root/radiance/ray/src/hd/rhd_ogl.c
Revision: 3.4
Committed: Mon Dec 21 15:10:13 1998 UTC (26 years, 4 months ago) by gwlarson
Changes since 3.3: +5 -9 lines
fixed problem with initial drawing
1 /* Copyright (c) 1998 Silicon Graphics, Inc. */
2
3 #ifndef lint
4 static char SCCSid[] = "$SunId$ SGI";
5 #endif
6
7 /*
8 * OpenGL driver for holodeck display.
9 * Based on GLX driver using T-mesh.
10 *
11 * Define symbol STEREO for stereo viewing.
12 * Define symbol DOBJ for display object viewing.
13 */
14
15 #ifdef NOSTEREO
16 #ifdef STEREO
17 #undef STEREO
18 #else
19 #undef NOSTEREO
20 #endif
21 #endif
22
23 #include "standard.h"
24
25 #include <sys/types.h>
26 #include <GL/glx.h>
27 #include <GL/glu.h>
28 #ifdef STEREO
29 #include <X11/extensions/SGIStereo.h>
30 #endif
31
32 #include "rhd_odraw.h"
33 #ifdef DOBJ
34 #include "rhdobj.h"
35 #endif
36
37 #include "x11icon.h"
38
39 #ifndef RAYQLEN
40 #define RAYQLEN 10240 /* max. rays to queue before flush */
41 #endif
42
43 #ifndef PORTALP
44 #define PORTRED 2 /* portal red color */
45 #define PORTGRN -1 /* portal green left alone */
46 #define PORTBLU 128 /* portal blue color */
47 #define PORTALP -1 /* don't use alpha channel */
48 #endif
49 #define isportal(c) ((PORTRED<0 || (c)[0]==PORTRED) && \
50 (PORTGRN<0 || (c)[1]==PORTGRN) && \
51 (PORTBLU<0 || (c)[2]==PORTBLU) && \
52 (PORTALP<0 || (c)[3]==PORTALP))
53
54 #ifndef FEQ
55 #define FEQ(a,b) ((a)-(b) <= FTINY && (a)-(b) >= -FTINY)
56 #endif
57
58 #define GAMMA 1.4 /* default gamma correction */
59
60 #define FRAMESTATE(s) (((s)&(ShiftMask|ControlMask))==(ShiftMask|ControlMask))
61
62 #define MOVPCT 7 /* percent distance to move /frame */
63 #define MOVDIR(b) ((b)==Button1 ? 1 : (b)==Button2 ? 0 : -1)
64 #define MOVDEG (-5) /* degrees to orbit CW/down /frame */
65 #define MOVORB(s) ((s)&ShiftMask ? 1 : (s)&ControlMask ? -1 : 0)
66
67 #define MINWIDTH 480 /* minimum graphics window width */
68 #define MINHEIGHT 400 /* minimum graphics window height */
69
70 #define VIEWDIST 356 /* assumed viewing distance (mm) */
71
72 #define BORWIDTH 5 /* border width */
73
74 #define setstereobuf(bid) (glXWaitGL(), \
75 XSGISetStereoBuffer(ourdisplay, gwind, bid), \
76 glXWaitX())
77
78 #define ourscreen DefaultScreen(ourdisplay)
79 #define ourroot RootWindow(ourdisplay,ourscreen)
80 #define ourmask (StructureNotifyMask|ExposureMask|KeyPressMask|\
81 ButtonPressMask|ButtonReleaseMask)
82
83 #define levptr(etype) ((etype *)&currentevent)
84
85 struct driver odev; /* global device driver structure */
86
87 char odev_args[64]; /* command arguments */
88
89 static GLfloat *depthbuffer = NULL; /* depth buffer */
90
91 #ifdef STEREO
92 static VIEW vwright; /* right eye view */
93 static GLfloat *depthright = NULL; /* right depth buffer */
94 #endif
95
96 static int rayqleft = 0; /* rays left to queue before flush */
97
98 static XEvent currentevent; /* current event */
99
100 static int mapped = 0; /* window is mapped? */
101 static unsigned long ourblack=0, ourwhite=~0;
102
103 static Display *ourdisplay = NULL; /* our display */
104 static XVisualInfo *ourvinf; /* our visual information */
105 static Window gwind = 0; /* our graphics window */
106 static GLXContext gctx; /* our GLX context */
107
108 static double pwidth, pheight; /* pixel dimensions (mm) */
109
110 static double dev_zmin, dev_zmax; /* fore and aft clipping plane dist. */
111 static double dev_zrat; /* (1. - dev_zmin/dev_zmax) */
112
113 #define setzrat() (dev_zrat = 1. - dev_zmin/dev_zmax)
114 #define mapdepth(d) ((d)>0.9995 ? FHUGE : dev_zmin/(1.-(d)*dev_zrat))
115
116 static int inpresflags; /* input result flags */
117
118 static int headlocked; /* lock vertical motion */
119
120 static int isperspective; /* perspective/ortho view */
121
122 static int viewsteady; /* is view steady? */
123
124 static int resizewindow(), getevent(), getkey(), moveview(), wipeclean(),
125 xferdepth(), freedepth(), setglortho(),
126 setglpersp(), getframe(), getmove(), fixwindow(), mytmflags();
127
128 static double getdistance();
129
130 #ifdef STEREO
131 static int pushright(), popright();
132 #endif
133
