root/radiance/ray/src/hd/rhd_ogl.c
Revision: 3.3
Committed: Mon Dec 21 11:42:38 1998 UTC (26 years, 5 months ago) by gwlarson
Changes since 3.2: +62 -29 lines
got portals working with or without alpha buffer
1 /* Copyright (c) 1998 Silicon Graphics, Inc. */
2
3 #ifndef lint
4 static char SCCSid[] = "$SunId$ SGI";
5 #endif
6
7 /*
8 * OpenGL driver for holodeck display.
9 * Based on GLX driver using T-mesh.
10 *
11 * Define symbol STEREO for stereo viewing.
12 * Define symbol DOBJ for display object viewing.
13 */
14
15 #ifdef NOSTEREO
16 #ifdef STEREO
17 #undef STEREO
18 #else
19 #undef NOSTEREO
20 #endif
21 #endif
22
23 #include "standard.h"
24
25 #include <sys/types.h>
26 #include <GL/glx.h>
27 #include <GL/glu.h>
28 #ifdef STEREO
29 #include <X11/extensions/SGIStereo.h>
30 #endif
31
32 #include "rhd_odraw.h"
33 #ifdef DOBJ
34 #include "rhdobj.h"
35 #endif
36
37 #include "x11icon.h"
38
39 #ifndef RAYQLEN
40 #define RAYQLEN 10240 /* max. rays to queue before flush */
41 #endif
42
43 #ifndef PORTALP
44 #define PORTRED 2 /* portal red color */
45 #define PORTGRN -1 /* portal green left alone */
46 #define PORTBLU 128 /* portal blue color */
47 #define PORTALP -1 /* don't use alpha channel */
48 #endif
49 #define isportal(c) ((PORTRED<0 || (c)[0]==PORTRED) && \
50 (PORTGRN<0 || (c)[1]==PORTGRN) && \
51 (PORTBLU<0 || (c)[2]==PORTBLU) && \
52 (PORTALP<0 || (c)[3]==PORTALP))
53
54 #ifndef FEQ
55 #define FEQ(a,b) ((a)-(b) <= FTINY && (a)-(b) >= -FTINY)
56 #endif
57
58 #define GAMMA 1.4 /* default gamma correction */
59
60 #define FRAMESTATE(s) (((s)&(ShiftMask|ControlMask))==(ShiftMask|ControlMask))
61
62 #define MOVPCT 7 /* percent distance to move /frame */
63 #define MOVDIR(b) ((b)==Button1 ? 1 : (b)==Button2 ? 0 : -1)
64 #define MOVDEG (-5) /* degrees to orbit CW/down /frame */
65 #define MOVORB(s) ((s)&ShiftMask ? 1 : (s)&ControlMask ? -1 : 0)
66
67 #define MINWIDTH 480 /* minimum graphics window width */
68 #define MINHEIGHT 400 /* minimum graphics window height */
69
70 #define VIEWDIST 356 /* assumed viewing distance (mm) */
71
72 #define BORWIDTH 5 /* border width */
73
74 #define setstereobuf(bid) (glXWaitGL(), \
75 XSGISetStereoBuffer(ourdisplay, gwind, bid), \
76 glXWaitX())
77
78 #define ourscreen DefaultScreen(ourdisplay)
79 #define ourroot RootWindow(ourdisplay,ourscreen)
80 #define ourmask (StructureNotifyMask|ExposureMask|KeyPressMask|\
81 ButtonPressMask|ButtonReleaseMask)
82
83 #define levptr(etype) ((etype *)&currentevent)
84
85 struct driver odev; /* global device driver structure */
86
87 char odev_args[64]; /* command arguments */
88
89 static GLfloat *depthbuffer = NULL; /* depth buffer */
90
91 #ifdef STEREO
92 static VIEW vwright; /* right eye view */
93 static GLfloat *depthright = NULL; /* right depth buffer */
94 #endif
95
96 static int rayqleft = 0; /* rays left to queue before flush */
97
98 static XEvent currentevent; /* current event */
99
100 static int mapped = 0; /* window is mapped? */
101 static unsigned long ourblack=0, ourwhite=~0;
102
103 static Display *ourdisplay = NULL; /* our display */
104 static XVisualInfo *ourvinf; /* our visual information */
105 static Window gwind = 0; /* our graphics window */
106 static GLXContext gctx; /* our GLX context */
107
108 static double pwidth, pheight; /* pixel dimensions (mm) */
109
110 static double dev_zmin, dev_zmax; /* fore and aft clipping plane dist. */
111 static double dev_zrat; /* (1. - dev_zmin/dev_zmax) */
112
113 #define setzrat() (dev_zrat = 1. - dev_zmin/dev_zmax)
114 #define mapdepth(d) ((d)>0.9995 ? FHUGE : dev_zmin/(1.-(d)*dev_zrat))
115
116 static int inpresflags; /* input result flags */
117
118 static int headlocked; /* lock vertical motion */
119
120 static int isperspective; /* perspective/ortho view */
121
122 static int viewsteady; /* is view steady? */
123
124 static int resizewindow(), getevent(), getkey(), moveview(), wipeclean(),
125 xferdepth(), freedepth(), setglortho(),
126 setglpersp(), getframe(), getmove(), fixwindow(), mytmflags();
127
128 static double getdistance();
129
130 #ifdef STEREO
131 static int pushright(), popright();
