root/radiance/ray/src/hd/rhd_ogl.c
Revision: 3.24
Committed: Thu Jan 1 11:21:55 2004 UTC (21 years, 4 months ago) by schorsch
Changes since 3.23: +127 -80 lines
Ansification and prototypes.
2 static const char RCSid[] = "$Id: rhd_ogl.c,v 3.23 2003/09/19 18:33:05 greg Exp $";
5 * OpenGL driver for holodeck display.
6 * Based on GLX driver using T-mesh.
7 *
8 * Define symbol STEREO for stereo viewing.
9 * Define symbol DOBJ for display object viewing.
10 */
11
12 #ifdef NOSTEREO
13 #ifdef STEREO
14 #undef STEREO
15 #else
16 #undef NOSTEREO
17 #endif
18 #endif
19
20
21 #include <time.h>
22 #include <GL/glx.h>
23 #include <GL/glu.h>
24 #ifdef STEREO
25 #include <X11/extensions/SGIStereo.h>
26 #endif
27
28 #include "standard.h"
29 #include "rhd_odraw.h"
30 #include "rhdisp.h"
31 #ifdef DOBJ
32 #include "rhdobj.h"
33 #endif
34
35 #include "x11icon.h"
36
37 #ifndef RAYQLEN
38 #define RAYQLEN 0 /* max. rays to queue before flush */
39 #endif
40 #ifndef MINWIDTH
41 #define MINWIDTH 480 /* minimum graphics window width */
42 #define MINHEIGHT 400 /* minimum graphics window height */
43 #endif
44 #ifndef VIEWDIST
45 #define VIEWDIST 356 /* assumed viewing distance (mm) */
46 #endif
47 #ifndef BORWIDTH
48 #define BORWIDTH 5 /* border width */
49 #endif
50
51 #ifndef FEQ
52 #define FEQ(a,b) ((a)-(b) <= FTINY && (a)-(b) >= -FTINY)
53 #endif
54
55 #define VWHEADLOCK 01 /* head position is locked flag */
56 #define VWPERSP 02 /* perspective view is set */
57 #define VWORTHO 04 /* orthographic view is set */
58 #define VWCHANGE 010 /* view has changed */
59 #define VWSTEADY 020 /* view is now steady */
60 #define VWMAPPED 040 /* window is mapped */
61
62 #define GAMMA 1.4 /* default gamma correction */
63
64 #define FRAMESTATE(s) (((s)&(ShiftMask|ControlMask))==(ShiftMask|ControlMask))
65
66 #define MOVPCT 7 /* percent distance to move /frame */
67 #define MOVDIR(b) ((b)==Button1 ? 1 : (b)==Button2 ? 0 : -1)
68 #define MOVDEG (-5) /* degrees to orbit CW/down /frame */
69 #define MOVORB(s) ((s)&ShiftMask ? 1 : (s)&ControlMask ? -1 : 0)
70
71 #define setstereobuf(bid) (glXWaitGL(), \
72 XSGISetStereoBuffer(ourdisplay, gwind, bid), \
73 glXWaitX())
74
75 #define ourscreen DefaultScreen(ourdisplay)
76 #define ourroot RootWindow(ourdisplay,ourscreen)
77 #define ourmask (StructureNotifyMask|ExposureMask|KeyPressMask|\
78 ButtonPressMask|ButtonReleaseMask)
79
80 #define levptr(etype) ((etype *)&currentevent)
81
82 struct driver odev; /* global device driver structure */
83
84 char odev_args[64]; /* command arguments */
85
86 static GLfloat *depthbuffer = NULL; /* depth buffer */
87
88 #ifdef STEREO
89 static VIEW vwright; /* right eye view */
90 static GLfloat *depthright = NULL; /* right depth buffer */
91 #endif
92
93 static int rayqleft = 0; /* rays left to queue before flush */
94
95 static XEvent currentevent; /* current event */
96
97 static unsigned long ourblack=0, ourwhite=~0;
98
99 static Display *ourdisplay = NULL; /* our display */
100 static XVisualInfo *ourvinf; /* our visual information */
101 static Window gwind = 0; /* our graphics window */
102 static GLXContext gctx; /* our GLX context */
103
104 static double pwidth, pheight; /* pixel dimensions (mm) */
105
106 static double dev_zmin, dev_zmax; /* fore and aft clipping plane dist. */
107 static double dev_zrat; /* (1. - dev_zmin/dev_zmax) */
108
109 #define setzrat() (dev_zrat = 1. - dev_zmin/dev_zmax)
110 #define mapdepth(d) ((d)>0.9995 ? FHUGE : dev_zmin/(1.-(d)*dev_zrat))
111
112 static int inpresflags; /* input result flags */
113
114 static int viewflags; /* what's happening with view */
115
116 /*
117 static int resizewindow(), getevent(), getkey(), moveview(), wipeclean(),
118 xferdepth(), freedepth(), setglortho(),
119 setglpersp(), getframe(), getmove(), fixwindow(), mytmflags();
120
121 static double getdistance();
122 */
123 static void checkglerr(char *where);
124 static void xferdepth(void);
125 static void freedepth(void);
126 static double getdistance(int dx, int dy, FVECT direc);
127 static int mytmflags(void);
128 static void getevent(void);
129 static void draw3dline(register FVECT wp[2]);
130 static void draw_grids(int fore);
131 static int moveview(int dx, int dy, int mov, int orb);
132 static void getframe(XButtonPressedEvent *ebut);
133 static void getmove(XButtonPressedEvent *ebut);