134 extern int gmPortals; /* GL portal list id */
135
136 extern time_t time();
137
138
139 dev_open(id) /* initialize GLX driver */
140 char *id;
141 {
142 extern char *getenv();
143 static RGBPRIMS myprims = STDPRIMS;
144 #if (PORTALP<0)
145 static int atlBest[] = {GLX_RGBA, GLX_RED_SIZE,8,
146 GLX_GREEN_SIZE,8, GLX_BLUE_SIZE,8,
147 GLX_DEPTH_SIZE,15, None};
148 #else
149 static int atlBest[] = {GLX_RGBA, GLX_RED_SIZE,8,
150 GLX_GREEN_SIZE,8, GLX_BLUE_SIZE,8,
151 GLX_ALPHA_SIZE,2, GLX_DEPTH_SIZE,15, None};
152 #endif
153 char *ev;
154 double gamval = GAMMA;
155 RGBPRIMP dpri = stdprims;
156 XSetWindowAttributes ourwinattr;
157 XWMHints ourxwmhints;
158 XSizeHints oursizhints;
159 /* check for unsupported stereo */
160 #ifdef NOSTEREO
161 error(INTERNAL, "stereo display driver unavailable");
162 #endif
163 /* open display server */
164 ourdisplay = XOpenDisplay(NULL);
165 if (ourdisplay == NULL)
166 error(USER, "cannot open X-windows; DISPLAY variable set?\n");
167 #ifdef STEREO
168 switch (XSGIQueryStereoMode(ourdisplay, ourroot)) {
169 case STEREO_TOP:
170 case STEREO_BOTTOM:
171 break;
172 case STEREO_OFF:
173 error(USER,
174 "wrong video mode: run \"/usr/gfx/setmon -n STR_TOP\" first");
175 case X_STEREO_UNSUPPORTED:
176 error(USER, "stereo mode not supported on this screen");
177 default:
178 error(INTERNAL, "unknown stereo mode");
179 }
180 #endif
181 /* find a usable visual */
182 ourvinf = glXChooseVisual(ourdisplay, ourscreen, atlBest);
183 if (ourvinf == NULL)
184 error(USER, "no suitable visuals available");
185 /* get a context */
186 gctx = glXCreateContext(ourdisplay, ourvinf, NULL, GL_TRUE);
187 /* set gamma and tone mapping */
188 if ((ev = XGetDefault(ourdisplay, "radiance", "gamma")) != NULL
189 || (ev = getenv("DISPLAY_GAMMA")) != NULL)
190 gamval = atof(ev);
191 if ((ev = getenv("DISPLAY_PRIMARIES")) != NULL &&
192 sscanf(ev, "%f %f %f %f %f %f %f %f",
193 &myprims[RED][CIEX],&myprims[RED][CIEY],
194 &myprims[GRN][CIEX],&myprims[GRN][CIEY],
195 &myprims[BLU][CIEX],&myprims[BLU][CIEY],
196 &myprims[WHT][CIEX],&myprims[WHT][CIEY]) >= 6)
197 dpri = myprims;
198 if (tmInit(mytmflags(), dpri, gamval) == NULL)
199 error(SYSTEM, "not enough memory in dev_open");
200 /* open window */
201 ourwinattr.background_pixel = ourblack;
202 ourwinattr.border_pixel = ourblack;
203 ourwinattr.event_mask = ourmask;
204 /* this is stupid */
205 ourwinattr.colormap = XCreateColormap(ourdisplay, ourroot,
206 ourvinf->visual, AllocNone);
207 gwind = XCreateWindow(ourdisplay, ourroot, 0, 0,
208 DisplayWidth(ourdisplay,ourscreen)-2*BORWIDTH,
209 #ifdef STEREO
210 (DisplayHeight(ourdisplay,ourscreen)-2*BORWIDTH)/2,
211 #else
212 DisplayHeight(ourdisplay,ourscreen)-2*BORWIDTH,
213 #endif
214 BORWIDTH, ourvinf->depth, InputOutput, ourvinf->visual,
215 CWBackPixel|CWBorderPixel|CWColormap|CWEventMask, &ourwinattr);
216 if (gwind == 0)
217 error(SYSTEM, "cannot create window\n");
218 XStoreName(ourdisplay, gwind, id);
219 /* set window manager hints */
220 ourxwmhints.flags = InputHint|IconPixmapHint;
221 ourxwmhints.input = True;
222 ourxwmhints.icon_pixmap = XCreateBitmapFromData(ourdisplay,
223 gwind, x11icon_bits, x11icon_width, x11icon_height);
224 XSetWMHints(ourdisplay, gwind, &ourxwmhints);
225 oursizhints.min_width = MINWIDTH;
226 #ifdef STEREO
227 oursizhints.min_height = MINHEIGHT/2;
228 oursizhints.max_width = DisplayWidth(ourdisplay,ourscreen)-2*BORWIDTH;
229 oursizhints.max_height = (DisplayHeight(ourdisplay,ourscreen) -
230 2*BORWIDTH)/2;
231 oursizhints.flags = PMinSize|PMaxSize;
232 #else
233 oursizhints.min_height = MINHEIGHT;
234 oursizhints.flags = PMinSize;
235 #endif
236 XSetNormalHints(ourdisplay, gwind, &oursizhints);
237 /* set GLX context */
238 glXMakeCurrent(ourdisplay, gwind, gctx);
239 glEnable(GL_DEPTH_TEST);
240 glDepthFunc(GL_LEQUAL);
241 glDisable(GL_DITHER);
242 glFrontFace(GL_CCW);
243 glDisable(GL_CULL_FACE);
244 glLightModeli(GL_LIGHT_MODEL_TWO_SIDE, GL_TRUE);
245 glPolygonMode(GL_FRONT_AND_BACK, GL_FILL);
246 /* figure out sensible view */
247 pwidth = (double)DisplayWidthMM(ourdisplay, ourscreen) /
