root/radiance/ray/src/hd/rhd_ogl.c
Revision: 3.16
Committed: Mon Mar 8 17:31:49 1999 UTC (26 years, 2 months ago) by gwlarson
Changes since 3.15: +0 -1 lines
1 /* Copyright (c) 1999 Silicon Graphics, Inc. */
2
3 #ifndef lint
4 static char SCCSid[] = "$SunId$ SGI";
5 #endif
6
7 /*
8 * OpenGL driver for holodeck display.
9 * Based on GLX driver using T-mesh.
10 *
11 * Define symbol STEREO for stereo viewing.
12 * Define symbol DOBJ for display object viewing.
13 */
14
15 #ifdef NOSTEREO
16 #ifdef STEREO
17 #undef STEREO
18 #else
19 #undef NOSTEREO
20 #endif
21 #endif
22
23 #include "standard.h"
24
25 #include <GL/glx.h>
26 #include <GL/glu.h>
27 #ifdef STEREO
28 #include <X11/extensions/SGIStereo.h>
29 #endif
30
31 #include "rhd_odraw.h"
32 #ifdef DOBJ
33 #include "rhdobj.h"
34 #endif
35
36 #include "x11icon.h"
37
38 #ifndef RAYQLEN
39 #define RAYQLEN 0 /* max. rays to queue before flush */
40 #endif
41 #ifndef MINWIDTH
42 #define MINWIDTH 480 /* minimum graphics window width */
43 #define MINHEIGHT 400 /* minimum graphics window height */
44 #endif
45 #ifndef VIEWDIST
46 #define VIEWDIST 356 /* assumed viewing distance (mm) */
47 #endif
48 #ifndef BORWIDTH
49 #define BORWIDTH 5 /* border width */
50 #endif
51
52 #ifndef FEQ
53 #define FEQ(a,b) ((a)-(b) <= FTINY && (a)-(b) >= -FTINY)
54 #endif
55
56 #define VWHEADLOCK 01 /* head position is locked flag */
57 #define VWPERSP 02 /* perspective view is set */
58 #define VWORTHO 04 /* orthographic view is set */
59 #define VWCHANGE 010 /* view has changed */
60 #define VWSTEADY 020 /* view is now steady */
61 #define VWMAPPED 040 /* window is mapped */
62
63 #define GAMMA 1.4 /* default gamma correction */
64
65 #define FRAMESTATE(s) (((s)&(ShiftMask|ControlMask))==(ShiftMask|ControlMask))
66
67 #define MOVPCT 7 /* percent distance to move /frame */
68 #define MOVDIR(b) ((b)==Button1 ? 1 : (b)==Button2 ? 0 : -1)
69 #define MOVDEG (-5) /* degrees to orbit CW/down /frame */
70 #define MOVORB(s) ((s)&ShiftMask ? 1 : (s)&ControlMask ? -1 : 0)
71
72 #define setstereobuf(bid) (glXWaitGL(), \
73 XSGISetStereoBuffer(ourdisplay, gwind, bid), \
74 glXWaitX())
75
76 #define ourscreen DefaultScreen(ourdisplay)
77 #define ourroot RootWindow(ourdisplay,ourscreen)
78 #define ourmask (StructureNotifyMask|ExposureMask|KeyPressMask|\
79 ButtonPressMask|ButtonReleaseMask)
80
81 #define levptr(etype) ((etype *)&currentevent)
82
83 struct driver odev; /* global device driver structure */
84
85 char odev_args[64]; /* command arguments */
86
87 static GLfloat *depthbuffer = NULL; /* depth buffer */
88
89 #ifdef STEREO
90 static VIEW vwright; /* right eye view */
91 static GLfloat *depthright = NULL; /* right depth buffer */
92 #endif
93
94 static int rayqleft = 0; /* rays left to queue before flush */
95
96 static XEvent currentevent; /* current event */
97
98 static unsigned long ourblack=0, ourwhite=~0;
99
100 static Display *ourdisplay = NULL; /* our display */
101 static XVisualInfo *ourvinf; /* our visual information */
102 static Window gwind = 0; /* our graphics window */
103 static GLXContext gctx; /* our GLX context */
104
105 static double pwidth, pheight; /* pixel dimensions (mm) */
106
107 static double dev_zmin, dev_zmax; /* fore and aft clipping plane dist. */
108 static double dev_zrat; /* (1. - dev_zmin/dev_zmax) */
109
110 #define setzrat() (dev_zrat = 1. - dev_zmin/dev_zmax)
111 #define mapdepth(d) ((d)>0.9995 ? FHUGE : dev_zmin/(1.-(d)*dev_zrat))
112
113 static int inpresflags; /* input result flags */
114
115 static int viewflags; /* what's happening with view */
116
117 static int resizewindow(), getevent(), getkey(), moveview(), wipeclean(),
118 xferdepth(), freedepth(), setglortho(),
119 setglpersp(), getframe(), getmove(), fixwindow(), mytmflags();
120
121 static double getdistance();
122
123 #ifdef STEREO
124 static int pushright(), popright();
125 #endif
126
127 extern int gmPortals; /* GL portal list id */
128
129 extern time_t time();
130
131
132 dev_open(id) /* initialize GLX driver */
133 char *id;
134 {
135 extern char *getenv();
136 static RGBPRIMS myprims = STDPRIMS;
137 static int atlBest[] = {GLX_RGBA, GLX_DOUBLEBUFFER,
