1 |
#ifndef lint |
2 |
static const char RCSid[] = "$Id$"; |
3 |
#endif |
4 |
5 |
* Routines for drawing samples using depth buffer checks. |
6 |
7 |
8 |
#include "standard.h" |
9 |
10 |
#include <GL/glx.h> |
11 |
#include <GL/glu.h> |
12 |
13 |
#include "rhd_odraw.h" |
14 |
15 |
#ifndef DEPTHEPS |
16 |
#define DEPTHEPS 0.02 /* depth epsilon */ |
17 |
#endif |
18 |
#ifndef SAMPSPERBLOCK |
19 |
#define SAMPSPERBLOCK 1024 /* target samples per image block */ |
20 |
#endif |
21 |
#ifndef SFREEFRAC |
22 |
#define SFREEFRAC 0.2 /* fraction to free at a time */ |
23 |
#endif |
24 |
#ifndef REDRAWTHRESH |
25 |
#define REDRAWTHRESH 10240 /* number of samples for dissolve */ |
26 |
#endif |
27 |
#ifndef MAXFAN |
28 |
#define MAXFAN 32 /* maximum arms in a triangle fan */ |
29 |
#endif |
30 |
#ifndef MINFAN |
31 |
#define MINFAN 4 /* minimum arms in a triangle fan */ |
32 |
#endif |
33 |
#ifndef FANSIZE |
34 |
#define FANSIZE 3.5 /* fan sizing factor */ |
35 |
#endif |
36 |
37 |
#define NEWMAP 01 /* need to recompute mapping */ |
38 |
#define NEWRGB 02 /* need to remap RGB values */ |
39 |
#define NEWHIST 04 /* clear histogram as well */ |
40 |
41 |
struct ODview *odView; /* our view list */ |
42 |
int odNViews; /* number of views in our list */ |
43 |
44 |
struct ODsamp odS; /* sample values */ |
45 |
46 |
static int needmapping; /* what needs doing with tone map */ |
47 |
48 |
49 |
#define SAMP32 (32*(2*sizeof(short)+sizeof(union ODfunion)+sizeof(TMbright)+\ |
50 |
6*sizeof(BYTE))+sizeof(int4)) |
51 |
52 |
int |
53 |
odInit(n) /* initialize drawing routines */ |
54 |
int n; |
55 |
56 |
int nbytes, i, j, k, nextsamp, count, blockdiv; |
57 |
int res[2]; |
58 |
59 |
if (odNViews > 0) { /* deallocate view structures */ |
60 |
for (i = odNViews; i--; ) { |
61 |
free((void *)odView[i].bmap); |
62 |
free((void *)odView[i].pmap); |
63 |
if (odView[i].emap != NULL) |
64 |
free((void *)odView[i].emap); |
65 |
66 |
free((void *)odView); |
67 |
odView = NULL; |
68 |
odNViews = 0; |
69 |
70 |
if (n && n != odS.nsamp) { |
71 |
/* round space up to nearest power of 2 */ |
72 |
nbytes = (n+31)/32 * SAMP32; |
73 |
for (i = 1024; nbytes > i-8; i <<= 1) |
74 |
75 |
n = (i-8)/SAMP32 * 32; |
76 |
needmapping = NEWHIST; |
77 |
78 |
if (n != odS.nsamp) { /* (re)allocate sample array */ |
79 |
if (odS.nsamp) |
80 |
free(odS.base); |
81 |
odS.nsamp = 0; |
82 |
if (!n) |
83 |
return(0); |
84 |
85 |
odS.base = (char *)malloc(nbytes); |
86 |
if (odS.base == NULL) |
87 |
return(0); |
88 |
/* assign larger alignment types earlier */ |
89 |
odS.f = (union ODfunion *)odS.base; |
90 |
odS.redraw = (int4 *)(odS.f + n); |
91 |
odS.ip = (short (*)[2])(odS.redraw + n/32); |
92 |
odS.brt = (TMbright *)(odS.ip + n); |