134 static void getkey(register XKeyPressedEvent *ekey);
135 static void fixwindow(register XExposeEvent *eexp);
136 static void resizewindow(register XConfigureEvent *ersz);
137 static void waitabit(void);
138 static void setglpersp(void);
139 static void setglortho(void);
140 static void wipeclean(void);
141
142
143 #ifdef STEREO
144 static void pushright(void);
145 static void popright(void);
146 #endif
147
148 extern int gmPortals; /* GL portal list id */
149
150 extern time_t time();
151
152
153 extern void
154 dev_open(id) /* initialize GLX driver */
155 char *id;
156 {
157 extern char *getenv();
158 static RGBPRIMS myprims = STDPRIMS;
159 static int atlBest[] = {GLX_RGBA, GLX_DOUBLEBUFFER,
160 GLX_RED_SIZE,8, GLX_GREEN_SIZE,8,
161 GLX_BLUE_SIZE,8, GLX_DEPTH_SIZE,15, None};
162 static int atlOK[] = {GLX_RGBA, GLX_DOUBLEBUFFER,
163 GLX_RED_SIZE,4, GLX_GREEN_SIZE,4,
164 GLX_BLUE_SIZE,4, GLX_DEPTH_SIZE,15, None};
165 char *ev;
166 double gamval = GAMMA;
167 RGBPRIMP dpri = stdprims;
168 XSetWindowAttributes ourwinattr;
169 XWMHints ourxwmhints;
170 XSizeHints oursizhints;
171 /* check for unsupported stereo */
172 #ifdef NOSTEREO
173 error(INTERNAL, "stereo display driver unavailable");
174 #endif
175 /* open display server */
176 ourdisplay = XOpenDisplay(NULL);
177 CHECK(ourdisplay==NULL, USER,
178 "cannot open X-windows; DISPLAY variable set?");
179 #ifdef STEREO
180 switch (XSGIQueryStereoMode(ourdisplay, ourroot)) {
181 case STEREO_TOP:
182 case STEREO_BOTTOM:
183 break;
184 case STEREO_OFF:
185 error(USER,
186 "wrong video mode: run \"/usr/gfx/setmon -n STR_TOP\" first");
187 case X_STEREO_UNSUPPORTED:
188 error(USER, "stereo mode not supported on this screen");
189 default:
190 error(INTERNAL, "unknown stereo mode");
191 }
192 #endif
193 /* find a usable visual */
194 ourvinf = glXChooseVisual(ourdisplay, ourscreen, atlBest);
195 if (ourvinf == NULL)
196 ourvinf = glXChooseVisual(ourdisplay, ourscreen, atlOK);
197 CHECK(ourvinf==NULL, USER, "no suitable visuals available");
198 /* get a context */
199 gctx = glXCreateContext(ourdisplay, ourvinf, NULL, GL_TRUE);
200 /* set gamma and tone mapping */
201 if ((ev = XGetDefault(ourdisplay, "radiance", "gamma")) != NULL
202 || (ev = getenv("DISPLAY_GAMMA")) != NULL)
203 gamval = atof(ev);
204 if ((ev = getenv("DISPLAY_PRIMARIES")) != NULL &&
205 sscanf(ev, "%f %f %f %f %f %f %f %f",
206 &myprims[RED][CIEX],&myprims[RED][CIEY],
207 &myprims[GRN][CIEX],&myprims[GRN][CIEY],
208 &myprims[BLU][CIEX],&myprims[BLU][CIEY],
209 &myprims[WHT][CIEX],&myprims[WHT][CIEY]) >= 6)
210 dpri = myprims;
211 if (tmInit(mytmflags(), dpri, gamval) == NULL)
212 error(SYSTEM, "not enough memory in dev_open");
213 /* open window */
214 ourwinattr.background_pixel = ourblack;
215 ourwinattr.border_pixel = ourblack;
216 ourwinattr.event_mask = ourmask;
217 /* this is stupid */
218 ourwinattr.colormap = XCreateColormap(ourdisplay, ourroot,
219 ourvinf->visual, AllocNone);
220 gwind = XCreateWindow(ourdisplay, ourroot, 0, 0,
221 DisplayWidth(ourdisplay,ourscreen)-2*BORWIDTH,
222 #ifdef STEREO
223 (DisplayHeight(ourdisplay,ourscreen)-2*BORWIDTH)/2,
224 #else
225 DisplayHeight(ourdisplay,ourscreen)-2*BORWIDTH,
226 #endif
227 BORWIDTH, ourvinf->depth, InputOutput, ourvinf->visual,
228 CWBackPixel|CWBorderPixel|CWColormap|CWEventMask, &ourwinattr);
229 CHECK(gwind==0, SYSTEM, "cannot create window");
230 XStoreName(ourdisplay, gwind, id);
231 /* set window manager hints */
232 ourxwmhints.flags = InputHint|IconPixmapHint;
233 ourxwmhints.input = True;
234 ourxwmhints.icon_pixmap = XCreateBitmapFromData(ourdisplay,
235 gwind, x11icon_bits, x11icon_width, x11icon_height);
236 XSetWMHints(ourdisplay, gwind, &ourxwmhints);
237 oursizhints.min_width = MINWIDTH;
238 #ifdef STEREO
239 oursizhints.min_height = MINHEIGHT/2;
240 oursizhints.max_width = DisplayWidth(ourdisplay,ourscreen)-2*BORWIDTH;
241 oursizhints.max_height = (DisplayHeight(ourdisplay,ourscreen) -
242 2*BORWIDTH)/2;
243 oursizhints.flags = PMinSize|PMaxSize;
244 #else
245 oursizhints.min_height = MINHEIGHT;
246 oursizhints.flags = PMinSize;
247 #endif
248 XSetNormalHints(ourdisplay, gwind, &oursizhints);
249 /* set GLX context */
250 glXMakeCurrent(ourdisplay, gwind, gctx);
251 glEnable(GL_DEPTH_TEST);
252 glDepthFunc(GL_LEQUAL);
253 glClearColor(0, 0, 0, 0);
254 glFrontFace(GL_CCW);
255 glDisable(GL_CULL_FACE);
