input = True;
210 ourxwmhints.icon_pixmap = XCreateBitmapFromData(ourdisplay,
211 gwind, x11icon_bits, x11icon_width, x11icon_height);
212 XSetWMHints(ourdisplay, gwind, &ourxwmhints);
213 oursizhints.min_width = MINWIDTH;
214 #ifdef STEREO
215 oursizhints.min_height = MINHEIGHT/2;
216 oursizhints.max_width = DisplayWidth(ourdisplay,ourscreen)-2*BORWIDTH;
217 oursizhints.max_height = (DisplayHeight(ourdisplay,ourscreen) -
218 2*BORWIDTH)/2;
219 oursizhints.flags = PMinSize|PMaxSize;
220 #else
221 oursizhints.min_height = MINHEIGHT;
222 oursizhints.flags = PMinSize;
223 #endif
224 XSetNormalHints(ourdisplay, gwind, &oursizhints);
225 /* set GLX context */
226 glXMakeCurrent(ourdisplay, gwind, gctx);
227 glEnable(GL_DEPTH_TEST);
228 glDepthFunc(GL_LEQUAL);
229 glClearColor(0, 0, 0, 0);
230 glFrontFace(GL_CCW);
231 glDisable(GL_CULL_FACE);
232 glLightModeli(GL_LIGHT_MODEL_TWO_SIDE, GL_TRUE);
233 glPolygonMode(GL_FRONT_AND_BACK, GL_FILL);
234 glPixelStorei(GL_PACK_ALIGNMENT, 1);
235 glPixelStorei(GL_UNPACK_ALIGNMENT, 1);
236 /* figure out sensible view */
237 pwidth = (double)DisplayWidthMM(ourdisplay, ourscreen) /
238 DisplayWidth(ourdisplay, ourscreen);
239 pheight = (double)DisplayHeightMM(ourdisplay, ourscreen) /
240 DisplayHeight(ourdisplay, ourscreen);
241 #ifdef STEREO
242 pheight *= 2.;
243 setstereobuf(STEREO_BUFFER_LEFT);
244 #endif
245 checkglerr("setting rendering parameters");
246 copystruct(&odev.v, &stdview);
247 odev.v.type = VT_PER;
248 viewflags = VWSTEADY; /* view starts static */
249 /* map the window */
250 XMapWindow(ourdisplay, gwind);
251 dev_input(); /* sets size and view angles */
252 if (!odInit(DisplayWidth(ourdisplay,ourscreen) *
253 DisplayHeight(ourdisplay,ourscreen) / 3))
254 error(SYSTEM, "insufficient memory for value storage");
255 odev.name = id;
256 odev.firstuse = 1; /* can't recycle samples */
257 odev.ifd = ConnectionNumber(ourdisplay);
258 }
259
260
261 dev_close() /* close our display and free resources */
262 {
263 #ifdef DOBJ
264 dobj_cleanup();
265 #endif
266 freedepth();
267 gmEndGeom();
268 gmEndPortal();
269 odDone();
270 glXMakeCurrent(ourdisplay, None, NULL);
271 glXDestroyContext(ourdisplay, gctx);
272 XDestroyWindow(ourdisplay, gwind);
273 gwind = 0;
274 XCloseDisplay(ourdisplay);
275 ourdisplay = NULL;
276 tmDone(NULL);
277 odev.v.type = 0;
278 odev.hres = odev.vres = 0;
279 odev.ifd = -1;
280 }
281
282
283 dev_clear() /* clear our representation */
284 {
285 viewflags |= VWCHANGE; /* pretend our view has changed */
286 wipeclean(); /* clean off display and samples */
287 dev_flush(); /* redraw geometry & get depth */
288 rayqleft = 0; /* hold off update */
289 }
290
291
292 int
293 dev_view(nv) /* assign new driver view */
294 register VIEW *nv;
295 {
296 double d;
297
298 if (nv->type != VT_PER || /* check view legality */
299 nv->horiz > 160. || nv->vert > 160.) {
300 error(COMMAND, "illegal view type/angle");
301 nv->type = odev.v.type;
302 nv->horiz = odev.v.horiz;
303 nv->vert = odev.v.vert;
304 return(0);
305 }
306 if (nv != &odev.v) {
