--- ray/src/hd/rhd_odraw.h 1998/12/18 11:55:19 3.1 +++ ray/src/hd/rhd_odraw.h 2003/06/20 00:25:49 3.9 @@ -1,31 +1,28 @@ -/* Copyright (c) 1998 Silicon Graphics, Inc. */ - -/* SCCSid "$SunId$ SGI" */ - +/* RCSid $Id: rhd_odraw.h,v 3.9 2003/06/20 00:25:49 greg Exp $ */ /* * Header for OpenGL cone drawing routines with depth buffer checks. + * + * Include after "standard.h" */ -#undef NOPROTO -#define NOPROTO 1 #include "color.h" #include "tonemap.h" #include "rhdriver.h" -#ifndef int4 -#define int4 int -#endif - extern struct ODview { + int sfirst, snext; /* first sample and first in next view */ short hhi, vhi; /* screen image resolution */ short hlow, vlow; /* block resolution */ + int n2redraw; /* approx. number of samples needing redraw */ struct ODblock { short nsamp; /* number of samples in block */ short nused; /* number actually allocated */ int first; /* first sample in this block */ int free; /* index for block free list */ + float pthresh; /* proximity threshold */ } *bmap; /* low resolution image map */ - int4 *emap; /* low resolution edge presence map */ + int32 *emap; /* low resolution edge presence map */ + int32 *pmap; /* high resolution presence map */ GLfloat *dmap; /* high resolution depth map */ } *odView; /* our view list */ @@ -34,14 +31,14 @@ extern int odNViews; /* number of views in our list */ extern struct ODsamp { union ODfunion { float prox; /* viewpoint proximity */ - int4 next; /* next in free list */ + int32 next; /* next in free list */ } *f; /* free list next or proximity */ short (*ip)[2]; /* image position array */ TMbright *brt; /* encoded brightness array */ BYTE (*chr)[3]; /* encoded chrominance array */ BYTE (*rgb)[3]; /* tone-mapped color array */ - int4 *redraw; /* redraw flags */ + int32 *redraw; /* redraw flags */ int nsamp; /* total number of samples */ char *base; /* base of allocated memory */ } odS; /* sample values */ @@ -53,7 +50,7 @@ extern struct ODsamp { #define CLR4(f,i) FL4OP(f,i,&=~) #define TGL4(f,i) FL4OP(f,i,^=) #define FL4NELS(n) (((n)+0x1f)>>5) -#define CLR4ALL(f,n) bzero((char *)(f),FL4NELS(n)*sizeof(int4)) +#define CLR4ALL(f,n) bzero((char *)(f),FL4NELS(n)*sizeof(int32)) #endif #define OMAXDEPTH 32000 /* maximum depth value */ @@ -111,6 +108,13 @@ needs to be redrawn in the next call to odUpdate(). void +odRedrawAll() : everything needs to be redrawn + +Redraw everything in all views on the next call to odUpdate(). +Unless odRemap() is called, no new tone mapping will be done. + + +void odUpdate(vn) : update the current view int vn; : view number @@ -118,9 +122,11 @@ Draw all new and undrawn sample values since last call void -odRemap() : recompute tone mapping +odRemap(newhist) : recompute tone mapping +int newhist; : flag whether to clear history Recompute the tone mapping for all the samples in all the views -and redraw them on the next call(s) to odUpdate(). +and redraw them on the next call(s) to odUpdate(). If newhist +is non-zero, then clear the previous sample history. **********************************************************************/