132 #endif
133
134 extern int gmPortals; /* GL portal list id */
135
136 extern time_t time();
137
138
139 dev_open(id) /* initialize GLX driver */
140 char *id;
141 {
142 extern char *getenv();
143 static RGBPRIMS myprims = STDPRIMS;
144 #if (PORTALP<0)
145 static int atlBest[] = {GLX_RGBA, GLX_RED_SIZE,8,
146 GLX_GREEN_SIZE,8, GLX_BLUE_SIZE,8,
147 GLX_DEPTH_SIZE,15, None};
148 #else
149 static int atlBest[] = {GLX_RGBA, GLX_RED_SIZE,8,
150 GLX_GREEN_SIZE,8, GLX_BLUE_SIZE,8,
151 GLX_ALPHA_SIZE,2, GLX_DEPTH_SIZE,15, None};
152 #endif
153 char *ev;
154 double gamval = GAMMA;
155 RGBPRIMP dpri = stdprims;
156 XSetWindowAttributes ourwinattr;
157 XWMHints ourxwmhints;
158 XSizeHints oursizhints;
159 /* check for unsupported stereo */
160 #ifdef NOSTEREO
161 error(INTERNAL, "stereo display driver unavailable");
162 #endif
163 /* open display server */
164 ourdisplay = XOpenDisplay(NULL);
165 if (ourdisplay == NULL)
166 error(USER, "cannot open X-windows; DISPLAY variable set?\n");
167 #ifdef STEREO
168 switch (XSGIQueryStereoMode(ourdisplay, ourroot)) {
169 case STEREO_TOP:
170 case STEREO_BOTTOM:
171 break;
172 case STEREO_OFF:
173 error(USER,
174 "wrong video mode: run \"/usr/gfx/setmon -n STR_TOP\" first");
175 case X_STEREO_UNSUPPORTED:
176 error(USER, "stereo mode not supported on this screen");
177 default:
178 error(INTERNAL, "unknown stereo mode");
179 }
180 #endif
181 /* find a usable visual */
182 ourvinf = glXChooseVisual(ourdisplay, ourscreen, atlBest);
183 if (ourvinf == NULL)
184 error(USER, "no suitable visuals available");
185 /* get a context */
186 gctx = glXCreateContext(ourdisplay, ourvinf, NULL, GL_TRUE);
187 /* set gamma and tone mapping */
188 if ((ev = XGetDefault(ourdisplay, "radiance", "gamma")) != NULL
189 || (ev = getenv("DISPLAY_GAMMA")) != NULL)
190 gamval = atof(ev);
191 if ((ev = getenv("DISPLAY_PRIMARIES")) != NULL &&
192 sscanf(ev, "%f %f %f %f %f %f %f %f",
193 &myprims[RED][CIEX],&myprims[RED][CIEY],
194 &myprims[GRN][CIEX],&myprims[GRN][CIEY],
195 &myprims[BLU][CIEX],&myprims[BLU][CIEY],
196 &myprims[WHT][CIEX],&myprims[WHT][CIEY]) >= 6)
197 dpri = myprims;
198 if (tmInit(mytmflags(), dpri, gamval) == NULL)
199 error(SYSTEM, "not enough memory in dev_open");
200 /* open window */
201 ourwinattr.background_pixel = ourblack;
202 ourwinattr.border_pixel = ourblack;
203 ourwinattr.event_mask = ourmask;
204 /* this is stupid */
205 ourwinattr.colormap = XCreateColormap(ourdisplay, ourroot,
206 ourvinf->visual, AllocNone);
207 gwind = XCreateWindow(ourdisplay, ourroot, 0, 0,
208 DisplayWidth(ourdisplay,ourscreen)-2*BORWIDTH,
209 #ifdef STEREO
210 (DisplayHeight(ourdisplay,ourscreen)-2*BORWIDTH)/2,
211 #else
212 DisplayHeight(ourdisplay,ourscreen)-2*BORWIDTH,
213 #endif
214 BORWIDTH, ourvinf->depth, InputOutput, ourvinf->visual,
215 CWBackPixel|CWBorderPixel|CWColormap|CWEventMask, &ourwinattr);
216 if (gwind == 0)
217 error(SYSTEM, "cannot create window\n");
218 XStoreName(ourdisplay, gwind, id);
219 /* set window manager hints */
220 ourxwmhints.flags = InputHint|IconPixmapHint;
221 ourxwmhints.input = True;
222 ourxwmhints.icon_pixmap = XCreateBitmapFromData(ourdisplay,
223 gwind, x11icon_bits, x11icon_width, x11icon_height);
224 XSetWMHints(ourdisplay, gwind, &ourxwmhints);
225 oursizhints.min_width = MINWIDTH;
226 #ifdef STEREO
227 oursizhints.min_height = MINHEIGHT/2;
228 oursizhints.max_width = DisplayWidth(ourdisplay,ourscreen)-2*BORWIDTH;
229 oursizhints.max_height = (DisplayHeight(ourdisplay,ourscreen) -
230 2*BORWIDTH)/2;
231 oursizhints.flags = PMinSize|PMaxSize;
232 #else
233 oursizhints.min_height = MINHEIGHT;
234 oursizhints.flags = PMinSize;
235 #endif
236 XSetNormalHints(ourdisplay, gwind, &oursizhints);
237 /* set GLX context */
238 glXMakeCurrent(ourdisplay, gwind, gctx);
239 glEnable(GL_DEPTH_TEST);
240 glDepthFunc(GL_LEQUAL);
241 glDisable(GL_DITHER);
242 glFrontFace(GL_CCW);
243 glDisable(GL_CULL_FACE);
244 glLightModeli(GL_LIGHT_MODEL_TWO_SIDE, GL_TRUE);
245 glPolygonMode(GL_FRONT_AND_BACK, GL_FILL);
246 /* figure out sensible view */
247 pwidth = (double)DisplayWidthMM(ourdisplay, ourscreen) /
