root/radiance/ray/src/hd/rhd_ogl.c
Revision: 3.8
Committed: Tue Dec 22 10:18:44 1998 UTC (26 years, 7 months ago) by gwlarson
Changes since 3.7: +22 -16 lines
improved portal code
1 /* Copyright (c) 1998 Silicon Graphics, Inc. */
2
3 #ifndef lint
4 static char SCCSid[] = "$SunId$ SGI";
5 #endif
6
7 /*
8 * OpenGL driver for holodeck display.
9 * Based on GLX driver using T-mesh.
10 *
11 * Define symbol STEREO for stereo viewing.
12 * Define symbol DOBJ for display object viewing.
13 */
14
15 #ifdef NOSTEREO
16 #ifdef STEREO
17 #undef STEREO
18 #else
19 #undef NOSTEREO
20 #endif
21 #endif
22
23 #include "standard.h"
24
25 #include <sys/types.h>
26 #include <GL/glx.h>
27 #include <GL/glu.h>
28 #ifdef STEREO
29 #include <X11/extensions/SGIStereo.h>
30 #endif
31
32 #include "rhd_odraw.h"
33 #ifdef DOBJ
34 #include "rhdobj.h"
35 #endif
36
37 #include "x11icon.h"
38
39 #ifndef RAYQLEN
40 #define RAYQLEN 50000 /* max. rays to queue before flush */
41 #endif
42
43 /* values other than 0 or 255 do not map reliably */
44 #ifndef PORTALP
45 #define PORTRED 0 /* -1, 0 or 255 */
46 #define PORTGRN -1 /* -1, 0 or 255 */
47 #define PORTBLU 255 /* -1, 0 or 255 */
48 #define PORTALP -1 /* -1 or 255 */
49 #endif
50 #define isportal(c) ((PORTRED<0 || (c)[0]==PORTRED) && \
51 (PORTGRN<0 || (c)[1]==PORTGRN) && \
52 (PORTBLU<0 || (c)[2]==PORTBLU) && \
53 (PORTALP<0 || (c)[3]==PORTALP))
54 #define doportals() if (gmPortals) \
55 gmDrawPortals(PORTRED,PORTGRN,PORTBLU,PORTALP); else
56
57 #ifndef FEQ
58 #define FEQ(a,b) ((a)-(b) <= FTINY && (a)-(b) >= -FTINY)
59 #endif
60
61 #define VWHEADLOCK 01 /* head position is locked flag */
62 #define VWPERSP 02 /* perspective view is set */
63 #define VWORTHO 04 /* orthographic view is set */
64 #define VWCHANGE 010 /* view has changed */
65 #define VWSTEADY 020 /* view is now steady */
66 #define VWMAPPED 040 /* window is mapped */
67
68 #define GAMMA 1.4 /* default gamma correction */
69
70 #define FRAMESTATE(s) (((s)&(ShiftMask|ControlMask))==(ShiftMask|ControlMask))
71
72 #define MOVPCT 7 /* percent distance to move /frame */
73 #define MOVDIR(b) ((b)==Button1 ? 1 : (b)==Button2 ? 0 : -1)
74 #define MOVDEG (-5) /* degrees to orbit CW/down /frame */
75 #define MOVORB(s) ((s)&ShiftMask ? 1 : (s)&ControlMask ? -1 : 0)
76
77 #define MINWIDTH 480 /* minimum graphics window width */
78 #define MINHEIGHT 400 /* minimum graphics window height */
79
80 #define VIEWDIST 356 /* assumed viewing distance (mm) */
81
82 #define BORWIDTH 5 /* border width */
83
84 #define setstereobuf(bid) (glXWaitGL(), \
85 XSGISetStereoBuffer(ourdisplay, gwind, bid), \
86 glXWaitX())
87
88 #define ourscreen DefaultScreen(ourdisplay)
89 #define ourroot RootWindow(ourdisplay,ourscreen)
90 #define ourmask (StructureNotifyMask|ExposureMask|KeyPressMask|\
91 ButtonPressMask|ButtonReleaseMask)
92
93 #define levptr(etype) ((etype *)&currentevent)
94
95 struct driver odev; /* global device driver structure */
96
97 char odev_args[64]; /* command arguments */
98
99 static GLfloat *depthbuffer = NULL; /* depth buffer */
100
101 #ifdef STEREO
102 static VIEW vwright; /* right eye view */
103 static GLfloat *depthright = NULL; /* right depth buffer */
104 #endif
105
106 static int rayqleft = 0; /* rays left to queue before flush */
107
108 static XEvent currentevent; /* current event */
109
110 static unsigned long ourblack=0, ourwhite=~0;
111
112 static Display *ourdisplay = NULL; /* our display */
113 static XVisualInfo *ourvinf; /* our visual information */
114 static Window gwind = 0; /* our graphics window */
115 static GLXContext gctx; /* our GLX context */
116
117 static double pwidth, pheight; /* pixel dimensions (mm) */
118
119 static double dev_zmin, dev_zmax; /* fore and aft clipping plane dist. */
120 static double dev_zrat; /* (1. - dev_zmin/dev_zmax) */
121
122 #define setzrat() (dev_zrat = 1. - dev_zmin/dev_zmax)
123 #define mapdepth(d) ((d)>0.9995 ? FHUGE : dev_zmin/(1.-(d)*dev_zrat))
124
125 static int inpresflags; /* input result flags */
126
127 static int viewflags; /* what's happening with view */
128
129 static int resizewindow(), getevent(), getkey(), moveview(), wipeclean(),