138 GLX_RED_SIZE,8, GLX_GREEN_SIZE,8,
139 GLX_BLUE_SIZE,8, GLX_DEPTH_SIZE,15, None};
140 static int atlOK[] = {GLX_RGBA, GLX_DOUBLEBUFFER,
141 GLX_RED_SIZE,4, GLX_GREEN_SIZE,4,
142 GLX_BLUE_SIZE,4, GLX_DEPTH_SIZE,15, None};
143 char *ev;
144 double gamval = GAMMA;
145 RGBPRIMP dpri = stdprims;
146 XSetWindowAttributes ourwinattr;
147 XWMHints ourxwmhints;
148 XSizeHints oursizhints;
149 /* check for unsupported stereo */
150 #ifdef NOSTEREO
151 error(INTERNAL, "stereo display driver unavailable");
152 #endif
153 /* open display server */
154 ourdisplay = XOpenDisplay(NULL);
155 CHECK(ourdisplay==NULL, USER,
156 "cannot open X-windows; DISPLAY variable set?");
157 #ifdef STEREO
158 switch (XSGIQueryStereoMode(ourdisplay, ourroot)) {
159 case STEREO_TOP:
160 case STEREO_BOTTOM:
161 break;
162 case STEREO_OFF:
163 error(USER,
164 "wrong video mode: run \"/usr/gfx/setmon -n STR_TOP\" first");
165 case X_STEREO_UNSUPPORTED:
166 error(USER, "stereo mode not supported on this screen");
167 default:
168 error(INTERNAL, "unknown stereo mode");
169 }
170 #endif
171 /* find a usable visual */
172 ourvinf = glXChooseVisual(ourdisplay, ourscreen, atlBest);
173 if (ourvinf == NULL)
174 ourvinf = glXChooseVisual(ourdisplay, ourscreen, atlOK);
175 CHECK(ourvinf==NULL, USER, "no suitable visuals available");
176 /* get a context */
177 gctx = glXCreateContext(ourdisplay, ourvinf, NULL, GL_TRUE);
178 /* set gamma and tone mapping */
179 if ((ev = XGetDefault(ourdisplay, "radiance", "gamma")) != NULL
180 || (ev = getenv("DISPLAY_GAMMA")) != NULL)
181 gamval = atof(ev);
182 if ((ev = getenv("DISPLAY_PRIMARIES")) != NULL &&
183 sscanf(ev, "%f %f %f %f %f %f %f %f",
184 &myprims[RED][CIEX],&myprims[RED][CIEY],
185 &myprims[GRN][CIEX],&myprims[GRN][CIEY],
186 &myprims[BLU][CIEX],&myprims[BLU][CIEY],
187 &myprims[WHT][CIEX],&myprims[WHT][CIEY]) >= 6)
188 dpri = myprims;
189 if (tmInit(mytmflags(), dpri, gamval) == NULL)
190 error(SYSTEM, "not enough memory in dev_open");
191 /* open window */
192 ourwinattr.background_pixel = ourblack;
193 ourwinattr.border_pixel = ourblack;
194 ourwinattr.event_mask = ourmask;
195 /* this is stupid */
196 ourwinattr.colormap = XCreateColormap(ourdisplay, ourroot,
197 ourvinf->visual, AllocNone);
198 gwind = XCreateWindow(ourdisplay, ourroot, 0, 0,
199 DisplayWidth(ourdisplay,ourscreen)-2*BORWIDTH,
200 #ifdef STEREO
201 (DisplayHeight(ourdisplay,ourscreen)-2*BORWIDTH)/2,
202 #else
203 DisplayHeight(ourdisplay,ourscreen)-2*BORWIDTH,
204 #endif
205 BORWIDTH, ourvinf->depth, InputOutput, ourvinf->visual,
206 CWBackPixel|CWBorderPixel|CWColormap|CWEventMask, &ourwinattr);
207 CHECK(gwind==0, SYSTEM, "cannot create window");
208 XStoreName(ourdisplay, gwind, id);
209 /* set window manager hints */
210 ourxwmhints.flags = InputHint|IconPixmapHint;
211 ourxwmhints.input = True;
212 ourxwmhints.icon_pixmap = XCreateBitmapFromData(ourdisplay,
213 gwind, x11icon_bits, x11icon_width, x11icon_height);
214 XSetWMHints(ourdisplay, gwind, &ourxwmhints);
215 oursizhints.min_width = MINWIDTH;
216 #ifdef STEREO
217 oursizhints.min_height = MINHEIGHT/2;
218 oursizhints.max_width = DisplayWidth(ourdisplay,ourscreen)-2*BORWIDTH;
219 oursizhints.max_height = (DisplayHeight(ourdisplay,ourscreen) -
220 2*BORWIDTH)/2;
221 oursizhints.flags = PMinSize|PMaxSize;
222 #else
223 oursizhints.min_height = MINHEIGHT;
224 oursizhints.flags = PMinSize;
225 #endif
226 XSetNormalHints(ourdisplay, gwind, &oursizhints);
227 /* set GLX context */
228 glXMakeCurrent(ourdisplay, gwind, gctx);
229 glEnable(GL_DEPTH_TEST);
230 glDepthFunc(GL_LEQUAL);
231 glClearColor(0, 0, 0, 0);
232 glFrontFace(GL_CCW);
233 glDisable(GL_CULL_FACE);
234 glLightModeli(GL_LIGHT_MODEL_TWO_SIDE, GL_TRUE);
235 glPolygonMode(GL_FRONT_AND_BACK, GL_FILL);
236 glPixelStorei(GL_PACK_ALIGNMENT, 1);
237 glPixelStorei(GL_UNPACK_ALIGNMENT, 1);
238 /* figure out sensible view */
239 pwidth = (double)DisplayWidthMM(ourdisplay, ourscreen) /
240 DisplayWidth(ourdisplay, ourscreen);
241 pheight = (double)DisplayHeightMM(ourdisplay, ourscreen) /
242 DisplayHeight(ourdisplay, ourscreen);
243 #ifdef STEREO
244 pheight *= 2.;