256 glLightModeli(GL_LIGHT_MODEL_TWO_SIDE, GL_TRUE);
257 glPolygonMode(GL_FRONT_AND_BACK, GL_FILL);
258 glPixelStorei(GL_PACK_ALIGNMENT, 1);
259 glPixelStorei(GL_UNPACK_ALIGNMENT, 1);
260 /* figure out sensible view */
261 pwidth = (double)DisplayWidthMM(ourdisplay, ourscreen) /
262 DisplayWidth(ourdisplay, ourscreen);
263 pheight = (double)DisplayHeightMM(ourdisplay, ourscreen) /
264 DisplayHeight(ourdisplay, ourscreen);
265 #ifdef STEREO
266 pheight *= 2.;
267 setstereobuf(STEREO_BUFFER_LEFT);
268 #endif
269 checkglerr("setting rendering parameters");
270 odev.v = stdview;
271 odev.v.type = VT_PER;
272 viewflags = VWSTEADY; /* view starts static */
273 /* map the window */
274 XMapWindow(ourdisplay, gwind);
275 dev_input(); /* sets size and view angles */
276 if (!odInit(DisplayWidth(ourdisplay,ourscreen) *
277 DisplayHeight(ourdisplay,ourscreen) / 3))
278 error(SYSTEM, "insufficient memory for value storage");
279 odev.name = id;
280 odev.firstuse = 1; /* can't recycle samples */
281 odev.ifd = ConnectionNumber(ourdisplay);
282 }
283
284
285 extern void
286 dev_close(void) /* close our display and free resources */
287 {
288 #ifdef DOBJ
289 dobj_cleanup();
290 #endif
291 freedepth();
292 gmEndGeom();
293 gmEndPortal();
294 odDone();
295 glXMakeCurrent(ourdisplay, None, NULL);
296 glXDestroyContext(ourdisplay, gctx);
297 XDestroyWindow(ourdisplay, gwind);
298 gwind = 0;
299 XCloseDisplay(ourdisplay);
300 ourdisplay = NULL;
301 tmDone(NULL);
302 odev.v.type = 0;
303 odev.hres = odev.vres = 0;
304 odev.ifd = -1;
305 }
306
307
308 extern void
309 dev_clear(void) /* clear our representation */
310 {
311 viewflags |= VWCHANGE; /* pretend our view has changed */
312 wipeclean(); /* clean off display and samples */
313 dev_flush(); /* redraw geometry & get depth */
314 rayqleft = 0; /* hold off update */
315 }
316
317
318 extern int
319 dev_view( /* assign new driver view */
320 register VIEW *nv
321 )
322 {
323 if (nv->type != VT_PER || /* check view legality */
324 nv->horiz > 160. || nv->vert > 160.) {
325 error(COMMAND, "illegal view type/angle");
326 nv->type = odev.v.type;
327 nv->horiz = odev.v.horiz;
328 nv->vert = odev.v.vert;
329 return(0);
330 }
331 if (nv != &odev.v) {
332 /* resize window? */
333 if (!FEQ(nv->horiz,odev.v.horiz) ||
334 !FEQ(nv->vert,odev.v.vert)) {
335 int dw = DisplayWidth(ourdisplay,ourscreen);
336 int dh = DisplayHeight(ourdisplay,ourscreen);
337
338 dw -= 25; /* for window frame */
339 dh -= 50;
340 #ifdef STEREO
341 dh /= 2;
342 #endif
343 odev.hres = 2.*VIEWDIST/pwidth *
344 tan(PI/180./2.*nv->horiz);
345 odev.vres = 2.*VIEWDIST/pheight *
346 tan(PI/180./2.*nv->vert);
347 if (odev.hres > dw) {
348 odev.vres = dw * odev.vres / odev.hres;
349 odev.hres = dw;
350 }
351 if (odev.vres > dh) {
352 odev.hres = dh * odev.hres / odev.vres;
353 odev.vres = dh;
354 }
355 XResizeWindow(ourdisplay, gwind, odev.hres, odev.vres);
356 dev_input(); /* get resize event */
357 }
358 odev.v = *nv; /* setview() already called */
359 viewflags |= VWCHANGE;
360 }
361 #ifdef STEREO
362 vwright = *nv;
363 d = eyesepdist / sqrt(nv->hn2);
364 VSUM(vwright.vp, nv->vp, nv->hvec, d);
365 /* setview(&vwright); -- Unnecessary */
366 #endif
367 wipeclean();
368 return(1);
369 }
370
371
372 extern void
373 dev_section( /* add octree for geometry rendering */
374 char *gfn,
375 char *pfn
376 )
377 {
378 if (gfn == NULL) {
379 gmEndGeom();
380 gmEndPortal();
381 wipeclean(); /* new geometry, so redraw it */
382 return;
383 }
384 if (access(gfn, R_OK) == 0)
385 gmNewGeom(gfn);
386 #ifdef DEBUG
387 else {
388 sprintf(errmsg, "cannot load octree \"%s\"", gfn);
389 error(WARNING, errmsg);
390 }
391 #endif
392 if (pfn != NULL)
393 gmNewPortal(pfn);
394 }
395
396
397 extern void
398 dev_auxcom( /* process an auxiliary command */
399 char *cmd,
400 char *args
401 )
402 {
403 #ifdef DOBJ
404 int vischange;
405
406 if ((vischange = dobj_command(cmd, args)) >= 0) {
407 if (vischange) {
408 imm_mode = beam_sync(1) > 0;
409 dev_clear();
410 }
411 return;
412 }
413 #endif
414 sprintf(errmsg, "%s: unknown command", cmd);
415 error(COMMAND, errmsg);
416 }
417
418
419 extern VIEW *
420 dev_auxview( /* return nth auxiliary view */
421 int n,
422 int hvres[2]
423 )
424 {
425 hvres[0] = odev.hres; hvres[1] = odev.vres;
426 if (n == 0)
427 return(&odev.v);
428 #ifdef STEREO
429 if (n == 1)