248 DisplayWidth(ourdisplay, ourscreen);
249 pheight = (double)DisplayHeightMM(ourdisplay, ourscreen) /
250 DisplayHeight(ourdisplay, ourscreen);
251 #ifdef STEREO
252 pheight *= 2.;
253 setstereobuf(STEREO_BUFFER_LEFT);
254 #endif
255 checkglerr("setting rendering parameters");
256 copystruct(&odev.v, &stdview);
257 odev.v.type = VT_PER;
258 headlocked = 0; /* free up head movement */
259 viewsteady = 1; /* view starts static */
260 isperspective = -1; /* but no view set, yet */
261 /* map the window */
262 XMapWindow(ourdisplay, gwind);
263 dev_input(); /* sets size and view angles */
264 if (!odInit(DisplayWidth(ourdisplay,ourscreen) *
265 DisplayHeight(ourdisplay,ourscreen) / 10))
266 error(SYSTEM, "insufficient memory for value storage");
267 odev.name = id;
268 odev.firstuse = 1; /* can't recycle samples */
269 odev.ifd = ConnectionNumber(ourdisplay);
270 }
271
272
273 dev_close() /* close our display and free resources */
274 {
275 #ifdef DOBJ
276 dobj_cleanup();
277 #endif
278 freedepth();
279 gmEndGeom();
280 gmEndPortal();
281 odDone();
282 glXMakeCurrent(ourdisplay, None, NULL);
283 glXDestroyContext(ourdisplay, gctx);
284 XDestroyWindow(ourdisplay, gwind);
285 gwind = 0;
286 XCloseDisplay(ourdisplay);
287 ourdisplay = NULL;
288 tmDone(NULL);
289 odev.v.type = 0;
290 odev.hres = odev.vres = 0;
291 odev.ifd = -1;
292 }
293
294
295 dev_clear() /* clear our representation */
296 {
297 wipeclean();
298 rayqleft = 0; /* hold off update */
299 }
300
301
302 int
303 dev_view(nv) /* assign new driver view */
304 register VIEW *nv;
305 {
306 double d;
307
308 if (nv->type != VT_PER || /* check view legality */
309 nv->horiz > 160. || nv->vert > 160.) {
310 error(COMMAND, "illegal view type/angle");
311 nv->type = odev.v.type;
312 nv->horiz = odev.v.horiz;
313 nv->vert = odev.v.vert;
314 return(0);
315 }
316 if (nv != &odev.v) {
317 /* resize window? */
318 if (!FEQ(nv->horiz,odev.v.horiz) ||
319 !FEQ(nv->vert,odev.v.vert)) {
320 int dw = DisplayWidth(ourdisplay,ourscreen);
321 int dh = DisplayHeight(ourdisplay,ourscreen);
322
323 dw -= 25; /* for window frame */
324 dh -= 50;
325 #ifdef STEREO
326 dh /= 2;
327 #endif
328 odev.hres = 2.*VIEWDIST/pwidth *
329 tan(PI/180./2.*nv->horiz);
330 odev.vres = 2.*VIEWDIST/pheight *
331 tan(PI/180./2.*nv->vert);
332 if (odev.hres > dw) {
333 odev.vres = dw * odev.vres / odev.hres;
334 odev.hres = dw;
335 }
336 if (odev.vres > dh) {
337 odev.hres = dh * odev.hres / odev.vres;
338 odev.vres = dh;
339 }
340 XResizeWindow(ourdisplay, gwind, odev.hres, odev.vres);
341 dev_input(); /* get resize event */
342 }
343 copystruct(&odev.v, nv); /* setview() already called */
344 #ifdef STEREO
345 copystruct(&vwright, nv);
346 d = eyesepdist / sqrt(nv->hn2);
347 VSUM(vwright.vp, nv->vp, nv->hvec, d);
348 /* setview(&vwright); -- Unnecessary */
349 #endif
350 } else
351 viewsteady = 1;
352 wipeclean();
353 return(1);
354 }
355
356
357 dev_section(gfn, pfn) /* add octree for geometry rendering */
358 char *gfn, *pfn;
359 {
360 extern char *index();
361 char *cp;
362
363 if (gfn == NULL) {
364 gmEndGeom();
365 gmEndPortal();
366 return;
367 }
368 if (access(gfn, R_OK) == 0)
369 gmNewGeom(gfn);
370 #ifdef DEBUG
371 else {
372 sprintf(errmsg, "cannot load octree \"%s\"", gfn);
373 error(WARNING, errmsg);
374 }
375 #endif
376 if (pfn != NULL)
377 gmNewPortal(pfn);
378 }
379
380
381 dev_auxcom(cmd, args) /* process an auxiliary command */
382 char *cmd, *args;
383 {
384 #ifdef DOBJ
385 if (dobj_command(cmd, args) >= 0)
386 return;
387 #endif
388 sprintf(errmsg, "%s: unknown command", cmd);
389 error(COMMAND, errmsg);
390 }
391
392
393 VIEW *
394 dev_auxview(n, hvres) /* return nth auxiliary view */
395 int n;
396 int hvres[2];
397 {
398 hvres[0] = odev.hres; hvres[1] = odev.vres;
399 if (n == 0)
400 return(&odev.v);
401 #ifdef STEREO
402 if (n == 1)
403 return(&vwright);
404 #endif
405 return(NULL);
406 }
407
408
409 int
410 dev_input() /* get X11 input */
411 {
412 inpresflags = 0;
413
414 do
415 getevent();
416
417 while (XPending(ourdisplay) > 0);
418
419 odev.inpready = 0;
420
421 return(inpresflags);
422 }
423