307 /* resize window? */
308 if (!FEQ(nv->horiz,odev.v.horiz) ||
309 !FEQ(nv->vert,odev.v.vert)) {
310 int dw = DisplayWidth(ourdisplay,ourscreen);
311 int dh = DisplayHeight(ourdisplay,ourscreen);
312
313 dw -= 25; /* for window frame */
314 dh -= 50;
315 #ifdef STEREO
316 dh /= 2;
317 #endif
318 odev.hres = 2.*VIEWDIST/pwidth *
319 tan(PI/180./2.*nv->horiz);
320 odev.vres = 2.*VIEWDIST/pheight *
321 tan(PI/180./2.*nv->vert);
322 if (odev.hres > dw) {
323 odev.vres = dw * odev.vres / odev.hres;
324 odev.hres = dw;
325 }
326 if (odev.vres > dh) {
327 odev.hres = dh * odev.hres / odev.vres;
328 odev.vres = dh;
329 }
330 XResizeWindow(ourdisplay, gwind, odev.hres, odev.vres);
331 dev_input(); /* get resize event */
332 }
333 copystruct(&odev.v, nv); /* setview() already called */
334 viewflags |= VWCHANGE;
335 }
336 #ifdef STEREO
337 copystruct(&vwright, nv);
338 d = eyesepdist / sqrt(nv->hn2);
339 VSUM(vwright.vp, nv->vp, nv->hvec, d);
340 /* setview(&vwright); -- Unnecessary */
341 #endif
342 wipeclean();
343 return(1);
344 }
345
346
347 dev_section(gfn, pfn) /* add octree for geometry rendering */
348 char *gfn, *pfn;
349 {
350 char *cp;
351
352 if (gfn == NULL) {
353 gmEndGeom();
354 gmEndPortal();
355 wipeclean(); /* new geometry, so redraw it */
356 return;
357 }
358 if (access(gfn, R_OK) == 0)
359 gmNewGeom(gfn);
360 #ifdef DEBUG
361 else {
362 sprintf(errmsg, "cannot load octree \"%s\"", gfn);
363 error(WARNING, errmsg);
364 }
365 #endif
366 if (pfn != NULL)
367 gmNewPortal(pfn);
368 }
369
370
371 dev_auxcom(cmd, args) /* process an auxiliary command */
372 char *cmd, *args;
373 {
374 #ifdef DOBJ
375 int vischange;
376
377 if ((vischange = dobj_command(cmd, args)) >= 0) {
378 if (vischange) {
379 imm_mode = beam_sync(1) > 0;
380 dev_clear();
381 }
382 return;
383 }
384 #endif
385 sprintf(errmsg, "%s: unknown command", cmd);
386 error(COMMAND, errmsg);
387 }
388
389
390 VIEW *
391 dev_auxview(n, hvres) /* return nth auxiliary view */
392 int n;
393 int hvres[2];
394 {
395 hvres[0] = odev.hres; hvres[1] = odev.vres;
396 if (n == 0)
397 return(&odev.v);
398 #ifdef STEREO
399 if (n == 1)
400 return(&vwright);
401 #endif
402 return(NULL);
403 }
404
405
406 int
407 dev_input() /* get X11 input */
408 {
409 inpresflags = 0;
410
411 do
412 getevent();
413
414 while (XPending(ourdisplay) > 0);
415
416 odev.inpready = 0;
417
418 return(inpresflags);
419 }
420
421
422 dev_value(c, d, p) /* add a pixel value to our texture */
423 COLR c;
424 FVECT d, p;
425 {
426 #ifdef DOBJ
427 if (dobj_lightsamp != NULL) { /* in light source sampling */
428 (*dobj_lightsamp)(c, d, p);
429 return;
430 }
431 #endif
432 odSample(c, d, p); /* add to display representation */
433 if (!--rayqleft)
434 dev_flush(); /* flush output */
435 }
436
437
438 int
439 dev_flush() /* flush output as appropriate */
440 {
441 int ndrawn;
442
443 if ((viewflags&(VWMAPPED|VWPERSP)) == (VWMAPPED|VWPERSP)) {
444 #ifdef STEREO
445 pushright(); /* draw right eye */
446 ndrawn = gmDrawGeom();
447 #ifdef DOBJ
448 ndrawn += dobj_render();
