root/radiance/ray/src/hd/rhd_ogl.c
Revision: 3.25
Committed: Thu Feb 12 18:55:50 2004 UTC (20 years, 7 months ago) by greg
Changes since 3.24: +2 -1 lines
2 static const char RCSid[] = "$Id: rhd_ogl.c,v 3.24 2004/01/01 11:21:55 schorsch Exp $";
5 * OpenGL driver for holodeck display.
6 * Based on GLX driver using T-mesh.
7 *
8 * Define symbol STEREO for stereo viewing.
9 * Define symbol DOBJ for display object viewing.
10 */
11
12 #ifdef NOSTEREO
13 #ifdef STEREO
14 #undef STEREO
15 #else
16 #undef NOSTEREO
17 #endif
18 #endif
19
20
21 #include <time.h>
22 #include <GL/glx.h>
23 #include <GL/glu.h>
24 #ifdef STEREO
25 #include <X11/extensions/SGIStereo.h>
26 #endif
27
28 #include "standard.h"
29 #include "rhd_odraw.h"
30 #include "rhdisp.h"
31 #include "paths.h"
32 #ifdef DOBJ
33 #include "rhdobj.h"
34 #endif
35
36 #include "x11icon.h"
37
38 #ifndef RAYQLEN
39 #define RAYQLEN 0 /* max. rays to queue before flush */
40 #endif
41 #ifndef MINWIDTH
42 #define MINWIDTH 480 /* minimum graphics window width */
43 #define MINHEIGHT 400 /* minimum graphics window height */
44 #endif
45 #ifndef VIEWDIST
46 #define VIEWDIST 356 /* assumed viewing distance (mm) */
47 #endif
48 #ifndef BORWIDTH
49 #define BORWIDTH 5 /* border width */
50 #endif
51
52 #ifndef FEQ
53 #define FEQ(a,b) ((a)-(b) <= FTINY && (a)-(b) >= -FTINY)
54 #endif
55
56 #define VWHEADLOCK 01 /* head position is locked flag */
57 #define VWPERSP 02 /* perspective view is set */
58 #define VWORTHO 04 /* orthographic view is set */
59 #define VWCHANGE 010 /* view has changed */
60 #define VWSTEADY 020 /* view is now steady */
61 #define VWMAPPED 040 /* window is mapped */
62
63 #define GAMMA 1.4 /* default gamma correction */
64
65 #define FRAMESTATE(s) (((s)&(ShiftMask|ControlMask))==(ShiftMask|ControlMask))
66
67 #define MOVPCT 7 /* percent distance to move /frame */
68 #define MOVDIR(b) ((b)==Button1 ? 1 : (b)==Button2 ? 0 : -1)
69 #define MOVDEG (-5) /* degrees to orbit CW/down /frame */
70 #define MOVORB(s) ((s)&ShiftMask ? 1 : (s)&ControlMask ? -1 : 0)
71
72 #define setstereobuf(bid) (glXWaitGL(), \
73 XSGISetStereoBuffer(ourdisplay, gwind, bid), \
74 glXWaitX())
75
76 #define ourscreen DefaultScreen(ourdisplay)
77 #define ourroot RootWindow(ourdisplay,ourscreen)
78 #define ourmask (StructureNotifyMask|ExposureMask|KeyPressMask|\
79 ButtonPressMask|ButtonReleaseMask)
80
81 #define levptr(etype) ((etype *)&currentevent)
82
83 struct driver odev; /* global device driver structure */
84
85 char odev_args[64]; /* command arguments */
86
87 static GLfloat *depthbuffer = NULL; /* depth buffer */
88
89 #ifdef STEREO
90 static VIEW vwright; /* right eye view */
91 static GLfloat *depthright = NULL; /* right depth buffer */
92 #endif
93
94 static int rayqleft = 0; /* rays left to queue before flush */
95
96 static XEvent currentevent; /* current event */
97
98 static unsigned long ourblack=0, ourwhite=~0;
99
100 static Display *ourdisplay = NULL; /* our display */
101 static XVisualInfo *ourvinf; /* our visual information */
102 static Window gwind = 0; /* our graphics window */
103 static GLXContext gctx; /* our GLX context */
104
105 static double pwidth, pheight; /* pixel dimensions (mm) */
106
107 static double dev_zmin, dev_zmax; /* fore and aft clipping plane dist. */
108 static double dev_zrat; /* (1. - dev_zmin/dev_zmax) */
109
110 #define setzrat() (dev_zrat = 1. - dev_zmin/dev_zmax)
111 #define mapdepth(d) ((d)>0.9995 ? FHUGE : dev_zmin/(1.-(d)*dev_zrat))
112
113 static int inpresflags; /* input result flags */
114
115 static int viewflags; /* what's happening with view */
116
117 /*
118 static int resizewindow(), getevent(), getkey(), moveview(), wipeclean(),
119 xferdepth(), freedepth(), setglortho(),
120 setglpersp(), getframe(), getmove(), fixwindow(), mytmflags();
121
122 static double getdistance();
123 */
124 static void checkglerr(char *where);
125 static void xferdepth(void);
126 static void freedepth(void);
127 static double getdistance(int dx, int dy, FVECT direc);
128 static int mytmflags(void);
129 static void getevent(void);
130 static void draw3dline(register FVECT wp[2]);
131 static void draw_grids(int fore);
132 static int moveview(int dx, int dy, int mov, int orb);
133 static void getframe(XButtonPressedEvent *ebut);
134 static void getmove(XButtonPressedEvent *ebut);