430 return(&vwright);
431 #endif
432 return(NULL);
433 }
434
435
436 extern int
437 dev_input(void) /* get X11 input */
438 {
439 inpresflags = 0;
440
441 do
442 getevent();
443
444 while (XPending(ourdisplay) > 0);
445
446 odev.inpready = 0;
447
448 return(inpresflags);
449 }
450
451
452 extern void
453 dev_value( /* add a pixel value to our texture */
454 COLR c,
455 FVECT d,
456 FVECT p
457 )
458 {
459 #ifdef DOBJ
460 if (dobj_lightsamp != NULL) { /* in light source sampling */
461 (*dobj_lightsamp)(c, d, p);
462 return;
463 }
464 #endif
465 odSample(c, d, p); /* add to display representation */
466 if (!--rayqleft)
467 dev_flush(); /* flush output */
468 }
469
470
471 extern int
472 dev_flush(void) /* flush output as appropriate */
473 {
474 int ndrawn;
475
476 if ((viewflags&(VWMAPPED|VWPERSP)) == (VWMAPPED|VWPERSP)) {
477 #ifdef STEREO
478 pushright(); /* draw right eye */
479 ndrawn = gmDrawGeom();
480 #ifdef DOBJ
481 ndrawn += dobj_render();
482 #endif
483 checkglerr("rendering right eye");
484 popright(); /* draw left eye */
485 #endif
486 ndrawn = gmDrawGeom();
487 #ifdef DOBJ
488 ndrawn += dobj_render();
489 #endif
490 glXSwapBuffers(ourdisplay, gwind);
491 checkglerr("rendering base view");
492 }
493 if ((viewflags&(VWMAPPED|VWSTEADY|VWPERSP|VWORTHO)) ==
494 (VWMAPPED|VWSTEADY|VWPERSP)) {
495 /* first time after steady */
496 if (ndrawn)
497 xferdepth(); /* transfer and clear depth */
498 setglortho(); /* set orthographic view */
499
500 }
501 if ((viewflags&(VWMAPPED|VWSTEADY|VWPERSP|VWORTHO)) ==
502 (VWMAPPED|VWSTEADY|VWORTHO)) {
503 /* else update cones */
504 #ifdef STEREO
505 pushright();
506 odUpdate(1); /* draw right eye */
507 popright();
508 #endif
509 odUpdate(0); /* draw left eye */
510 glFlush(); /* flush OpenGL */
511 }
512 rayqleft = RAYQLEN;
513 /* flush X11 and return # pending */
514 return(odev.inpready = XPending(ourdisplay));
515 }
516
517
518 static void
519 checkglerr( /* check for GL or GLU error */
520 char *where
521 )
522 {
523 register GLenum errcode;
524
525 while ((errcode = glGetError()) != GL_NO_ERROR) {
526 sprintf(errmsg, "OpenGL error %s: %s",
527 where, gluErrorString(errcode));
528 error(WARNING, errmsg);
529 }
530 }
531
532
533 static void
534 xferdepth(void) /* load and clear depth buffer */
535 {
536 register GLfloat *dbp;
537 register GLubyte *pbuf;
538
539 if (depthbuffer == NULL) { /* allocate private depth buffer */
540 #ifdef STEREO
541 depthright = (GLfloat *)malloc(
542 odev.hres*odev.vres*sizeof(GLfloat));
543 #endif
544 depthbuffer = (GLfloat *)malloc(
545 odev.hres*odev.vres*sizeof(GLfloat));
546 CHECK(depthbuffer==NULL, SYSTEM, "out of memory in xferdepth");
547 }
548 /* allocate alpha buffer for portals */
549 if (gmPortals)
550 pbuf = (GLubyte *)malloc(odev.hres*odev.vres*sizeof(GLubyte));
551 else
552 pbuf = NULL;
553 #ifdef STEREO
554 pushright();
555 glReadPixels(0, 0, odev.hres, odev.vres,
556 GL_DEPTH_COMPONENT, GL_FLOAT, depthright);
557 if (pbuf != NULL) {
558 glClear(GL_COLOR_BUFFER_BIT);
559 gmDrawPortals(0xff, -1, -1, -1);
560 glReadPixels(0, 0, odev.hres, odev.vres,
561 GL_RED, GL_UNSIGNED_BYTE, pbuf);
562 }
563 for (dbp = depthright + odev.hres*odev.vres; dbp-- > depthright; )
564 if (pbuf != NULL && pbuf[dbp-depthright]&0x40)
565 *dbp = FHUGE;
566 else
567 *dbp = mapdepth(*dbp);
568 glClear(GL_DEPTH_BUFFER_BIT);
569 odDepthMap(1, depthright);
570 popright();
571 #endif
572 /* read back depth buffer */
573 glReadPixels(0, 0, odev.hres, odev.vres,
574 GL_DEPTH_COMPONENT, GL_FLOAT, depthbuffer);
575 if (pbuf != NULL) {
576 glClear(GL_COLOR_BUFFER_BIT); /* find portals */
577 gmDrawPortals(0xff, -1, -1, -1);
578 glReadPixels(0, 0, odev.hres, odev.vres,
579 GL_RED, GL_UNSIGNED_BYTE, pbuf);
580 #ifdef DEBUG
581 glXSwapBuffers(ourdisplay, gwind);
582 #endif
583 }
584 for (dbp = depthbuffer + odev.hres*odev.vres; dbp-- > depthbuffer; )
585 if (pbuf != NULL && pbuf[dbp-depthbuffer]&0x40)
586 *dbp = FHUGE;
587 else
588 *dbp = mapdepth(*dbp);
589 glClear(GL_DEPTH_BUFFER_BIT); /* clear system depth buffer */
590 odDepthMap(0, depthbuffer); /* transfer depth data */
591 if (pbuf != NULL)
592 free((void *)pbuf); /* free our portal buffer */
593 }
594
595
596 static void
597 freedepth(void) /* free recorded depth buffer */
598 {
599 if (depthbuffer == NULL)
600 return;
601 #ifdef STEREO
602 odDepthMap(1, NULL);