449 #endif
450 checkglerr("rendering right eye");
451 popright(); /* draw left eye */
452 #endif
453 ndrawn = gmDrawGeom();
454 #ifdef DOBJ
455 ndrawn += dobj_render();
456 #endif
457 glXSwapBuffers(ourdisplay, gwind);
458 checkglerr("rendering base view");
459 }
460 if ((viewflags&(VWMAPPED|VWSTEADY|VWPERSP|VWORTHO)) ==
461 (VWMAPPED|VWSTEADY|VWPERSP)) {
462 /* first time after steady */
463 if (ndrawn)
464 xferdepth(); /* transfer and clear depth */
465 setglortho(); /* set orthographic view */
466
467 }
468 if ((viewflags&(VWMAPPED|VWSTEADY|VWPERSP|VWORTHO)) ==
469 (VWMAPPED|VWSTEADY|VWORTHO)) {
470 /* else update cones */
471 #ifdef STEREO
472 pushright();
473 odUpdate(1); /* draw right eye */
474 popright();
475 #endif
476 odUpdate(0); /* draw left eye */
477 glFlush(); /* flush OpenGL */
478 }
479 rayqleft = RAYQLEN;
480 /* flush X11 and return # pending */
481 return(odev.inpready = XPending(ourdisplay));
482 }
483
484
485 checkglerr(where) /* check for GL or GLU error */
486 char *where;
487 {
488 register GLenum errcode;
489
490 while ((errcode = glGetError()) != GL_NO_ERROR) {
491 sprintf(errmsg, "OpenGL error %s: %s",
492 where, gluErrorString(errcode));
493 error(WARNING, errmsg);
494 }
495 }
496
497
498 static
499 xferdepth() /* load and clear depth buffer */
500 {
501 register GLfloat *dbp;
502 register GLubyte *pbuf;
503
504 if (depthbuffer == NULL) { /* allocate private depth buffer */
505 #ifdef STEREO
506 depthright = (GLfloat *)malloc(
507 odev.hres*odev.vres*sizeof(GLfloat));
508 #endif
509 depthbuffer = (GLfloat *)malloc(
510 odev.hres*odev.vres*sizeof(GLfloat));
511 CHECK(depthbuffer==NULL, SYSTEM, "out of memory in xferdepth");
512 }
513 /* allocate alpha buffer for portals */
514 if (gmPortals)
515 pbuf = (GLubyte *)malloc(odev.hres*odev.vres*sizeof(GLubyte));
516 else
517 pbuf = NULL;
518 #ifdef STEREO
519 pushright();
520 glReadPixels(0, 0, odev.hres, odev.vres,
521 GL_DEPTH_COMPONENT, GL_FLOAT, depthright);
522 if (pbuf != NULL) {
523 glClear(GL_COLOR_BUFFER_BIT);
524 gmDrawPortals(0xff, -1, -1, -1);
525 glReadPixels(0, 0, odev.hres, odev.vres,
526 GL_RED, GL_UNSIGNED_BYTE, pbuf);
527 }
528 for (dbp = depthright + odev.hres*odev.vres; dbp-- > depthright; )
529 if (pbuf != NULL && pbuf[dbp-depthright]&0x40)
530 *dbp = FHUGE;
531 else
532 *dbp = mapdepth(*dbp);
533 glClear(GL_DEPTH_BUFFER_BIT);
534 odDepthMap(1, depthright);
535 popright();
536 #endif
537 /* read back depth buffer */
538 glReadPixels(0, 0, odev.hres, odev.vres,
539 GL_DEPTH_COMPONENT, GL_FLOAT, depthbuffer);
540 if (pbuf != NULL) {
541 glClear(GL_COLOR_BUFFER_BIT); /* find portals */
542 gmDrawPortals(0xff, -1, -1, -1);
543 glReadPixels(0, 0, odev.hres, odev.vres,
544 GL_RED, GL_UNSIGNED_BYTE, pbuf);
545 #ifdef DEBUG
546 glXSwapBuffers(ourdisplay, gwind);
547 #endif
548 }
549 for (dbp = depthbuffer + odev.hres*odev.vres; dbp-- > depthbuffer; )
550 if (pbuf != NULL && pbuf[dbp-depthbuffer]&0x40)
551 *dbp = FHUGE;
552 else
553 *dbp = mapdepth(*dbp);
554 glClear(GL_DEPTH_BUFFER_BIT); /* clear system depth buffer */