135 static void getkey(register XKeyPressedEvent *ekey);
136 static void fixwindow(register XExposeEvent *eexp);
137 static void resizewindow(register XConfigureEvent *ersz);
138 static void waitabit(void);
139 static void setglpersp(void);
140 static void setglortho(void);
141 static void wipeclean(void);
142
143
144 #ifdef STEREO
145 static void pushright(void);
146 static void popright(void);
147 #endif
148
149 extern int gmPortals; /* GL portal list id */
150
151 extern time_t time();
152
153
154 extern void
155 dev_open(id) /* initialize GLX driver */
156 char *id;
157 {
158 extern char *getenv();
159 static RGBPRIMS myprims = STDPRIMS;
160 static int atlBest[] = {GLX_RGBA, GLX_DOUBLEBUFFER,
161 GLX_RED_SIZE,8, GLX_GREEN_SIZE,8,
162 GLX_BLUE_SIZE,8, GLX_DEPTH_SIZE,15, None};
163 static int atlOK[] = {GLX_RGBA, GLX_DOUBLEBUFFER,
164 GLX_RED_SIZE,4, GLX_GREEN_SIZE,4,
165 GLX_BLUE_SIZE,4, GLX_DEPTH_SIZE,15, None};
166 char *ev;
167 double gamval = GAMMA;
168 RGBPRIMP dpri = stdprims;
169 XSetWindowAttributes ourwinattr;
170 XWMHints ourxwmhints;
171 XSizeHints oursizhints;
172 /* check for unsupported stereo */
173 #ifdef NOSTEREO
174 error(INTERNAL, "stereo display driver unavailable");
175 #endif
176 /* open display server */
177 ourdisplay = XOpenDisplay(NULL);
178 CHECK(ourdisplay==NULL, USER,
179 "cannot open X-windows; DISPLAY variable set?");
180 #ifdef STEREO
181 switch (XSGIQueryStereoMode(ourdisplay, ourroot)) {
182 case STEREO_TOP:
183 case STEREO_BOTTOM:
184 break;
185 case STEREO_OFF:
186 error(USER,
187 "wrong video mode: run \"/usr/gfx/setmon -n STR_TOP\" first");
188 case X_STEREO_UNSUPPORTED:
189 error(USER, "stereo mode not supported on this screen");
190 default:
191 error(INTERNAL, "unknown stereo mode");
192 }
193 #endif
194 /* find a usable visual */
195 ourvinf = glXChooseVisual(ourdisplay, ourscreen, atlBest);
196 if (ourvinf == NULL)
197 ourvinf = glXChooseVisual(ourdisplay, ourscreen, atlOK);
198 CHECK(ourvinf==NULL, USER, "no suitable visuals available");
199 /* get a context */
200 gctx = glXCreateContext(ourdisplay, ourvinf, NULL, GL_TRUE);
201 /* set gamma and tone mapping */
202 if ((ev = XGetDefault(ourdisplay, "radiance", "gamma")) != NULL
203 || (ev = getenv("DISPLAY_GAMMA")) != NULL)
204 gamval = atof(ev);
205 if ((ev = getenv("DISPLAY_PRIMARIES")) != NULL &&
206 sscanf(ev, "%f %f %f %f %f %f %f %f",
207 &myprims[RED][CIEX],&myprims[RED][CIEY],
208 &myprims[GRN][CIEX],&myprims[GRN][CIEY],
209 &myprims[BLU][CIEX],&myprims[BLU][CIEY],
210 &myprims[WHT][CIEX],&myprims[WHT][CIEY]) >= 6)
211 dpri = myprims;
212 if (tmInit(mytmflags(), dpri, gamval) == NULL)
213 error(SYSTEM, "not enough memory in dev_open");
214 /* open window */
215 ourwinattr.background_pixel = ourblack;
216 ourwinattr.border_pixel = ourblack;
217 ourwinattr.event_mask = ourmask;
218 /* this is stupid */
219 ourwinattr.colormap = XCreateColormap(ourdisplay, ourroot,
220 ourvinf->visual, AllocNone);
221 gwind = XCreateWindow(ourdisplay, ourroot, 0, 0,
222 DisplayWidth(ourdisplay,ourscreen)-2*BORWIDTH,
223 #ifdef STEREO
224 (DisplayHeight(ourdisplay,ourscreen)-2*BORWIDTH)/2,
225 #else
226 DisplayHeight(ourdisplay,ourscreen)-2*BORWIDTH,
227 #endif
228 BORWIDTH, ourvinf->depth, InputOutput, ourvinf->visual,
229 CWBackPixel|CWBorderPixel|CWColormap|CWEventMask, &ourwinattr);
230 CHECK(gwind==0, SYSTEM, "cannot create window");
231 XStoreName(ourdisplay, gwind, id);
232 /* set window manager hints */
233 ourxwmhints.flags = InputHint|IconPixmapHint;
234 ourxwmhints.input = True;
235 ourxwmhints.icon_pixmap = XCreateBitmapFromData(ourdisplay,
236 gwind, x11icon_bits, x11icon_width, x11icon_height);
237 XSetWMHints(ourdisplay, gwind, &ourxwmhints);
238 oursizhints.min_width = MINWIDTH;
239 #ifdef STEREO
240 oursizhints.min_height = MINHEIGHT/2;
241 oursizhints.max_width = DisplayWidth(ourdisplay,ourscreen)-2*BORWIDTH;
242 oursizhints.max_height = (DisplayHeight(ourdisplay,ourscreen) -
243 2*BORWIDTH)/2;
244 oursizhints.flags = PMinSize|PMaxSize;
245 #else
246 oursizhints.min_height = MINHEIGHT;
247 oursizhints.flags = PMinSize;
248 #endif
249 XSetNormalHints(ourdisplay, gwind, &oursizhints);
250 /* set GLX context */
251 glXMakeCurrent(ourdisplay, gwind, gctx);
252 glEnable(GL_DEPTH_TEST);
253 glDepthFunc(GL_LEQUAL);
254 glClearColor(0, 0, 0, 0);
255 glFrontFace(GL_CCW);
256 glDisable(GL_CULL_FACE);
