root/radiance/ray/src/hd/rhd_odraw.h
Revision: 3.8
Committed: Tue Mar 4 05:49:21 2003 UTC (22 years, 5 months ago) by greg
Changes since 3.7: +1 -3 lines
1 /* RCSid $Id$ */
2 /*
3 * Header for OpenGL cone drawing routines with depth buffer checks.
4 */
5
6 #include "color.h"
7 #include "tonemap.h"
8 #include "rhdriver.h"
9
10 #ifndef int4
11 #define int4 int
12 #endif
13
14 extern struct ODview {
15 int sfirst, snext; /* first sample and first in next view */
16 short hhi, vhi; /* screen image resolution */
17 short hlow, vlow; /* block resolution */
18 int n2redraw; /* approx. number of samples needing redraw */
19 struct ODblock {
20 short nsamp; /* number of samples in block */
21 short nused; /* number actually allocated */
22 int first; /* first sample in this block */
23 int free; /* index for block free list */
24 float pthresh; /* proximity threshold */
25 } *bmap; /* low resolution image map */
26 int4 *emap; /* low resolution edge presence map */
27 int4 *pmap; /* high resolution presence map */
28 GLfloat *dmap; /* high resolution depth map */
29 } *odView; /* our view list */
30
31 extern int odNViews; /* number of views in our list */
32
33 extern struct ODsamp {
34 union ODfunion {
35 float prox; /* viewpoint proximity */
36 int4 next; /* next in free list */
37
38 } *f; /* free list next or proximity */
39 short (*ip)[2]; /* image position array */
40 TMbright *brt; /* encoded brightness array */
41 BYTE (*chr)[3]; /* encoded chrominance array */
42 BYTE (*rgb)[3]; /* tone-mapped color array */
43 int4 *redraw; /* redraw flags */
44 int nsamp; /* total number of samples */
45 char *base; /* base of allocated memory */
46 } odS; /* sample values */
47
48 #ifndef FL4OP
49 #define FL4OP(f,i,op) ((f)[(i)>>5] op (1L<<((i)&0x1f)))
50 #define CHK4(f,i) FL4OP(f,i,&)
51 #define SET4(f,i) FL4OP(f,i,|=)
52 #define CLR4(f,i) FL4OP(f,i,&=~)
53 #define TGL4(f,i) FL4OP(f,i,^=)
54 #define FL4NELS(n) (((n)+0x1f)>>5)
55 #define CLR4ALL(f,n) bzero((char *)(f),FL4NELS(n)*sizeof(int4))
56 #endif
57
58 #define OMAXDEPTH 32000 /* maximum depth value */
59
60 #define nextfree(i) f[i].next /* free pointers */
61 #define closeness(i) f[i].prox /* viewpoint proximity */
62 #define ENDFREE (-1) /* free list terminator */
63
64 #define odClean() odInit(odS.nsamp) /* clear samples */
65 #define odDone() odInit(0) /* free samples */
66
67
68 /*****************************************************************************
69 * Interface routines:
70
71
72 int
73 odInit(nsamps) : allocate and initialize memory
74 int nsamps; : number of samples to make available
75
76 If nsamps is zero, then this becomes a deallocation routine. If nsamps
77 is the same as last time, then this merely clears all data. The dev_auxview()
78 function may be called to determine the current view(s). The odAlloc()
79 function returns the number of samples actually allocated.
80
81
82 void
83 odSample(c, d, p) : register new sample value
84 COLR c; : pixel color (RGBE)
85 FVECT d; : ray direction vector
86 FVECT p; : world intersection point
87
88 If p is NULL, then the point is at infinity.
89
90
91 void
92 odDepthMap(vn, dm) : set depth map for the given view
93 int vn; : view number
94 GLfloat *dm; : depth map
95
96 Assign the depth map associated with view number vn. The map has
97 been preallocated, and won't be freed until it is no longer needed
98 (after an odAlloc() call). All depth values are the projected
99 distance along the view direction from the view origin. If dm
100 is NULL, then there is no depth map associated with this view.
101
102
103 void
104 odRedraw(vn, x0, y0, x1, y1) : region needs to be redrawn
105 int vn; : view number
106 int x0, y0, x1, y1; : rectangle to redraw
107
108 This call indicates that the given rectangular region in view vn
109 needs to be redrawn in the next call to odUpdate().
110
111
112 void
113 odRedrawAll() : everything needs to be redrawn
114
115 Redraw everything in all views on the next call to odUpdate().
116 Unless odRemap() is called, no new tone mapping will be done.
117
118
119 void
120 odUpdate(vn) : update the current view
121 int vn; : view number
122
123 Draw all new and undrawn sample values since last call for this view.
124
125
126 void
127 odRemap(newhist) : recompute tone mapping
128 int newhist; : flag whether to clear history
129
130 Recompute the tone mapping for all the samples in all the views
131 and redraw them on the next call(s) to odUpdate(). If newhist
132 is non-zero, then clear the previous sample history.
133
134 **********************************************************************/