130 xferdepth(), freedepth(), setglortho(),
131 setglpersp(), getframe(), getmove(), fixwindow(), mytmflags();
132
133 static double getdistance();
134
135 #ifdef STEREO
136 static int pushright(), popright();
137 #endif
138
139 extern int gmPortals; /* GL portal list id */
140
141 extern time_t time();
142
143
144 dev_open(id) /* initialize GLX driver */
145 char *id;
146 {
147 extern char *getenv();
148 static RGBPRIMS myprims = STDPRIMS;
149 #if (PORTALP<0)
150 static int atlBest[] = {GLX_RGBA, GLX_DOUBLEBUFFER,
151 GLX_RED_SIZE,8, GLX_GREEN_SIZE,8,
152 GLX_BLUE_SIZE,8, GLX_DEPTH_SIZE,15, None};
153 static int atlOK[] = {GLX_RGBA, GLX_DOUBLEBUFFER,
154 GLX_RED_SIZE,4, GLX_GREEN_SIZE,4,
155 GLX_BLUE_SIZE,4, GLX_DEPTH_SIZE,15, None};
156 #else
157 static int atlBest[] = {GLX_RGBA, GLX_DOUBLEBUFFER,
158 GLX_RED_SIZE,8, GLX_GREEN_SIZE,8,
159 GLX_BLUE_SIZE,8, GLX_ALPHA_SIZE,1,
160 GLX_DEPTH_SIZE,15, None};
161 static int atlOK[] = {GLX_RGBA, GLX_DOUBLEBUFFER,
162 GLX_RED_SIZE,5, GLX_GREEN_SIZE,5,
163 GLX_BLUE_SIZE,5, GLX_ALPHA_SIZE,1,
164 GLX_DEPTH_SIZE,15, None};
165 #endif
166 char *ev;
167 double gamval = GAMMA;
168 RGBPRIMP dpri = stdprims;
169 XSetWindowAttributes ourwinattr;
170 XWMHints ourxwmhints;
171 XSizeHints oursizhints;
172 /* check for unsupported stereo */
173 #ifdef NOSTEREO
174 error(INTERNAL, "stereo display driver unavailable");
175 #endif
176 /* open display server */
177 ourdisplay = XOpenDisplay(NULL);
178 CHECK(ourdisplay==NULL, USER,
179 "cannot open X-windows; DISPLAY variable set?");
180 #ifdef STEREO
181 switch (XSGIQueryStereoMode(ourdisplay, ourroot)) {
182 case STEREO_TOP:
183 case STEREO_BOTTOM:
184 break;
185 case STEREO_OFF:
186 error(USER,
187 "wrong video mode: run \"/usr/gfx/setmon -n STR_TOP\" first");
188 case X_STEREO_UNSUPPORTED:
189 error(USER, "stereo mode not supported on this screen");
190 default:
191 error(INTERNAL, "unknown stereo mode");
192 }
193 #endif
194 /* find a usable visual */
195 ourvinf = glXChooseVisual(ourdisplay, ourscreen, atlBest);
196 if (ourvinf == NULL)
197 ourvinf = glXChooseVisual(ourdisplay, ourscreen, atlOK);
198 CHECK(ourvinf==NULL, USER, "no suitable visuals available");
199 /* get a context */
200 gctx = glXCreateContext(ourdisplay, ourvinf, NULL, GL_TRUE);
201 /* set gamma and tone mapping */
202 if ((ev = XGetDefault(ourdisplay, "radiance", "gamma")) != NULL
203 || (ev = getenv("DISPLAY_GAMMA")) != NULL)
204 gamval = atof(ev);
205 if ((ev = getenv("DISPLAY_PRIMARIES")) != NULL &&
206 sscanf(ev, "%f %f %f %f %f %f %f %f",
207 &myprims[RED][CIEX],&myprims[RED][CIEY],
208 &myprims[GRN][CIEX],&myprims[GRN][CIEY],
209 &myprims[BLU][CIEX],&myprims[BLU][CIEY],
210 &myprims[WHT][CIEX],&myprims[WHT][CIEY]) >= 6)
211 dpri = myprims;
212 if (tmInit(mytmflags(), dpri, gamval) == NULL)
213 error(SYSTEM, "not enough memory in dev_open");
214 /* open window */
215 ourwinattr.background_pixel = ourblack;
216 ourwinattr.border_pixel = ourblack;
217 ourwinattr.event_mask = ourmask;
218 /* this is stupid */
219 ourwinattr.colormap = XCreateColormap(ourdisplay, ourroot,
220 ourvinf->visual, AllocNone);
221 gwind = XCreateWindow(ourdisplay, ourroot, 0, 0,
222 DisplayWidth(ourdisplay,ourscreen)-2*BORWIDTH,
223 #ifdef STEREO
224 (DisplayHeight(ourdisplay,ourscreen)-2*BORWIDTH)/2,
225 #else
226 DisplayHeight(ourdisplay,ourscreen)-2*BORWIDTH,
227 #endif
228 BORWIDTH, ourvinf->depth, InputOutput, ourvinf->visual,
229 CWBackPixel|CWBorderPixel|CWColormap|CWEventMask, &ourwinattr);
230 CHECK(gwind==0, SYSTEM, "cannot create window");
231 XStoreName(ourdisplay, gwind, id);
232 /* set window manager hints */
233 ourxwmhints.flags = InputHint|IconPixmapHint;
234 ourxwmhints.input = True;
235 ourxwmhints.icon_pixmap = XCreateBitmapFromData(ourdisplay,
236 gwind, x11icon_bits, x11icon_width, x11icon_height);
237 XSetWMHints(ourdisplay, gwind, &ourxwmhints);
238 oursizhints.min_width = MINWIDTH;
239 #ifdef STEREO
240 oursizhints.min_height = MINHEIGHT/2;
241 oursizhints.max_width = DisplayWidth(ourdisplay,ourscreen)-2*BORWIDTH;
242 oursizhints.max_height = (DisplayHeight(ourdisplay,ourscreen) -