93 |
odS.chr = (BYTE (*)[3])(odS.brt + n); |
94 |
odS.rgb = (BYTE (*)[3])(odS.chr + n); |
95 |
odS.nsamp = n; |
96 |
97 |
if (!n) |
98 |
return(0); |
99 |
/* allocate view information */ |
100 |
count = 0; /* count pixels */ |
101 |
for (i = 0; dev_auxview(i, res) != NULL; i++) |
102 |
count += res[0]*res[1]; |
103 |
odView = (struct ODview *)malloc(i*sizeof(struct ODview)); |
104 |
if (odView == NULL) |
105 |
return(0); |
106 |
odNViews = i; |
107 |
blockdiv = sqrt(count/(n/SAMPSPERBLOCK)) + 0.5; |
108 |
if (blockdiv < 8) blockdiv = 8; |
109 |
nextsamp = 0; count /= blockdiv*blockdiv; /* # blocks */ |
110 |
while (i--) { /* initialize each view */ |
111 |
dev_auxview(i, res); |
112 |
odView[i].hhi = res[0]; |
113 |
odView[i].hlow = (res[0] + blockdiv/2) / blockdiv; |
114 |
if (odView[i].hlow < 1) odView[i].hlow = 1; |
115 |
odView[i].vhi = res[1]; |
116 |
odView[i].vlow = (res[1] + blockdiv/2) / blockdiv; |
117 |
if (odView[i].vlow < 1) odView[i].vlow = 1; |
118 |
odView[i].emap = NULL; |
119 |
odView[i].dmap = NULL; |
120 |
odView[i].pmap = (int4 *)calloc(FL4NELS(res[0]*res[1]), |
121 |
sizeof(int4)); |
122 |
if (odView[i].pmap == NULL) |
123 |
return(0); |
124 |
j = odView[i].hlow*odView[i].vlow; |
125 |
odView[i].bmap = (struct ODblock *)malloc( |
126 |
j * sizeof(struct ODblock)); |
127 |
if (odView[i].bmap == NULL) |
128 |
return(0); |
129 |
DCHECK(count<=0 | nextsamp>=n, |
130 |
CONSISTENCY, "counter botch in odInit"); |
131 |
if (!i) count = j; |
132 |
odView[i].sfirst = nextsamp; |
133 |
while (j--) { /* initialize blocks & free lists */ |
134 |
odView[i].bmap[j].pthresh = FHUGE; |
135 |
odView[i].bmap[j].first = k = nextsamp; |
136 |
nextsamp += odView[i].bmap[j].nsamp = |
137 |
(n - nextsamp)/count--; |
138 |
odView[i].bmap[j].free = k; |
139 |
while (++k < nextsamp) |
140 |
odS.nextfree(k-1) = k; |
141 |
odS.nextfree(k-1) = ENDFREE; |
142 |
odView[i].bmap[j].nused = 0; |
143 |
144 |
odView[i].snext = nextsamp; |
145 |
odView[i].n2redraw = 0; |
146 |
147 |
CLR4ALL(odS.redraw, odS.nsamp); /* clear redraw flags */ |
148 |
for (i = odS.nsamp; i--; ) { /* clear values */ |
149 |
odS.ip[i][0] = odS.ip[i][1] = -1; |
150 |
odS.brt[i] = TM_NOBRT; |
151 |
152 |
needmapping |= NEWMAP; /* compute new map on update */ |
153 |
return(odS.nsamp); /* return number of samples */ |
154 |
155 |
156 |
#undef SAMP32 |
157 |
158 |
159 |
int |
160 |
sampcmp(s0, s1) /* sample order, descending proximity */ |
161 |
int *s0, *s1; |
162 |
163 |
register double diff = odS.closeness(*s1) - odS.closeness(*s0); |
164 |
165 |
return (diff > FTINY ? 1 : diff < -FTINY ? -1 : 0); |
166 |
167 |
168 |
169 |
int |
170 |
odAllocBlockSamp(vn, hh, vh, prox) /* allocate sample from block */ |