248 DisplayWidth(ourdisplay, ourscreen);
249 pheight = (double)DisplayHeightMM(ourdisplay, ourscreen) /
250 DisplayHeight(ourdisplay, ourscreen);
251 #ifdef STEREO
252 pheight *= 2.;
253 setstereobuf(STEREO_BUFFER_LEFT);
254 #endif
255 checkglerr("setting rendering parameters");
256 copystruct(&odev.v, &stdview);
257 odev.v.type = VT_PER;
258 headlocked = 0; /* free up head movement */
259 viewsteady = 1; /* view starts static */
260 isperspective = -1; /* but no view set, yet */
261 /* map the window */
262 XMapWindow(ourdisplay, gwind);
263 dev_input(); /* sets size and view angles */
264 if (!odInit(DisplayWidth(ourdisplay,ourscreen) *
265 DisplayHeight(ourdisplay,ourscreen) / 4))
266 error(SYSTEM, "insufficient memory for value storage");
267 odev.name = id;
268 odev.firstuse = 1; /* can't recycle samples */
269 odev.ifd = ConnectionNumber(ourdisplay);
270 }
271
272
273 dev_close() /* close our display and free resources */
274 {
275 #ifdef DOBJ
276 dobj_cleanup();
277 #endif
278 freedepth();
279 gmEndGeom();
280 gmEndPortal();
281 odDone();
282 glXMakeCurrent(ourdisplay, None, NULL);
283 glXDestroyContext(ourdisplay, gctx);
284 XDestroyWindow(ourdisplay, gwind);
285 gwind = 0;
286 XCloseDisplay(ourdisplay);
287 ourdisplay = NULL;
288 tmDone(NULL);
289 odev.v.type = 0;
290 odev.hres = odev.vres = 0;
291 odev.ifd = -1;
292 }
293
294
295 dev_clear() /* clear our representation */
296 {
297 wipeclean();
298 rayqleft = 0; /* hold off update */
299 }
300
301
302 int
303 dev_view(nv) /* assign new driver view */
304 register VIEW *nv;
305 {
306 double d;
307
308 if (nv->type != VT_PER || /* check view legality */
309 nv->horiz > 160. || nv->vert > 160.) {
310 error(COMMAND, "illegal view type/angle");
311 nv->type = odev.v.type;
312 nv->horiz = odev.v.horiz;
313 nv->vert = odev.v.vert;
314 return(0);
315 }
316 if (nv != &odev.v) {
317 /* resize window? */
318 if (!FEQ(nv->horiz,odev.v.horiz) ||
319 !FEQ(nv->vert,odev.v.vert)) {
320 int dw = DisplayWidth(ourdisplay,ourscreen);
321 int dh = DisplayHeight(ourdisplay,ourscreen);
322
323 dw -= 25; /* for window frame */
324 dh -= 50;
325 #ifdef STEREO
326 dh /= 2;
327 #endif
328 odev.hres = 2.*VIEWDIST/pwidth *
329 tan(PI/180./2.*nv->horiz);
330 odev.vres = 2.*VIEWDIST/pheight *
331 tan(PI/180./2.*nv->vert);
332 if (odev.hres > dw) {
333 odev.vres = dw * odev.vres / odev.hres;
334 odev.hres = dw;
335 }
336 if (odev.vres > dh) {
337 odev.hres = dh * odev.hres / odev.vres;
338 odev.vres = dh;
339 }
340 XResizeWindow(ourdisplay, gwind, odev.hres, odev.vres);
341 dev_input(); /* get resize event */
342 }
343 copystruct(&odev.v, nv); /* setview() already called */
344 #ifdef STEREO
345 copystruct(&vwright, nv);
346 d = eyesepdist / sqrt(nv->hn2);
347 VSUM(vwright.vp, nv->vp, nv->hvec, d);
348 /* setview(&vwright); -- Unnecessary */
349 #endif
350 } else
351 viewsteady = 1;
352 wipeclean();
353 return(1);
354 }
355
356
357 dev_section(gfn, pfn) /* add octree for geometry rendering */
358 char *gfn, *pfn;
359 {
360 extern char *index();
361 char *cp;
362
363 if (gfn == NULL) {
364 gmEndGeom();
365 gmEndPortal();
366 wipeclean(); /* new geometry, so redraw it */
367 return;
368 }
369 if (access(gfn, R_OK) == 0)
370 gmNewGeom(gfn);
371 #ifdef DEBUG
372 else {
373 sprintf(errmsg, "cannot load octree \"%s\"", gfn);
374 error(WARNING, errmsg);
375 }
376 #endif
377 if (pfn != NULL)
378 gmNewPortal(pfn);
379 }
380
381
382 dev_auxcom(cmd, args) /* process an auxiliary command */
383 char *cmd, *args;
384 {
385 #ifdef DOBJ
386 if (dobj_command(cmd, args) >= 0)
387 return;
388 #endif
389 sprintf(errmsg, "%s: unknown command", cmd);
390 error(COMMAND, errmsg);
391 }
392
393
394 VIEW *
395 dev_auxview(n, hvres) /* return nth auxiliary view */
396 int n;
397 int hvres[2];
398 {
399 hvres[0] = odev.hres; hvres[1] = odev.vres;
400 if (n == 0)
401 return(&odev.v);
402 #ifdef STEREO
403 if (n == 1)
404 return(&vwright);
405 #endif
406 return(NULL);
407 }
408
409
410 int
411 dev_input() /* get X11 input */
412 {
413 inpresflags = 0;
414
415 do
416 getevent();
417
418 while (XPending(ourdisplay) > 0);
419
420 odev.inpready = 0;