243 2*BORWIDTH)/2;
244 oursizhints.flags = PMinSize|PMaxSize;
245 #else
246 oursizhints.min_height = MINHEIGHT;
247 oursizhints.flags = PMinSize;
248 #endif
249 XSetNormalHints(ourdisplay, gwind, &oursizhints);
250 /* set GLX context */
251 glXMakeCurrent(ourdisplay, gwind, gctx);
252 glEnable(GL_DEPTH_TEST);
253 glDepthFunc(GL_LEQUAL);
254 glEnable(GL_DITHER);
255 glFrontFace(GL_CCW);
256 glDisable(GL_CULL_FACE);
257 glLightModeli(GL_LIGHT_MODEL_TWO_SIDE, GL_TRUE);
258 glPolygonMode(GL_FRONT_AND_BACK, GL_FILL);
259 /* figure out sensible view */
260 pwidth = (double)DisplayWidthMM(ourdisplay, ourscreen) /
261 DisplayWidth(ourdisplay, ourscreen);
262 pheight = (double)DisplayHeightMM(ourdisplay, ourscreen) /
263 DisplayHeight(ourdisplay, ourscreen);
264 #ifdef STEREO
265 pheight *= 2.;
266 setstereobuf(STEREO_BUFFER_LEFT);
267 #endif
268 checkglerr("setting rendering parameters");
269 copystruct(&odev.v, &stdview);
270 odev.v.type = VT_PER;
271 viewflags = VWSTEADY; /* view starts static */
272 /* map the window */
273 XMapWindow(ourdisplay, gwind);
274 dev_input(); /* sets size and view angles */
275 if (!odInit(DisplayWidth(ourdisplay,ourscreen) *
276 DisplayHeight(ourdisplay,ourscreen) / 4))
277 error(SYSTEM, "insufficient memory for value storage");
278 odev.name = id;
279 odev.firstuse = 1; /* can't recycle samples */
280 odev.ifd = ConnectionNumber(ourdisplay);
281 }
282
283
284 dev_close() /* close our display and free resources */
285 {
286 #ifdef DOBJ
287 dobj_cleanup();
288 #endif
289 freedepth();
290 gmEndGeom();
291 gmEndPortal();
292 odDone();
293 glXMakeCurrent(ourdisplay, None, NULL);
294 glXDestroyContext(ourdisplay, gctx);
295 XDestroyWindow(ourdisplay, gwind);
296 gwind = 0;
297 XCloseDisplay(ourdisplay);
298 ourdisplay = NULL;
299 tmDone(NULL);
300 odev.v.type = 0;
301 odev.hres = odev.vres = 0;
302 odev.ifd = -1;
303 }
304
305
306 dev_clear() /* clear our representation */
307 {
308 wipeclean();
309 rayqleft = 0; /* hold off update */
310 }
311
312
313 int
314 dev_view(nv) /* assign new driver view */
315 register VIEW *nv;
316 {
317 double d;
318
319 if (nv->type != VT_PER || /* check view legality */
320 nv->horiz > 160. || nv->vert > 160.) {
321 error(COMMAND, "illegal view type/angle");
322 nv->type = odev.v.type;
323 nv->horiz = odev.v.horiz;
324 nv->vert = odev.v.vert;
325 return(0);
326 }
327 if (nv != &odev.v) {
328 /* resize window? */
329 if (!FEQ(nv->horiz,odev.v.horiz) ||
330 !FEQ(nv->vert,odev.v.vert)) {
331 int dw = DisplayWidth(ourdisplay,ourscreen);
332 int dh = DisplayHeight(ourdisplay,ourscreen);
333
334 dw -= 25; /* for window frame */
335 dh -= 50;
336 #ifdef STEREO
337 dh /= 2;
338 #endif
339 odev.hres = 2.*VIEWDIST/pwidth *
340 tan(PI/180./2.*nv->horiz);
341 odev.vres = 2.*VIEWDIST/pheight *
342 tan(PI/180./2.*nv->vert);
343 if (odev.hres > dw) {
344 odev.vres = dw * odev.vres / odev.hres;
345 odev.hres = dw;
346 }
347 if (odev.vres > dh) {
348 odev.hres = dh * odev.hres / odev.vres;
349 odev.vres = dh;
350 }
351 XResizeWindow(ourdisplay, gwind, odev.hres, odev.vres);
352 dev_input(); /* get resize event */
353 }
354 copystruct(&odev.v, nv); /* setview() already called */
355 #ifdef STEREO
356 copystruct(&vwright, nv);
357 d = eyesepdist / sqrt(nv->hn2);
358 VSUM(vwright.vp, nv->vp, nv->hvec, d);
359 /* setview(&vwright); -- Unnecessary */
360 #endif
361 viewflags |= VWCHANGE;
362 }
363 wipeclean();
364 return(1);
365 }
366
367
368 dev_section(gfn, pfn) /* add octree for geometry rendering */
369 char *gfn, *pfn;
370 {
371 extern char *index();
372 char *cp;
373
374 if (gfn == NULL) {
375 gmEndGeom();
376 gmEndPortal();
377 wipeclean(); /* new geometry, so redraw it */
378 return;
379 }
380 if (access(gfn, R_OK) == 0)
381 gmNewGeom(gfn);
382 #ifdef DEBUG
383 else {
384 sprintf(errmsg, "cannot load octree \"%s\"", gfn);
385 error(WARNING, errmsg);
386 }
387 #endif
388 if (pfn != NULL)
389 gmNewPortal(pfn);
390 }
391
392
393 dev_auxcom(cmd, args) /* process an auxiliary command */
394 char *cmd, *args;
395 {
396 #ifdef DOBJ
397 if (dobj_command(cmd, args) >= 0)
398 return;