171 |
int vn, hh, vh; |
172 |
double prox; |
173 |
174 |
int si[SAMPSPERBLOCK+SAMPSPERBLOCK/4]; |
175 |
int hl, vl; |
176 |
VIEW *vw; |
177 |
FVECT ro, rd; |
178 |
int res[2]; |
179 |
register struct ODblock *bp; |
180 |
register int i, j; |
181 |
/* get block */ |
182 |
hl = hh*odView[vn].hlow/odView[vn].hhi; |
183 |
vl = vh*odView[vn].vlow/odView[vn].vhi; |
184 |
bp = odView[vn].bmap + vl*odView[vn].hlow + hl; |
185 |
if (prox > bp->pthresh) |
186 |
return(-1); /* worse than free list occupants */ |
187 |
/* check for duplicate pixel */ |
188 |
if (CHK4(odView[vn].pmap, vh*odView[vn].hhi + hh)) |
189 |
i = bp->first + bp->nsamp; |
190 |
else |
191 |
i = 0; |
192 |
while (i-- > bp->first) |
193 |
if (hh == odS.ip[i][0] && vh == odS.ip[i][1]) { /* found it! */ |
194 |
/* search free list for it */ |
195 |
if (i == bp->free) |
196 |
break; /* special case */ |
197 |
if (bp->free != ENDFREE) |
198 |
for (j = bp->free; odS.nextfree(j) != ENDFREE; |
199 |
j = odS.nextfree(j)) |
200 |
if (odS.nextfree(j) == i) { |
201 |
odS.nextfree(j) = |
202 |
odS.nextfree(i); |
203 |
bp->nused++; |
204 |
goto gotit; |
205 |
206 |
if (prox >= 0.99*odS.closeness(i)) |
207 |
return(-1); /* previous sample is fine */ |
208 |
goto gotit; |
209 |
210 |
if (bp->free != ENDFREE) { /* allocate from free list */ |
211 |
i = bp->free; |
212 |
if (odS.ip[i][0] >= 0 & odS.ip[i][1] >= 0) |
213 |
CLR4(odView[vn].pmap, odS.ip[i][1]*odView[vn].hhi + |
214 |
odS.ip[i][0]); |
215 |
bp->free = odS.nextfree(i); |
216 |
bp->nused++; |
217 |
goto gotit; |
218 |
219 |
DCHECK(bp->nsamp<=0, CONSISTENCY, |
220 |
"no available samples in odAllocBlockSamp"); |
221 |
DCHECK(bp->nsamp > sizeof(si)/sizeof(si[0]), CONSISTENCY, |
222 |
"too many samples in odAllocBlockSamp"); |
223 |
/* free some samples */ |
224 |
if ((vw = dev_auxview(vn, res)) == NULL) |
225 |
error(CONSISTENCY, "bad view number in odAllocBlockSamp"); |
226 |
for (i = bp->nsamp; i--; ) /* figure out which are worse */ |
227 |
si[i] = bp->first + i; |
228 |
qsort((char *)si, bp->nsamp, sizeof(int), sampcmp); |
229 |
i = bp->nsamp*SFREEFRAC + .5; /* put them into free list */ |
230 |
if (i >= bp->nsamp) i = bp->nsamp-1; /* paranoia */ |
231 |
bp->pthresh = odS.closeness(si[i]); /* new proximity threshold */ |
232 |
while (--i > 0) { |
233 |
odS.nextfree(si[i]) = bp->free; |
234 |
bp->free = si[i]; |
235 |
bp->nused--; |
236 |
237 |
i = si[0]; /* use worst sample */ |
238 |
CLR4(odView[vn].pmap, odS.ip[i][1]*odView[vn].hhi + odS.ip[i][0]); |
239 |
gotit: |
240 |
odS.ip[i][0] = hh; |
241 |
odS.ip[i][1] = vh; |
242 |
odS.closeness(i) = prox; |
243 |
SET4(odView[vn].pmap, vh*odView[vn].hhi + hh); |
244 |
return(i); |
245 |
246 |
247 |
248 |