555 odDepthMap(0, depthbuffer); /* transfer depth data */
556 if (pbuf != NULL)
557 free((void *)pbuf); /* free our portal buffer */
558 }
559
560
561 static
562 freedepth() /* free recorded depth buffer */
563 {
564 if (depthbuffer == NULL)
565 return;
566 #ifdef STEREO
567 odDepthMap(1, NULL);
568 free((void *)depthright);
569 depthright = NULL;
570 #endif
571 odDepthMap(0, NULL);
572 free((void *)depthbuffer);
573 depthbuffer = NULL;
574 }
575
576
577 static double
578 getdistance(dx, dy, direc) /* distance from fore plane along view ray */
579 int dx, dy;
580 FVECT direc;
581 {
582 GLfloat gldepth;
583 double dist;
584
585 if (dx<0 | dx>=odev.hres | dy<0 | dy>=odev.vres)
586 return(FHUGE);
587 if (depthbuffer != NULL)
588 dist = depthbuffer[dy*odev.hres + dx];
589 else {
590 glReadPixels(dx,dy, 1,1, GL_DEPTH_COMPONENT,
591 GL_FLOAT, &gldepth);
592 dist = mapdepth(gldepth);
593 }
594 if (dist >= .99*FHUGE)
595 return(FHUGE);
596 return((dist-odev.v.vfore)/DOT(direc,odev.v.vdir));
597 }
598
599
600 #ifdef STEREO
601 static
602 pushright() /* push on right view & buffer */
603 {
604 double d;
605
606 setstereobuf(STEREO_BUFFER_RIGHT);
607 if (viewflags & VWPERSP) {
608 glMatrixMode(GL_MODELVIEW);
609 glPushMatrix();
610 d = -eyesepdist / sqrt(odev.v.hn2);
611 glTranslated(d*odev.v.hvec[0], d*odev.v.hvec[1],
612 d*odev.v.hvec[2]);
613 checkglerr("setting right view");
614 }
615 }
616
617
618 static
619 popright() /* pop off right view & buffer */
620 {
621 if (viewflags & VWPERSP) {
622 glMatrixMode(GL_MODELVIEW);
623 glPopMatrix();
624 }
625 setstereobuf(STEREO_BUFFER_LEFT);
626 }
627 #endif
628
629
630 static int
631 mytmflags() /* figure out tone mapping flags */
632 {
633 extern char *progname;
634 register char *cp, *tail;
635 /* find basic name */
636 for (cp = tail = progname; *cp; cp++)
637 if (*cp == '/')
638 tail = cp+1;
639 for (cp = tail; *cp && *cp != '.'; cp++)
640 ;
641 #ifdef DEBUG
642 if (cp > tail && cp[-1] == 'h')
643 return(TM_F_HUMAN);
644 else
645 return(TM_F_CAMERA);
646 #else
647 if (cp > tail && cp[-1] == 'h')
648 return(TM_F_HUMAN|TM_F_NOSTDERR);
649 else
650 return(TM_F_CAMERA|TM_F_NOSTDERR);
651 #endif
652 }
653
654
655 static
656 getevent() /* get next event */
657 {
658 XNextEvent(ourdisplay, levptr(XEvent));
659 switch (levptr(XEvent)->type) {
660 case ConfigureNotify:
661 resizewindow(levptr(XConfigureEvent));
662 break;
663 case UnmapNotify:
664 viewflags &= ~VWMAPPED;
665 break;
666 case MapNotify:
667 odRemap(0);
668 viewflags |= VWMAPPED;
669 break;
670 case Expose:
671 fixwindow(levptr(XExposeEvent));
672 break;
673 case KeyPress:
674 getkey(levptr(XKeyPressedEvent));
675 break;
676 case ButtonPress:
677 if (FRAMESTATE(levptr(XButtonPressedEvent)->state))
678 getframe(levptr(XButtonPressedEvent));
679 else
680 getmove(levptr(XButtonPressedEvent));
681 break;
682 }
683 }
684
685
686 static
687 draw3dline(wp) /* draw 3d line in world coordinates */
688 register FVECT wp[2];
689 {
690 glVertex3d(wp[0][0], wp[0][1], wp[0][2]);