245 setstereobuf(STEREO_BUFFER_LEFT);
246 #endif
247 checkglerr("setting rendering parameters");
248 copystruct(&odev.v, &stdview);
249 odev.v.type = VT_PER;
250 viewflags = VWSTEADY; /* view starts static */
251 /* map the window */
252 XMapWindow(ourdisplay, gwind);
253 dev_input(); /* sets size and view angles */
254 if (!odInit(DisplayWidth(ourdisplay,ourscreen) *
255 DisplayHeight(ourdisplay,ourscreen) / 3))
256 error(SYSTEM, "insufficient memory for value storage");
257 odev.name = id;
258 odev.firstuse = 1; /* can't recycle samples */
259 odev.ifd = ConnectionNumber(ourdisplay);
260 }
261
262
263 dev_close() /* close our display and free resources */
264 {
265 #ifdef DOBJ
266 dobj_cleanup();
267 #endif
268 freedepth();
269 gmEndGeom();
270 gmEndPortal();
271 odDone();
272 glXMakeCurrent(ourdisplay, None, NULL);
273 glXDestroyContext(ourdisplay, gctx);
274 XDestroyWindow(ourdisplay, gwind);
275 gwind = 0;
276 XCloseDisplay(ourdisplay);
277 ourdisplay = NULL;
278 tmDone(NULL);
279 odev.v.type = 0;
280 odev.hres = odev.vres = 0;
281 odev.ifd = -1;
282 }
283
284
285 dev_clear() /* clear our representation */
286 {
287 viewflags |= VWCHANGE; /* pretend our view has changed */
288 wipeclean(); /* clean off display and samples */
289 dev_flush(); /* redraw geometry & get depth */
290 rayqleft = 0; /* hold off update */
291 }
292
293
294 int
295 dev_view(nv) /* assign new driver view */
296 register VIEW *nv;
297 {
298 double d;
299
300 if (nv->type != VT_PER || /* check view legality */
301 nv->horiz > 160. || nv->vert > 160.) {
302 error(COMMAND, "illegal view type/angle");
303 nv->type = odev.v.type;
304 nv->horiz = odev.v.horiz;
305 nv->vert = odev.v.vert;
306 return(0);
307 }
308 if (nv != &odev.v) {
309 /* resize window? */
310 if (!FEQ(nv->horiz,odev.v.horiz) ||
311 !FEQ(nv->vert,odev.v.vert)) {
312 int dw = DisplayWidth(ourdisplay,ourscreen);
313 int dh = DisplayHeight(ourdisplay,ourscreen);
314
315 dw -= 25; /* for window frame */
316 dh -= 50;
317 #ifdef STEREO
318 dh /= 2;
319 #endif
320 odev.hres = 2.*VIEWDIST/pwidth *
321 tan(PI/180./2.*nv->horiz);
322 odev.vres = 2.*VIEWDIST/pheight *
323 tan(PI/180./2.*nv->vert);
324 if (odev.hres > dw) {
325 odev.vres = dw * odev.vres / odev.hres;
326 odev.hres = dw;
327 }
328 if (odev.vres > dh) {
329 odev.hres = dh * odev.hres / odev.vres;
330 odev.vres = dh;
331 }
332 XResizeWindow(ourdisplay, gwind, odev.hres, odev.vres);
333 dev_input(); /* get resize event */
334 }
335 copystruct(&odev.v, nv); /* setview() already called */
336 viewflags |= VWCHANGE;
337 }
338 #ifdef STEREO
339 copystruct(&vwright, nv);
340 d = eyesepdist / sqrt(nv->hn2);
341 VSUM(vwright.vp, nv->vp, nv->hvec, d);
342 /* setview(&vwright); -- Unnecessary */
343 #endif
344 wipeclean();
345 return(1);
346 }
347
348
349 dev_section(gfn, pfn) /* add octree for geometry rendering */
350 char *gfn, *pfn;
351 {
352 extern char *index();
353 char *cp;
354
355 if (gfn == NULL) {
356 gmEndGeom();
357 gmEndPortal();
358 wipeclean(); /* new geometry, so redraw it */
359 return;
360 }
361 if (access(gfn, R_OK) == 0)
362 gmNewGeom(gfn);
363 #ifdef DEBUG
364 else {
365 sprintf(errmsg, "cannot load octree \"%s\"", gfn);
366 error(WARNING, errmsg);
367 }
368 #endif
369 if (pfn != NULL)
370 gmNewPortal(pfn);
371 }
372
373
374 dev_auxcom(cmd, args) /* process an auxiliary command */
375 char *cmd, *args;
376 {
377 #ifdef DOBJ
378 int vischange;
379
380 if ((vischange = dobj_command(cmd, args)) >= 0) {
381 if (vischange) {
382 imm_mode = beam_sync(1) > 0;
383 dev_clear();
384 }
385 return;
386 }
387 #endif
388 sprintf(errmsg, "%s: unknown command", cmd);
389 error(COMMAND, errmsg);
390 }
391
392
393 VIEW *
394 dev_auxview(n, hvres) /* return nth auxiliary view */
395 int n;
396 int hvres[2];
397 {
398 hvres[0] = odev.hres; hvres[1] = odev.vres;
399 if (n == 0)
400 return(&odev.v);
401 #ifdef STEREO
402 if (n == 1)
403 return(&vwright);
404 #endif
405 return(NULL);
406 }
407
408
409 int
410 dev_input() /* get X11 input */
411 {
412 inpresflags = 0;
413
414 do
415 getevent();
416
417 while (XPending(ourdisplay) > 0);
418
419 odev.inpready = 0;
420
421 return(inpresflags);