odSample(c, d, p) /* add a sample value */ |
249 |
COLR c; |
250 |
FVECT d, p; |
251 |
252 |
FVECT disp; |
253 |
double d0, d1, h, v, prox; |
254 |
register VIEW *vw; |
255 |
int hh, vh; |
256 |
int res[2]; |
257 |
register int i, id; |
258 |
259 |
DCHECK(odS.nsamp<=0, CONSISTENCY, "no samples allocated in odSample"); |
260 |
/* add value to each view */ |
261 |
for (i = 0; (vw = dev_auxview(i, res)) != NULL; i++) { |
262 |
DCHECK(i>=odNViews, CONSISTENCY, "too many views in odSample"); |
263 |
CHECK(vw->type!=VT_PER, INTERNAL, |
264 |
"cannot handle non-perspective views"); |
265 |
if (p != NULL) { /* compute view position */ |
266 |
VSUB(disp, p, vw->vp); |
267 |
d0 = DOT(disp, vw->vdir); |
268 |
if (d0 <= vw->vfore+FTINY) |
269 |
continue; /* too close */ |
270 |
} else { |
271 |
VCOPY(disp, d); |
272 |
273 |
if (d0 <= FTINY) /* behind view */ |
274 |
continue; |
275 |
276 |
h = DOT(disp,vw->hvec)/(d0*vw->hn2) + 0.5 - vw->hoff; |
277 |
if (h < 0. || h >= 1.) |
278 |
continue; /* left or right */ |
279 |
v = DOT(disp,vw->vvec)/(d0*vw->vn2) + 0.5 - vw->voff; |
280 |
if (v < 0. || v >= 1.) |
281 |
continue; /* above or below */ |
282 |
hh = h * res[0]; |
283 |
vh = v * res[1]; |
284 |
if (odView[i].dmap != NULL) { /* check depth */ |
285 |
d1 = odView[i].dmap[vh*res[0] + hh]; |
286 |
if (d1 < 0.99*FHUGE && (d0 > (1.+DEPTHEPS)*d1 || |
287 |
(1.+DEPTHEPS)*d0 < d1)) |
288 |
continue; /* occlusion error */ |
289 |
290 |
if (p != NULL) { /* compute closeness (sin^2) */ |
291 |
d1 = DOT(disp, d); |
292 |
prox = 1. - d1*d1/DOT(disp,disp); |
293 |
} else |
294 |
prox = 0.; |
295 |
/* allocate sample */ |
296 |
id = odAllocBlockSamp(i, hh, vh, prox); |
297 |
if (id < 0) |
298 |
continue; /* not good enough */ |
299 |
/* convert color */ |
300 |
tmCvColrs(&odS.brt[id], odS.chr[id], (COLR *)c, 1); |
301 |
if (imm_mode | needmapping) /* if immediate mode */ |
302 |
needmapping |= NEWRGB; /* map it later */ |
303 |
else /* else map it now */ |
304 |
tmMapPixels(odS.rgb[id], &odS.brt[id], odS.chr[id], 1); |
305 |
SET4(odS.redraw, id); /* mark for redraw */ |
306 |
odView[i].n2redraw++; |
307 |
308 |
309 |
310 |
311 |
odRemap(newhist) /* recompute tone mapping */ |
312 |
int newhist; |
313 |
314 |
needmapping |= NEWMAP|NEWRGB; |
315 |
if (newhist) |
316 |
needmapping |= NEWHIST; |
317 |
318 |
319 |
320 |
odRedrawAll() /* mark all samples for redraw */ |
321 |
322 |
register int i; |
323 |
324 |
if ((needmapping&(NEWMAP|NEWRGB)) == (NEWMAP|NEWRGB)) |
325 |
return; /* will be called later, anyway */ |
326 |
for (i = odS.nsamp; i--; ) |
327 |
if (odS.ip[i][0] >= 0) |
328 |
SET4(odS.redraw, i); |
329 |
/* not right, but not important */ |
330 |
for (i = 0; i < odNViews; i++) |
331 |