421
422 return(inpresflags);
423 }
424
425
426 dev_value(c, d, p) /* add a pixel value to our texture */
427 COLR c;
428 FVECT d, p;
429 {
430 #ifdef DOBJ
431 if (dobj_lightsamp != NULL) { /* in light source sampling */
432 (*dobj_lightsamp)(c, d, p);
433 return;
434 }
435 #endif
436 odSample(c, d, p); /* add to display representation */
437 if (!--rayqleft)
438 dev_flush(); /* flush output */
439 }
440
441
442 int
443 dev_flush() /* flush output as appropriate */
444 {
445 int ndrawn;
446
447 if (mapped && isperspective > 0) {
448 #ifdef STEREO
449 pushright(); /* draw right eye */
450 ndrawn = gmDrawGeom();
451 #ifdef DOBJ
452 ndrawn += dobj_render();
453 #endif
454 if (ndrawn)
455 gmDrawPortals(PORTRED, PORTGRN, PORTBLU, PORTALP);
456 checkglerr("rendering right eye");
457 popright(); /* draw left eye */
458 #endif
459 ndrawn = gmDrawGeom();
460 #ifdef DOBJ
461 ndrawn += dobj_render();
462 #endif
463 if (ndrawn)
464 gmDrawPortals(PORTRED, PORTGRN, PORTBLU, PORTALP);
465 checkglerr("rendering base view");
466 }
467 if (mapped && viewsteady)
468 if (isperspective > 0) { /* first time after steady */
469 if (ndrawn)
470 xferdepth(); /* transfer and clear depth */
471 setglortho(); /* set orthographic view */
472 } else if (!isperspective) {
473 #ifdef STEREO
474 pushright();
475 odUpdate(1); /* draw right eye */
476 popright();
477 #endif
478 odUpdate(0); /* draw left eye */
479 }
480 glFlush(); /* flush OpenGL */
481 rayqleft = RAYQLEN;
482 /* flush X11 and return # pending */
483 return(odev.inpready = XPending(ourdisplay));
484 }
485
486
487 checkglerr(where) /* check for GL or GLU error */
488 char *where;
489 {
490 register GLenum errcode;
491
492 while ((errcode = glGetError()) != GL_NO_ERROR) {
493 sprintf(errmsg, "OpenGL error %s: %s",
494 where, gluErrorString(errcode));
495 error(WARNING, errmsg);
496 }
497 }
498
499
500 static
501 xferdepth() /* load and clear depth buffer */
502 {
503 register GLfloat *dbp;
504 register GLubyte *cbuf;
505
506 if (depthbuffer == NULL) { /* allocate private depth buffer */
507 #ifdef STEREO
508 depthright = (GLfloat *)malloc(
509 odev.hres*odev.vres*sizeof(GLfloat));
510 #endif
511 depthbuffer = (GLfloat *)malloc(
512 odev.hres*odev.vres*sizeof(GLfloat));
513 if (depthbuffer == NULL)
514 error(SYSTEM, "out of memory in xferdepth");
515 }
516 /* allocate alpha buffer for portals */
517 if (gmPortals)
518 cbuf = (GLubyte *)malloc(odev.hres*odev.vres*
519 (4*sizeof(GLubyte)));
520 else
521 cbuf = NULL;
522 #ifdef STEREO
523 setstereobuf(STEREO_BUFFER_RIGHT);
524 glReadPixels(0, 0, odev.hres, odev.vres,
525 GL_DEPTH_COMPONENT, GL_FLOAT, depthright);
526 if (cbuf != NULL)
527 glReadPixels(0, 0, odev.hres, odev.vres,
528 GL_RGBA, GL_UNSIGNED_BYTE, cbuf);
529 for (dbp = depthright + odev.hres*odev.vres; dbp-- > depthright; )
530 if (cbuf != NULL && isportal(cbuf+4*(dbp-depthright)))
531 *dbp = FHUGE;
532 else
533 *dbp = mapdepth(*dbp);
534 glClear(GL_DEPTH_BUFFER_BIT);
535 setstereobuf(STEREO_BUFFER_LEFT);
536 odDepthMap(1, depthright);
537 #endif
538 /* read back depth buffer */
539 glReadPixels(0, 0, odev.hres, odev.vres,
540 GL_DEPTH_COMPONENT, GL_FLOAT, depthbuffer);
541 if (cbuf != NULL)
542 glReadPixels(0, 0, odev.hres, odev.vres,
543 GL_RGBA, GL_UNSIGNED_BYTE, cbuf);
544 for (dbp = depthbuffer + odev.hres*odev.vres; dbp-- > depthbuffer; )
545 if (cbuf != NULL && isportal(cbuf+4*(dbp-depthbuffer)))
546 *dbp = FHUGE;
547 else
548 *dbp = mapdepth(*dbp);
549 glClear(GL_DEPTH_BUFFER_BIT); /* clear system depth buffer */
550 if (cbuf != NULL)
551 free((char *)cbuf); /* free our color buffer */
552 odDepthMap(0, depthbuffer); /* transfer depth data */
553 }
554
555
556 static
557 freedepth() /* free recorded depth buffer */
558 {
559 if (depthbuffer == NULL)
560 return;
561 #ifdef STEREO
562 odDepthMap(1, NULL);
563 free((char *)depthright);
564 depthright = NULL;
565 #endif
566 odDepthMap(0, NULL);
567 free((char *)depthbuffer);
568 depthbuffer = NULL;
569 }
570
571
572 static double
573 getdistance(dx, dy, direc) /* distance from fore plane along view ray */
574 int dx, dy;
575 FVECT direc;
576 {