691 glVertex3d(wp[1][0], wp[1][1], wp[1][2]);
692 }
693
694
695 static
696 draw_grids(fore) /* draw holodeck section grids */
697 int fore;
698 {
699 glPushAttrib(GL_LIGHTING_BIT|GL_ENABLE_BIT);
700 glDisable(GL_LIGHTING);
701 if (fore)
702 glColor3ub(4, 250, 250);
703 else
704 glColor3ub(0, 0, 0);
705 glBegin(GL_LINES); /* draw each grid line */
706 gridlines(draw3dline);
707 glEnd();
708 checkglerr("drawing grid lines");
709 glPopAttrib();
710 }
711
712
713 static
714 moveview(dx, dy, mov, orb) /* move our view */
715 int dx, dy, mov, orb;
716 {
717 VIEW nv;
718 FVECT odir, v1, wip;
719 double d, d1;
720 register int li;
721 /* start with old view */
722 copystruct(&nv, &odev.v);
723 /* orient our motion */
724 if (viewray(v1, odir, &odev.v,
725 (dx+.5)/odev.hres, (dy+.5)/odev.vres) < -FTINY)
726 return(0); /* outside view */
727 if (mov | orb) { /* moving relative to geometry */
728 d = getdistance(dx, dy, odir); /* distance from front plane */
729 #ifdef DOBJ
730 d1 = dobj_trace(NULL, v1, odir);
731 if (d1 < d)
732 d = d1;
733 #endif
734 if (d >= .99*FHUGE)
735 d = 0.5*(dev_zmax+dev_zmin); /* just guess */
736 VSUM(wip, v1, odir, d);
737 VSUB(odir, wip, odev.v.vp);
738 } else /* panning with constant viewpoint */
739 VCOPY(nv.vdir, odir);
740 if (orb && mov) { /* orbit left/right */
741 spinvector(odir, odir, nv.vup, d=MOVDEG*PI/180.*mov);
742 VSUM(nv.vp, wip, odir, -1.);
743 spinvector(nv.vdir, nv.vdir, nv.vup, d);
744 } else if (orb) { /* orbit up/down */
745 fcross(v1, odir, nv.vup);
746 if (normalize(v1) == 0.)
747 return(0);
748 spinvector(odir, odir, v1, d=MOVDEG*PI/180.*orb);
749 VSUM(nv.vp, wip, odir, -1.);
750 spinvector(nv.vdir, nv.vdir, v1, d);
751 } else if (mov) { /* move forward/backward */
752 d = MOVPCT/100. * mov;
753 VSUM(nv.vp, nv.vp, odir, d);
754 }
755 if (!mov ^ !orb && viewflags&VWHEADLOCK) { /* restore height */
756 VSUM(v1, odev.v.vp, nv.vp, -1.);
757 d = DOT(v1, nv.vup);
758 VSUM(nv.vp, nv.vp, odev.v.vup, d);
759 }
760 if (setview(&nv) != NULL)
761 return(0); /* illegal view */
762 dev_view(&nv);
763 inpresflags |= DFL(DC_SETVIEW);
764 return(1);
765 }
766
767
768 static
769 getframe(ebut) /* get focus frame */
770 XButtonPressedEvent *ebut;
771 {
772 int startx = ebut->x, starty = ebut->y;
773 int endx, endy;
774
775 XMaskEvent(ourdisplay, ButtonReleaseMask, levptr(XEvent));
776 endx = levptr(XButtonReleasedEvent)->x;
777 endy = levptr(XButtonReleasedEvent)->y;
778 if (endx == startx | endy == starty) {
779 XBell(ourdisplay, 0);
780 return;
781 }
782 if (endx < startx) {register int c = endx; endx = startx; startx = c;}
783 if (endy < starty) {register int c = endy; endy = starty; starty = c;}
784 sprintf(odev_args, "%.3f %.3f %.3f %.3f",
785 (startx+.5)/odev.hres, 1.-(endy+.5)/odev.vres,
786 (endx+.5)/odev.hres, 1.-(starty+.5)/odev.vres);
787 inpresflags |= DFL(DC_FOCUS);
788 }
789
790
791 static
792 waitabit() /* pause a moment */
793 {
794 struct timespec ts;
795 ts.tv_sec = 0;
796 ts.tv_nsec = 50000000;
797 nanosleep(&ts, NULL);
798 }
799
800
801 static