odView[i].n2redraw = odView[i].snext - odView[i].sfirst; |
332 |
333 |
334 |
335 |
odRedraw(vn, hmin, vmin, hmax, vmax) /* redraw view region */ |
336 |
int vn, hmin, vmin, hmax, vmax; |
337 |
338 |
int i, j; |
339 |
340 |
register int k; |
341 |
342 |
if (vn<0 | vn>=odNViews) |
343 |
return; |
344 |
/* check view limits */ |
345 |
if (hmin < 0) hmin = 0; |
346 |
if (hmax >= odView[vn].hhi) hmax = odView[vn].hhi-1; |
347 |
if (vmin < 0) vmin = 0; |
348 |
if (vmax >= odView[vn].vhi) vmax = odView[vn].vhi-1; |
349 |
if (hmax <= hmin | vmax <= vmin) |
350 |
return; |
351 |
/* convert to low resolution */ |
352 |
hmin = hmin * odView[vn].hlow / odView[vn].hhi; |
353 |
hmax = hmax * odView[vn].hlow / odView[vn].hhi; |
354 |
vmin = vmin * odView[vn].vlow / odView[vn].vhi; |
355 |
vmax = vmax * odView[vn].vlow / odView[vn].vhi; |
356 |
/* mark block samples for redraw, inclusive */ |
357 |
for (i = hmin; i <= hmax; i++) |
358 |
for (j = vmin; j <= vmax; j++) { |
359 |
bp = odView[vn].bmap + j*odView[vn].hlow + i; |
360 |
for (k = bp->nsamp; k--; ) |
361 |
if (odS.ip[bp->first+k][0] >= 0) { |
362 |
SET4(odS.redraw, bp->first+k); |
363 |
odView[vn].n2redraw++; |
364 |
365 |
366 |
367 |
368 |
369 |
odDepthMap(vn, dm) /* assign depth map for view */ |
370 |
int vn; |
371 |
GLfloat *dm; |
372 |
373 |
double d0, d1; |
374 |
int i, j, hmin, hmax, vmin, vmax; |
375 |
register int k, l; |
376 |
377 |
if (dm == NULL) { /* free edge map */ |
378 |
379 |
return; /* too late -- they're gone! */ |
380 |
if (odView[vn].emap != NULL) |
381 |
free((void *)odView[vn].emap); |
382 |
odView[vn].emap = NULL; |
383 |
odView[vn].dmap = NULL; |
384 |
return; |
385 |
386 |
DCHECK(vn<0 | vn>=odNViews, CONSISTENCY, |
387 |
"bad view number in odDepthMap"); |
388 |
odView[vn].dmap = dm; /* initialize edge map */ |
389 |
if (odView[vn].emap == NULL) { |
390 |
odView[vn].emap = (int4 *)malloc( |
391 |
FL4NELS(odView[vn].hlow*odView[vn].vlow)*sizeof(int4)); |
392 |
if (odView[vn].emap == NULL) |
393 |
error(SYSTEM, "out of memory in odDepthMap"); |
394 |
395 |
CLR4ALL(odView[vn].emap, odView[vn].hlow*odView[vn].vlow); |
396 |
/* compute edge map */ |
397 |
vmin = odView[vn].vhi; /* enter loopsville */ |
398 |
for (j = odView[vn].vlow; j--; ) { |
399 |
vmax = vmin; |
400 |
vmin = j*odView[vn].vhi/odView[vn].vlow; |
401 |
hmin = odView[vn].hhi; |
402 |
for (i = odView[vn].hlow; i--; ) { |
403 |
hmax = hmin; |
404 |
hmin = i*odView[vn].hhi/odView[vn].hlow; |
405 |
for (l = vmin; l < vmax; l++) { /* vertical edges */ |
406 |
d1 = dm[l*odView[vn].hhi+hmin]; |
407 |
for (k = hmin+1; k < hmax; k++) { |
408 |
d0 = d1; |
409 |
d1 = dm[l*odView[vn].hhi+k]; |
410 |
if (d0 > (1.+DEPTHEPS)*d1 || |
411 |
(1.+DEPTHEPS)*d0 < d1) { |