577 GLfloat gldepth;
578 GLubyte glcolor[4];
579 double dist;
580
581 if (dx<0 | dx>=odev.hres | dy<0 | dy>=odev.vres)
582 return(FHUGE);
583 if (depthbuffer != NULL)
584 dist = depthbuffer[dy*odev.hres + dx];
585 else {
586 glReadPixels(dx,dy, 1,1, GL_DEPTH_COMPONENT,
587 GL_FLOAT, &gldepth);
588 if (gmPortals) {
589 glReadPixels(dx,dy, 1,1, GL_RGBA,
590 GL_UNSIGNED_BYTE, glcolor);
591 if (isportal(glcolor))
592 return(FHUGE);
593 }
594 dist = mapdepth(gldepth);
595 }
596 if (dist >= .99*FHUGE)
597 return(FHUGE);
598 return((dist-odev.v.vfore)/DOT(direc,odev.v.vdir));
599 }
600
601
602 #ifdef STEREO
603 static
604 pushright() /* push on right view & buffer */
605 {
606 double d;
607
608 setstereobuf(STEREO_BUFFER_RIGHT);
609 if (isperspective > 0) {
610 glMatrixMode(GL_MODELVIEW);
611 glPushMatrix();
612 d = -eyesepdist / sqrt(odev.v.hn2);
613 glTranslated(d*odev.v.hvec[0], d*odev.v.hvec[1],
614 d*odev.v.hvec[2]);
615 checkglerr("setting right view");
616 }
617 }
618
619
620 static
621 popright() /* pop off right view & buffer */
622 {
623 if (isperspective > 0) {
624 glMatrixMode(GL_MODELVIEW);
625 glPopMatrix();
626 }
627 setstereobuf(STEREO_BUFFER_LEFT);
628 }
629 #endif
630
631
632 static int
633 mytmflags() /* figure out tone mapping flags */
634 {
635 extern char *progname;
636 register char *cp, *tail;
637 /* find basic name */
638 for (cp = tail = progname; *cp; cp++)
639 if (*cp == '/')
640 tail = cp+1;
641 for (cp = tail; *cp && *cp != '.'; cp++)
642 ;
643 #ifdef DEBUG
644 if (cp > tail && cp[-1] == 'h')
645 return(TM_F_HUMAN);
646 else
647 return(TM_F_CAMERA);
648 #else
649 if (cp > tail && cp[-1] == 'h')
650 return(TM_F_HUMAN|TM_F_NOSTDERR);
651 else
652 return(TM_F_CAMERA|TM_F_NOSTDERR);
653 #endif
654 }
655
656
657 static
658 getevent() /* get next event */
659 {
660 XNextEvent(ourdisplay, levptr(XEvent));
661 switch (levptr(XEvent)->type) {
662 case ConfigureNotify:
663 resizewindow(levptr(XConfigureEvent));
664 break;
665 case UnmapNotify:
666 mapped = 0;
667 break;
668 case MapNotify:
669 odRemap(0);
670 mapped = 1;
671 break;
672 case Expose:
673 fixwindow(levptr(XExposeEvent));
674 break;
675 case KeyPress:
676 getkey(levptr(XKeyPressedEvent));
677 break;
678 case ButtonPress:
679 if (FRAMESTATE(levptr(XButtonPressedEvent)->state))
680 getframe(levptr(XButtonPressedEvent));
681 else
682 getmove(levptr(XButtonPressedEvent));
683 break;
684 }
685 }
686
687
688 static
689 draw3dline(wp) /* draw 3d line in world coordinates */
690 register FVECT wp[2];
691 {
692 glVertex3d(wp[0][0], wp[0][1], wp[0][2]);
693 glVertex3d(wp[1][0], wp[1][1], wp[1][2]);
694 }
695
696
697 static
698 draw_grids(fore) /* draw holodeck section grids */
699 int fore;
700 {
701 glPushAttrib(GL_LIGHTING_BIT|GL_ENABLE_BIT);
702 glDisable(GL_LIGHTING);
703 if (fore)
704 glColor3ub(0, 255, 255);
705 else
706 glColor3ub(0, 0, 0);
707 glBegin(GL_LINES); /* draw each grid line */
708 gridlines(draw3dline);
709 glEnd();
710 checkglerr("drawing grid lines");
711 glPopAttrib();
712 }
713
714
715 static
716 moveview(dx, dy, mov, orb) /* move our view */
717 int dx, dy, mov, orb;
718 {
719 VIEW nv;
720 FVECT odir, v1, wip;
721 double d, d1;
722 register int li;
723 /* start with old view */
724 copystruct(&nv, &odev.v);
725 /* orient our motion */
726 if (viewray(v1, odir, &odev.v,
727 (dx+.5)/odev.hres, (dy+.5)/odev.vres) < -FTINY)
728 return(0); /* outside view */
729 if (mov | orb) { /* moving relative to geometry */
730 d = getdistance(dx, dy, odir); /* distance from front plane */
731 #ifdef DOBJ
732 d1 = dobj_trace(NULL, v1, odir);
733 if (d1 < d)
734 d = d1;
735 #endif
736 if (d >= .99*FHUGE)
737 d = 0.5*(dev_zmax+dev_zmin); /* just guess */
738 VSUM(wip, v1, odir, d);
739 VSUB(odir, wip, odev.v.vp);
740 } else /* panning with constant viewpoint */
741 VCOPY(nv.vdir, odir);
742 if (orb && mov) { /* orbit left/right */
743 spinvector(odir, odir, nv.vup, d=MOVDEG*PI/180.*mov);
744 VSUM(nv.vp, wip, odir, -1.);
745 spinvector(nv.vdir, nv.vdir, nv.vup, d);
746 } else if (orb) { /* orbit up/down */
747 fcross(v1, odir, nv.vup);
748 if (normalize(v1) == 0.)