257 glLightModeli(GL_LIGHT_MODEL_TWO_SIDE, GL_TRUE);
258 glPolygonMode(GL_FRONT_AND_BACK, GL_FILL);
259 glPixelStorei(GL_PACK_ALIGNMENT, 1);
260 glPixelStorei(GL_UNPACK_ALIGNMENT, 1);
261 /* figure out sensible view */
262 pwidth = (double)DisplayWidthMM(ourdisplay, ourscreen) /
263 DisplayWidth(ourdisplay, ourscreen);
264 pheight = (double)DisplayHeightMM(ourdisplay, ourscreen) /
265 DisplayHeight(ourdisplay, ourscreen);
266 #ifdef STEREO
267 pheight *= 2.;
268 setstereobuf(STEREO_BUFFER_LEFT);
269 #endif
270 checkglerr("setting rendering parameters");
271 odev.v = stdview;
272 odev.v.type = VT_PER;
273 viewflags = VWSTEADY; /* view starts static */
274 /* map the window */
275 XMapWindow(ourdisplay, gwind);
276 dev_input(); /* sets size and view angles */
277 if (!odInit(DisplayWidth(ourdisplay,ourscreen) *
278 DisplayHeight(ourdisplay,ourscreen) / 3))
279 error(SYSTEM, "insufficient memory for value storage");
280 odev.name = id;
281 odev.firstuse = 1; /* can't recycle samples */
282 odev.ifd = ConnectionNumber(ourdisplay);
283 }
284
285
286 extern void
287 dev_close(void) /* close our display and free resources */
288 {
289 #ifdef DOBJ
290 dobj_cleanup();
291 #endif
292 freedepth();
293 gmEndGeom();
294 gmEndPortal();
295 odDone();
296 glXMakeCurrent(ourdisplay, None, NULL);
297 glXDestroyContext(ourdisplay, gctx);
298 XDestroyWindow(ourdisplay, gwind);
299 gwind = 0;
300 XCloseDisplay(ourdisplay);
301 ourdisplay = NULL;
302 tmDone(NULL);
303 odev.v.type = 0;
304 odev.hres = odev.vres = 0;
305 odev.ifd = -1;
306 }
307
308
309 extern void
310 dev_clear(void) /* clear our representation */
311 {
312 viewflags |= VWCHANGE; /* pretend our view has changed */
313 wipeclean(); /* clean off display and samples */
314 dev_flush(); /* redraw geometry & get depth */
315 rayqleft = 0; /* hold off update */
316 }
317
318
319 extern int
320 dev_view( /* assign new driver view */
321 register VIEW *nv
322 )
323 {
324 if (nv->type != VT_PER || /* check view legality */
325 nv->horiz > 160. || nv->vert > 160.) {
326 error(COMMAND, "illegal view type/angle");
327 nv->type = odev.v.type;
328 nv->horiz = odev.v.horiz;
329 nv->vert = odev.v.vert;
330 return(0);
331 }
332 if (nv != &odev.v) {
333 /* resize window? */
334 if (!FEQ(nv->horiz,odev.v.horiz) ||
335 !FEQ(nv->vert,odev.v.vert)) {
336 int dw = DisplayWidth(ourdisplay,ourscreen);
337 int dh = DisplayHeight(ourdisplay,ourscreen);
338
339 dw -= 25; /* for window frame */
340 dh -= 50;
341 #ifdef STEREO
342 dh /= 2;
343 #endif
344 odev.hres = 2.*VIEWDIST/pwidth *
345 tan(PI/180./2.*nv->horiz);
346 odev.vres = 2.*VIEWDIST/pheight *
347 tan(PI/180./2.*nv->vert);
348 if (odev.hres > dw) {
349 odev.vres = dw * odev.vres / odev.hres;
350 odev.hres = dw;
351 }
352 if (odev.vres > dh) {
353 odev.hres = dh * odev.hres / odev.vres;
354 odev.vres = dh;
355 }
356 XResizeWindow(ourdisplay, gwind, odev.hres, odev.vres);
357 dev_input(); /* get resize event */
358 }
359 odev.v = *nv; /* setview() already called */
360 viewflags |= VWCHANGE;
361 }
362 #ifdef STEREO
363 vwright = *nv;
364 d = eyesepdist / sqrt(nv->hn2);
365 VSUM(vwright.vp, nv->vp, nv->hvec, d);
366 /* setview(&vwright); -- Unnecessary */
367 #endif
368 wipeclean();
369 return(1);
370 }
371
372
373 extern void
374 dev_section( /* add octree for geometry rendering */
375 char *gfn,
376 char *pfn
377 )
378 {
379 if (gfn == NULL) {
380 gmEndGeom();
381 gmEndPortal();
382 wipeclean(); /* new geometry, so redraw it */
383 return;
384 }
385 if (access(gfn, R_OK) == 0)
386 gmNewGeom(gfn);
387 #ifdef DEBUG
388 else {
389 sprintf(errmsg, "cannot load octree \"%s\"", gfn);
390 error(WARNING, errmsg);
391 }
392 #endif
393 if (pfn != NULL)
394 gmNewPortal(pfn);
395 }
396
397
398 extern void
399 dev_auxcom( /* process an auxiliary command */
400 char *cmd,
401 char *args
402 )
403 {
404 #ifdef DOBJ
405 int vischange;
406
407 if ((vischange = dobj_command(cmd, args)) >= 0) {
408 if (vischange) {
409 imm_mode = beam_sync(1) > 0;
410 dev_clear();
411 }
412 return;
413 }
414 #endif
415 sprintf(errmsg, "%s: unknown command", cmd);
416 error(COMMAND, errmsg);
417 }
418
419
420 extern VIEW *
421 dev_auxview( /* return nth auxiliary view */
422 int n,
423 int hvres[2]
424 )
425 {
426 hvres[0] = odev.hres; hvres[1] = odev.vres;
427 if (n == 0)
428 return(&odev.v);
429 #ifdef STEREO
430 if (n == 1)
