root/radiance/ray/src/hd/rhd_odraw.h
Revision: 3.1
Committed: Fri Dec 18 11:55:19 1998 UTC (25 years, 6 months ago) by gwlarson
1 /* Copyright (c) 1998 Silicon Graphics, Inc. */
2
3 /* SCCSid "$SunId$ SGI" */
4
5 /*
6 * Header for OpenGL cone drawing routines with depth buffer checks.
7 */
8
9 #undef NOPROTO
10 #define NOPROTO 1
11 #include "color.h"
12 #include "tonemap.h"
13 #include "rhdriver.h"
14
15 #ifndef int4
16 #define int4 int
17 #endif
18
19 extern struct ODview {
20 short hhi, vhi; /* screen image resolution */
21 short hlow, vlow; /* block resolution */
22 struct ODblock {
23 short nsamp; /* number of samples in block */
24 short nused; /* number actually allocated */
25 int first; /* first sample in this block */
26 int free; /* index for block free list */
27 } *bmap; /* low resolution image map */
28 int4 *emap; /* low resolution edge presence map */
29 GLfloat *dmap; /* high resolution depth map */
30 } *odView; /* our view list */
31
32 extern int odNViews; /* number of views in our list */
33
34 extern struct ODsamp {
35 union ODfunion {
36 float prox; /* viewpoint proximity */
37 int4 next; /* next in free list */
38
39 } *f; /* free list next or proximity */
40 short (*ip)[2]; /* image position array */
41 TMbright *brt; /* encoded brightness array */
42 BYTE (*chr)[3]; /* encoded chrominance array */
43 BYTE (*rgb)[3]; /* tone-mapped color array */
44 int4 *redraw; /* redraw flags */
45 int nsamp; /* total number of samples */
46 char *base; /* base of allocated memory */
47 } odS; /* sample values */
48
49 #ifndef FL4OP
50 #define FL4OP(f,i,op) ((f)[(i)>>5] op (1L<<((i)&0x1f)))
51 #define CHK4(f,i) FL4OP(f,i,&)
52 #define SET4(f,i) FL4OP(f,i,|=)
53 #define CLR4(f,i) FL4OP(f,i,&=~)
54 #define TGL4(f,i) FL4OP(f,i,^=)
55 #define FL4NELS(n) (((n)+0x1f)>>5)
56 #define CLR4ALL(f,n) bzero((char *)(f),FL4NELS(n)*sizeof(int4))
57 #endif
58
59 #define OMAXDEPTH 32000 /* maximum depth value */
60
61 #define nextfree(i) f[i].next /* free pointers */
62 #define closeness(i) f[i].prox /* viewpoint proximity */
63 #define ENDFREE (-1) /* free list terminator */
64
65 #define odClean() odInit(odS.nsamp) /* clear samples */
66 #define odDone() odInit(0) /* free samples */
67
68
69 /*****************************************************************************
70 * Interface routines:
71
72
73 int
74 odInit(nsamps) : allocate and initialize memory
75 int nsamps; : number of samples to make available
76
77 If nsamps is zero, then this becomes a deallocation routine. If nsamps
78 is the same as last time, then this merely clears all data. The dev_auxview()
79 function may be called to determine the current view(s). The odAlloc()
80 function returns the number of samples actually allocated.
81
82
83 void
84 odSample(c, d, p) : register new sample value
85 COLR c; : pixel color (RGBE)
86 FVECT d; : ray direction vector
87 FVECT p; : world intersection point
88
89 If p is NULL, then the point is at infinity.
90
91
92 void
93 odDepthMap(vn, dm) : set depth map for the given view
94 int vn; : view number
95 GLfloat *dm; : depth map
96
97 Assign the depth map associated with view number vn. The map has
98 been preallocated, and won't be freed until it is no longer needed
99 (after an odAlloc() call). All depth values are the projected
100 distance along the view direction from the view origin. If dm
101 is NULL, then there is no depth map associated with this view.
102
103
104 void
105 odRedraw(vn, x0, y0, x1, y1) : region needs to be redrawn
106 int vn; : view number
107 int x0, y0, x1, y1; : rectangle to redraw
108
109 This call indicates that the given rectangular region in view vn
110 needs to be redrawn in the next call to odUpdate().
111
112
113 void
114 odUpdate(vn) : update the current view
115 int vn; : view number
116
117 Draw all new and undrawn sample values since last call for this view.
118
119
120 void
121 odRemap() : recompute tone mapping
122
123 Recompute the tone mapping for all the samples in all the views
124 and redraw them on the next call(s) to odUpdate().
125
126 **********************************************************************/