802 getmove(ebut) /* get view change */
803 XButtonPressedEvent *ebut;
804 {
805 int movdir = MOVDIR(ebut->button);
806 int movorb = MOVORB(ebut->state);
807 int ndrawn;
808 Window rootw, childw;
809 int rootx, rooty, wx, wy;
810 unsigned int statemask;
811
812 XNoOp(ourdisplay); /* makes sure we're not idle */
813
814 viewflags &= ~VWSTEADY; /* flag moving view */
815 setglpersp(); /* start us off in perspective */
816 while (!XCheckMaskEvent(ourdisplay,
817 ButtonReleaseMask, levptr(XEvent))) {
818 /* pause so as not to move too fast */
819 waitabit();
820 /* get cursor position */
821 if (!XQueryPointer(ourdisplay, gwind, &rootw, &childw,
822 &rootx, &rooty, &wx, &wy, &statemask))
823 break; /* on another screen */
824 /* compute view motion */
825 if (!moveview(wx, odev.vres-1-wy, movdir, movorb)) {
826 sleep(1);
827 continue; /* cursor in bad place */
828 }
829 draw_grids(1); /* redraw grid */
830 #ifdef STEREO
831 pushright();
832 draw_grids(1);
833 ndrawn = gmDrawGeom();
834 #ifdef DOBJ
835 ndrawn += dobj_render();
836 #endif
837 popright();
838 #endif
839 /* redraw octrees */
840 ndrawn = gmDrawGeom();
841 #ifdef DOBJ
842 ndrawn += dobj_render(); /* redraw objects */
843 #endif
844 glXSwapBuffers(ourdisplay, gwind);
845 if (!ndrawn)
846 sleep(1); /* for reasonable interaction */
847 }
848 if (!(inpresflags & DFL(DC_SETVIEW))) { /* do final motion */
849 movdir = MOVDIR(levptr(XButtonReleasedEvent)->button);
850 wx = levptr(XButtonReleasedEvent)->x;
851 wy = levptr(XButtonReleasedEvent)->y;
852 moveview(wx, odev.vres-1-wy, movdir, movorb);
853 }
854 viewflags |= VWSTEADY; /* done goofing around */
855 }
856
857
858 static
859 setglpersp() /* set perspective view in GL */
860 {
861 double d, xmin, xmax, ymin, ymax;
862 GLfloat vec[4];
863 double depthlim[2];
864 /* set depth limits */
865 gmDepthLimit(depthlim, odev.v.vp, odev.v.vdir);
866 if (depthlim[0] >= depthlim[1]) {
867 dev_zmin = 1.;
868 dev_zmax = 100.;
869 } else {
870 dev_zmin = 0.5*depthlim[0];
871 dev_zmax = 1.25*depthlim[1];
872 if (dev_zmin > dev_zmax/5.)
873 dev_zmin = dev_zmax/5.;
874 }
875 if (odev.v.vfore > FTINY)
876 dev_zmin = odev.v.vfore;
877 if (odev.v.vaft > FTINY)
878 dev_zmax = odev.v.vaft;
879 if (dev_zmin*500. < dev_zmax)
880 dev_zmin = dev_zmax/500.;
881 setzrat();
882 xmax = dev_zmin * tan(PI/180./2. * odev.v.horiz);
883 xmin = -xmax;
884 d = odev.v.hoff * (xmax - xmin);
885 xmin += d; xmax += d;
886 ymax = dev_zmin * tan(PI/180./2. * odev.v.vert);
887 ymin = -ymax;
888 d = odev.v.voff * (ymax - ymin);
889 ymin += d; ymax += d;
890 /* set view matrix */
891 glMatrixMode(GL_PROJECTION);
892 glLoadIdentity();
893 glFrustum(xmin, xmax, ymin, ymax, dev_zmin, dev_zmax);
894 gluLookAt(odev.v.vp[0], odev.v.vp[1], odev.v.vp[2],
895 odev.v.vp[0] + odev.v.vdir[0],
896 odev.v.vp[1] + odev.v.vdir[1],
897 odev.v.vp[2] + odev.v.vdir[2],
898 odev.v.vup[0], odev.v.vup[1], odev.v.vup[2]);
899 checkglerr("setting perspective view");
900 vec[0] = vec[1] = vec[2] = 0.; vec[3] = 1.;
901 glLightModelfv(GL_LIGHT_MODEL_AMBIENT, vec);