431 return(&vwright);
432 #endif
433 return(NULL);
434 }
435
436
437 extern int
438 dev_input(void) /* get X11 input */
439 {
440 inpresflags = 0;
441
442 do
443 getevent();
444
445 while (XPending(ourdisplay) > 0);
446
447 odev.inpready = 0;
448
449 return(inpresflags);
450 }
451
452
453 extern void
454 dev_value( /* add a pixel value to our texture */
455 COLR c,
456 FVECT d,
457 FVECT p
458 )
459 {
460 #ifdef DOBJ
461 if (dobj_lightsamp != NULL) { /* in light source sampling */
462 (*dobj_lightsamp)(c, d, p);
463 return;
464 }
465 #endif
466 odSample(c, d, p); /* add to display representation */
467 if (!--rayqleft)
468 dev_flush(); /* flush output */
469 }
470
471
472 extern int
473 dev_flush(void) /* flush output as appropriate */
474 {
475 int ndrawn;
476
477 if ((viewflags&(VWMAPPED|VWPERSP)) == (VWMAPPED|VWPERSP)) {
478 #ifdef STEREO
479 pushright(); /* draw right eye */
480 ndrawn = gmDrawGeom();
481 #ifdef DOBJ
482 ndrawn += dobj_render();
483 #endif
484 checkglerr("rendering right eye");
485 popright(); /* draw left eye */
486 #endif
487 ndrawn = gmDrawGeom();
488 #ifdef DOBJ
489 ndrawn += dobj_render();
490 #endif
491 glXSwapBuffers(ourdisplay, gwind);
492 checkglerr("rendering base view");
493 }
494 if ((viewflags&(VWMAPPED|VWSTEADY|VWPERSP|VWORTHO)) ==
495 (VWMAPPED|VWSTEADY|VWPERSP)) {
496 /* first time after steady */
497 if (ndrawn)
498 xferdepth(); /* transfer and clear depth */
499 setglortho(); /* set orthographic view */
500
501 }
502 if ((viewflags&(VWMAPPED|VWSTEADY|VWPERSP|VWORTHO)) ==
503 (VWMAPPED|VWSTEADY|VWORTHO)) {
504 /* else update cones */
505 #ifdef STEREO
506 pushright();
507 odUpdate(1); /* draw right eye */
508 popright();
509 #endif
510 odUpdate(0); /* draw left eye */
511 glFlush(); /* flush OpenGL */
512 }
513 rayqleft = RAYQLEN;
514 /* flush X11 and return # pending */
515 return(odev.inpready = XPending(ourdisplay));
516 }
517
518
519 static void
520 checkglerr( /* check for GL or GLU error */
521 char *where
522 )
523 {
524 register GLenum errcode;
525
526 while ((errcode = glGetError()) != GL_NO_ERROR) {
527 sprintf(errmsg, "OpenGL error %s: %s",
528 where, gluErrorString(errcode));
529 error(WARNING, errmsg);
530 }
531 }
532
533
534 static void
535 xferdepth(void) /* load and clear depth buffer */
536 {
537 register GLfloat *dbp;
538 register GLubyte *pbuf;
539
540 if (depthbuffer == NULL) { /* allocate private depth buffer */
541 #ifdef STEREO
542 depthright = (GLfloat *)malloc(
543 odev.hres*odev.vres*sizeof(GLfloat));
544 #endif
545 depthbuffer = (GLfloat *)malloc(
546 odev.hres*odev.vres*sizeof(GLfloat));
547 CHECK(depthbuffer==NULL, SYSTEM, "out of memory in xferdepth");
548 }
549 /* allocate alpha buffer for portals */
550 if (gmPortals)
551 pbuf = (GLubyte *)malloc(odev.hres*odev.vres*sizeof(GLubyte));
552 else
553 pbuf = NULL;
554 #ifdef STEREO
555 pushright();
556 glReadPixels(0, 0, odev.hres, odev.vres,
557 GL_DEPTH_COMPONENT, GL_FLOAT, depthright);
558 if (pbuf != NULL) {
559 glClear(GL_COLOR_BUFFER_BIT);
560 gmDrawPortals(0xff, -1, -1, -1);
561 glReadPixels(0, 0, odev.hres, odev.vres,
562 GL_RED, GL_UNSIGNED_BYTE, pbuf);
563 }
564 for (dbp = depthright + odev.hres*odev.vres; dbp-- > depthright; )
565 if (pbuf != NULL && pbuf[dbp-depthright]&0x40)
566 *dbp = FHUGE;
567 else
568 *dbp = mapdepth(*dbp);
569 glClear(GL_DEPTH_BUFFER_BIT);
570 odDepthMap(1, depthright);
571 popright();
572 #endif
573 /* read back depth buffer */
574 glReadPixels(0, 0, odev.hres, odev.vres,
575 GL_DEPTH_COMPONENT, GL_FLOAT, depthbuffer);
576 if (pbuf != NULL) {
577 glClear(GL_COLOR_BUFFER_BIT); /* find portals */
578 gmDrawPortals(0xff, -1, -1, -1);
579 glReadPixels(0, 0, odev.hres, odev.vres,
580 GL_RED, GL_UNSIGNED_BYTE, pbuf);
581 #ifdef DEBUG
582 glXSwapBuffers(ourdisplay, gwind);
583 #endif
584 }
585 for (dbp = depthbuffer + odev.hres*odev.vres; dbp-- > depthbuffer; )
586 if (pbuf != NULL && pbuf[dbp-depthbuffer]&0x40)
587 *dbp = FHUGE;
588 else
589 *dbp = mapdepth(*dbp);
590 glClear(GL_DEPTH_BUFFER_BIT); /* clear system depth buffer */
591 odDepthMap(0, depthbuffer); /* transfer depth data */
592 if (pbuf != NULL)
593 free((void *)pbuf); /* free our portal buffer */
594 }
595
596
597 static void
598 freedepth(void) /* free recorded depth buffer */
599 {
600 if (depthbuffer == NULL)
601 return;
602 #ifdef STEREO
603 odDepthMap(1, NULL);