424
425 dev_value(c, d, p) /* add a pixel value to our texture */
426 COLR c;
427 FVECT d, p;
428 {
429 #ifdef DOBJ
430 if (dobj_lightsamp != NULL) { /* in light source sampling */
431 (*dobj_lightsamp)(c, d, p);
432 return;
433 }
434 #endif
435 odSample(c, d, p); /* add to display representation */
436 if (!--rayqleft)
437 dev_flush(); /* flush output */
438 }
439
440
441 int
442 dev_flush() /* flush output as appropriate */
443 {
444 int ndrawn;
445
446 if (mapped && isperspective > 0) {
447 #ifdef STEREO
448 pushright(); /* draw right eye */
449 ndrawn = gmDrawGeom();
450 #ifdef DOBJ
451 ndrawn += dobj_render();
452 #endif
453 if (ndrawn)
454 gmDrawPortals(PORTRED, PORTGRN, PORTBLU, PORTALP);
455 checkglerr("rendering right eye");
456 popright(); /* draw left eye */
457 #endif
458 ndrawn = gmDrawGeom();
459 #ifdef DOBJ
460 ndrawn += dobj_render();
461 #endif
462 if (ndrawn)
463 gmDrawPortals(PORTRED, PORTGRN, PORTBLU, PORTALP);
464 checkglerr("rendering base view");
465 }
466 if (mapped && viewsteady) {
467 if (isperspective) { /* first time after steady */
468 #ifdef STEREO
469 pushright();
470 popright();
471 #endif
472 if (ndrawn)
473 xferdepth(); /* transfer and clear depth */
474 setglortho(); /* set orthographic view */
475 } else {
476 #ifdef STEREO
477 pushright();
478 odUpdate(1); /* draw right eye */
479 popright();
480 #endif
481 odUpdate(0); /* draw left eye */
482 }
483 }
484 glFlush(); /* flush OpenGL */
485 rayqleft = RAYQLEN;
486 /* flush X11 and return # pending */
487 return(odev.inpready = XPending(ourdisplay));
488 }
489
490
491 checkglerr(where) /* check for GL or GLU error */
492 char *where;
493 {
494 register GLenum errcode;
495
496 while ((errcode = glGetError()) != GL_NO_ERROR) {
497 sprintf(errmsg, "OpenGL error %s: %s",
498 where, gluErrorString(errcode));
499 error(WARNING, errmsg);
500 }
501 }
502
503
504 static
505 xferdepth() /* load and clear depth buffer */
506 {
507 register GLfloat *dbp;
508 register GLubyte *cbuf;
509
510 if (depthbuffer == NULL) { /* allocate private depth buffer */
511 #ifdef STEREO
512 depthright = (GLfloat *)malloc(
513 odev.hres*odev.vres*sizeof(GLfloat));
514 #endif
515 depthbuffer = (GLfloat *)malloc(
516 odev.hres*odev.vres*sizeof(GLfloat));
517 if (depthbuffer == NULL)
518 error(SYSTEM, "out of memory in xferdepth");
519 }
520 /* allocate alpha buffer for portals */
521 if (gmPortals)
522 cbuf = (GLubyte *)malloc(odev.hres*odev.vres*
523 (4*sizeof(GLubyte)));
524 else
525 cbuf = NULL;
526 #ifdef STEREO
527 setstereobuf(STEREO_BUFFER_RIGHT);
528 glReadPixels(0, 0, odev.hres, odev.vres,
529 GL_DEPTH_COMPONENT, GL_FLOAT, depthright);
530 if (cbuf != NULL)
531 glReadPixels(0, 0, odev.hres, odev.vres,
532 GL_RGBA, GL_UNSIGNED_BYTE, cbuf);
533 for (dbp = depthright + odev.hres*odev.vres; dbp-- > depthright; )
534 if (cbuf != NULL && isportal(cbuf+4*(dbp-depthright)))
535 *dbp = FHUGE;
536 else
537 *dbp = mapdepth(*dbp);
538 glClear(GL_DEPTH_BUFFER_BIT);
539 setstereobuf(STEREO_BUFFER_LEFT);
540 odDepthMap(1, depthright);
541 #endif
542 /* read back depth buffer */
543 glReadPixels(0, 0, odev.hres, odev.vres,
544 GL_DEPTH_COMPONENT, GL_FLOAT, depthbuffer);
545 if (cbuf != NULL)
546 glReadPixels(0, 0, odev.hres, odev.vres,
547 GL_RGBA, GL_UNSIGNED_BYTE, cbuf);
548 for (dbp = depthbuffer + odev.hres*odev.vres; dbp-- > depthbuffer; )
549 if (cbuf != NULL && isportal(cbuf+4*(dbp-depthbuffer)))
550 *dbp = FHUGE;
551 else
552 *dbp = mapdepth(*dbp);
553 glClear(GL_DEPTH_BUFFER_BIT); /* clear system depth buffer */
554 if (cbuf != NULL)
555 free((char *)cbuf); /* free our color buffer */
556 odDepthMap(0, depthbuffer); /* transfer depth data */
557 }
558
559
560 static
561 freedepth() /* free recorded depth buffer */
562 {
563 if (depthbuffer == NULL)
564 return;
565 #ifdef STEREO
566 odDepthMap(1, NULL);
567 free((char *)depthright);
568 depthright = NULL;
569 #endif
570 odDepthMap(0, NULL);
571 free((char *)depthbuffer);
572 depthbuffer = NULL;
573 }
574
575
576 static double
577 getdistance(dx, dy, direc) /* distance from fore plane along view ray */
578 int dx, dy;
579 FVECT direc;