902 vec[0] = -odev.v.vdir[0];
903 vec[1] = -odev.v.vdir[1];
904 vec[2] = -odev.v.vdir[2];
905 vec[3] = 0.;
906 glLightfv(GL_LIGHT0, GL_POSITION, vec);
907 vec[0] = vec[1] = vec[2] = .7; vec[3] = 1.;
908 glLightfv(GL_LIGHT0, GL_SPECULAR, vec);
909 glLightfv(GL_LIGHT0, GL_DIFFUSE, vec);
910 vec[0] = vec[1] = vec[2] = .3; vec[3] = 1.;
911 glLightfv(GL_LIGHT0, GL_AMBIENT, vec);
912 glEnable(GL_LIGHT0);
913 glEnable(GL_LIGHTING); /* light our GL objects */
914 glShadeModel(GL_SMOOTH);
915 viewflags &= ~VWORTHO;
916 viewflags |= VWPERSP;
917 }
918
919
920 static
921 setglortho() /* set up orthographic view for cone drawing */
922 {
923 glDrawBuffer(GL_FRONT); /* use single-buffer mode */
924 /* set view matrix */
925 glMatrixMode(GL_PROJECTION);
926 glLoadIdentity();
927 glOrtho(0., (double)odev.hres, 0., (double)odev.vres,
928 0.001*OMAXDEPTH, 1.001*(-OMAXDEPTH));
929 checkglerr("setting orthographic view");
930 glDisable(GL_LIGHTING); /* cones are constant color */
931 glShadeModel(GL_FLAT);
932 viewflags &= ~VWPERSP;
933 viewflags |= VWORTHO;
934 }
935
936
937 static
938 wipeclean() /* prepare for redraw */
939 {
940 glDrawBuffer(GL_BACK); /* use double-buffer mode */
941 glReadBuffer(GL_BACK);
942 /* clear buffers */
943 #ifdef STEREO
944 setstereobuf(STEREO_BUFFER_RIGHT);
945 glClear(GL_DEPTH_BUFFER_BIT|GL_COLOR_BUFFER_BIT);
946 setstereobuf(STEREO_BUFFER_LEFT);
947 #endif
948 glClear(GL_DEPTH_BUFFER_BIT|GL_COLOR_BUFFER_BIT);
949 freedepth();
950 if ((viewflags&(VWCHANGE|VWSTEADY)) ==
951 (VWCHANGE|VWSTEADY)) { /* clear samples if new */
952 odClean();
953 viewflags &= ~VWCHANGE; /* change noted */
954 } else if (viewflags & VWSTEADY)
955 odRedrawAll();
956 setglpersp(); /* reset view & clipping planes */
957 }
958
959
960 static
961 getkey(ekey) /* get input key */
962 register XKeyPressedEvent *ekey;
963 {
964 Window rootw, childw;
965 int rootx, rooty, wx, wy;
966 unsigned int statemask;
967 int n;
968 char buf[8];
969
970 n = XLookupString(ekey, buf, sizeof(buf), NULL, NULL);
971 if (n != 1)
972 return;
973 switch (buf[0]) {
974 case 'h': /* turn on height motion lock */
975 viewflags |= VWHEADLOCK;
976 return;
977 case 'H': /* turn off height motion lock */
978 viewflags &= ~VWHEADLOCK;
979 return;
980 case 'l': /* retrieve last view */
981 inpresflags |= DFL(DC_LASTVIEW);
982 return;
983 case 'p': /* pause computation */
984 inpresflags |= DFL(DC_PAUSE);
985 return;
986 case 'v': /* spit out view */
987 inpresflags |= DFL(DC_GETVIEW);
988 return;
989 case 'f': /* frame view position */
990 if (!XQueryPointer(ourdisplay, gwind, &rootw, &childw,
991 &rootx, &rooty, &wx, &wy, &statemask))
992 return; /* on another screen */
993 sprintf(odev_args, "%.4f %.4f", (wx+.5)/odev.hres,
994 1.-(wy+.5)/odev.vres);
995 inpresflags |= DFL(DC_FOCUS);
996 return;
997 case 'F': /* unfocus */
998 odev_args[0] = '\0';
999 inpresflags |= DFL(DC_FOCUS);
1000 return;
1001 case '\n':
1002 case '\r': /* resume computation */
1003 inpresflags |= DFL(DC_RESUME);
1004 return;
1005 case CTRL('R'): /* redraw screen */