412 |
SET4(odView[vn].emap, |
413 |
j*odView[vn].hlow + i); |
414 |
break; |
415 |
416 |
417 |
if (k < hmax) |
418 |
break; |
419 |
420 |
if (l < vmax) |
421 |
continue; |
422 |
for (k = hmin; k < hmax; k++) { /* horizontal edges */ |
423 |
d1 = dm[vmin*odView[vn].hhi+k]; |
424 |
for (l = vmin+1; l < vmax; l++) { |
425 |
d0 = d1; |
426 |
427 |
428 |
429 |
430 |
431 |
break; |
432 |
433 |
434 |
if (l < vmax) |
435 |
break; |
436 |
437 |
438 |
439 |
440 |
441 |
442 |
odUpdate(vn) /* update this view */ |
443 |
int vn; |
444 |
445 |
static short primes[] = {9431,6803,4177,2659,1609,887,587,251,47,1}; |
446 |
int myprime; |
447 |
register int i, n; |
448 |
449 |
450 |
"bad view number in odUpdate"); |
451 |
/* need to do some tone mapping? */ |
452 |
if (needmapping & NEWRGB) { |
453 |
if (needmapping & NEWMAP) { |
454 |
if (needmapping & NEWHIST) |
455 |
tmClearHisto(); |
456 |
needmapping &= ~NEWHIST; |
457 |
if (tmAddHisto(odS.brt,odS.nsamp,1) != TM_E_OK) |
458 |
return; |
459 |
if (tmComputeMapping(0.,0.,0.) != TM_E_OK) |
460 |
return; |
461 |
needmapping &= ~NEWMAP; |
462 |
odRedrawAll(); /* redraw everything */ |
463 |
464 |
if (tmMapPixels((BYTE *)(odS.rgb), odS.brt, |
465 |
(BYTE *)(odS.chr), odS.nsamp) != TM_E_OK) |
466 |
return; |
467 |
needmapping &= ~NEWRGB; |
468 |
469 |
if (odView[vn].n2redraw <= 0) |
470 |
return; |
471 |
#if REDRAWTHRESH |
472 |
if (odView[vn].n2redraw < REDRAWTHRESH) |
473 |
goto quickdraw; |
474 |
/* pick a good prime step size */ |
475 |
n = odView[vn].snext - odView[vn].sfirst; |
476 |
for (i = 0; primes[i]<<5 >= n; i++) |
477 |
478 |
while ((myprime = primes[i++]) > 1) |
479 |
if (n % myprime) |
480 |
break; |
481 |
/* dissolve in new samples */ |
482 |
for (i = odView[vn].sfirst; n-- > 0; i += myprime) { |
483 |
if (i >= odView[vn].snext) |
484 |
i -= odView[vn].snext - odView[vn].sfirst; |
485 |
if (CHK4(odS.redraw, i)) { |
486 |
odDrawSamp(vn, i); |
487 |
CLR4(odS.redraw, i); |
488 |
489 |
490 |
odView[vn].n2redraw = 0; |
491 |
return; |
492 |
quickdraw: /* quicker sparse flag checking */ |
493 |
#endif |
494 |
/* redraw samples at end */ |
495 |
for (i = odView[vn].snext-31; i < odView[vn].snext; i++) |
496 |
497 |
498 |
499 |
500 |
/* faster flag checks in middle */ |
501 |
for (n = odView[vn].snext>>5; n-- > (odView[vn].sfirst+0x1f)>>5; ) |
502 |
for (i = 0; odS.redraw[n]; i++) /* skips faster */ |
503 |
if (odS.redraw[n] & 1L<<i) { |
504 |
odDrawSamp(vn, (n<<5)+i); |
505 |
odS.redraw[n] &= ~(1L<<i); |
506 |
507 |
/* redraw samples at beginning */ |
508 |
for (i = odView[vn].sfirst; i < odView[vn].sfirst+31; i++) |
509 |
510 |
511 |
512 |
513 |
514 |
515 |
516 |
517 |
/* this turned out to be unnecessary */ |
518 |
#if 0 |