604 free((void *)depthright);
605 depthright = NULL;
606 #endif
607 odDepthMap(0, NULL);
608 free((void *)depthbuffer);
609 depthbuffer = NULL;
610 }
611
612
613 static double
614 getdistance( /* distance from fore plane along view ray */
615 int dx,
616 int dy,
617 FVECT direc
618 )
619 {
620 GLfloat gldepth;
621 double dist;
622
623 if ((dx<0) | (dx>=odev.hres) | (dy<0) | (dy>=odev.vres))
624 return(FHUGE);
625 if (depthbuffer != NULL)
626 dist = depthbuffer[dy*odev.hres + dx];
627 else {
628 glReadPixels(dx,dy, 1,1, GL_DEPTH_COMPONENT,
629 GL_FLOAT, &gldepth);
630 if (gldepth <= FTINY)
631 return (FHUGE); /* call failed */
632 dist = mapdepth(gldepth);
633 }
634 if (dist >= .99*FHUGE)
635 return(FHUGE);
636 return((dist-odev.v.vfore)/DOT(direc,odev.v.vdir));
637 }
638
639
640 #ifdef STEREO
641 static void
642 pushright(void) /* push on right view & buffer */
643 {
644 double d;
645
646 setstereobuf(STEREO_BUFFER_RIGHT);
647 if (viewflags & VWPERSP) {
648 glMatrixMode(GL_MODELVIEW);
649 glPushMatrix();
650 d = -eyesepdist / sqrt(odev.v.hn2);
651 glTranslated(d*odev.v.hvec[0], d*odev.v.hvec[1],
652 d*odev.v.hvec[2]);
653 checkglerr("setting right view");
654 }
655 }
656
657
658 static void
659 popright(void) /* pop off right view & buffer */
660 {
661 if (viewflags & VWPERSP) {
662 glMatrixMode(GL_MODELVIEW);
663 glPopMatrix();
664 }
665 setstereobuf(STEREO_BUFFER_LEFT);
666 }
667 #endif
668
669
670 static int
671 mytmflags(void) /* figure out tone mapping flags */
672 {
673 extern char *progname;
674 register char *cp, *tail;
675 /* find basic name */
676 for (cp = tail = progname; *cp; cp++)
677 if (*cp == '/')
678 tail = cp+1;
679 for (cp = tail; *cp && *cp != '.'; cp++)
680 ;
681 #ifdef DEBUG
682 if (cp > tail && cp[-1] == 'h')
683 return(TM_F_HUMAN);
684 else
685 return(TM_F_CAMERA);
686 #else
687 if (cp > tail && cp[-1] == 'h')
688 return(TM_F_HUMAN|TM_F_NOSTDERR);
689 else
690 return(TM_F_CAMERA|TM_F_NOSTDERR);
691 #endif
692 }
693
694
695 static void
696 getevent(void) /* get next event */
697 {
698 XNextEvent(ourdisplay, levptr(XEvent));
699 switch (levptr(XEvent)->type) {
700 case ConfigureNotify:
701 resizewindow(levptr(XConfigureEvent));
702 break;
703 case UnmapNotify:
704 viewflags &= ~VWMAPPED;
705 break;
706 case MapNotify:
707 odRemap(0);
708 viewflags |= VWMAPPED;
709 break;
710 case Expose:
711 fixwindow(levptr(XExposeEvent));
712 break;
713 case KeyPress:
714 getkey(levptr(XKeyPressedEvent));
715 break;
716 case ButtonPress:
717 if (FRAMESTATE(levptr(XButtonPressedEvent)->state))
718 getframe(levptr(XButtonPressedEvent));
719 else
720 getmove(levptr(XButtonPressedEvent));
721 break;
722 }
723 }
724
725
726 static void
727 draw3dline( /* draw 3d line in world coordinates */
728 register FVECT wp[2]
729 )
730 {
731 glVertex3d(wp[0][0], wp[0][1], wp[0][2]);
732 glVertex3d(wp[1][0], wp[1][1], wp[1][2]);
733 }
734
735
736 static void
737 draw_grids( /* draw holodeck section grids */
738 int fore
739 )
740 {
741 glPushAttrib(GL_LIGHTING_BIT|GL_ENABLE_BIT);
742 glDisable(GL_LIGHTING);
743 if (fore)
744 glColor3ub(4, 250, 250);
745 else
746 glColor3ub(0, 0, 0);
747 glBegin(GL_LINES); /* draw each grid line */
748 gridlines(draw3dline);
749 glEnd();
750 checkglerr("drawing grid lines");
751 glPopAttrib();
752 }
753
754
755 static int
756 moveview( /* move our view */
757 int dx,
758 int dy,
759 int mov,
760 int orb
761 )
762 {
763 VIEW nv;
764 FVECT odir, v1, wip;
765 double d, d1;
766 /* start with old view */
767 nv = odev.v;
768 /* orient our motion */
769 if (viewray(v1, odir, &odev.v,
770 (dx+.5)/odev.hres, (dy+.5)/odev.vres) < -FTINY)
771 return(0); /* outside view */
772 if (mov | orb) { /* moving relative to geometry */
773 d = getdistance(dx, dy, odir); /* distance from front plane */
774 #ifdef DOBJ
775 d1 = dobj_trace(NULL, v1, odir);
776 if (d1 < d)
777 d = d1;
778 #endif
779 if (d >= .99*FHUGE)
780 d = 0.5*(dev_zmax+dev_zmin); /* just guess */
781 VSUM(wip, v1, odir, d);
782 VSUB(odir, wip, odev.v.vp);
783 } else /* panning with constant viewpoint */
784 VCOPY(nv.vdir, odir);
785 if (orb && mov) { /* orbit left/right */
786 spinvector(odir, odir, nv.vup, d=MOVDEG*PI/180.*mov);
787 VSUM(nv.vp, wip, odir, -1.);
788 spinvector(nv.vdir, nv.vdir, nv.vup, d);
789 } else if (orb) { /* orbit up/down */
790 fcross(v1, odir, nv.vup);
791 if (normalize(v1) == 0.)