580 {
581 GLfloat gldepth;
582 GLubyte glcolor[4];
583 double dist;
584
585 if (dx<0 | dx>=odev.hres | dy<0 | dy>=odev.vres)
586 return(FHUGE);
587 if (depthbuffer != NULL)
588 dist = depthbuffer[dy*odev.hres + dx];
589 else {
590 glReadPixels(dx,dy, 1,1, GL_DEPTH_COMPONENT,
591 GL_FLOAT, &gldepth);
592 if (gmPortals) {
593 glReadPixels(dx,dy, 1,1, GL_RGBA,
594 GL_UNSIGNED_BYTE, glcolor);
595 if (isportal(glcolor))
596 return(FHUGE);
597 }
598 dist = mapdepth(gldepth);
599 }
600 if (dist >= .99*FHUGE)
601 return(FHUGE);
602 return((dist-odev.v.vfore)/DOT(direc,odev.v.vdir));
603 }
604
605
606 #ifdef STEREO
607 static
608 pushright() /* push on right view & buffer */
609 {
610 double d;
611
612 setstereobuf(STEREO_BUFFER_RIGHT);
613 if (isperspective > 0) {
614 glMatrixMode(GL_MODELVIEW);
615 glPushMatrix();
616 d = -eyesepdist / sqrt(odev.v.hn2);
617 glTranslated(d*odev.v.hvec[0], d*odev.v.hvec[1],
618 d*odev.v.hvec[2]);
619 checkglerr("setting right view");
620 }
621 }
622
623
624 static
625 popright() /* pop off right view & buffer */
626 {
627 if (isperspective > 0) {
628 glMatrixMode(GL_MODELVIEW);
629 glPopMatrix();
630 }
631 setstereobuf(STEREO_BUFFER_LEFT);
632 }
633 #endif
634
635
636 static int
637 mytmflags() /* figure out tone mapping flags */
638 {
639 extern char *progname;
640 register char *cp, *tail;
641 /* find basic name */
642 for (cp = tail = progname; *cp; cp++)
643 if (*cp == '/')
644 tail = cp+1;
645 for (cp = tail; *cp && *cp != '.'; cp++)
646 ;
647 #ifdef DEBUG
648 if (cp > tail && cp[-1] == 'h')
649 return(TM_F_HUMAN);
650 else
651 return(TM_F_CAMERA);
652 #else
653 if (cp > tail && cp[-1] == 'h')
654 return(TM_F_HUMAN|TM_F_NOSTDERR);
655 else
656 return(TM_F_CAMERA|TM_F_NOSTDERR);
657 #endif
658 }
659
660
661 static
662 getevent() /* get next event */
663 {
664 XNextEvent(ourdisplay, levptr(XEvent));
665 switch (levptr(XEvent)->type) {
666 case ConfigureNotify:
667 resizewindow(levptr(XConfigureEvent));
668 break;
669 case UnmapNotify:
670 mapped = 0;
671 break;
672 case MapNotify:
673 odRemap(0);
674 mapped = 1;
675 break;
676 case Expose:
677 fixwindow(levptr(XExposeEvent));
678 break;
679 case KeyPress:
680 getkey(levptr(XKeyPressedEvent));
681 break;
682 case ButtonPress:
683 if (FRAMESTATE(levptr(XButtonPressedEvent)->state))
684 getframe(levptr(XButtonPressedEvent));
685 else
686 getmove(levptr(XButtonPressedEvent));
687 break;
688 }
689 }
690
691
692 static
693 draw3dline(wp) /* draw 3d line in world coordinates */
694 register FVECT wp[2];
695 {
696 glVertex3d(wp[0][0], wp[0][1], wp[0][2]);
697 glVertex3d(wp[1][0], wp[1][1], wp[1][2]);
698 }
699
700
701 static
702 draw_grids(fore) /* draw holodeck section grids */
703 int fore;
704 {
705 glPushAttrib(GL_LIGHTING_BIT|GL_ENABLE_BIT);
706 glDisable(GL_LIGHTING);
707 if (fore)
708 glColor3ub(0, 255, 255);
709 else
710 glColor3ub(0, 0, 0);
711 glBegin(GL_LINES); /* draw each grid line */
712 gridlines(draw3dline);
713 glEnd();
714 checkglerr("drawing grid lines");
715 glPopAttrib();
716 }
717
718
719 static
720 moveview(dx, dy, mov, orb) /* move our view */
721 int dx, dy, mov, orb;
722 {
723 VIEW nv;
724 FVECT odir, v1, wip;
725 double d, d1;
726 register int li;
727 /* start with old view */
728 copystruct(&nv, &odev.v);
729 /* orient our motion */
730 if (viewray(v1, odir, &odev.v,
731 (dx+.5)/odev.hres, (dy+.5)/odev.vres) < -FTINY)
732 return(0); /* outside view */
733 if (mov | orb) { /* moving relative to geometry */
734 d = getdistance(dx, dy, odir); /* distance from front plane */
735 #ifdef DOBJ
736 d1 = dobj_trace(NULL, v1, odir);
737 if (d1 < d)
738 d = d1;
739 #endif
740 if (d >= .99*FHUGE)
741 d = 0.5*(dev_zmax+dev_zmin); /* just guess */
742 VSUM(wip, v1, odir, d);
743 VSUB(odir, wip, odev.v.vp);
744 } else /* panning with constant viewpoint */
745 VCOPY(nv.vdir, odir);
746 if (orb && mov) { /* orbit left/right */
747 spinvector(odir, odir, nv.vup, d=MOVDEG*PI/180.*mov);
748 VSUM(nv.vp, wip, odir, -1.);
749 spinvector(nv.vdir, nv.vdir, nv.vup, d);
750 } else if (orb) { /* orbit up/down */
751 fcross(v1, odir, nv.vup);
752 if (normalize(v1) == 0.)