749 return(0);
750 spinvector(odir, odir, v1, d=MOVDEG*PI/180.*orb);
751 VSUM(nv.vp, wip, odir, -1.);
752 spinvector(nv.vdir, nv.vdir, v1, d);
753 } else if (mov) { /* move forward/backward */
754 d = MOVPCT/100. * mov;
755 VSUM(nv.vp, nv.vp, odir, d);
756 }
757 if (!mov ^ !orb && headlocked) { /* restore head height */
758 VSUM(v1, odev.v.vp, nv.vp, -1.);
759 d = DOT(v1, nv.vup);
760 VSUM(nv.vp, nv.vp, odev.v.vup, d);
761 }
762 if (setview(&nv) != NULL)
763 return(0); /* illegal view */
764 dev_view(&nv);
765 inpresflags |= DFL(DC_SETVIEW);
766 return(1);
767 }
768
769
770 static
771 getframe(ebut) /* get focus frame */
772 XButtonPressedEvent *ebut;
773 {
774 int startx = ebut->x, starty = ebut->y;
775 int endx, endy;
776
777 XMaskEvent(ourdisplay, ButtonReleaseMask, levptr(XEvent));
778 endx = levptr(XButtonReleasedEvent)->x;
779 endy = levptr(XButtonReleasedEvent)->y;
780 if (endx == startx | endy == starty) {
781 XBell(ourdisplay, 0);
782 return;
783 }
784 if (endx < startx) {register int c = endx; endx = startx; startx = c;}
785 if (endy < starty) {register int c = endy; endy = starty; starty = c;}
786 sprintf(odev_args, "%.3f %.3f %.3f %.3f",
787 (startx+.5)/odev.hres, 1.-(endy+.5)/odev.vres,
788 (endx+.5)/odev.hres, 1.-(starty+.5)/odev.vres);
789 inpresflags |= DFL(DC_FOCUS);
790 }
791
792
793 static
794 getmove(ebut) /* get view change */
795 XButtonPressedEvent *ebut;
796 {
797 int movdir = MOVDIR(ebut->button);
798 int movorb = MOVORB(ebut->state);
799 int ndrawn;
800 Window rootw, childw;
801 int rootx, rooty, wx, wy;
802 unsigned int statemask;
803
804 XNoOp(ourdisplay); /* makes sure we're not idle */
805
806 viewsteady = 0; /* flag moving view */
807 setglpersp(&odev.v); /* start us off in perspective */
808 while (!XCheckMaskEvent(ourdisplay,
809 ButtonReleaseMask, levptr(XEvent))) {
810 /* get cursor position */
811 if (!XQueryPointer(ourdisplay, gwind, &rootw, &childw,
812 &rootx, &rooty, &wx, &wy, &statemask))
813 break; /* on another screen */
814 /* compute view motion */
815 if (!moveview(wx, odev.vres-1-wy, movdir, movorb)) {
816 sleep(1);
817 continue; /* cursor in bad place */
818 }
819 draw_grids(1); /* redraw grid */
820 #ifdef STEREO
821 pushright();
822 draw_grids(1);
823 ndrawn = gmDrawGeom();
824 #ifdef DOBJ
825 ndrawn += dobj_render();
826 #endif
827 if (ndrawn)
828 gmDrawPortals(PORTRED, PORTGRN, PORTBLU, PORTALP);
829 popright();
830 #endif
831 /* redraw octrees */
832 ndrawn = gmDrawGeom();
833 #ifdef DOBJ
834 ndrawn += dobj_render(); /* redraw objects */
835 #endif
836 if (ndrawn)
837 gmDrawPortals(PORTRED, PORTGRN, PORTBLU, PORTALP);
838 glFlush();
839 if (!ndrawn) {
840 sleep(1); /* for reasonable interaction */
841 #ifdef STEREO
842 pushright();
843 draw_grids(0);
844 popright();
845 #endif
846 draw_grids(0);
847 }
848 }
849 if (!(inpresflags & DFL(DC_SETVIEW))) { /* do final motion */
850 movdir = MOVDIR(levptr(XButtonReleasedEvent)->button);
851 wx = levptr(XButtonReleasedEvent)->x;
852 wy = levptr(XButtonReleasedEvent)->y;
853 moveview(wx, odev.vres-1-wy, movdir, movorb);
854 }
855 }
856
857
858 static
859 setglpersp(vp) /* set perspective view in GL */
860 register VIEW *vp;
861 {
862 double d, xmin, xmax, ymin, ymax;
863 GLfloat vec[4];
864 double depthlim[2];
865 /* set depth limits */
866 gmDepthLimit(depthlim, odev.v.vp, odev.v.vdir);
867 if (depthlim[0] >= depthlim[1]) {
868 dev_zmin = 1.;
869 dev_zmax = 100.;
870 } else {
871 dev_zmin = 0.5*depthlim[0];
872 dev_zmax = 1.75*depthlim[1];
873 if (dev_zmin > dev_zmax/5.)