792 return(0);
793 spinvector(odir, odir, v1, d=MOVDEG*PI/180.*orb);
794 VSUM(nv.vp, wip, odir, -1.);
795 spinvector(nv.vdir, nv.vdir, v1, d);
796 } else if (mov) { /* move forward/backward */
797 d = MOVPCT/100. * mov;
798 VSUM(nv.vp, nv.vp, odir, d);
799 }
800 if (!mov ^ !orb && viewflags&VWHEADLOCK) { /* restore height */
801 VSUM(v1, odev.v.vp, nv.vp, -1.);
802 d = DOT(v1, nv.vup);
803 VSUM(nv.vp, nv.vp, odev.v.vup, d);
804 }
805 if (setview(&nv) != NULL)
806 return(0); /* illegal view */
807 dev_view(&nv);
808 inpresflags |= DFL(DC_SETVIEW);
809 return(1);
810 }
811
812
813 static void
814 getframe( /* get focus frame */
815 XButtonPressedEvent *ebut
816 )
817 {
818 int startx = ebut->x, starty = ebut->y;
819 int endx, endy;
820
821 XMaskEvent(ourdisplay, ButtonReleaseMask, levptr(XEvent));
822 endx = levptr(XButtonReleasedEvent)->x;
823 endy = levptr(XButtonReleasedEvent)->y;
824 if ((endx == startx) | (endy == starty)) {
825 XBell(ourdisplay, 0);
826 return;
827 }
828 if (endx < startx) {register int c = endx; endx = startx; startx = c;}
829 if (endy < starty) {register int c = endy; endy = starty; starty = c;}
830 sprintf(odev_args, "%.3f %.3f %.3f %.3f",
831 (startx+.5)/odev.hres, 1.-(endy+.5)/odev.vres,
832 (endx+.5)/odev.hres, 1.-(starty+.5)/odev.vres);
833 inpresflags |= DFL(DC_FOCUS);
834 }
835
836
837 static void
838 waitabit(void) /* pause a moment */
839 {
840 struct timespec ts;
841 ts.tv_sec = 0;
842 ts.tv_nsec = 100000000L;
843 nanosleep(&ts, NULL);
844 }
845
846
847 static void
848 getmove( /* get view change */
849 XButtonPressedEvent *ebut
850 )
851 {
852 int movdir = MOVDIR(ebut->button);
853 int movorb = MOVORB(ebut->state);
854 int ndrawn;
855 Window rootw, childw;
856 int rootx, rooty, wx, wy;
857 unsigned int statemask;
858
859 XNoOp(ourdisplay); /* makes sure we're not idle */
860
861 viewflags &= ~VWSTEADY; /* flag moving view */
862 setglpersp(); /* start us off in perspective */
863 while (!XCheckMaskEvent(ourdisplay,
864 ButtonReleaseMask, levptr(XEvent))) {
865 /* pause so as not to move too fast */
866 waitabit();
867 /* get cursor position */
868 if (!XQueryPointer(ourdisplay, gwind, &rootw, &childw,
869 &rootx, &rooty, &wx, &wy, &statemask))
870 break; /* on another screen */
871 /* compute view motion */
872 if (!moveview(wx, odev.vres-1-wy, movdir, movorb)) {
873 sleep(1);
874 continue; /* cursor in bad place */
875 }
876 draw_grids(1); /* redraw grid */
877 #ifdef STEREO
878 pushright();
879 draw_grids(1);
880 ndrawn = gmDrawGeom();
881 #ifdef DOBJ
882 ndrawn += dobj_render();
883 #endif
884 popright();
885 #endif
886 /* redraw octrees */
887 ndrawn = gmDrawGeom();
888 #ifdef DOBJ
889 ndrawn += dobj_render(); /* redraw objects */
890 #endif
891 glXSwapBuffers(ourdisplay, gwind);
892 if (!ndrawn)
893 sleep(1); /* for reasonable interaction */
894 }
895 if (!(inpresflags & DFL(DC_SETVIEW))) { /* do final motion */
896 movdir = MOVDIR(levptr(XButtonReleasedEvent)->button);
897 wx = levptr(XButtonReleasedEvent)->x;
898 wy = levptr(XButtonReleasedEvent)->y;
899 moveview(wx, odev.vres-1-wy, movdir, movorb);
900 }
901 viewflags |= VWSTEADY; /* done goofing around */
902 }
903
904
905 static void
906 setglpersp(void) /* set perspective view in GL */
907 {
908 double d, xmin, xmax, ymin, ymax;
909 GLfloat vec[4];
910 double depthlim[2];
911 /* set depth limits */
912 gmDepthLimit(depthlim, odev.v.vp, odev.v.vdir);
913 if (depthlim[0] >= depthlim[1]) {
914 dev_zmin = 1.;
915 dev_zmax = 100.;
916 } else {
917 dev_zmin = 0.5*depthlim[0];
918 dev_zmax = 1.25*depthlim[1];
919 if (dev_zmin > dev_zmax/5.)