422 }
423
424
425 dev_value(c, d, p) /* add a pixel value to our texture */
426 COLR c;
427 FVECT d, p;
428 {
429 #ifdef DOBJ
430 if (dobj_lightsamp != NULL) { /* in light source sampling */
431 (*dobj_lightsamp)(c, d, p);
432 return;
433 }
434 #endif
435 odSample(c, d, p); /* add to display representation */
436 if (!--rayqleft)
437 dev_flush(); /* flush output */
438 }
439
440
441 int
442 dev_flush() /* flush output as appropriate */
443 {
444 int ndrawn;
445
446 if ((viewflags&(VWMAPPED|VWPERSP)) == (VWMAPPED|VWPERSP)) {
447 #ifdef STEREO
448 pushright(); /* draw right eye */
449 ndrawn = gmDrawGeom();
450 #ifdef DOBJ
451 ndrawn += dobj_render();
452 #endif
453 checkglerr("rendering right eye");
454 popright(); /* draw left eye */
455 #endif
456 ndrawn = gmDrawGeom();
457 #ifdef DOBJ
458 ndrawn += dobj_render();
459 #endif
460 glXSwapBuffers(ourdisplay, gwind);
461 checkglerr("rendering base view");
462 }
463 if ((viewflags&(VWMAPPED|VWSTEADY|VWPERSP|VWORTHO)) ==
464 (VWMAPPED|VWSTEADY|VWPERSP)) {
465 /* first time after steady */
466 if (ndrawn)
467 xferdepth(); /* transfer and clear depth */
468 setglortho(); /* set orthographic view */
469
470 }
471 if ((viewflags&(VWMAPPED|VWSTEADY|VWPERSP|VWORTHO)) ==
472 (VWMAPPED|VWSTEADY|VWORTHO)) {
473 /* else update cones */
474 #ifdef STEREO
475 pushright();
476 odUpdate(1); /* draw right eye */
477 popright();
478 #endif
479 odUpdate(0); /* draw left eye */
480 glFlush(); /* flush OpenGL */
481 }
482 rayqleft = RAYQLEN;
483 /* flush X11 and return # pending */
484 return(odev.inpready = XPending(ourdisplay));
485 }
486
487
488 checkglerr(where) /* check for GL or GLU error */
489 char *where;
490 {
491 register GLenum errcode;
492
493 while ((errcode = glGetError()) != GL_NO_ERROR) {
494 sprintf(errmsg, "OpenGL error %s: %s",
495 where, gluErrorString(errcode));
496 error(WARNING, errmsg);
497 }
498 }
499
500
501 static
502 xferdepth() /* load and clear depth buffer */
503 {
504 register GLfloat *dbp;
505 register GLubyte *pbuf;
506
507 if (depthbuffer == NULL) { /* allocate private depth buffer */
508 #ifdef STEREO
509 depthright = (GLfloat *)malloc(
510 odev.hres*odev.vres*sizeof(GLfloat));
511 #endif
512 depthbuffer = (GLfloat *)malloc(
513 odev.hres*odev.vres*sizeof(GLfloat));
514 CHECK(depthbuffer==NULL, SYSTEM, "out of memory in xferdepth");
515 }
516 /* allocate alpha buffer for portals */
517 if (gmPortals)
518 pbuf = (GLubyte *)malloc(odev.hres*odev.vres*sizeof(GLubyte));
519 else
520 pbuf = NULL;
521 #ifdef STEREO
522 pushright();
523 glReadPixels(0, 0, odev.hres, odev.vres,
524 GL_DEPTH_COMPONENT, GL_FLOAT, depthright);
525 if (pbuf != NULL) {
526 glClear(GL_COLOR_BUFFER_BIT);
527 gmDrawPortals(0xff, -1, -1, -1);
528 glReadPixels(0, 0, odev.hres, odev.vres,
529 GL_RED, GL_UNSIGNED_BYTE, pbuf);
530 }
531 for (dbp = depthright + odev.hres*odev.vres; dbp-- > depthright; )
532 if (pbuf != NULL && pbuf[dbp-depthright]&0x40)
533 *dbp = FHUGE;
534 else
535 *dbp = mapdepth(*dbp);
536 glClear(GL_DEPTH_BUFFER_BIT);
537 odDepthMap(1, depthright);
538 popright();
539 #endif
540 /* read back depth buffer */
541 glReadPixels(0, 0, odev.hres, odev.vres,
542 GL_DEPTH_COMPONENT, GL_FLOAT, depthbuffer);
543 if (pbuf != NULL) {
544 glClear(GL_COLOR_BUFFER_BIT); /* find portals */
545 gmDrawPortals(0xff, -1, -1, -1);
546 glReadPixels(0, 0, odev.hres, odev.vres,
547 GL_RED, GL_UNSIGNED_BYTE, pbuf);
548 #ifdef DEBUG
549 glXSwapBuffers(ourdisplay, gwind);
550 #endif
551 }
552 for (dbp = depthbuffer + odev.hres*odev.vres; dbp-- > depthbuffer; )
553 if (pbuf != NULL && pbuf[dbp-depthbuffer]&0x40)
554 *dbp = FHUGE;
555 else
556 *dbp = mapdepth(*dbp);
557 glClear(GL_DEPTH_BUFFER_BIT); /* clear system depth buffer */
558 odDepthMap(0, depthbuffer); /* transfer depth data */
559 if (pbuf != NULL)
560 free((char *)pbuf); /* free our portal buffer */
561 }
562
563
564 static
565 freedepth() /* free recorded depth buffer */
566 {
567 if (depthbuffer == NULL)
568 return;
569 #ifdef STEREO
570 odDepthMap(1, NULL);
571 free((char *)depthright);
572 depthright = NULL;
573 #endif
574 odDepthMap(0, NULL);
575 free((char *)depthbuffer);
