root/radiance/ray/src/hd/rhd_ogl.c
Wed Jun 7 17:52:04 2006 UTC (17 years, 11 months ago) by schorsch
Changes since 3.29: +9 -3 lines
Diff to previous 3.29 , to selected 3.14
Tue May 23 13:01:07 2006 UTC (18 years ago) by greg
Changes since 3.28: +4 -1 lines
Diff to previous 3.28 , to selected 3.14
Added missing variable needed for -DSTEREO
Sun Jul 24 19:53:08 2005 UTC (18 years, 10 months ago) by greg
Changes since 3.27: +3 -3 lines
Diff to previous 3.27 , to selected 3.14
Fri Jan 21 00:52:59 2005 UTC (19 years, 4 months ago) by greg
Changes since 3.26: +21 -6 lines
Diff to previous 3.26 , to selected 3.14
Fri Jan 7 20:33:02 2005 UTC (19 years, 4 months ago) by greg
Changes since 3.25: +6 -3 lines
Diff to previous 3.25 , to selected 3.14
Thu Feb 12 18:55:50 2004 UTC (20 years, 3 months ago) by greg
Changes since 3.24: +2 -1 lines
Diff to previous 3.24 , to selected 3.14
Changes since 3.23: +127 -80 lines
Diff to previous 3.23 , to selected 3.14
Ansification and prototypes.
Fri Sep 19 18:33:05 2003 UTC (20 years, 8 months ago) by greg
Changes since 3.22: +4 -2 lines
Diff to previous 3.22 , to selected 3.14
Changes since 3.21: +5 -5 lines
Diff to previous 3.21 , to selected 3.14
Mon May 19 16:32:18 2003 UTC (21 years ago) by greg
Changes since 3.20: +0 -1 lines
Diff to previous 3.20 , to selected 3.14
Eliminated unnecessary and problematic external function declarations
Mon Apr 14 16:56:19 2003 UTC (21 years, 1 month ago) by greg
Changes since 3.19: +1 -1 lines
Diff to previous 3.19 , to selected 3.14
Fixed interaction delay timing (supposed to be 50ms -- was 5ms)
Changes since 3.18: +18 -8 lines
Diff to previous 3.18 , to selected 3.14
Mon Jul 19 20:15:16 1999 UTC (24 years, 10 months ago) by gwlarson
Diff to previous 3.17 , to selected 3.14
changed fore/aft clipping limit
Mon Jun 28 16:30:22 1999 UTC (24 years, 11 months ago) by gwlarson
Changes since 3.16: +1 -1 lines
Diff to previous 3.16 , to selected 3.14
eliminated unnecessary argument to setglpersp()
Mon Mar 8 17:31:49 1999 UTC (25 years, 2 months ago) by gwlarson
Changes since 3.15: +0 -1 lines
Diff to previous 3.15 , to selected 3.14
Tue Jan 5 18:16:17 1999 UTC (25 years, 4 months ago) by gwlarson
Changes since 3.14: +10 -7 lines
Diff to previous 3.14
made VIEWDIST, MINWIDTH and BORWIDTH command-line definable
Revision 3.14 - (view) (download) (annotate) - [selected]
Sun Jan 3 13:40:25 1999 UTC (25 years, 4 months ago) by gwlarson
Changes since 3.13: +6 -6 lines
Diff to previous 3.13
fixed bug in stereo view computation after window resize
Fri Jan 1 10:41:28 1999 UTC (25 years, 4 months ago) by gwlarson
Diff to previous 3.12 , to selected 3.14
fixed aft clipping plane problem
Thu Dec 31 13:24:36 1998 UTC (25 years, 4 months ago) by gwlarson
Changes since 3.11: +12 -6 lines
Diff to previous 3.11 , to selected 3.14
fixed redrawing of local objects in OpenGL driver
Wed Dec 30 17:13:20 1998 UTC (25 years, 4 months ago) by gwlarson
Changes since 3.10: +9 -17 lines
Diff to previous 3.10 , to selected 3.14
fixed redraw when window is remapped
increased number of samples allocated
turned off incremental updates by default (RAYQLEN)
Wed Dec 23 17:43:42 1998 UTC (25 years, 5 months ago) by gwlarson
Changes since 3.9: +34 -14 lines
Diff to previous 3.9 , to selected 3.14
numerous bug fixes for stereo and object-drawing drivers
Tue Dec 22 12:59:17 1998 UTC (25 years, 5 months ago) by gwlarson
Changes since 3.8: +20 -56 lines
Diff to previous 3.8 , to selected 3.14
changed portal code to write and read back buffer
Tue Dec 22 10:18:44 1998 UTC (25 years, 5 months ago) by gwlarson
Changes since 3.7: +22 -16 lines
Diff to previous 3.7 , to selected 3.14
improved portal code
Tue Dec 22 09:40:32 1998 UTC (25 years, 5 months ago) by gwlarson
Changes since 3.6: +46 -34 lines
Diff to previous 3.6 , to selected 3.14
simplified view conditions with viewflags variable
Mon Dec 21 19:17:28 1998 UTC (25 years, 5 months ago) by gwlarson
Changes since 3.5: +40 -34 lines
Diff to previous 3.5 , to selected 3.14
switched to double-buffered display
Mon Dec 21 15:31:49 1998 UTC (25 years, 5 months ago) by gwlarson
Changes since 3.4: +6 -9 lines
Diff to previous 3.4 , to selected 3.14
replaced error calls with CHECK in some places
Mon Dec 21 15:10:13 1998 UTC (25 years, 5 months ago) by gwlarson
Changes since 3.3: +5 -9 lines
Diff to previous 3.3 , to selected 3.14
fixed problem with initial drawing
Mon Dec 21 11:42:38 1998 UTC (25 years, 5 months ago) by gwlarson
Changes since 3.2: +62 -29 lines
Diff to previous 3.2 , to selected 3.14
got portals working with or without alpha buffer
Sun Dec 20 20:36:48 1998 UTC (25 years, 5 months ago) by gwlarson
Changes since 3.1: +82 -33 lines
Diff to previous 3.1 , to selected 3.14
added port drawing into alpha buffer mask
changed tone remapping call
Fri Dec 18 11:55:19 1998 UTC (25 years, 5 months ago) by gwlarson
Diff to selected 3.14