399 #endif
400 sprintf(errmsg, "%s: unknown command", cmd);
401 error(COMMAND, errmsg);
402 }
403
404
405 VIEW *
406 dev_auxview(n, hvres) /* return nth auxiliary view */
407 int n;
408 int hvres[2];
409 {
410 hvres[0] = odev.hres; hvres[1] = odev.vres;
411 if (n == 0)
412 return(&odev.v);
413 #ifdef STEREO
414 if (n == 1)
415 return(&vwright);
416 #endif
417 return(NULL);
418 }
419
420
421 int
422 dev_input() /* get X11 input */
423 {
424 inpresflags = 0;
425
426 do
427 getevent();
428
429 while (XPending(ourdisplay) > 0);
430
431 odev.inpready = 0;
432
433 return(inpresflags);
434 }
435
436
437 dev_value(c, d, p) /* add a pixel value to our texture */
438 COLR c;
439 FVECT d, p;
440 {
441 #ifdef DOBJ
442 if (dobj_lightsamp != NULL) { /* in light source sampling */
443 (*dobj_lightsamp)(c, d, p);
444 return;
445 }
446 #endif
447 odSample(c, d, p); /* add to display representation */
448 if (!--rayqleft)
449 dev_flush(); /* flush output */
450 }
451
452
453 int
454 dev_flush() /* flush output as appropriate */
455 {
456 int ndrawn;
457
458 if ((viewflags&(VWMAPPED|VWPERSP)) == (VWMAPPED|VWPERSP)) {
459 #ifdef STEREO
460 pushright(); /* draw right eye */
461 ndrawn = gmDrawGeom();
462 #ifdef DOBJ
463 ndrawn += dobj_render();
464 #endif
465 if (ndrawn)
466 doportals();
467 checkglerr("rendering right eye");
468 popright(); /* draw left eye */
469 #endif
470 ndrawn = gmDrawGeom();
471 #ifdef DOBJ
472 ndrawn += dobj_render();
473 #endif
474 if (ndrawn)
475 doportals();
476 glXSwapBuffers(ourdisplay, gwind);
477 checkglerr("rendering base view");
478 }
479 if ((viewflags&(VWMAPPED|VWSTEADY|VWPERSP|VWORTHO)) ==
480 (VWMAPPED|VWSTEADY|VWPERSP)) {
481 /* first time after steady */
482 if (ndrawn)
483 xferdepth(); /* transfer and clear depth */
484 setglortho(); /* set orthographic view */
485
486 }
487 if ((viewflags&(VWMAPPED|VWSTEADY|VWPERSP|VWORTHO)) ==
488 (VWMAPPED|VWSTEADY|VWORTHO)) {
489 /* else update cones */
490 #ifdef STEREO
491 pushright();
492 odUpdate(1); /* draw right eye */
493 popright();
494 #endif
495 odUpdate(0); /* draw left eye */
496 glFlush(); /* flush OpenGL */
497 }
498 rayqleft = RAYQLEN;
499 /* flush X11 and return # pending */
500 return(odev.inpready = XPending(ourdisplay));
501 }
502
503
504 checkglerr(where) /* check for GL or GLU error */
505 char *where;
506 {
507 register GLenum errcode;
508
509 while ((errcode = glGetError()) != GL_NO_ERROR) {
510 sprintf(errmsg, "OpenGL error %s: %s",
511 where, gluErrorString(errcode));
512 error(WARNING, errmsg);
513 }
514 }
515
516
517 static
518 xferdepth() /* load and clear depth buffer */
519 {
520 register GLfloat *dbp;
521 register GLubyte *cbuf;
522
523 if (depthbuffer == NULL) { /* allocate private depth buffer */
524 #ifdef STEREO
525 depthright = (GLfloat *)malloc(
526 odev.hres*odev.vres*sizeof(GLfloat));
527 #endif
528 depthbuffer = (GLfloat *)malloc(
529 odev.hres*odev.vres*sizeof(GLfloat));
530 CHECK(depthbuffer==NULL, SYSTEM, "out of memory in xferdepth");
531 }
532 /* allocate alpha buffer for portals */
533 if (gmPortals)
534 cbuf = (GLubyte *)malloc(odev.hres*odev.vres *
535 (4*sizeof(GLubyte)));
536 else
537 cbuf = NULL;
538 #ifdef STEREO
539 setstereobuf(STEREO_BUFFER_RIGHT);
540 glReadPixels(0, 0, odev.hres, odev.vres,
541 GL_DEPTH_COMPONENT, GL_FLOAT, depthright);
542 if (cbuf != NULL)
543 glReadPixels(0, 0, odev.hres, odev.vres,
544 GL_RGBA, GL_UNSIGNED_BYTE, cbuf);
545 for (dbp = depthright + odev.hres*odev.vres; dbp-- > depthright; )
546 if (cbuf != NULL && isportal(cbuf+4*(dbp-depthright)))
547 *dbp = FHUGE;
548 else
549 *dbp = mapdepth(*dbp);
550 glClear(GL_DEPTH_BUFFER_BIT);
551 setstereobuf(STEREO_BUFFER_LEFT);
552 odDepthMap(1, depthright);
553 #endif
554 /* read back depth buffer */
555 glReadPixels(0, 0, odev.hres, odev.vres,
556 GL_DEPTH_COMPONENT, GL_FLOAT, depthbuffer);
557 if (cbuf != NULL)
558 glReadPixels(0, 0, odev.hres, odev.vres,
559 GL_RGBA, GL_UNSIGNED_BYTE, cbuf);
560 for (dbp = depthbuffer + odev.hres*odev.vres; dbp-- > depthbuffer; )
561 if (cbuf != NULL && isportal(cbuf+4*(dbp-depthbuffer)))
562 *dbp = FHUGE;
563 else
564 *dbp = mapdepth(*dbp);