576 depthbuffer = NULL;
577 }
578
579
580 static double
581 getdistance(dx, dy, direc) /* distance from fore plane along view ray */
582 int dx, dy;
583 FVECT direc;
584 {
585 GLfloat gldepth;
586 double dist;
587
588 if (dx<0 | dx>=odev.hres | dy<0 | dy>=odev.vres)
589 return(FHUGE);
590 if (depthbuffer != NULL)
591 dist = depthbuffer[dy*odev.hres + dx];
592 else {
593 glReadPixels(dx,dy, 1,1, GL_DEPTH_COMPONENT,
594 GL_FLOAT, &gldepth);
595 dist = mapdepth(gldepth);
596 }
597 if (dist >= .99*FHUGE)
598 return(FHUGE);
599 return((dist-odev.v.vfore)/DOT(direc,odev.v.vdir));
600 }
601
602
603 #ifdef STEREO
604 static
605 pushright() /* push on right view & buffer */
606 {
607 double d;
608
609 setstereobuf(STEREO_BUFFER_RIGHT);
610 if (viewflags & VWPERSP) {
611 glMatrixMode(GL_MODELVIEW);
612 glPushMatrix();
613 d = -eyesepdist / sqrt(odev.v.hn2);
614 glTranslated(d*odev.v.hvec[0], d*odev.v.hvec[1],
615 d*odev.v.hvec[2]);
616 checkglerr("setting right view");
617 }
618 }
619
620
621 static
622 popright() /* pop off right view & buffer */
623 {
624 if (viewflags & VWPERSP) {
625 glMatrixMode(GL_MODELVIEW);
626 glPopMatrix();
627 }
628 setstereobuf(STEREO_BUFFER_LEFT);
629 }
630 #endif
631
632
633 static int
634 mytmflags() /* figure out tone mapping flags */
635 {
636 extern char *progname;
637 register char *cp, *tail;
638 /* find basic name */
639 for (cp = tail = progname; *cp; cp++)
640 if (*cp == '/')
641 tail = cp+1;
642 for (cp = tail; *cp && *cp != '.'; cp++)
643 ;
644 #ifdef DEBUG
645 if (cp > tail && cp[-1] == 'h')
646 return(TM_F_HUMAN);
647 else
648 return(TM_F_CAMERA);
649 #else
650 if (cp > tail && cp[-1] == 'h')
651 return(TM_F_HUMAN|TM_F_NOSTDERR);
652 else
653 return(TM_F_CAMERA|TM_F_NOSTDERR);
654 #endif
655 }
656
657
658 static
659 getevent() /* get next event */
660 {
661 XNextEvent(ourdisplay, levptr(XEvent));
662 switch (levptr(XEvent)->type) {
663 case ConfigureNotify:
664 resizewindow(levptr(XConfigureEvent));
665 break;
666 case UnmapNotify:
667 viewflags &= ~VWMAPPED;
668 break;
669 case MapNotify:
670 odRemap(0);
671 viewflags |= VWMAPPED;
672 break;
673 case Expose:
674 fixwindow(levptr(XExposeEvent));
675 break;
676 case KeyPress:
677 getkey(levptr(XKeyPressedEvent));
678 break;
679 case ButtonPress:
680 if (FRAMESTATE(levptr(XButtonPressedEvent)->state))
681 getframe(levptr(XButtonPressedEvent));
682 else
683 getmove(levptr(XButtonPressedEvent));
684 break;
685 }
686 }
687
688
689 static
690 draw3dline(wp) /* draw 3d line in world coordinates */
691 register FVECT wp[2];
692 {
693 glVertex3d(wp[0][0], wp[0][1], wp[0][2]);
694 glVertex3d(wp[1][0], wp[1][1], wp[1][2]);
695 }
696
697
698 static
699 draw_grids(fore) /* draw holodeck section grids */
700 int fore;
701 {
702 glPushAttrib(GL_LIGHTING_BIT|GL_ENABLE_BIT);
703 glDisable(GL_LIGHTING);
704 if (fore)
705 glColor3ub(4, 250, 250);
706 else
707 glColor3ub(0, 0, 0);
708 glBegin(GL_LINES); /* draw each grid line */
709 gridlines(draw3dline);
710 glEnd();
711 checkglerr("drawing grid lines");
712 glPopAttrib();
713 }
714
715
716 static
717 moveview(dx, dy, mov, orb) /* move our view */
718 int dx, dy, mov, orb;
719 {
720 VIEW nv;
721 FVECT odir, v1, wip;
722 double d, d1;
723 register int li;
724 /* start with old view */
725 copystruct(&nv, &odev.v);
726 /* orient our motion */
727 if (viewray(v1, odir, &odev.v,
728 (dx+.5)/odev.hres, (dy+.5)/odev.vres) < -FTINY)
729 return(0); /* outside view */
730 if (mov | orb) { /* moving relative to geometry */
731 d = getdistance(dx, dy, odir); /* distance from front plane */
732 #ifdef DOBJ
733 d1 = dobj_trace(NULL, v1, odir);
734 if (d1 < d)
735 d = d1;
736 #endif
737 if (d >= .99*FHUGE)
738 d = 0.5*(dev_zmax+dev_zmin); /* just guess */
739 VSUM(wip, v1, odir, d);
740 VSUB(odir, wip, odev.v.vp);
741 } else /* panning with constant viewpoint */
742 VCOPY(nv.vdir, odir);
743 if (orb && mov) { /* orbit left/right */
744 spinvector(odir, odir, nv.vup, d=MOVDEG*PI/180.*mov);
745 VSUM(nv.vp, wip, odir, -1.);
746 spinvector(nv.vdir, nv.vdir, nv.vup, d);
747 } else if (orb) { /* orbit up/down */
748 fcross(v1, odir, nv.vup);
749 if (normalize(v1) == 0.)