519 |
static |
520 |
clip_end(p, o, vp) /* clip line segment to view */ |
521 |
GLshort p[3]; |
522 |
short o[2]; |
523 |
register struct ODview *vp; |
524 |
525 |
if (p[0] < 0) { |
526 |
p[1] = -o[0]*(p[1]-o[1])/(p[0]-o[0]) + o[1]; |
527 |
p[2] = -o[0]*p[2]/(p[0]-o[0]); |
528 |
p[0] = 0; |
529 |
} else if (p[0] >= vp->hhi) { |
530 |
p[1] = (vp->hhi-1-o[0])*(p[1]-o[1])/(p[0]-o[0]) + o[1]; |
531 |
p[2] = (vp->hhi-1-o[0])*p[2]/(p[0]-o[0]); |
532 |
p[0] = vp->hhi-1; |
533 |
534 |
if (p[1] < 0) { |
535 |
p[0] = -o[1]*(p[0]-o[0])/(p[1]-o[1]) + o[0]; |
536 |
p[2] = -o[1]*p[2]/(p[1]-o[1]); |
537 |
p[1] = 0; |
538 |
} else if (p[1] >= vp->vhi) { |
539 |
p[0] = (vp->vhi-1-o[1])*(p[0]-o[0])/(p[1]-o[1]) + o[0]; |
540 |
p[2] = (vp->vhi-1-o[1])*p[2]/(p[1]-o[1]); |
541 |
p[1] = vp->vhi-1; |
542 |
543 |
544 |
#endif |
545 |
546 |
547 |
static int |
548 |
make_arms(ar, cp, vp, sz) /* make arms for triangle fan */ |
549 |
GLshort ar[MAXFAN][3]; |
550 |
short cp[2]; |
551 |
552 |
double sz; |
553 |
554 |
int na, dv; |
555 |
double hrad, vrad, phi; |
556 |
register int i; |
557 |
558 |
DCHECK(sz > 1, CONSISTENCY, "super-unary size in make_arms"); |
559 |
na = MAXFAN*sz + 0.5; /* keep arc length constant */ |
560 |
if (na < MINFAN) na = MINFAN; |
561 |
hrad = FANSIZE*sz*vp->hhi/vp->hlow; |
562 |
vrad = FANSIZE*sz*vp->vhi/vp->vlow; |
563 |
if (hrad*vrad < 2.25) |
564 |
hrad = vrad = 1.5; |
565 |
dv = OMAXDEPTH*sz + 0.5; |
566 |
for (i = 0; i < na; i++) { |
567 |
phi = (2.*PI)*i/na; |
568 |
ar[i][0] = cp[0] + tcos(phi)*hrad + 0.5; |
569 |
ar[i][1] = cp[1] + tsin(phi)*vrad + 0.5; |
570 |
ar[i][2] = dv; |
571 |
/* clip_end(ar[i], cp, vp); */ |
572 |
573 |
return(na); |
574 |
575 |
576 |
577 |
static int |
578 |
depthchange(vp, x0, y0, x1, y1) /* check depth discontinuity */ |
579 |
580 |
int x0, y0, x1, y1; |
581 |
582 |
register double d0, d1; |
583 |
584 |
DCHECK(x0<0 | x0>=vp->hhi | y0<0 | y0>=vp->vhi, |
585 |
CONSISTENCY, "coordinates off view in depthchange"); |
586 |
587 |
if (x1<0 | x1>=vp->hhi | y1<0 | y1>=vp->vhi) |
588 |
return(1); |
589 |
590 |
d0 = vp->dmap[y0*vp->hhi + x0]; |
591 |
d1 = vp->dmap[y1*vp->hhi + x1]; |
592 |
593 |
return((1.+DEPTHEPS)*d0 < d1 || d0 > (1.+DEPTHEPS)*d1); |
594 |
595 |
596 |
597 |
static |
598 |
clip_edge(p, o, vp) /* clip line segment to depth edge */ |
599 |
GLshort p[3]; |
600 |
short o[2]; |
601 |
602 |
603 |
int x, y, xstep, ystep, rise, rise2, run, run2, n; |
604 |
605 |
DCHECK(vp->dmap==NULL, CONSISTENCY, |
606 |
"clip_edge called with no depth map"); |
607 |
x = o[0]; y = o[1]; |
608 |
run = p[0] - x; |
609 |
xstep = run > 0 ? 1 : -1; |
610 |
run *= xstep; |
611 |
rise = p[1] - y; |
612 |
ystep = rise > 0 ? 1 : -1; |
613 |
rise *= ystep; |
614 |
