--- ray/src/hd/rhd_odraw.h 2003/02/22 02:07:24 3.7 +++ ray/src/hd/rhd_odraw.h 2003/06/20 00:25:49 3.9 @@ -1,18 +1,14 @@ -/* RCSid: $Id: rhd_odraw.h,v 3.7 2003/02/22 02:07:24 greg Exp $ */ +/* RCSid $Id: rhd_odraw.h,v 3.9 2003/06/20 00:25:49 greg Exp $ */ /* * Header for OpenGL cone drawing routines with depth buffer checks. + * + * Include after "standard.h" */ -#undef NOPROTO -#define NOPROTO 1 #include "color.h" #include "tonemap.h" #include "rhdriver.h" -#ifndef int4 -#define int4 int -#endif - extern struct ODview { int sfirst, snext; /* first sample and first in next view */ short hhi, vhi; /* screen image resolution */ @@ -25,8 +21,8 @@ extern struct ODview { int free; /* index for block free list */ float pthresh; /* proximity threshold */ } *bmap; /* low resolution image map */ - int4 *emap; /* low resolution edge presence map */ - int4 *pmap; /* high resolution presence map */ + int32 *emap; /* low resolution edge presence map */ + int32 *pmap; /* high resolution presence map */ GLfloat *dmap; /* high resolution depth map */ } *odView; /* our view list */ @@ -35,14 +31,14 @@ extern int odNViews; /* number of views in our list */ extern struct ODsamp { union ODfunion { float prox; /* viewpoint proximity */ - int4 next; /* next in free list */ + int32 next; /* next in free list */ } *f; /* free list next or proximity */ short (*ip)[2]; /* image position array */ TMbright *brt; /* encoded brightness array */ BYTE (*chr)[3]; /* encoded chrominance array */ BYTE (*rgb)[3]; /* tone-mapped color array */ - int4 *redraw; /* redraw flags */ + int32 *redraw; /* redraw flags */ int nsamp; /* total number of samples */ char *base; /* base of allocated memory */ } odS; /* sample values */ @@ -54,7 +50,7 @@ extern struct ODsamp { #define CLR4(f,i) FL4OP(f,i,&=~) #define TGL4(f,i) FL4OP(f,i,^=) #define FL4NELS(n) (((n)+0x1f)>>5) -#define CLR4ALL(f,n) bzero((char *)(f),FL4NELS(n)*sizeof(int4)) +#define CLR4ALL(f,n) bzero((char *)(f),FL4NELS(n)*sizeof(int32)) #endif #define OMAXDEPTH 32000 /* maximum depth value */