920 dev_zmin = dev_zmax/5.;
921 }
922 if (odev.v.vfore > FTINY)
923 dev_zmin = odev.v.vfore;
924 if (odev.v.vaft > FTINY)
925 dev_zmax = odev.v.vaft;
926 if (dev_zmin*500. < dev_zmax)
927 dev_zmin = dev_zmax/500.;
928 setzrat();
929 xmax = dev_zmin * tan(PI/180./2. * odev.v.horiz);
930 xmin = -xmax;
931 d = odev.v.hoff * (xmax - xmin);
932 xmin += d; xmax += d;
933 ymax = dev_zmin * tan(PI/180./2. * odev.v.vert);
934 ymin = -ymax;
935 d = odev.v.voff * (ymax - ymin);
936 ymin += d; ymax += d;
937 /* set view matrix */
938 glMatrixMode(GL_PROJECTION);
939 glLoadIdentity();
940 glFrustum(xmin, xmax, ymin, ymax, dev_zmin, dev_zmax);
941 gluLookAt(odev.v.vp[0], odev.v.vp[1], odev.v.vp[2],
942 odev.v.vp[0] + odev.v.vdir[0],
943 odev.v.vp[1] + odev.v.vdir[1],
944 odev.v.vp[2] + odev.v.vdir[2],
945 odev.v.vup[0], odev.v.vup[1], odev.v.vup[2]);
946 checkglerr("setting perspective view");
947 vec[0] = vec[1] = vec[2] = 0.; vec[3] = 1.;
948 glLightModelfv(GL_LIGHT_MODEL_AMBIENT, vec);
949 vec[0] = -odev.v.vdir[0];
950 vec[1] = -odev.v.vdir[1];
951 vec[2] = -odev.v.vdir[2];
952 vec[3] = 0.;
953 glLightfv(GL_LIGHT0, GL_POSITION, vec);
954 vec[0] = vec[1] = vec[2] = .7; vec[3] = 1.;
955 glLightfv(GL_LIGHT0, GL_SPECULAR, vec);
956 glLightfv(GL_LIGHT0, GL_DIFFUSE, vec);
957 vec[0] = vec[1] = vec[2] = .3; vec[3] = 1.;
958 glLightfv(GL_LIGHT0, GL_AMBIENT, vec);
959 glEnable(GL_LIGHT0);
960 glEnable(GL_LIGHTING); /* light our GL objects */
961 glShadeModel(GL_SMOOTH);
962 viewflags &= ~VWORTHO;
963 viewflags |= VWPERSP;
964 }
965
966
967 static void
968 setglortho(void) /* set up orthographic view for cone drawing */
969 {
970 glDrawBuffer(GL_FRONT); /* use single-buffer mode */
971 /* set view matrix */
972 glMatrixMode(GL_PROJECTION);
973 glLoadIdentity();
974 glOrtho(0., (double)odev.hres, 0., (double)odev.vres,
975 0.001*OMAXDEPTH, 1.001*(-OMAXDEPTH));
976 checkglerr("setting orthographic view");
977 glDisable(GL_LIGHTING); /* cones are constant color */
978 glShadeModel(GL_FLAT);
979 viewflags &= ~VWPERSP;
980 viewflags |= VWORTHO;
981 }
982
983
984 static void
985 wipeclean(void) /* prepare for redraw */
986 {
987 glDrawBuffer(GL_BACK); /* use double-buffer mode */
988 glReadBuffer(GL_BACK);
989 /* clear buffers */
990 #ifdef STEREO
991 setstereobuf(STEREO_BUFFER_RIGHT);
992 glClear(GL_DEPTH_BUFFER_BIT|GL_COLOR_BUFFER_BIT);
993 setstereobuf(STEREO_BUFFER_LEFT);
994 #endif
995 glClear(GL_DEPTH_BUFFER_BIT|GL_COLOR_BUFFER_BIT);
996 freedepth();
997 if ((viewflags&(VWCHANGE|VWSTEADY)) ==
998 (VWCHANGE|VWSTEADY)) { /* clear samples if new */
999 odClean();
1000 viewflags &= ~VWCHANGE; /* change noted */
1001 } else if (viewflags & VWSTEADY)
1002 odRedrawAll();
1003 setglpersp(); /* reset view & clipping planes */
1004 }
1005
1006
1007 static void
1008 getkey( /* get input key */
1009 register XKeyPressedEvent *ekey
1010 )
1011 {
1012 Window rootw, childw;
1013 int rootx, rooty, wx, wy;
1014 unsigned int statemask;
1015 int n;
1016 char buf[8];
1017
1018 n = XLookupString(ekey, buf, sizeof(buf), NULL, NULL);
1019 if (n != 1)
1020 return;
1021 switch (buf[0]) {
1022 case 'h': /* turn on height motion lock */
1023 viewflags |= VWHEADLOCK;
1024 return;
1025 case 'H': /* turn off height motion lock */
1026 viewflags &= ~VWHEADLOCK;
1027 return;
1028 case 'l': /* retrieve last view */
1029 inpresflags |= DFL(DC_LASTVIEW);
1030 return;
1031 case 'p': /* pause computation */
1032 inpresflags |= DFL(DC_PAUSE);
1033 return;
1034 case 'v': /* spit out view */
1035 inpresflags |= DFL(DC_GETVIEW);
1036 return;
1037 case 'f': /* frame view position */