874 dev_zmin = dev_zmax/5.;
875 }
876 if (odev.v.vfore > FTINY)
877 dev_zmin = odev.v.vfore;
878 if (odev.v.vaft > FTINY)
879 dev_zmax = odev.v.vaft;
880 if (dev_zmin < dev_zmax/100.)
881 dev_zmin = dev_zmax/100.;
882 setzrat();
883 xmax = dev_zmin * tan(PI/180./2. * odev.v.horiz);
884 xmin = -xmax;
885 d = odev.v.hoff * (xmax - xmin);
886 xmin += d; xmax += d;
887 ymax = dev_zmin * tan(PI/180./2. * odev.v.vert);
888 ymin = -ymax;
889 d = odev.v.voff * (ymax - ymin);
890 ymin += d; ymax += d;
891 /* set view matrix */
892 glMatrixMode(GL_PROJECTION);
893 glLoadIdentity();
894 glFrustum(xmin, xmax, ymin, ymax, dev_zmin, dev_zmax);
895 gluLookAt(odev.v.vp[0], odev.v.vp[1], odev.v.vp[2],
896 odev.v.vp[0] + odev.v.vdir[0],
897 odev.v.vp[1] + odev.v.vdir[1],
898 odev.v.vp[2] + odev.v.vdir[2],
899 odev.v.vup[0], odev.v.vup[1], odev.v.vup[2]);
900 checkglerr("setting perspective view");
901 isperspective = 1;
902 vec[0] = vec[1] = vec[2] = 0.; vec[3] = 1.;
903 glLightModelfv(GL_LIGHT_MODEL_AMBIENT, vec);
904 vec[0] = -odev.v.vdir[0];
905 vec[1] = -odev.v.vdir[1];
906 vec[2] = -odev.v.vdir[2];
907 vec[3] = 0.;
908 glLightfv(GL_LIGHT0, GL_POSITION, vec);
909 vec[0] = vec[1] = vec[2] = .7; vec[3] = 1.;
910 glLightfv(GL_LIGHT0, GL_SPECULAR, vec);
911 glLightfv(GL_LIGHT0, GL_DIFFUSE, vec);
912 vec[0] = vec[1] = vec[2] = .3; vec[3] = 1.;
913 glLightfv(GL_LIGHT0, GL_AMBIENT, vec);
914 glEnable(GL_LIGHT0);
915 glEnable(GL_LIGHTING); /* light our GL objects */
916 glShadeModel(GL_SMOOTH);
917 }
918
919
920 static
921 setglortho() /* set up orthographic view for cone drawing */
922 {
923 /* set view matrix */
924 glMatrixMode(GL_PROJECTION);
925 glLoadIdentity();
926 glOrtho(0., (double)odev.hres, 0., (double)odev.vres,
927 0.001*OMAXDEPTH, 1.001*(-OMAXDEPTH));
928 checkglerr("setting orthographic view");
929 isperspective = 0;
930 glDisable(GL_LIGHTING); /* cones are constant color */
931 glShadeModel(GL_FLAT);
932 }
933
934
935 static
936 wipeclean() /* prepare for redraw */
937 {
938 /* clear depth buffer */
939 #ifdef STEREO
940 setstereobuf(STEREO_BUFFER_RIGHT);
941 glClear(GL_DEPTH_BUFFER_BIT);
942 setstereobuf(STEREO_BUFFER_LEFT);
943 #endif
944 glClear(GL_DEPTH_BUFFER_BIT);
945 if (viewsteady) /* clear samples if steady */
946 odClean();
947 freedepth();
948 setglpersp(&odev.v); /* reset view & clipping planes */
949 }
950
951
952 static
953 getkey(ekey) /* get input key */
954 register XKeyPressedEvent *ekey;
955 {
956 Window rootw, childw;
957 int rootx, rooty, wx, wy;
958 unsigned int statemask;
959 int n;
960 char buf[8];
961
962 n = XLookupString(ekey, buf, sizeof(buf), NULL, NULL);
963 if (n != 1)
964 return;
965 switch (buf[0]) {
966 case 'h': /* turn on height motion lock */
967 headlocked = 1;
968 return;
969 case 'H': /* turn off height motion lock */
970 headlocked = 0;
971 return;
972 case 'l': /* retrieve last view */
973 inpresflags |= DFL(DC_LASTVIEW);
974 return;
975 case 'p': /* pause computation */
976 inpresflags |= DFL(DC_PAUSE);
977 return;
978 case 'v': /* spit out view */
979 inpresflags |= DFL(DC_GETVIEW);
980 return;
981 case 'f': /* frame view position */
982 if (!XQueryPointer(ourdisplay, gwind, &rootw, &childw,
983 &rootx, &rooty, &wx, &wy, &statemask))