603 free((void *)depthright);
604 depthright = NULL;
605 #endif
606 odDepthMap(0, NULL);
607 free((void *)depthbuffer);
608 depthbuffer = NULL;
609 }
610
611
612 static double
613 getdistance( /* distance from fore plane along view ray */
614 int dx,
615 int dy,
616 FVECT direc
617 )
618 {
619 GLfloat gldepth;
620 double dist;
621
622 if ((dx<0) | (dx>=odev.hres) | (dy<0) | (dy>=odev.vres))
623 return(FHUGE);
624 if (depthbuffer != NULL)
625 dist = depthbuffer[dy*odev.hres + dx];
626 else {
627 glReadPixels(dx,dy, 1,1, GL_DEPTH_COMPONENT,
628 GL_FLOAT, &gldepth);
629 if (gldepth <= FTINY)
630 return (FHUGE); /* call failed */
631 dist = mapdepth(gldepth);
632 }
633 if (dist >= .99*FHUGE)
634 return(FHUGE);
635 return((dist-odev.v.vfore)/DOT(direc,odev.v.vdir));
636 }
637
638
639 #ifdef STEREO
640 static void
641 pushright(void) /* push on right view & buffer */
642 {
643 double d;
644
645 setstereobuf(STEREO_BUFFER_RIGHT);
646 if (viewflags & VWPERSP) {
647 glMatrixMode(GL_MODELVIEW);
648 glPushMatrix();
649 d = -eyesepdist / sqrt(odev.v.hn2);
650 glTranslated(d*odev.v.hvec[0], d*odev.v.hvec[1],
651 d*odev.v.hvec[2]);
652 checkglerr("setting right view");
653 }
654 }
655
656
657 static void
658 popright(void) /* pop off right view & buffer */
659 {
660 if (viewflags & VWPERSP) {
661 glMatrixMode(GL_MODELVIEW);
662 glPopMatrix();
663 }
664 setstereobuf(STEREO_BUFFER_LEFT);
665 }
666 #endif
667
668
669 static int
670 mytmflags(void) /* figure out tone mapping flags */
671 {
672 extern char *progname;
673 register char *cp, *tail;
674 /* find basic name */
675 for (cp = tail = progname; *cp; cp++)
676 if (*cp == '/')
677 tail = cp+1;
678 for (cp = tail; *cp && *cp != '.'; cp++)
679 ;
680 #ifdef DEBUG
681 if (cp > tail && cp[-1] == 'h')
682 return(TM_F_HUMAN);
683 else
684 return(TM_F_CAMERA);
685 #else
686 if (cp > tail && cp[-1] == 'h')
687 return(TM_F_HUMAN|TM_F_NOSTDERR);
688 else
689 return(TM_F_CAMERA|TM_F_NOSTDERR);
690 #endif
691 }
692
693
694 static void
695 getevent(void) /* get next event */
696 {
697 XNextEvent(ourdisplay, levptr(XEvent));
698 switch (levptr(XEvent)->type) {
699 case ConfigureNotify:
700 resizewindow(levptr(XConfigureEvent));
701 break;
702 case UnmapNotify:
703 viewflags &= ~VWMAPPED;
704 break;
705 case MapNotify:
706 odRemap(0);
707 viewflags |= VWMAPPED;
708 break;
709 case Expose:
710 fixwindow(levptr(XExposeEvent));
711 break;
712 case KeyPress:
713 getkey(levptr(XKeyPressedEvent));
714 break;
715 case ButtonPress:
716 if (FRAMESTATE(levptr(XButtonPressedEvent)->state))
717 getframe(levptr(XButtonPressedEvent));
718 else
719 getmove(levptr(XButtonPressedEvent));
720 break;
721 }
722 }
723
724
725 static void
726 draw3dline( /* draw 3d line in world coordinates */
727 register FVECT wp[2]
728 )
729 {
730 glVertex3d(wp[0][0], wp[0][1], wp[0][2]);
731 glVertex3d(wp[1][0], wp[1][1], wp[1][2]);
732 }
733
734
735 static void
736 draw_grids( /* draw holodeck section grids */
737 int fore
738 )
739 {
740 glPushAttrib(GL_LIGHTING_BIT|GL_ENABLE_BIT);
741 glDisable(GL_LIGHTING);
742 if (fore)
743 glColor3ub(4, 250, 250);
744 else
745 glColor3ub(0, 0, 0);
746 glBegin(GL_LINES); /* draw each grid line */
747 gridlines(draw3dline);
748 glEnd();
749 checkglerr("drawing grid lines");
750 glPopAttrib();
751 }
752
753
754 static int
755 moveview( /* move our view */
756 int dx,
757 int dy,
758 int mov,
759 int orb
760 )
761 {
762 VIEW nv;
763 FVECT odir, v1, wip;
764 double d, d1;
765 /* start with old view */
766 nv = odev.v;
767 /* orient our motion */
768 if (viewray(v1, odir, &odev.v,
769 (dx+.5)/odev.hres, (dy+.5)/odev.vres) < -FTINY)
770 return(0); /* outside view */
771 if (mov | orb) { /* moving relative to geometry */
772 d = getdistance(dx, dy, odir); /* distance from front plane */
773 #ifdef DOBJ
774 d1 = dobj_trace(NULL, v1, odir);
775 if (d1 < d)
776 d = d1;
777 #endif
778 if (d >= .99*FHUGE)
779 d = 0.5*(dev_zmax+dev_zmin); /* just guess */
780 VSUM(wip, v1, odir, d);
781 VSUB(odir, wip, odev.v.vp);
782 } else /* panning with constant viewpoint */
783 VCOPY(nv.vdir, odir);
784 if (orb && mov) { /* orbit left/right */
785 spinvector(odir, odir, nv.vup, d=MOVDEG*PI/180.*mov);
786 VSUM(nv.vp, wip, odir, -1.);
787 spinvector(nv.vdir, nv.vdir, nv.vup, d);
788 } else if (orb) { /* orbit up/down */
789 fcross(v1, odir, nv.vup);
790 if (normalize(v1) == 0.)