1038 if (!XQueryPointer(ourdisplay, gwind, &rootw, &childw,
1039 &rootx, &rooty, &wx, &wy, &statemask))
1040 return; /* on another screen */
1041 sprintf(odev_args, "%.4f %.4f", (wx+.5)/odev.hres,
1042 1.-(wy+.5)/odev.vres);
1043 inpresflags |= DFL(DC_FOCUS);
1044 return;
1045 case 'F': /* unfocus */
1046 odev_args[0] = '\0';
1047 inpresflags |= DFL(DC_FOCUS);
1048 return;
1049 case '\n':
1050 case '\r': /* resume computation */
1051 inpresflags |= DFL(DC_RESUME);
1052 return;
1053 case CTRL('R'): /* redraw screen */
1054 odRemap(0); /* new tone mapping */
1055 glClear(GL_DEPTH_BUFFER_BIT);
1056 #ifdef STEREO
1057 setstereobuf(STEREO_BUFFER_RIGHT);
1058 glClear(GL_DEPTH_BUFFER_BIT);
1059 setstereobuf(STEREO_BUFFER_LEFT);
1060 #endif
1061 return;
1062 case CTRL('L'): /* refresh from server */
1063 if (inpresflags & DFL(DC_REDRAW))
1064 return; /* already called */
1065 XRaiseWindow(ourdisplay, gwind);
1066 XFlush(ourdisplay); /* raise up window */
1067 sleep(1); /* wait for restacking */
1068 dev_clear(); /* clear buffer and samples */
1069 odRemap(1); /* start fresh histogram */
1070 inpresflags |= DFL(DC_REDRAW); /* resend values from server */
1071 return;
1072 case 'K': /* kill rtrace process(es) */
1073 inpresflags |= DFL(DC_KILL);
1074 break;
1075 case 'R': /* restart rtrace */
1076 inpresflags |= DFL(DC_RESTART);
1077 break;
1078 case 'C': /* clobber holodeck */
1079 inpresflags |= DFL(DC_CLOBBER);
1080 break;
1081 case 'q': /* quit the program */
1082 inpresflags |= DFL(DC_QUIT);
1083 return;
1084 default:
1085 XBell(ourdisplay, 0);
1086 return;
1087 }
1088 }
1089
1090
1091 static void
1092 fixwindow( /* repair damage to window */
1093 register XExposeEvent *eexp
1094 )
1095 {
1096 int xmin, ymin, xmax, ymax;
1097
1098 if ((odev.hres == 0) | (odev.vres == 0)) { /* first exposure */
1099 resizewindow((XConfigureEvent *)eexp);
1100 return;
1101 }
1102 xmin = eexp->x; xmax = eexp->x + eexp->width;
1103 ymin = odev.vres - eexp->y - eexp->height; ymax = odev.vres - eexp->y;
1104
1105 if (xmin <= 0 && xmax >= odev.hres-1 &&
1106 ymin <= 0 && ymax >= odev.vres) {
1107 DCHECK(eexp->count, WARNING, "multiple clear in fixwindow");
1108 wipeclean(); /* make sure we're go */
1109 return;
1110 }
1111 /* clear portion of depth */
1112 glPushAttrib(GL_DEPTH_BUFFER_BIT|GL_COLOR_BUFFER_BIT);
1113 glColorMask(GL_FALSE, GL_FALSE, GL_FALSE, GL_FALSE);
1114 glDepthFunc(GL_ALWAYS);
1115 glBegin(GL_POLYGON);
1116 glVertex3i(xmin, ymin, OMAXDEPTH);
1117 glVertex3i(xmax, ymin, OMAXDEPTH);
1118 glVertex3i(xmax, ymax, OMAXDEPTH);
1119 glVertex3i(xmin, ymax, OMAXDEPTH);
1120 glEnd();
1121 #ifdef STEREO
1122 setstereobuf(STEREO_BUFFER_RIGHT);
1123 glBegin(GL_POLYGON);
1124 glVertex3i(xmin, ymin, OMAXDEPTH);
1125 glVertex3i(xmax, ymin, OMAXDEPTH);
1126 glVertex3i(xmax, ymax, OMAXDEPTH);
1127 glVertex3i(xmin, ymax, OMAXDEPTH);
1128 glEnd();
1129 odRedraw(1, xmin, ymin, xmax, ymax);
1130 setstereobuf(STEREO_BUFFER_LEFT);
1131 #endif
1132 glPopAttrib();
1133 odRedraw(0, xmin, ymin, xmax, ymax);
1134 }
1135
1136
1137 static void
1138 resizewindow( /* resize window */
1139 register XConfigureEvent *ersz
1140 )
1141 {
1142 glViewport(0, 0, ersz->width, ersz->height);
1143
1144 if (ersz->width == odev.hres && ersz->height == odev.vres)
1145 return;
1146
1147 odev.hres = ersz->width;
1148 odev.vres = ersz->height;
1149
1150 odev.v.horiz = 2.*180./PI * atan(0.5/VIEWDIST*pwidth*odev.hres);
1151 odev.v.vert = 2.*180./PI * atan(0.5/VIEWDIST*pheight*odev.vres);
1152
1153 inpresflags |= DFL(DC_SETVIEW);
1154 viewflags |= VWCHANGE;
1155 }