753 return(0);
754 spinvector(odir, odir, v1, d=MOVDEG*PI/180.*orb);
755 VSUM(nv.vp, wip, odir, -1.);
756 spinvector(nv.vdir, nv.vdir, v1, d);
757 } else if (mov) { /* move forward/backward */
758 d = MOVPCT/100. * mov;
759 VSUM(nv.vp, nv.vp, odir, d);
760 }
761 if (!mov ^ !orb && headlocked) { /* restore head height */
762 VSUM(v1, odev.v.vp, nv.vp, -1.);
763 d = DOT(v1, nv.vup);
764 VSUM(nv.vp, nv.vp, odev.v.vup, d);
765 }
766 if (setview(&nv) != NULL)
767 return(0); /* illegal view */
768 dev_view(&nv);
769 inpresflags |= DFL(DC_SETVIEW);
770 return(1);
771 }
772
773
774 static
775 getframe(ebut) /* get focus frame */
776 XButtonPressedEvent *ebut;
777 {
778 int startx = ebut->x, starty = ebut->y;
779 int endx, endy;
780
781 XMaskEvent(ourdisplay, ButtonReleaseMask, levptr(XEvent));
782 endx = levptr(XButtonReleasedEvent)->x;
783 endy = levptr(XButtonReleasedEvent)->y;
784 if (endx == startx | endy == starty) {
785 XBell(ourdisplay, 0);
786 return;
787 }
788 if (endx < startx) {register int c = endx; endx = startx; startx = c;}
789 if (endy < starty) {register int c = endy; endy = starty; starty = c;}
790 sprintf(odev_args, "%.3f %.3f %.3f %.3f",
791 (startx+.5)/odev.hres, 1.-(endy+.5)/odev.vres,
792 (endx+.5)/odev.hres, 1.-(starty+.5)/odev.vres);
793 inpresflags |= DFL(DC_FOCUS);
794 }
795
796
797 static
798 getmove(ebut) /* get view change */
799 XButtonPressedEvent *ebut;
800 {
801 int movdir = MOVDIR(ebut->button);
802 int movorb = MOVORB(ebut->state);
803 int ndrawn;
804 Window rootw, childw;
805 int rootx, rooty, wx, wy;
806 unsigned int statemask;
807
808 XNoOp(ourdisplay); /* makes sure we're not idle */
809
810 viewsteady = 0; /* flag moving view */
811 setglpersp(&odev.v); /* start us off in perspective */
812 while (!XCheckMaskEvent(ourdisplay,
813 ButtonReleaseMask, levptr(XEvent))) {
814 /* get cursor position */
815 if (!XQueryPointer(ourdisplay, gwind, &rootw, &childw,
816 &rootx, &rooty, &wx, &wy, &statemask))
817 break; /* on another screen */
818 /* compute view motion */
819 if (!moveview(wx, odev.vres-1-wy, movdir, movorb)) {
820 sleep(1);
821 continue; /* cursor in bad place */
822 }
823 draw_grids(1); /* redraw grid */
824 #ifdef STEREO
825 pushright();
826 draw_grids(1);
827 ndrawn = gmDrawGeom();
828 #ifdef DOBJ
829 ndrawn += dobj_render();
830 #endif
831 if (ndrawn)
832 gmDrawPortals(PORTRED, PORTGRN, PORTBLU, PORTALP);
833 popright();
834 #endif
835 /* redraw octrees */
836 ndrawn = gmDrawGeom();
837 #ifdef DOBJ
838 ndrawn += dobj_render(); /* redraw objects */
839 #endif
840 if (ndrawn)
841 gmDrawPortals(PORTRED, PORTGRN, PORTBLU, PORTALP);
842 glFlush();
843 if (!ndrawn) {
844 sleep(1); /* for reasonable interaction */
845 #ifdef STEREO
846 pushright();
847 draw_grids(0);
848 popright();
849 #endif
850 draw_grids(0);
851 }
852 }
853 if (!(inpresflags & DFL(DC_SETVIEW))) { /* do final motion */
854 movdir = MOVDIR(levptr(XButtonReleasedEvent)->button);
855 wx = levptr(XButtonReleasedEvent)->x;
856 wy = levptr(XButtonReleasedEvent)->y;
857 moveview(wx, odev.vres-1-wy, movdir, movorb);
858 }
859 }
860
861
862 static
863 setglpersp(vp) /* set perspective view in GL */
864 register VIEW *vp;
865 {
866 double d, xmin, xmax, ymin, ymax;
867 GLfloat vec[4];
868 double depthlim[2];
869 /* set depth limits */
870 gmDepthLimit(depthlim, odev.v.vp, odev.v.vdir);
871 if (depthlim[0] >= depthlim[1]) {
872 dev_zmin = 1.;
873 dev_zmax = 100.;
874 } else {
875 dev_zmin = 0.5*depthlim[0];
876 dev_zmax = 1.75*depthlim[1];
877 if (dev_zmin > dev_zmax/5.)
