| 1 |
/* Copyright (c) 1998 Silicon Graphics, Inc. */
| 2 |
| 3 |
/* SCCSid "$SunId$ SGI" */
| 4 |
| 5 |
| 6 |
* Header for OpenGL cone drawing routines with depth buffer checks.
| 7 |
| 8 |
| 9 |
#undef NOPROTO
| 10 |
#define NOPROTO 1
| 11 |
#include "color.h"
| 12 |
#include "tonemap.h"
| 13 |
#include "rhdriver.h"
| 14 |
| 15 |
#ifndef int4
| 16 |
#define int4 int
| 17 |
#endif
| 18 |
| 19 |
extern struct ODview {
| 20 |
int sfirst, snext; /* first sample and first in next view */
| 21 |
short hhi, vhi; /* screen image resolution */
| 22 |
short hlow, vlow; /* block resolution */
| 23 |
int n2redraw; /* approx. number of samples needing redraw */
| 24 |
struct ODblock {
| 25 |
short nsamp; /* number of samples in block */
| 26 |
short nused; /* number actually allocated */
| 27 |
int first; /* first sample in this block */
| 28 |
int free; /* index for block free list */
| 29 |
float pthresh; /* proximity threshold */
| 30 |
} *bmap; /* low resolution image map */
| 31 |
int4 *emap; /* low resolution edge presence map */
| 32 |
int4 *pmap; /* high resolution presence map */
| 33 |
GLfloat *dmap; /* high resolution depth map */
| 34 |
} *odView; /* our view list */
| 35 |
| 36 |
extern int odNViews; /* number of views in our list */
| 37 |
| 38 |
extern struct ODsamp {
| 39 |
union ODfunion {
| 40 |
float prox; /* viewpoint proximity */
| 41 |
int4 next; /* next in free list */
| 42 |
| 43 |
} *f; /* free list next or proximity */
| 44 |
short (*ip)[2]; /* image position array */
| 45 |
TMbright *brt; /* encoded brightness array */
| 46 |
BYTE (*chr)[3]; /* encoded chrominance array */
| 47 |
BYTE (*rgb)[3]; /* tone-mapped color array */
| 48 |
int4 *redraw; /* redraw flags */
| 49 |
int nsamp; /* total number of samples */
| 50 |
char *base; /* base of allocated memory */
| 51 |
} odS; /* sample values */
| 52 |
| 53 |
#ifndef FL4OP
| 54 |
#define FL4OP(f,i,op) ((f)[(i)>>5] op (1L<<((i)&0x1f)))
| 55 |
#define CHK4(f,i) FL4OP(f,i,&)
| 56 |
#define SET4(f,i) FL4OP(f,i,|=)
| 57 |
#define CLR4(f,i) FL4OP(f,i,&=~)
| 58 |
#define TGL4(f,i) FL4OP(f,i,^=)
| 59 |
#define FL4NELS(n) (((n)+0x1f)>>5)
| 60 |
#define CLR4ALL(f,n) bzero((char *)(f),FL4NELS(n)*sizeof(int4))
| 61 |
#endif
| 62 |
| 63 |
#define OMAXDEPTH 32000 /* maximum depth value */
| 64 |
| 65 |
#define nextfree(i) f[i].next /* free pointers */
| 66 |
#define closeness(i) f[i].prox /* viewpoint proximity */
| 67 |
#define ENDFREE (-1) /* free list terminator */
| 68 |
| 69 |
#define odClean() odInit(odS.nsamp) /* clear samples */
| 70 |
#define odDone() odInit(0) /* free samples */
| 71 |
| 72 |
| 73 |
| 74 |
* Interface routines:
| 75 |
| 76 |
| 77 |
int
| 78 |
odInit(nsamps) : allocate and initialize memory
| 79 |
int nsamps; : number of samples to make available
| 80 |
| 81 |
If nsamps is zero, then this becomes a deallocation routine. If nsamps
| 82 |
is the same as last time, then this merely clears all data. The dev_auxview()
| 83 |
function may be called to determine the current view(s). The odAlloc()
| 84 |
function returns the number of samples actually allocated.
| 85 |
| 86 |
| 87 |
void
| 88 |
odSample(c, d, p) : register new sample value
| 89 |
COLR c; : pixel color (RGBE)
| 90 |
FVECT d; : ray direction vector
| 91 |
FVECT p; : world intersection point
| 92 |
| 93 |
If p is NULL, then the point is at infinity.
| 94 |
| 95 |
| 96 |
void
| 97 |
odDepthMap(vn, dm) : set depth map for the given view
| 98 |
int vn; : view number
| 99 |
GLfloat *dm; : depth map
| 100 |
| 101 |
Assign the depth map associated with view number vn. The map has
| 102 |
been preallocated, and won't be freed until it is no longer needed
| 103 |
(after an odAlloc() call). All depth values are the projected
| 104 |
distance along the view direction from the view origin. If dm
| 105 |
is NULL, then there is no depth map associated with this view.
| 106 |
| 107 |
| 108 |
void
| 109 |
odRedraw(vn, x0, y0, x1, y1) : region needs to be redrawn
| 110 |
| 111 |
int x0, y0, x1, y1; : rectangle to redraw
| 112 |
| 113 |
This call indicates that the given rectangular region in view vn
| 114 |
needs to be redrawn in the next call to odUpdate().
| 115 |
| 116 |
| 117 |
void
| 118 |
odRedrawAll() : everything needs to be redrawn
| 119 |
| 120 |
Redraw everything in all views on the next call to odUpdate().
| 121 |
Unless odRemap() is called, no new tone mapping will be done.
| 122 |
| 123 |
| 124 |
void
| 125 |
odUpdate(vn) : update the current view
| 126 |
| 127 |
| 128 |
Draw all new and undrawn sample values since last call for this view.
| 129 |
| 130 |
| 131 |
void
| 132 |
odRemap(newhist) : recompute tone mapping
| 133 |
int newhist; : flag whether to clear history
| 134 |
| 135 |
Recompute the tone mapping for all the samples in all the views
| 136 |
and redraw them on the next call(s) to odUpdate(). If newhist
| 137 |
is non-zero, then clear the previous sample history.
| 138 |
| 139 |