565 glClear(GL_DEPTH_BUFFER_BIT); /* clear system depth buffer */
566 if (cbuf != NULL)
567 free((char *)cbuf); /* free our color buffer */
568 odDepthMap(0, depthbuffer); /* transfer depth data */
569 }
570
571
572 static
573 freedepth() /* free recorded depth buffer */
574 {
575 if (depthbuffer == NULL)
576 return;
577 #ifdef STEREO
578 odDepthMap(1, NULL);
579 free((char *)depthright);
580 depthright = NULL;
581 #endif
582 odDepthMap(0, NULL);
583 free((char *)depthbuffer);
584 depthbuffer = NULL;
585 }
586
587
588 static double
589 getdistance(dx, dy, direc) /* distance from fore plane along view ray */
590 int dx, dy;
591 FVECT direc;
592 {
593 GLfloat gldepth;
594 GLubyte glcolor[4];
595 double dist;
596
597 if (dx<0 | dx>=odev.hres | dy<0 | dy>=odev.vres)
598 return(FHUGE);
599 if (depthbuffer != NULL)
600 dist = depthbuffer[dy*odev.hres + dx];
601 else {
602 glReadPixels(dx,dy, 1,1, GL_DEPTH_COMPONENT,
603 GL_FLOAT, &gldepth);
604 if (gmPortals) {
605 glReadPixels(dx,dy, 1,1, GL_RGBA,
606 GL_UNSIGNED_BYTE, glcolor);
607 if (isportal(glcolor))
608 return(FHUGE);
609 }
610 dist = mapdepth(gldepth);
611 }
612 if (dist >= .99*FHUGE)
613 return(FHUGE);
614 return((dist-odev.v.vfore)/DOT(direc,odev.v.vdir));
615 }
616
617
618 #ifdef STEREO
619 static
620 pushright() /* push on right view & buffer */
621 {
622 double d;
623
624 setstereobuf(STEREO_BUFFER_RIGHT);
625 if (viewflags & VWPERSP) {
626 glMatrixMode(GL_MODELVIEW);
627 glPushMatrix();
628 d = -eyesepdist / sqrt(odev.v.hn2);
629 glTranslated(d*odev.v.hvec[0], d*odev.v.hvec[1],
630 d*odev.v.hvec[2]);
631 checkglerr("setting right view");
632 }
633 }
634
635
636 static
637 popright() /* pop off right view & buffer */
638 {
639 if (viewflags & VWPERSP) {
640 glMatrixMode(GL_MODELVIEW);
641 glPopMatrix();
642 }
643 setstereobuf(STEREO_BUFFER_LEFT);
644 }
645 #endif
646
647
648 static int
649 mytmflags() /* figure out tone mapping flags */
650 {
651 extern char *progname;
652 register char *cp, *tail;
653 /* find basic name */
654 for (cp = tail = progname; *cp; cp++)
655 if (*cp == '/')
656 tail = cp+1;
657 for (cp = tail; *cp && *cp != '.'; cp++)
658 ;
659 #ifdef DEBUG
660 if (cp > tail && cp[-1] == 'h')
661 return(TM_F_HUMAN);
662 else
663 return(TM_F_CAMERA);
664 #else
665 if (cp > tail && cp[-1] == 'h')
666 return(TM_F_HUMAN|TM_F_NOSTDERR);
667 else
668 return(TM_F_CAMERA|TM_F_NOSTDERR);
669 #endif
670 }
671
672
673 static
674 getevent() /* get next event */
675 {
676 XNextEvent(ourdisplay, levptr(XEvent));
677 switch (levptr(XEvent)->type) {
678 case ConfigureNotify:
679 resizewindow(levptr(XConfigureEvent));
680 break;
681 case UnmapNotify:
682 viewflags &= ~VWMAPPED;
683 break;
684 case MapNotify:
685 odRemap(0);
686 viewflags |= VWMAPPED;
687 break;
688 case Expose:
689 fixwindow(levptr(XExposeEvent));
690 break;
691 case KeyPress:
692 getkey(levptr(XKeyPressedEvent));
693 break;
694 case ButtonPress:
695 if (FRAMESTATE(levptr(XButtonPressedEvent)->state))
696 getframe(levptr(XButtonPressedEvent));
697 else
698 getmove(levptr(XButtonPressedEvent));
699 break;
700 }
701 }
702
703
704 static
705 draw3dline(wp) /* draw 3d line in world coordinates */
706 register FVECT wp[2];
707 {
708 glVertex3d(wp[0][0], wp[0][1], wp[0][2]);
709 glVertex3d(wp[1][0], wp[1][1], wp[1][2]);
710 }
711
712
713 static
714 draw_grids(fore) /* draw holodeck section grids */
715 int fore;
716 {
717 glPushAttrib(GL_LIGHTING_BIT|GL_ENABLE_BIT);
718 glDisable(GL_LIGHTING);
719 if (fore)
720 glColor3ub(4, 250, 250);
721 else
722 glColor3ub(0, 0, 0);
723 glBegin(GL_LINES); /* draw each grid line */
724 gridlines(draw3dline);
725 glEnd();
726 checkglerr("drawing grid lines");
727 glPopAttrib();
728 }
729
730
731 static
732 moveview(dx, dy, mov, orb) /* move our view */
733 int dx, dy, mov, orb;
734 {
735 VIEW nv;
736 FVECT odir, v1, wip;
737 double d, d1;
738 register int li;
739 /* start with old view */
740 copystruct(&nv, &odev.v);
741 /* orient our motion */
742 if (viewray(v1, odir, &odev.v,
743 (dx+.5)/odev.hres, (dy+.5)/odev.vres) < -FTINY)
744 return(0); /* outside view */