878 dev_zmin = dev_zmax/5.;
879 }
880 if (odev.v.vfore > FTINY)
881 dev_zmin = odev.v.vfore;
882 if (odev.v.vaft > FTINY)
883 dev_zmax = odev.v.vaft;
884 if (dev_zmin < dev_zmax/100.)
885 dev_zmin = dev_zmax/100.;
886 setzrat();
887 xmax = dev_zmin * tan(PI/180./2. * odev.v.horiz);
888 xmin = -xmax;
889 d = odev.v.hoff * (xmax - xmin);
890 xmin += d; xmax += d;
891 ymax = dev_zmin * tan(PI/180./2. * odev.v.vert);
892 ymin = -ymax;
893 d = odev.v.voff * (ymax - ymin);
894 ymin += d; ymax += d;
895 /* set view matrix */
896 glMatrixMode(GL_PROJECTION);
897 glLoadIdentity();
898 glFrustum(xmin, xmax, ymin, ymax, dev_zmin, dev_zmax);
899 gluLookAt(odev.v.vp[0], odev.v.vp[1], odev.v.vp[2],
900 odev.v.vp[0] + odev.v.vdir[0],
901 odev.v.vp[1] + odev.v.vdir[1],
902 odev.v.vp[2] + odev.v.vdir[2],
903 odev.v.vup[0], odev.v.vup[1], odev.v.vup[2]);
904 checkglerr("setting perspective view");
905 isperspective = 1;
906 vec[0] = vec[1] = vec[2] = 0.; vec[3] = 1.;
907 glLightModelfv(GL_LIGHT_MODEL_AMBIENT, vec);
908 vec[0] = -odev.v.vdir[0];
909 vec[1] = -odev.v.vdir[1];
910 vec[2] = -odev.v.vdir[2];
911 vec[3] = 0.;
912 glLightfv(GL_LIGHT0, GL_POSITION, vec);
913 vec[0] = vec[1] = vec[2] = .7; vec[3] = 1.;
914 glLightfv(GL_LIGHT0, GL_SPECULAR, vec);
915 glLightfv(GL_LIGHT0, GL_DIFFUSE, vec);
916 vec[0] = vec[1] = vec[2] = .3; vec[3] = 1.;
917 glLightfv(GL_LIGHT0, GL_AMBIENT, vec);
918 glEnable(GL_LIGHT0);
919 glEnable(GL_LIGHTING); /* light our GL objects */
920 glShadeModel(GL_SMOOTH);
921 }
922
923
924 static
925 setglortho() /* set up orthographic view for cone drawing */
926 {
927 /* set view matrix */
928 glMatrixMode(GL_PROJECTION);
929 glLoadIdentity();
930 glOrtho(0., (double)odev.hres, 0., (double)odev.vres,
931 0.001*OMAXDEPTH, 1.001*(-OMAXDEPTH));
932 checkglerr("setting orthographic view");
933 isperspective = 0;
934 glDisable(GL_LIGHTING); /* cones are constant color */
935 glShadeModel(GL_FLAT);
936 }
937
938
939 static
940 wipeclean() /* prepare for redraw */
941 {
942 /* clear depth buffer */
943 #ifdef STEREO
944 setstereobuf(STEREO_BUFFER_RIGHT);
945 glClear(GL_DEPTH_BUFFER_BIT);
946 setstereobuf(STEREO_BUFFER_LEFT);
947 #endif
948 glClear(GL_DEPTH_BUFFER_BIT);
949 if (viewsteady) /* clear samples if steady */
950 odClean();
951 freedepth();
952 setglpersp(&odev.v); /* reset view & clipping planes */
953 }
954
955
956 static
957 getkey(ekey) /* get input key */
958 register XKeyPressedEvent *ekey;
959 {
960 Window rootw, childw;
961 int rootx, rooty, wx, wy;
962 unsigned int statemask;
963 int n;
964 char buf[8];
965
966 n = XLookupString(ekey, buf, sizeof(buf), NULL, NULL);
967 if (n != 1)
968 return;
969 switch (buf[0]) {
970 case 'h': /* turn on height motion lock */
971 headlocked = 1;
972 return;
973 case 'H': /* turn off height motion lock */
974 headlocked = 0;
975 return;
976 case 'l': /* retrieve last view */
977 inpresflags |= DFL(DC_LASTVIEW);
978 return;
979 case 'p': /* pause computation */
980 inpresflags |= DFL(DC_PAUSE);
981 return;
982 case 'v': /* spit out view */
983 inpresflags |= DFL(DC_GETVIEW);
984 return;
985 case 'f': /* frame view position */
986 if (!XQueryPointer(ourdisplay, gwind, &rootw, &childw,
987 &rootx, &rooty, &wx, &wy, &statemask))