750 return(0);
751 spinvector(odir, odir, v1, d=MOVDEG*PI/180.*orb);
752 VSUM(nv.vp, wip, odir, -1.);
753 spinvector(nv.vdir, nv.vdir, v1, d);
754 } else if (mov) { /* move forward/backward */
755 d = MOVPCT/100. * mov;
756 VSUM(nv.vp, nv.vp, odir, d);
757 }
758 if (!mov ^ !orb && viewflags&VWHEADLOCK) { /* restore height */
759 VSUM(v1, odev.v.vp, nv.vp, -1.);
760 d = DOT(v1, nv.vup);
761 VSUM(nv.vp, nv.vp, odev.v.vup, d);
762 }
763 if (setview(&nv) != NULL)
764 return(0); /* illegal view */
765 dev_view(&nv);
766 inpresflags |= DFL(DC_SETVIEW);
767 return(1);
768 }
769
770
771 static
772 getframe(ebut) /* get focus frame */
773 XButtonPressedEvent *ebut;
774 {
775 int startx = ebut->x, starty = ebut->y;
776 int endx, endy;
777
778 XMaskEvent(ourdisplay, ButtonReleaseMask, levptr(XEvent));
779 endx = levptr(XButtonReleasedEvent)->x;
780 endy = levptr(XButtonReleasedEvent)->y;
781 if (endx == startx | endy == starty) {
782 XBell(ourdisplay, 0);
783 return;
784 }
785 if (endx < startx) {register int c = endx; endx = startx; startx = c;}
786 if (endy < starty) {register int c = endy; endy = starty; starty = c;}
787 sprintf(odev_args, "%.3f %.3f %.3f %.3f",
788 (startx+.5)/odev.hres, 1.-(endy+.5)/odev.vres,
789 (endx+.5)/odev.hres, 1.-(starty+.5)/odev.vres);
790 inpresflags |= DFL(DC_FOCUS);
791 }
792
793
794 static
795 getmove(ebut) /* get view change */
796 XButtonPressedEvent *ebut;
797 {
798 int movdir = MOVDIR(ebut->button);
799 int movorb = MOVORB(ebut->state);
800 int ndrawn;
801 Window rootw, childw;
802 int rootx, rooty, wx, wy;
803 unsigned int statemask;
804
805 XNoOp(ourdisplay); /* makes sure we're not idle */
806
807 viewflags &= ~VWSTEADY; /* flag moving view */
808 setglpersp(); /* start us off in perspective */
809 while (!XCheckMaskEvent(ourdisplay,
810 ButtonReleaseMask, levptr(XEvent))) {
811 /* get cursor position */
812 if (!XQueryPointer(ourdisplay, gwind, &rootw, &childw,
813 &rootx, &rooty, &wx, &wy, &statemask))
814 break; /* on another screen */
815 /* compute view motion */
816 if (!moveview(wx, odev.vres-1-wy, movdir, movorb)) {
817 sleep(1);
818 continue; /* cursor in bad place */
819 }
820 draw_grids(1); /* redraw grid */
821 #ifdef STEREO
822 pushright();
823 draw_grids(1);
824 ndrawn = gmDrawGeom();
825 #ifdef DOBJ
826 ndrawn += dobj_render();
827 #endif
828 popright();
829 #endif
830 /* redraw octrees */
831 ndrawn = gmDrawGeom();
832 #ifdef DOBJ
833 ndrawn += dobj_render(); /* redraw objects */
834 #endif
835 glXSwapBuffers(ourdisplay, gwind);
836 if (!ndrawn)
837 sleep(1); /* for reasonable interaction */
838 }
839 if (!(inpresflags & DFL(DC_SETVIEW))) { /* do final motion */
840 movdir = MOVDIR(levptr(XButtonReleasedEvent)->button);
841 wx = levptr(XButtonReleasedEvent)->x;
842 wy = levptr(XButtonReleasedEvent)->y;
843 moveview(wx, odev.vres-1-wy, movdir, movorb);
844 }
845 viewflags |= VWSTEADY; /* done goofing around */
846 }
847
848
849 static
850 setglpersp() /* set perspective view in GL */
851 {
852 double d, xmin, xmax, ymin, ymax;
853 GLfloat vec[4];
854 double depthlim[2];
855 /* set depth limits */
856 gmDepthLimit(depthlim, odev.v.vp, odev.v.vdir);
857 if (depthlim[0] >= depthlim[1]) {
858 dev_zmin = 1.;
859 dev_zmax = 100.;
860 } else {
861 dev_zmin = 0.5*depthlim[0];
862 dev_zmax = 1.25*depthlim[1];
863 if (dev_zmin > dev_zmax/5.)