1006 odRemap(0); /* new tone mapping */
1007 glClear(GL_DEPTH_BUFFER_BIT);
1008 #ifdef STEREO
1009 setstereobuf(STEREO_BUFFER_RIGHT);
1010 glClear(GL_DEPTH_BUFFER_BIT);
1011 setstereobuf(STEREO_BUFFER_LEFT);
1012 #endif
1013 return;
1014 case CTRL('L'): /* refresh from server */
1015 if (inpresflags & DFL(DC_REDRAW))
1016 return; /* already called */
1017 XRaiseWindow(ourdisplay, gwind);
1018 XFlush(ourdisplay); /* raise up window */
1019 sleep(1); /* wait for restacking */
1020 dev_clear(); /* clear buffer and samples */
1021 odRemap(1); /* start fresh histogram */
1022 inpresflags |= DFL(DC_REDRAW); /* resend values from server */
1023 return;
1024 case 'K': /* kill rtrace process(es) */
1025 inpresflags |= DFL(DC_KILL);
1026 break;
1027 case 'R': /* restart rtrace */
1028 inpresflags |= DFL(DC_RESTART);
1029 break;
1030 case 'C': /* clobber holodeck */
1031 inpresflags |= DFL(DC_CLOBBER);
1032 break;
1033 case 'q': /* quit the program */
1034 inpresflags |= DFL(DC_QUIT);
1035 return;
1036 default:
1037 XBell(ourdisplay, 0);
1038 return;
1039 }
1040 }
1041
1042
1043 static
1044 fixwindow(eexp) /* repair damage to window */
1045 register XExposeEvent *eexp;
1046 {
1047 int xmin, ymin, xmax, ymax;
1048
1049 if (odev.hres == 0 | odev.vres == 0) { /* first exposure */
1050 resizewindow((XConfigureEvent *)eexp);
1051 return;
1052 }
1053 xmin = eexp->x; xmax = eexp->x + eexp->width;
1054 ymin = odev.vres - eexp->y - eexp->height; ymax = odev.vres - eexp->y;
1055
1056 if (xmin <= 0 && xmax >= odev.hres-1 &&
1057 ymin <= 0 && ymax >= odev.vres) {
1058 DCHECK(eexp->count, WARNING, "multiple clear in fixwindow");
1059 wipeclean(); /* make sure we're go */
1060 return;
1061 }
1062 /* clear portion of depth */
1063 glPushAttrib(GL_DEPTH_BUFFER_BIT|GL_COLOR_BUFFER_BIT);
1064 glColorMask(GL_FALSE, GL_FALSE, GL_FALSE, GL_FALSE);
1065 glDepthFunc(GL_ALWAYS);
1066 glBegin(GL_POLYGON);
1067 glVertex3i(xmin, ymin, OMAXDEPTH);
1068 glVertex3i(xmax, ymin, OMAXDEPTH);
1069 glVertex3i(xmax, ymax, OMAXDEPTH);
1070 glVertex3i(xmin, ymax, OMAXDEPTH);
1071 glEnd();
1072 #ifdef STEREO
1073 setstereobuf(STEREO_BUFFER_RIGHT);
1074 glBegin(GL_POLYGON);
1075 glVertex3i(xmin, ymin, OMAXDEPTH);
1076 glVertex3i(xmax, ymin, OMAXDEPTH);
1077 glVertex3i(xmax, ymax, OMAXDEPTH);
1078 glVertex3i(xmin, ymax, OMAXDEPTH);
1079 glEnd();
1080 odRedraw(1, xmin, ymin, xmax, ymax);
1081 setstereobuf(STEREO_BUFFER_LEFT);
1082 #endif
1083 glPopAttrib();
1084 odRedraw(0, xmin, ymin, xmax, ymax);
1085 }
1086
1087
1088 static
1089 resizewindow(ersz) /* resize window */
1090 register XConfigureEvent *ersz;
1091 {
1092 glViewport(0, 0, ersz->width, ersz->height);
1093
1094 if (ersz->width == odev.hres && ersz->height == odev.vres)
1095 return;
1096
1097 odev.hres = ersz->width;
1098 odev.vres = ersz->height;
1099
1100 odev.v.horiz = 2.*180./PI * atan(0.5/VIEWDIST*pwidth*odev.hres);
1101 odev.v.vert = 2.*180./PI * atan(0.5/VIEWDIST*pheight*odev.vres);
1102
1103 inpresflags |= DFL(DC_SETVIEW);
1104 viewflags |= VWCHANGE;
1105 }