984 return; /* on another screen */
985 sprintf(odev_args, "%.4f %.4f", (wx+.5)/odev.hres,
986 1.-(wy+.5)/odev.vres);
987 inpresflags |= DFL(DC_FOCUS);
988 return;
989 case 'F': /* unfocus */
990 odev_args[0] = '\0';
991 inpresflags |= DFL(DC_FOCUS);
992 return;
993 case '\n':
994 case '\r': /* resume computation */
995 inpresflags |= DFL(DC_RESUME);
996 return;
997 case CTRL('R'): /* redraw screen */
998 odRemap(0);
999 glClear(GL_COLOR_BUFFER_BIT|GL_DEPTH_BUFFER_BIT);
1000 #ifdef STEREO
1001 setstereobuf(STEREO_BUFFER_RIGHT);
1002 glClear(GL_COLOR_BUFFER_BIT|GL_DEPTH_BUFFER_BIT);
1003 setstereobuf(STEREO_BUFFER_LEFT);
1004 #endif
1005 return;
1006 case CTRL('L'): /* refresh from server */
1007 if (inpresflags & DFL(DC_REDRAW))
1008 return;
1009 XRaiseWindow(ourdisplay, gwind);
1010 XFlush(ourdisplay);
1011 sleep(1);
1012 wipeclean(); /* fresh display */
1013 odRemap(1); /* fresh tone mapping */
1014 dev_flush(); /* draw octrees */
1015 inpresflags |= DFL(DC_REDRAW); /* resend values from server */
1016 rayqleft = 0; /* hold off update */
1017 return;
1018 case 'K': /* kill rtrace process(es) */
1019 inpresflags |= DFL(DC_KILL);
1020 break;
1021 case 'R': /* restart rtrace */
1022 inpresflags |= DFL(DC_RESTART);
1023 break;
1024 case 'C': /* clobber holodeck */
1025 inpresflags |= DFL(DC_CLOBBER);
1026 break;
1027 case 'q': /* quit the program */
1028 inpresflags |= DFL(DC_QUIT);
1029 return;
1030 default:
1031 XBell(ourdisplay, 0);
1032 return;
1033 }
1034 }
1035
1036
1037 static
1038 fixwindow(eexp) /* repair damage to window */
1039 register XExposeEvent *eexp;
1040 {
1041 int xmin, ymin, xmax, ymax;
1042
1043 if (odev.hres == 0 | odev.vres == 0) { /* first exposure */
1044 resizewindow((XConfigureEvent *)eexp);
1045 return;
1046 }
1047 xmin = eexp->x; xmax = eexp->x + eexp->width;
1048 ymin = odev.vres - eexp->y - eexp->height; ymax = odev.vres - eexp->y;
1049 /* clear portion of depth */
1050 glPushAttrib(GL_DEPTH_BUFFER_BIT|GL_COLOR_BUFFER_BIT);
1051 glColorMask(GL_FALSE, GL_FALSE, GL_FALSE, GL_FALSE);
1052 glDepthFunc(GL_ALWAYS);
1053 glBegin(GL_POLYGON);
1054 glVertex3i(xmin, ymin, OMAXDEPTH);
1055 glVertex3i(xmax, ymin, OMAXDEPTH);
1056 glVertex3i(xmax, ymax, OMAXDEPTH);
1057 glVertex3i(xmin, ymax, OMAXDEPTH);
1058 glEnd();
1059 #ifdef STEREO
1060 setstereobuf(STEREO_BUFFER_RIGHT);
1061 glBegin(GL_POLYGON);
1062 glVertex3i(xmin, ymin, OMAXDEPTH);
1063 glVertex3i(xmax, ymin, OMAXDEPTH);
1064 glVertex3i(xmax, ymax, OMAXDEPTH);
1065 glVertex3i(xmin, ymax, OMAXDEPTH);
1066 glEnd();
1067 odRedraw(1, xmin, ymin, xmax, ymax);
1068 setstereobuf(STEREO_BUFFER_LEFT);
1069 #endif
1070 glPopAttrib();
1071 odRedraw(0, xmin, ymin, xmax, ymax);
1072 }
1073
1074
1075 static
1076 resizewindow(ersz) /* resize window */
1077 register XConfigureEvent *ersz;
1078 {
1079 glViewport(0, 0, ersz->width, ersz->height);
1080
1081 if (ersz->width == odev.hres && ersz->height == odev.vres)
1082 return;
1083
1084 odev.hres = ersz->width;
1085 odev.vres = ersz->height;
1086
1087 odev.v.horiz = 2.*180./PI * atan(0.5/VIEWDIST*pwidth*odev.hres);
1088 odev.v.vert = 2.*180./PI * atan(0.5/VIEWDIST*pheight*odev.vres);
1089
1090 inpresflags |= DFL(DC_SETVIEW);
1091 }