791 return(0);
792 spinvector(odir, odir, v1, d=MOVDEG*PI/180.*orb);
793 VSUM(nv.vp, wip, odir, -1.);
794 spinvector(nv.vdir, nv.vdir, v1, d);
795 } else if (mov) { /* move forward/backward */
796 d = MOVPCT/100. * mov;
797 VSUM(nv.vp, nv.vp, odir, d);
798 }
799 if (!mov ^ !orb && viewflags&VWHEADLOCK) { /* restore height */
800 VSUM(v1, odev.v.vp, nv.vp, -1.);
801 d = DOT(v1, nv.vup);
802 VSUM(nv.vp, nv.vp, odev.v.vup, d);
803 }
804 if (setview(&nv) != NULL)
805 return(0); /* illegal view */
806 dev_view(&nv);
807 inpresflags |= DFL(DC_SETVIEW);
808 return(1);
809 }
810
811
812 static void
813 getframe( /* get focus frame */
814 XButtonPressedEvent *ebut
815 )
816 {
817 int startx = ebut->x, starty = ebut->y;
818 int endx, endy;
819
820 XMaskEvent(ourdisplay, ButtonReleaseMask, levptr(XEvent));
821 endx = levptr(XButtonReleasedEvent)->x;
822 endy = levptr(XButtonReleasedEvent)->y;
823 if ((endx == startx) | (endy == starty)) {
824 XBell(ourdisplay, 0);
825 return;
826 }
827 if (endx < startx) {register int c = endx; endx = startx; startx = c;}
828 if (endy < starty) {register int c = endy; endy = starty; starty = c;}
829 sprintf(odev_args, "%.3f %.3f %.3f %.3f",
830 (startx+.5)/odev.hres, 1.-(endy+.5)/odev.vres,
831 (endx+.5)/odev.hres, 1.-(starty+.5)/odev.vres);
832 inpresflags |= DFL(DC_FOCUS);
833 }
834
835
836 static void
837 waitabit(void) /* pause a moment */
838 {
839 struct timespec ts;
840 ts.tv_sec = 0;
841 ts.tv_nsec = 100000000L;
842 nanosleep(&ts, NULL);
843 }
844
845
846 static void
847 getmove( /* get view change */
848 XButtonPressedEvent *ebut
849 )
850 {
851 int movdir = MOVDIR(ebut->button);
852 int movorb = MOVORB(ebut->state);
853 int ndrawn;
854 Window rootw, childw;
855 int rootx, rooty, wx, wy;
856 unsigned int statemask;
857
858 XNoOp(ourdisplay); /* makes sure we're not idle */
859
860 viewflags &= ~VWSTEADY; /* flag moving view */
861 setglpersp(); /* start us off in perspective */
862 while (!XCheckMaskEvent(ourdisplay,
863 ButtonReleaseMask, levptr(XEvent))) {
864 /* pause so as not to move too fast */
865 waitabit();
866 /* get cursor position */
867 if (!XQueryPointer(ourdisplay, gwind, &rootw, &childw,
868 &rootx, &rooty, &wx, &wy, &statemask))
869 break; /* on another screen */
870 /* compute view motion */
871 if (!moveview(wx, odev.vres-1-wy, movdir, movorb)) {
872 sleep(1);
873 continue; /* cursor in bad place */
874 }
875 draw_grids(1); /* redraw grid */
876 #ifdef STEREO
877 pushright();
878 draw_grids(1);
879 ndrawn = gmDrawGeom();
880 #ifdef DOBJ
881 ndrawn += dobj_render();
882 #endif
883 popright();
884 #endif
885 /* redraw octrees */
886 ndrawn = gmDrawGeom();
887 #ifdef DOBJ
888 ndrawn += dobj_render(); /* redraw objects */
889 #endif
890 glXSwapBuffers(ourdisplay, gwind);
891 if (!ndrawn)
892 sleep(1); /* for reasonable interaction */
893 }
894 if (!(inpresflags & DFL(DC_SETVIEW))) { /* do final motion */
895 movdir = MOVDIR(levptr(XButtonReleasedEvent)->button);
896 wx = levptr(XButtonReleasedEvent)->x;
897 wy = levptr(XButtonReleasedEvent)->y;
898 moveview(wx, odev.vres-1-wy, movdir, movorb);
899 }
900 viewflags |= VWSTEADY; /* done goofing around */
901 }
902
903
904 static void
905 setglpersp(void) /* set perspective view in GL */
906 {
907 double d, xmin, xmax, ymin, ymax;
908 GLfloat vec[4];
909 double depthlim[2];
910 /* set depth limits */
911 gmDepthLimit(depthlim, odev.v.vp, odev.v.vdir);
912 if (depthlim[0] >= depthlim[1]) {
913 dev_zmin = 1.;
914 dev_zmax = 100.;
915 } else {
916 dev_zmin = 0.5*depthlim[0];
917 dev_zmax = 1.25*depthlim[1];
918 if (dev_zmin > dev_zmax/5.)
