1 |
/* Copyright (c) 1998 Silicon Graphics, Inc. */ |
2 |
3 |
/* SCCSid "$SunId$ SGI" */ |
4 |
5 |
6 |
* Header for OpenGL cone drawing routines with depth buffer checks. |
7 |
8 |
9 |
#undef NOPROTO |
10 |
#define NOPROTO 1 |
11 |
#include "color.h" |
12 |
#include "tonemap.h" |
13 |
#include "rhdriver.h" |
14 |
15 |
#ifndef int4 |
16 |
#define int4 int |
17 |
#endif |
18 |
19 |
extern struct ODview { |
20 |
int sfirst, snext; /* first sample and first in next view */ |
21 |
short hhi, vhi; /* screen image resolution */ |
22 |
short hlow, vlow; /* block resolution */ |
23 |
struct ODblock { |
24 |
short nsamp; /* number of samples in block */ |
25 |
short nused; /* number actually allocated */ |
26 |
int first; /* first sample in this block */ |
27 |
int free; /* index for block free list */ |
28 |
float pthresh; /* proximity threshold */ |
29 |
} *bmap; /* low resolution image map */ |
30 |
int4 *emap; /* low resolution edge presence map */ |
31 |
int4 *pmap; /* high resolution presence map */ |
32 |
GLfloat *dmap; /* high resolution depth map */ |
33 |
} *odView; /* our view list */ |
34 |
35 |
extern int odNViews; /* number of views in our list */ |
36 |
37 |
extern struct ODsamp { |
38 |
union ODfunion { |
39 |
float prox; /* viewpoint proximity */ |
40 |
int4 next; /* next in free list */ |
41 |
42 |
} *f; /* free list next or proximity */ |
43 |
short (*ip)[2]; /* image position array */ |
44 |
TMbright *brt; /* encoded brightness array */ |
45 |
BYTE (*chr)[3]; /* encoded chrominance array */ |
46 |
BYTE (*rgb)[3]; /* tone-mapped color array */ |
47 |
int4 *redraw; /* redraw flags */ |
48 |
int nsamp; /* total number of samples */ |
49 |
char *base; /* base of allocated memory */ |
50 |
} odS; /* sample values */ |
51 |
52 |
#ifndef FL4OP |
53 |
#define FL4OP(f,i,op) ((f)[(i)>>5] op (1L<<((i)&0x1f))) |
54 |
#define CHK4(f,i) FL4OP(f,i,&) |
55 |
#define SET4(f,i) FL4OP(f,i,|=) |
56 |
#define CLR4(f,i) FL4OP(f,i,&=~) |
57 |
#define TGL4(f,i) FL4OP(f,i,^=) |
58 |
#define FL4NELS(n) (((n)+0x1f)>>5) |
59 |
#define CLR4ALL(f,n) bzero((char *)(f),FL4NELS(n)*sizeof(int4)) |
60 |
#endif |
61 |
62 |
#define OMAXDEPTH 32000 /* maximum depth value */ |
63 |
64 |
#define nextfree(i) f[i].next /* free pointers */ |
65 |
#define closeness(i) f[i].prox /* viewpoint proximity */ |
66 |
#define ENDFREE (-1) /* free list terminator */ |
67 |
68 |
#define odClean() odInit(odS.nsamp) /* clear samples */ |
69 |
#define odDone() odInit(0) /* free samples */ |
70 |
71 |
72 |
73 |
* Interface routines: |
74 |
75 |
76 |
int |
77 |
odInit(nsamps) : allocate and initialize memory |
78 |
int nsamps; : number of samples to make available |
79 |
80 |
If nsamps is zero, then this becomes a deallocation routine. If nsamps |
81 |
is the same as last time, then this merely clears all data. The dev_auxview() |
82 |
function may be called to determine the current view(s). The odAlloc() |
83 |
function returns the number of samples actually allocated. |
84 |
85 |
86 |
void |
87 |
odSample(c, d, p) : register new sample value |
88 |
COLR c; : pixel color (RGBE) |
89 |
FVECT d; : ray direction vector |
90 |
FVECT p; : world intersection point |
91 |
92 |
If p is NULL, then the point is at infinity. |
93 |
94 |
95 |
void |
96 |
odDepthMap(vn, dm) : set depth map for the given view |
97 |
int vn; : view number |
98 |
GLfloat *dm; : depth map |
99 |
100 |
Assign the depth map associated with view number vn. The map has |
101 |
been preallocated, and won't be freed until it is no longer needed |
102 |
(after an odAlloc() call). All depth values are the projected |
103 |
distance along the view direction from the view origin. If dm |
104 |
is NULL, then there is no depth map associated with this view. |
105 |
106 |
107 |
void |
108 |
odRedraw(vn, x0, y0, x1, y1) : region needs to be redrawn |
109 |
110 |
int x0, y0, x1, y1; : rectangle to redraw |
111 |
112 |
This call indicates that the given rectangular region in view vn |
113 |
needs to be redrawn in the next call to odUpdate(). |
114 |
115 |
116 |
void |
117 |
odRedrawAll() : everything needs to be redrawn |
118 |
119 |
Redraw everything in all views on the next call to odUpdate(). |
120 |
Unless odRemap() is called, no new tone mapping will be done. |
121 |
122 |
123 |
void |
124 |
odUpdate(vn) : update the current view |
125 |
126 |
127 |
Draw all new and undrawn sample values since last call for this view. |
128 |
129 |
130 |
void |
131 |
odRemap(newhist) : recompute tone mapping |
132 |
int newhist; : flag whether to clear history |
133 |
134 |
Recompute the tone mapping for all the samples in all the views |
135 |
and redraw them on the next call(s) to odUpdate(). If newhist |
136 |
is non-zero, then clear the previous sample history. |
137 |
138 |