745 if (mov | orb) { /* moving relative to geometry */
746 d = getdistance(dx, dy, odir); /* distance from front plane */
747 #ifdef DOBJ
748 d1 = dobj_trace(NULL, v1, odir);
749 if (d1 < d)
750 d = d1;
751 #endif
752 if (d >= .99*FHUGE)
753 d = 0.5*(dev_zmax+dev_zmin); /* just guess */
754 VSUM(wip, v1, odir, d);
755 VSUB(odir, wip, odev.v.vp);
756 } else /* panning with constant viewpoint */
757 VCOPY(nv.vdir, odir);
758 if (orb && mov) { /* orbit left/right */
759 spinvector(odir, odir, nv.vup, d=MOVDEG*PI/180.*mov);
760 VSUM(nv.vp, wip, odir, -1.);
761 spinvector(nv.vdir, nv.vdir, nv.vup, d);
762 } else if (orb) { /* orbit up/down */
763 fcross(v1, odir, nv.vup);
764 if (normalize(v1) == 0.)
765 return(0);
766 spinvector(odir, odir, v1, d=MOVDEG*PI/180.*orb);
767 VSUM(nv.vp, wip, odir, -1.);
768 spinvector(nv.vdir, nv.vdir, v1, d);
769 } else if (mov) { /* move forward/backward */
770 d = MOVPCT/100. * mov;
771 VSUM(nv.vp, nv.vp, odir, d);
772 }
773 if (!mov ^ !orb && viewflags&VWHEADLOCK) { /* restore height */
774 VSUM(v1, odev.v.vp, nv.vp, -1.);
775 d = DOT(v1, nv.vup);
776 VSUM(nv.vp, nv.vp, odev.v.vup, d);
777 }
778 if (setview(&nv) != NULL)
779 return(0); /* illegal view */
780 dev_view(&nv);
781 inpresflags |= DFL(DC_SETVIEW);
782 return(1);
783 }
784
785
786 static
787 getframe(ebut) /* get focus frame */
788 XButtonPressedEvent *ebut;
789 {
790 int startx = ebut->x, starty = ebut->y;
791 int endx, endy;
792
793 XMaskEvent(ourdisplay, ButtonReleaseMask, levptr(XEvent));
794 endx = levptr(XButtonReleasedEvent)->x;
795 endy = levptr(XButtonReleasedEvent)->y;
796 if (endx == startx | endy == starty) {
797 XBell(ourdisplay, 0);
798 return;
799 }
800 if (endx < startx) {register int c = endx; endx = startx; startx = c;}
801 if (endy < starty) {register int c = endy; endy = starty; starty = c;}
802 sprintf(odev_args, "%.3f %.3f %.3f %.3f",
803 (startx+.5)/odev.hres, 1.-(endy+.5)/odev.vres,
804 (endx+.5)/odev.hres, 1.-(starty+.5)/odev.vres);
805 inpresflags |= DFL(DC_FOCUS);
806 }
807
808
809 static
810 getmove(ebut) /* get view change */
811 XButtonPressedEvent *ebut;
812 {
813 int movdir = MOVDIR(ebut->button);
814 int movorb = MOVORB(ebut->state);
815 int ndrawn;
816 Window rootw, childw;
817 int rootx, rooty, wx, wy;
818 unsigned int statemask;
819
820 XNoOp(ourdisplay); /* makes sure we're not idle */
821
822 viewflags &= ~VWSTEADY; /* flag moving view */
823 setglpersp(&odev.v); /* start us off in perspective */
824 while (!XCheckMaskEvent(ourdisplay,
825 ButtonReleaseMask, levptr(XEvent))) {
826 /* get cursor position */
827 if (!XQueryPointer(ourdisplay, gwind, &rootw, &childw,
828 &rootx, &rooty, &wx, &wy, &statemask))
829 break; /* on another screen */
830 /* compute view motion */
831 if (!moveview(wx, odev.vres-1-wy, movdir, movorb)) {
832 sleep(1);
833 continue; /* cursor in bad place */
834 }
835 draw_grids(1); /* redraw grid */
836 #ifdef STEREO
837 pushright();
838 draw_grids(1);
839 ndrawn = gmDrawGeom();
840 #ifdef DOBJ
841 ndrawn += dobj_render();
842 #endif
843 if (ndrawn)
844 doportals();
845 popright();
846 #endif
847 /* redraw octrees */
848 ndrawn = gmDrawGeom();
849 #ifdef DOBJ
850 ndrawn += dobj_render(); /* redraw objects */
851 #endif
852 if (ndrawn)
853 doportals();
854 glXSwapBuffers(ourdisplay, gwind);
855 if (!ndrawn)
856 sleep(1); /* for reasonable interaction */
857 }
858 if (!(inpresflags & DFL(DC_SETVIEW))) { /* do final motion */
859 movdir = MOVDIR(levptr(XButtonReleasedEvent)->button);
860 wx = levptr(XButtonReleasedEvent)->x;
861 wy = levptr(XButtonReleasedEvent)->y;
862 moveview(wx, odev.vres-1-wy, movdir, movorb);
863 }
864 viewflags |= VWSTEADY; /* done goofing around */
865 }
866
867
868 static
869 setglpersp(vp) /* set perspective view in GL */
870 register VIEW *vp;
871 {
872 double d, xmin, xmax, ymin, ymax;
873 GLfloat vec[4];
874 double depthlim[2];
875 /* set depth limits */
876 gmDepthLimit(depthlim, odev.v.vp, odev.v.vdir);
877 if (depthlim[0] >= depthlim[1]) {
878 dev_zmin = 1.;
879 dev_zmax = 100.;
880 } else {
881 dev_zmin = 0.5*depthlim[0];
882 dev_zmax = 1.75*depthlim[1];
883 if (dev_zmin > dev_zmax/5.)