864 dev_zmin = dev_zmax/5.;
865 }
866 if (odev.v.vfore > FTINY)
867 dev_zmin = odev.v.vfore;
868 if (odev.v.vaft > FTINY)
869 dev_zmax = odev.v.vaft;
870 if (dev_zmin < dev_zmax/100.)
871 dev_zmin = dev_zmax/100.;
872 setzrat();
873 xmax = dev_zmin * tan(PI/180./2. * odev.v.horiz);
874 xmin = -xmax;
875 d = odev.v.hoff * (xmax - xmin);
876 xmin += d; xmax += d;
877 ymax = dev_zmin * tan(PI/180./2. * odev.v.vert);
878 ymin = -ymax;
879 d = odev.v.voff * (ymax - ymin);
880 ymin += d; ymax += d;
881 /* set view matrix */
882 glMatrixMode(GL_PROJECTION);
883 glLoadIdentity();
884 glFrustum(xmin, xmax, ymin, ymax, dev_zmin, dev_zmax);
885 gluLookAt(odev.v.vp[0], odev.v.vp[1], odev.v.vp[2],
886 odev.v.vp[0] + odev.v.vdir[0],
887 odev.v.vp[1] + odev.v.vdir[1],
888 odev.v.vp[2] + odev.v.vdir[2],
889 odev.v.vup[0], odev.v.vup[1], odev.v.vup[2]);
890 checkglerr("setting perspective view");
891 vec[0] = vec[1] = vec[2] = 0.; vec[3] = 1.;
892 glLightModelfv(GL_LIGHT_MODEL_AMBIENT, vec);
893 vec[0] = -odev.v.vdir[0];
894 vec[1] = -odev.v.vdir[1];
895 vec[2] = -odev.v.vdir[2];
896 vec[3] = 0.;
897 glLightfv(GL_LIGHT0, GL_POSITION, vec);
898 vec[0] = vec[1] = vec[2] = .7; vec[3] = 1.;
899 glLightfv(GL_LIGHT0, GL_SPECULAR, vec);
900 glLightfv(GL_LIGHT0, GL_DIFFUSE, vec);
901 vec[0] = vec[1] = vec[2] = .3; vec[3] = 1.;
902 glLightfv(GL_LIGHT0, GL_AMBIENT, vec);
903 glEnable(GL_LIGHT0);
904 glEnable(GL_LIGHTING); /* light our GL objects */
905 glShadeModel(GL_SMOOTH);
906 viewflags &= ~VWORTHO;
907 viewflags |= VWPERSP;
908 }
909
910
911 static
912 setglortho() /* set up orthographic view for cone drawing */
913 {
914 glDrawBuffer(GL_FRONT); /* use single-buffer mode */
915 /* set view matrix */
916 glMatrixMode(GL_PROJECTION);
917 glLoadIdentity();
918 glOrtho(0., (double)odev.hres, 0., (double)odev.vres,
919 0.001*OMAXDEPTH, 1.001*(-OMAXDEPTH));
920 checkglerr("setting orthographic view");
921 glDisable(GL_LIGHTING); /* cones are constant color */
922 glShadeModel(GL_FLAT);
923 viewflags &= ~VWPERSP;
924 viewflags |= VWORTHO;
925 }
926
927
928 static
929 wipeclean() /* prepare for redraw */
930 {
931 glDrawBuffer(GL_BACK); /* use double-buffer mode */
932 glReadBuffer(GL_BACK);
933 /* clear buffers */
934 #ifdef STEREO
935 setstereobuf(STEREO_BUFFER_RIGHT);
936 glClear(GL_DEPTH_BUFFER_BIT|GL_COLOR_BUFFER_BIT);
937 setstereobuf(STEREO_BUFFER_LEFT);
938 #endif
939 glClear(GL_DEPTH_BUFFER_BIT|GL_COLOR_BUFFER_BIT);
940 freedepth();
941 if ((viewflags&(VWCHANGE|VWSTEADY)) ==
942 (VWCHANGE|VWSTEADY)) { /* clear samples if new */
943 odClean();
944 viewflags &= ~VWCHANGE; /* change noted */
945 } else if (viewflags & VWSTEADY)
946 odRedrawAll();
947 setglpersp(&odev.v); /* reset view & clipping planes */
948 }
949
950
951 static
952 getkey(ekey) /* get input key */
953 register XKeyPressedEvent *ekey;
954 {
955 Window rootw, childw;
956 int rootx, rooty, wx, wy;
957 unsigned int statemask;
958 int n;
959 char buf[8];
960
961 n = XLookupString(ekey, buf, sizeof(buf), NULL, NULL);
962 if (n != 1)
963 return;
964 switch (buf[0]) {
965 case 'h': /* turn on height motion lock */
966 viewflags |= VWHEADLOCK;
967 return;
968 case 'H': /* turn off height motion lock */
969 viewflags &= ~VWHEADLOCK;
970 return;
971 case 'l': /* retrieve last view */
972 inpresflags |= DFL(DC_LASTVIEW);
973 return;
974 case 'p': /* pause computation */
975 inpresflags |= DFL(DC_PAUSE);
976 return;
977 case 'v': /* spit out view */
978 inpresflags |= DFL(DC_GETVIEW);
979 return;
980 case 'f': /* frame view position */