988 return; /* on another screen */
989 sprintf(odev_args, "%.4f %.4f", (wx+.5)/odev.hres,
990 1.-(wy+.5)/odev.vres);
991 inpresflags |= DFL(DC_FOCUS);
992 return;
993 case 'F': /* unfocus */
994 odev_args[0] = '\0';
995 inpresflags |= DFL(DC_FOCUS);
996 return;
997 case '\n':
998 case '\r': /* resume computation */
999 inpresflags |= DFL(DC_RESUME);
1000 return;
1001 case CTRL('R'): /* redraw screen */
1002 odRemap(0);
1003 glClear(GL_COLOR_BUFFER_BIT|GL_DEPTH_BUFFER_BIT);
1004 #ifdef STEREO
1005 setstereobuf(STEREO_BUFFER_RIGHT);
1006 glClear(GL_COLOR_BUFFER_BIT|GL_DEPTH_BUFFER_BIT);
1007 setstereobuf(STEREO_BUFFER_LEFT);
1008 #endif
1009 return;
1010 case CTRL('L'): /* refresh from server */
1011 if (inpresflags & DFL(DC_REDRAW))
1012 return;
1013 XRaiseWindow(ourdisplay, gwind);
1014 XFlush(ourdisplay);
1015 sleep(1);
1016 wipeclean(); /* fresh display */
1017 odRemap(1); /* fresh tone mapping */
1018 dev_flush(); /* draw octrees */
1019 inpresflags |= DFL(DC_REDRAW); /* resend values from server */
1020 rayqleft = 0; /* hold off update */
1021 return;
1022 case 'K': /* kill rtrace process(es) */
1023 inpresflags |= DFL(DC_KILL);
1024 break;
1025 case 'R': /* restart rtrace */
1026 inpresflags |= DFL(DC_RESTART);
1027 break;
1028 case 'C': /* clobber holodeck */
1029 inpresflags |= DFL(DC_CLOBBER);
1030 break;
1031 case 'q': /* quit the program */
1032 inpresflags |= DFL(DC_QUIT);
1033 return;
1034 default:
1035 XBell(ourdisplay, 0);
1036 return;
1037 }
1038 }
1039
1040
1041 static
1042 fixwindow(eexp) /* repair damage to window */
1043 register XExposeEvent *eexp;
1044 {
1045 int xmin, ymin, xmax, ymax;
1046
1047 if (odev.hres == 0 | odev.vres == 0) { /* first exposure */
1048 resizewindow((XConfigureEvent *)eexp);
1049 return;
1050 }
1051 xmin = eexp->x; xmax = eexp->x + eexp->width;
1052 ymin = odev.vres - eexp->y - eexp->height; ymax = odev.vres - eexp->y;
1053 /* clear portion of depth */
1054 glPushAttrib(GL_DEPTH_BUFFER_BIT|GL_COLOR_BUFFER_BIT);
1055 glColorMask(GL_FALSE, GL_FALSE, GL_FALSE, GL_FALSE);
1056 glDepthFunc(GL_ALWAYS);
1057 glBegin(GL_POLYGON);
1058 glVertex3i(xmin, ymin, OMAXDEPTH);
1059 glVertex3i(xmax, ymin, OMAXDEPTH);
1060 glVertex3i(xmax, ymax, OMAXDEPTH);
1061 glVertex3i(xmin, ymax, OMAXDEPTH);
1062 glEnd();
1063 #ifdef STEREO
1064 setstereobuf(STEREO_BUFFER_RIGHT);
1065 glBegin(GL_POLYGON);
1066 glVertex3i(xmin, ymin, OMAXDEPTH);
1067 glVertex3i(xmax, ymin, OMAXDEPTH);
1068 glVertex3i(xmax, ymax, OMAXDEPTH);
1069 glVertex3i(xmin, ymax, OMAXDEPTH);
1070 glEnd();
1071 odRedraw(1, xmin, ymin, xmax, ymax);
1072 setstereobuf(STEREO_BUFFER_LEFT);
1073 #endif
1074 glPopAttrib();
1075 odRedraw(0, xmin, ymin, xmax, ymax);
1076 }
1077
1078
1079 static
1080 resizewindow(ersz) /* resize window */
1081 register XConfigureEvent *ersz;
1082 {
1083 glViewport(0, 0, ersz->width, ersz->height);
1084
1085 if (ersz->width == odev.hres && ersz->height == odev.vres)
1086 return;
1087
1088 odev.hres = ersz->width;
1089 odev.vres = ersz->height;
1090
1091 odev.v.horiz = 2.*180./PI * atan(0.5/VIEWDIST*pwidth*odev.hres);
1092 odev.v.vert = 2.*180./PI * atan(0.5/VIEWDIST*pheight*odev.vres);
1093
1094 inpresflags |= DFL(DC_SETVIEW);
1095 }