919 dev_zmin = dev_zmax/5.;
920 }
921 if (odev.v.vfore > FTINY)
922 dev_zmin = odev.v.vfore;
923 if (odev.v.vaft > FTINY)
924 dev_zmax = odev.v.vaft;
925 if (dev_zmin*500. < dev_zmax)
926 dev_zmin = dev_zmax/500.;
927 setzrat();
928 xmax = dev_zmin * tan(PI/180./2. * odev.v.horiz);
929 xmin = -xmax;
930 d = odev.v.hoff * (xmax - xmin);
931 xmin += d; xmax += d;
932 ymax = dev_zmin * tan(PI/180./2. * odev.v.vert);
933 ymin = -ymax;
934 d = odev.v.voff * (ymax - ymin);
935 ymin += d; ymax += d;
936 /* set view matrix */
937 glMatrixMode(GL_PROJECTION);
938 glLoadIdentity();
939 glFrustum(xmin, xmax, ymin, ymax, dev_zmin, dev_zmax);
940 gluLookAt(odev.v.vp[0], odev.v.vp[1], odev.v.vp[2],
941 odev.v.vp[0] + odev.v.vdir[0],
942 odev.v.vp[1] + odev.v.vdir[1],
943 odev.v.vp[2] + odev.v.vdir[2],
944 odev.v.vup[0], odev.v.vup[1], odev.v.vup[2]);
945 checkglerr("setting perspective view");
946 vec[0] = vec[1] = vec[2] = 0.; vec[3] = 1.;
947 glLightModelfv(GL_LIGHT_MODEL_AMBIENT, vec);
948 vec[0] = -odev.v.vdir[0];
949 vec[1] = -odev.v.vdir[1];
950 vec[2] = -odev.v.vdir[2];
951 vec[3] = 0.;
952 glLightfv(GL_LIGHT0, GL_POSITION, vec);
953 vec[0] = vec[1] = vec[2] = .7; vec[3] = 1.;
954 glLightfv(GL_LIGHT0, GL_SPECULAR, vec);
955 glLightfv(GL_LIGHT0, GL_DIFFUSE, vec);
956 vec[0] = vec[1] = vec[2] = .3; vec[3] = 1.;
957 glLightfv(GL_LIGHT0, GL_AMBIENT, vec);
958 glEnable(GL_LIGHT0);
959 glEnable(GL_LIGHTING); /* light our GL objects */
960 glShadeModel(GL_SMOOTH);
961 viewflags &= ~VWORTHO;
962 viewflags |= VWPERSP;
963 }
964
965
966 static void
967 setglortho(void) /* set up orthographic view for cone drawing */
968 {
969 glDrawBuffer(GL_FRONT); /* use single-buffer mode */
970 /* set view matrix */
971 glMatrixMode(GL_PROJECTION);
972 glLoadIdentity();
973 glOrtho(0., (double)odev.hres, 0., (double)odev.vres,
974 0.001*OMAXDEPTH, 1.001*(-OMAXDEPTH));
975 checkglerr("setting orthographic view");
976 glDisable(GL_LIGHTING); /* cones are constant color */
977 glShadeModel(GL_FLAT);
978 viewflags &= ~VWPERSP;
979 viewflags |= VWORTHO;
980 }
981
982
983 static void
984 wipeclean(void) /* prepare for redraw */
985 {
986 glDrawBuffer(GL_BACK); /* use double-buffer mode */
987 glReadBuffer(GL_BACK);
988 /* clear buffers */
989 #ifdef STEREO
990 setstereobuf(STEREO_BUFFER_RIGHT);
991 glClear(GL_DEPTH_BUFFER_BIT|GL_COLOR_BUFFER_BIT);
992 setstereobuf(STEREO_BUFFER_LEFT);
993 #endif
994 glClear(GL_DEPTH_BUFFER_BIT|GL_COLOR_BUFFER_BIT);
995 freedepth();
996 if ((viewflags&(VWCHANGE|VWSTEADY)) ==
997 (VWCHANGE|VWSTEADY)) { /* clear samples if new */
998 odClean();
999 viewflags &= ~VWCHANGE; /* change noted */
1000 } else if (viewflags & VWSTEADY)
1001 odRedrawAll();
1002 setglpersp(); /* reset view & clipping planes */
1003 }
1004
1005
1006 static void
1007 getkey( /* get input key */
1008 register XKeyPressedEvent *ekey
1009 )
1010 {
1011 Window rootw, childw;
1012 int rootx, rooty, wx, wy;
1013 unsigned int statemask;
1014 int n;
1015 char buf[8];
1016
1017 n = XLookupString(ekey, buf, sizeof(buf), NULL, NULL);
1018 if (n != 1)
1019 return;
1020 switch (buf[0]) {
1021 case 'h': /* turn on height motion lock */
1022 viewflags |= VWHEADLOCK;
1023 return;
1024 case 'H': /* turn off height motion lock */
1025 viewflags &= ~VWHEADLOCK;
1026 return;
1027 case 'l': /* retrieve last view */
1028 inpresflags |= DFL(DC_LASTVIEW);
1029 return;
1030 case 'p': /* pause computation */
1031 inpresflags |= DFL(DC_PAUSE);
1032 return;
1033 case 'v': /* spit out view */
1034 inpresflags |= DFL(DC_GETVIEW);
1035 return;
1036 case 'f': /* frame view position */