981 if (!XQueryPointer(ourdisplay, gwind, &rootw, &childw,
982 &rootx, &rooty, &wx, &wy, &statemask))
983 return; /* on another screen */
984 sprintf(odev_args, "%.4f %.4f", (wx+.5)/odev.hres,
985 1.-(wy+.5)/odev.vres);
986 inpresflags |= DFL(DC_FOCUS);
987 return;
988 case 'F': /* unfocus */
989 odev_args[0] = '\0';
990 inpresflags |= DFL(DC_FOCUS);
991 return;
992 case '\n':
993 case '\r': /* resume computation */
994 inpresflags |= DFL(DC_RESUME);
995 return;
996 case CTRL('R'): /* redraw screen */
997 odRemap(0); /* new tone mapping */
998 glClear(GL_DEPTH_BUFFER_BIT);
999 #ifdef STEREO
1000 setstereobuf(STEREO_BUFFER_RIGHT);
1001 glClear(GL_DEPTH_BUFFER_BIT);
1002 setstereobuf(STEREO_BUFFER_LEFT);
1003 #endif
1004 return;
1005 case CTRL('L'): /* refresh from server */
1006 if (inpresflags & DFL(DC_REDRAW))
1007 return; /* already called */
1008 XRaiseWindow(ourdisplay, gwind);
1009 XFlush(ourdisplay); /* raise up window */
1010 sleep(1); /* wait for restacking */
1011 dev_clear(); /* clear buffer and samples */
1012 odRemap(1); /* start fresh histogram */
1013 inpresflags |= DFL(DC_REDRAW); /* resend values from server */
1014 return;
1015 case 'K': /* kill rtrace process(es) */
1016 inpresflags |= DFL(DC_KILL);
1017 break;
1018 case 'R': /* restart rtrace */
1019 inpresflags |= DFL(DC_RESTART);
1020 break;
1021 case 'C': /* clobber holodeck */
1022 inpresflags |= DFL(DC_CLOBBER);
1023 break;
1024 case 'q': /* quit the program */
1025 inpresflags |= DFL(DC_QUIT);
1026 return;
1027 default:
1028 XBell(ourdisplay, 0);
1029 return;
1030 }
1031 }
1032
1033
1034 static
1035 fixwindow(eexp) /* repair damage to window */
1036 register XExposeEvent *eexp;
1037 {
1038 int xmin, ymin, xmax, ymax;
1039
1040 if (odev.hres == 0 | odev.vres == 0) { /* first exposure */
1041 resizewindow((XConfigureEvent *)eexp);
1042 return;
1043 }
1044 xmin = eexp->x; xmax = eexp->x + eexp->width;
1045 ymin = odev.vres - eexp->y - eexp->height; ymax = odev.vres - eexp->y;
1046
1047 if (xmin <= 0 && xmax >= odev.hres-1 &&
1048 ymin <= 0 && ymax >= odev.vres) {
1049 DCHECK(eexp->count, WARNING, "multiple clear in fixwindow");
1050 wipeclean(); /* make sure we're go */
1051 return;
1052 }
1053 /* clear portion of depth */
1054 glPushAttrib(GL_DEPTH_BUFFER_BIT|GL_COLOR_BUFFER_BIT);
1055 glColorMask(GL_FALSE, GL_FALSE, GL_FALSE, GL_FALSE);
1056 glDepthFunc(GL_ALWAYS);
1057 glBegin(GL_POLYGON);
1058 glVertex3i(xmin, ymin, OMAXDEPTH);
1059 glVertex3i(xmax, ymin, OMAXDEPTH);
1060 glVertex3i(xmax, ymax, OMAXDEPTH);
1061 glVertex3i(xmin, ymax, OMAXDEPTH);
1062 glEnd();
1063 #ifdef STEREO
1064 setstereobuf(STEREO_BUFFER_RIGHT);
1065 glBegin(GL_POLYGON);
1066 glVertex3i(xmin, ymin, OMAXDEPTH);
1067 glVertex3i(xmax, ymin, OMAXDEPTH);
1068 glVertex3i(xmax, ymax, OMAXDEPTH);
1069 glVertex3i(xmin, ymax, OMAXDEPTH);
1070 glEnd();
1071 odRedraw(1, xmin, ymin, xmax, ymax);
1072 setstereobuf(STEREO_BUFFER_LEFT);
1073 #endif
1074 glPopAttrib();
1075 odRedraw(0, xmin, ymin, xmax, ymax);
1076 }
1077
1078
1079 static
1080 resizewindow(ersz) /* resize window */
1081 register XConfigureEvent *ersz;
1082 {
1083 glViewport(0, 0, ersz->width, ersz->height);
1084
1085 if (ersz->width == odev.hres && ersz->height == odev.vres)
1086 return;
1087
1088 odev.hres = ersz->width;
1089 odev.vres = ersz->height;
1090
1091 odev.v.horiz = 2.*180./PI * atan(0.5/VIEWDIST*pwidth*odev.hres);
1092 odev.v.vert = 2.*180./PI * atan(0.5/VIEWDIST*pheight*odev.vres);
1093
1094 inpresflags |= DFL(DC_SETVIEW);
1095 viewflags |= VWCHANGE;
1096 }
