root/radiance/ray/src/hd/rhd_odraw.h
Revision: 3.4
Committed: Tue Dec 22 17:05:54 1998 UTC (25 years, 5 months ago) by gwlarson
1 /* Copyright (c) 1998 Silicon Graphics, Inc. */
2
3 /* SCCSid "$SunId$ SGI" */
4
5 /*
6 * Header for OpenGL cone drawing routines with depth buffer checks.
7 */
8
9 #undef NOPROTO
10 #define NOPROTO 1
11 #include "color.h"
12 #include "tonemap.h"
13 #include "rhdriver.h"
14
15 #ifndef int4
16 #define int4 int
17 #endif
18
19 extern struct ODview {
20 int sfirst, snext; /* first sample and first in next view */
21 short hhi, vhi; /* screen image resolution */
22 short hlow, vlow; /* block resolution */
23 struct ODblock {
24 short nsamp; /* number of samples in block */
25 short nused; /* number actually allocated */
26 int first; /* first sample in this block */
27 int free; /* index for block free list */
28 float pthresh; /* proximity threshold */
29 } *bmap; /* low resolution image map */
30 int4 *emap; /* low resolution edge presence map */
31 int4 *pmap; /* high resolution presence map */
32 GLfloat *dmap; /* high resolution depth map */
33 } *odView; /* our view list */
34
35 extern int odNViews; /* number of views in our list */
36
37 extern struct ODsamp {
38 union ODfunion {
39 float prox; /* viewpoint proximity */
40 int4 next; /* next in free list */
41
42 } *f; /* free list next or proximity */
43 short (*ip)[2]; /* image position array */
44 TMbright *brt; /* encoded brightness array */
45 BYTE (*chr)[3]; /* encoded chrominance array */
46 BYTE (*rgb)[3]; /* tone-mapped color array */
47 int4 *redraw; /* redraw flags */
48 int nsamp; /* total number of samples */
49 char *base; /* base of allocated memory */
50 } odS; /* sample values */
51
52 #ifndef FL4OP
53 #define FL4OP(f,i,op) ((f)[(i)>>5] op (1L<<((i)&0x1f)))
54 #define CHK4(f,i) FL4OP(f,i,&)
55 #define SET4(f,i) FL4OP(f,i,|=)
56 #define CLR4(f,i) FL4OP(f,i,&=~)
57 #define TGL4(f,i) FL4OP(f,i,^=)
58 #define FL4NELS(n) (((n)+0x1f)>>5)
59 #define CLR4ALL(f,n) bzero((char *)(f),FL4NELS(n)*sizeof(int4))
60 #endif
61
62 #define OMAXDEPTH 32000 /* maximum depth value */
63
64 #define nextfree(i) f[i].next /* free pointers */
65 #define closeness(i) f[i].prox /* viewpoint proximity */
66 #define ENDFREE (-1) /* free list terminator */
67
68 #define odClean() odInit(odS.nsamp) /* clear samples */
69 #define odDone() odInit(0) /* free samples */
70
71
72 /*****************************************************************************
73 * Interface routines:
74
75
76 int
77 odInit(nsamps) : allocate and initialize memory
78 int nsamps; : number of samples to make available
79
80 If nsamps is zero, then this becomes a deallocation routine. If nsamps
81 is the same as last time, then this merely clears all data. The dev_auxview()
82 function may be called to determine the current view(s). The odAlloc()
83 function returns the number of samples actually allocated.
84
85
86 void
87 odSample(c, d, p) : register new sample value
88 COLR c; : pixel color (RGBE)
89 FVECT d; : ray direction vector
90 FVECT p; : world intersection point
91
92 If p is NULL, then the point is at infinity.
93
94
95 void
96 odDepthMap(vn, dm) : set depth map for the given view
97 int vn; : view number
98 GLfloat *dm; : depth map
99
100 Assign the depth map associated with view number vn. The map has
101 been preallocated, and won't be freed until it is no longer needed
102 (after an odAlloc() call). All depth values are the projected
103 distance along the view direction from the view origin. If dm
104 is NULL, then there is no depth map associated with this view.
105
106
107 void
108 odRedraw(vn, x0, y0, x1, y1) : region needs to be redrawn
109 int vn; : view number
110 int x0, y0, x1, y1; : rectangle to redraw
111
112 This call indicates that the given rectangular region in view vn
113 needs to be redrawn in the next call to odUpdate().
114
115
116 void
117 odUpdate(vn) : update the current view
118 int vn; : view number
119
120 Draw all new and undrawn sample values since last call for this view.
121
122
123 void
124 odRemap(newhist) : recompute tone mapping
125 int newhist; : flag whether to clear history
126
127 Recompute the tone mapping for all the samples in all the views
128 and redraw them on the next call(s) to odUpdate(). If newhist
129 is non-zero, then clear the previous sample history.
130
131 **********************************************************************/