1037 if (!XQueryPointer(ourdisplay, gwind, &rootw, &childw,
1038 &rootx, &rooty, &wx, &wy, &statemask))
1039 return; /* on another screen */
1040 sprintf(odev_args, "%.4f %.4f", (wx+.5)/odev.hres,
1041 1.-(wy+.5)/odev.vres);
1042 inpresflags |= DFL(DC_FOCUS);
1043 return;
1044 case 'F': /* unfocus */
1045 odev_args[0] = '\0';
1046 inpresflags |= DFL(DC_FOCUS);
1047 return;
1048 case '\n':
1049 case '\r': /* resume computation */
1050 inpresflags |= DFL(DC_RESUME);
1051 return;
1052 case CTRL('R'): /* redraw screen */
1053 odRemap(0); /* new tone mapping */
1054 glClear(GL_DEPTH_BUFFER_BIT);
1055 #ifdef STEREO
1056 setstereobuf(STEREO_BUFFER_RIGHT);
1057 glClear(GL_DEPTH_BUFFER_BIT);
1058 setstereobuf(STEREO_BUFFER_LEFT);
1059 #endif
1060 return;
1061 case CTRL('L'): /* refresh from server */
1062 if (inpresflags & DFL(DC_REDRAW))
1063 return; /* already called */
1064 XRaiseWindow(ourdisplay, gwind);
1065 XFlush(ourdisplay); /* raise up window */
1066 sleep(1); /* wait for restacking */
1067 dev_clear(); /* clear buffer and samples */
1068 odRemap(1); /* start fresh histogram */
1069 inpresflags |= DFL(DC_REDRAW); /* resend values from server */
1070 return;
1071 case 'K': /* kill rtrace process(es) */
1072 inpresflags |= DFL(DC_KILL);
1073 break;
1074 case 'R': /* restart rtrace */
1075 inpresflags |= DFL(DC_RESTART);
1076 break;
1077 case 'C': /* clobber holodeck */
1078 inpresflags |= DFL(DC_CLOBBER);
1079 break;
1080 case 'q': /* quit the program */
1081 inpresflags |= DFL(DC_QUIT);
1082 return;
1083 default:
1084 XBell(ourdisplay, 0);
1085 return;
1086 }
1087 }
1088
1089
1090 static void
1091 fixwindow( /* repair damage to window */
1092 register XExposeEvent *eexp
1093 )
1094 {
1095 int xmin, ymin, xmax, ymax;
1096
1097 if ((odev.hres == 0) | (odev.vres == 0)) { /* first exposure */
1098 resizewindow((XConfigureEvent *)eexp);
1099 return;
1100 }
1101 xmin = eexp->x; xmax = eexp->x + eexp->width;
1102 ymin = odev.vres - eexp->y - eexp->height; ymax = odev.vres - eexp->y;
1103
1104 if (xmin <= 0 && xmax >= odev.hres-1 &&
1105 ymin <= 0 && ymax >= odev.vres) {
1106 DCHECK(eexp->count, WARNING, "multiple clear in fixwindow");
1107 wipeclean(); /* make sure we're go */
1108 return;
1109 }
1110 /* clear portion of depth */
1111 glPushAttrib(GL_DEPTH_BUFFER_BIT|GL_COLOR_BUFFER_BIT);
1112 glColorMask(GL_FALSE, GL_FALSE, GL_FALSE, GL_FALSE);
1113 glDepthFunc(GL_ALWAYS);
1114 glBegin(GL_POLYGON);
1115 glVertex3i(xmin, ymin, OMAXDEPTH);
1116 glVertex3i(xmax, ymin, OMAXDEPTH);
1117 glVertex3i(xmax, ymax, OMAXDEPTH);
1118 glVertex3i(xmin, ymax, OMAXDEPTH);
1119 glEnd();
1120 #ifdef STEREO
1121 setstereobuf(STEREO_BUFFER_RIGHT);
1122 glBegin(GL_POLYGON);
1123 glVertex3i(xmin, ymin, OMAXDEPTH);
1124 glVertex3i(xmax, ymin, OMAXDEPTH);
1125 glVertex3i(xmax, ymax, OMAXDEPTH);
1126 glVertex3i(xmin, ymax, OMAXDEPTH);
1127 glEnd();
1128 odRedraw(1, xmin, ymin, xmax, ymax);
1129 setstereobuf(STEREO_BUFFER_LEFT);
1130 #endif
1131 glPopAttrib();
1132 odRedraw(0, xmin, ymin, xmax, ymax);
1133 }
1134
1135
1136 static void
1137 resizewindow( /* resize window */
1138 register XConfigureEvent *ersz
1139 )
1140 {
1141 glViewport(0, 0, ersz->width, ersz->height);
1142
1143 if (ersz->width == odev.hres && ersz->height == odev.vres)
1144 return;
1145
1146 odev.hres = ersz->width;
1147 odev.vres = ersz->height;
1148
1149 odev.v.horiz = 2.*180./PI * atan(0.5/VIEWDIST*pwidth*odev.hres);
1150 odev.v.vert = 2.*180./PI * atan(0.5/VIEWDIST*pheight*odev.vres);
1151
1152 inpresflags |= DFL(DC_SETVIEW);
1153 viewflags |= VWCHANGE;
1154 }