884 dev_zmin = dev_zmax/5.;
885 }
886 if (odev.v.vfore > FTINY)
887 dev_zmin = odev.v.vfore;
888 if (odev.v.vaft > FTINY)
889 dev_zmax = odev.v.vaft;
890 if (dev_zmin < dev_zmax/100.)
891 dev_zmin = dev_zmax/100.;
892 setzrat();
893 xmax = dev_zmin * tan(PI/180./2. * odev.v.horiz);
894 xmin = -xmax;
895 d = odev.v.hoff * (xmax - xmin);
896 xmin += d; xmax += d;
897 ymax = dev_zmin * tan(PI/180./2. * odev.v.vert);
898 ymin = -ymax;
899 d = odev.v.voff * (ymax - ymin);
900 ymin += d; ymax += d;
901 /* set view matrix */
902 glMatrixMode(GL_PROJECTION);
903 glLoadIdentity();
904 glFrustum(xmin, xmax, ymin, ymax, dev_zmin, dev_zmax);
905 gluLookAt(odev.v.vp[0], odev.v.vp[1], odev.v.vp[2],
906 odev.v.vp[0] + odev.v.vdir[0],
907 odev.v.vp[1] + odev.v.vdir[1],
908 odev.v.vp[2] + odev.v.vdir[2],
909 odev.v.vup[0], odev.v.vup[1], odev.v.vup[2]);
910 checkglerr("setting perspective view");
911 vec[0] = vec[1] = vec[2] = 0.; vec[3] = 1.;
912 glLightModelfv(GL_LIGHT_MODEL_AMBIENT, vec);
913 vec[0] = -odev.v.vdir[0];
914 vec[1] = -odev.v.vdir[1];
915 vec[2] = -odev.v.vdir[2];
916 vec[3] = 0.;
917 glLightfv(GL_LIGHT0, GL_POSITION, vec);
918 vec[0] = vec[1] = vec[2] = .7; vec[3] = 1.;
919 glLightfv(GL_LIGHT0, GL_SPECULAR, vec);
920 glLightfv(GL_LIGHT0, GL_DIFFUSE, vec);
921 vec[0] = vec[1] = vec[2] = .3; vec[3] = 1.;
922 glLightfv(GL_LIGHT0, GL_AMBIENT, vec);
923 glEnable(GL_LIGHT0);
924 glEnable(GL_LIGHTING); /* light our GL objects */
925 glShadeModel(GL_SMOOTH);
926 viewflags &= ~VWORTHO;
927 viewflags |= VWPERSP;
928 }
929
930
931 static
932 setglortho() /* set up orthographic view for cone drawing */
933 {
934 glDrawBuffer(GL_FRONT); /* use single-buffer mode */
935 /* set view matrix */
936 glMatrixMode(GL_PROJECTION);
937 glLoadIdentity();
938 glOrtho(0., (double)odev.hres, 0., (double)odev.vres,
939 0.001*OMAXDEPTH, 1.001*(-OMAXDEPTH));
940 checkglerr("setting orthographic view");
941 glDisable(GL_LIGHTING); /* cones are constant color */
942 glShadeModel(GL_FLAT);
943 viewflags &= ~VWPERSP;
944 viewflags |= VWORTHO;
945 }
946
947
948 static
949 wipeclean() /* prepare for redraw */
950 {
951 glDrawBuffer(GL_BACK); /* use double-buffer mode */
952 glReadBuffer(GL_FRONT); /* read back visible contents */
953 glColorMask(GL_TRUE, GL_TRUE, GL_TRUE, GL_TRUE);
954 /* clear buffers */
955 #ifdef STEREO
956 setstereobuf(STEREO_BUFFER_RIGHT);
957 glClear(GL_DEPTH_BUFFER_BIT|GL_COLOR_BUFFER_BIT);
958 setstereobuf(STEREO_BUFFER_LEFT);
959 #endif
960 glClear(GL_DEPTH_BUFFER_BIT|GL_COLOR_BUFFER_BIT);
961 glColorMask(GL_TRUE, GL_TRUE, GL_TRUE, GL_FALSE);
962 freedepth();
963 if ((viewflags&(VWCHANGE|VWSTEADY)) ==
964 (VWCHANGE|VWSTEADY)) { /* clear samples if new */
965 odClean();
966 viewflags &= ~VWCHANGE; /* change noted */
967 }
968 setglpersp(&odev.v); /* reset view & clipping planes */
969 }
970
971
972 static
973 getkey(ekey) /* get input key */
974 register XKeyPressedEvent *ekey;
975 {
976 Window rootw, childw;
977 int rootx, rooty, wx, wy;
978 unsigned int statemask;
979 int n;
980 char buf[8];
981
982 n = XLookupString(ekey, buf, sizeof(buf), NULL, NULL);
983 if (n != 1)
984 return;
985 switch (buf[0]) {
986 case 'h': /* turn on height motion lock */
987 viewflags |= VWHEADLOCK;
988 return;
989 case 'H': /* turn off height motion lock */
990 viewflags &= ~VWHEADLOCK;
991 return;
992 case 'l': /* retrieve last view */
993 inpresflags |= DFL(DC_LASTVIEW);
994 return;
995 case 'p': /* pause computation */
996 inpresflags |= DFL(DC_PAUSE);
997 return;
998 case 'v': /* spit out view */
999 inpresflags |= DFL(DC_GETVIEW);
1000 return;
1001 case 'f': /* frame view position */
1002 if (!XQueryPointer(ourdisplay, gwind, &rootw, &childw,
1003 &rootx, &rooty, &wx, &wy, &statemask))
1004 return; /* on another screen */
1005 sprintf(odev_args, "%.4f %.4f", (wx+.5)/odev.hres,
1006 1.-(wy+.5)/odev.vres);
1007 inpresflags |= DFL(DC_FOCUS);
1008 return;
1009 case 'F': /* unfocus */
1010 odev_args[0] = '\0';
1011 inpresflags |= DFL(DC_FOCUS);
1012 return;
1013 case '\n':
1014 case '\r': /* resume computation */
1015 inpresflags |= DFL(DC_RESUME);
1016 return;
1017 case CTRL('R'): /* redraw screen */
1018 odRemap(0);
1019 glClear(GL_DEPTH_BUFFER_BIT);
1020 #ifdef STEREO
1021 setstereobuf(STEREO_BUFFER_RIGHT);
1022 glClear(GL_DEPTH_BUFFER_BIT);
1023 setstereobuf(STEREO_BUFFER_LEFT);
1024 #endif
1025 return;
1026 case CTRL('L'): /* refresh from server */
1027 if (inpresflags & DFL(DC_REDRAW))
1028 return;
1029 XRaiseWindow(ourdisplay, gwind);
1030 XFlush(ourdisplay);
1031 sleep(1);
1032 wipeclean(); /* fresh display */
1033 odRemap(1); /* fresh tone mapping */
1034 dev_flush(); /* draw octrees */
1035 inpresflags |= DFL(DC_REDRAW); /* resend values from server */
1036 rayqleft = 0; /* hold off update */
1037 return;
1038 case 'K': /* kill rtrace process(es) */
1039 inpresflags |= DFL(DC_KILL);
1040 break;
1041 case 'R': /* restart rtrace */
1042 inpresflags |= DFL(DC_RESTART);
1043 break;
1044 case 'C': /* clobber holodeck */
1045 inpresflags |= DFL(DC_CLOBBER);
1046 break;
1047 case 'q': /* quit the program */
1048 inpresflags |= DFL(DC_QUIT);
1049 return;
1050 default:
1051 XBell(ourdisplay, 0);
1052 return;
1053 }
1054 }
1055
1056
1057 static
1058 fixwindow(eexp) /* repair damage to window */
1059 register XExposeEvent *eexp;
1060 {
1061 int xmin, ymin, xmax, ymax;
1062
1063 if (odev.hres == 0 | odev.vres == 0) { /* first exposure */
1064 resizewindow((XConfigureEvent *)eexp);
1065 return;
1066 }
1067 xmin = eexp->x; xmax = eexp->x + eexp->width;
1068 ymin = odev.vres - eexp->y - eexp->height; ymax = odev.vres - eexp->y;
1069 /* clear portion of depth */
1070 glPushAttrib(GL_DEPTH_BUFFER_BIT|GL_COLOR_BUFFER_BIT);
1071 glColorMask(GL_FALSE, GL_FALSE, GL_FALSE, GL_FALSE);
1072 glDepthFunc(GL_ALWAYS);
1073 glBegin(GL_POLYGON);
1074 glVertex3i(xmin, ymin, OMAXDEPTH);
1075 glVertex3i(xmax, ymin, OMAXDEPTH);
1076 glVertex3i(xmax, ymax, OMAXDEPTH);
1077 glVertex3i(xmin, ymax, OMAXDEPTH);
1078 glEnd();
1079 #ifdef STEREO
1080 setstereobuf(STEREO_BUFFER_RIGHT);
1081 glBegin(GL_POLYGON);
1082 glVertex3i(xmin, ymin, OMAXDEPTH);
1083 glVertex3i(xmax, ymin, OMAXDEPTH);
1084 glVertex3i(xmax, ymax, OMAXDEPTH);
1085 glVertex3i(xmin, ymax, OMAXDEPTH);
1086 glEnd();
1087 odRedraw(1, xmin, ymin, xmax, ymax);
1088 setstereobuf(STEREO_BUFFER_LEFT);
1089 #endif
1090 glPopAttrib();
1091 odRedraw(0, xmin, ymin, xmax, ymax);
1092 }
1093
1094
1095 static
1096 resizewindow(ersz) /* resize window */
1097 register XConfigureEvent *ersz;
1098 {
1099 glViewport(0, 0, ersz->width, ersz->height);
1100
1101 if (ersz->width == odev.hres && ersz->height == odev.vres)
1102 return;
1103
1104 odev.hres = ersz->width;
1105 odev.vres = ersz->height;
1106
1107 odev.v.horiz = 2.*180./PI * atan(0.5/VIEWDIST*pwidth*odev.hres);
1108 odev.v.vert = 2.*180./PI * atan(0.5/VIEWDIST*pheight*odev.vres);
1109
1110 inpresflags |= DFL(DC_SETVIEW);
1111 viewflags |= VWCHANGE;
1112 }