rise2 = run2 = 0; |
615 |
if (rise > run) rise2 = 1; |
616 |
else run2 = 1; |
617 |
n = rise + run; |
618 |
while (n--) /* run out arm, checking depth */ |
619 |
if (run2 > rise2) { |
620 |
x += xstep; |
621 |
rise2 += rise; |
622 |
if (depthchange(vp, x-xstep, y, x, y)) |
623 |
break; |
624 |
} else { |
625 |
y += ystep; |
626 |
run2 += run; |
627 |
if (depthchange(vp, x, y-ystep, x, y)) |
628 |
break; |
629 |
630 |
if (n < 0) /* found something? */ |
631 |
return; |
632 |
if (run > rise) |
633 |
p[2] = (x - o[0])*p[2]/(p[0] - o[0]); |
634 |
else |
635 |
p[2] = (y - o[1])*p[2]/(p[1] - o[1]); |
636 |
p[0] = x; |
637 |
p[1] = y; |
638 |
639 |
640 |
641 |
static int |
642 |
getblock(vp, h, v) /* get block index */ |
643 |
644 |
register int h, v; |
645 |
646 |
if (h<0 | h>=vp->hhi | v<0 | v>=vp->vhi) |
647 |
return(-1); |
648 |
return(h*vp->hlow/vp->hhi + v*vp->vlow/vp->vhi*vp->hlow); |
649 |
650 |
651 |
652 |
static int |
653 |
blockedge(vp, bi0, bi1) /* check for edge between blocks? */ |
654 |
655 |
register int bi0, bi1; |
656 |
657 |
if (bi1 == bi0) |
658 |
return(0); /* same block */ |
659 |
if (bi1 < 0) |
660 |
return(1); /* end off view */ |
661 |
if (CHK4(vp->emap, bi1)) |
662 |
return(1); /* end block has edges */ |
663 |
if (bi1 == bi0+1 || bi1 == bi0-1 || |
664 |
bi1 == bi0+vp->hlow || bi1 == bi0-vp->hlow) |
665 |
return(0); /* end in adjacent block -- no edges */ |
666 |
return(1); /* conservative for rarer case */ |
667 |
668 |
669 |
670 |
odDrawSamp(vn, id) /* draw view sample */ |
671 |
int vn; |
672 |
register int id; |
673 |
674 |
GLshort arm[MAXFAN][3]; |
675 |
int narms, blockindex; |
676 |
677 |
double size; |
678 |
int home_edges; |
679 |
register int i; |
680 |
681 |
vp = odView + vn; |
682 |
blockindex = getblock(vp, odS.ip[id][0], odS.ip[id][1]); |
683 |
DCHECK(blockindex<0, CONSISTENCY, "bad sample handed to odDrawSamp"); |
684 |
DCHECK(vp->bmap[blockindex].nused <= 0, |
685 |
CONSISTENCY, "bad in-use count in odDrawSamp"); |
686 |
/* create triangle fan */ |
687 |
size = 1./sqrt((double)vp->bmap[blockindex].nused); |
688 |
narms = make_arms(arm, odS.ip[id], vp, size); |
689 |
if (vp->emap != NULL) { /* check for edge collisions */ |
690 |
home_edges = CHK4(vp->emap, blockindex); |
691 |
for (i = 0; i < narms; i++) |
692 |
if (home_edges || blockedge(vp, blockindex, |
693 |
getblock(vp, arm[i][0], arm[i][1]))) |
694 |
clip_edge(arm[i], odS.ip[id], vp); |
695 |
696 |
/* draw triangle fan */ |
697 |
glColor3ub(odS.rgb[id][0], odS.rgb[id][1], odS.rgb[id][2]); |
698 |
glBegin(GL_TRIANGLE_FAN); |
699 |
glVertex3s((GLshort)odS.ip[id][0], (GLshort)odS.ip[id][1], (GLshort)0); |
700 |
701 |
glVertex3sv(arm[i]); |
702 |
glVertex3sv(arm[0]); /* connect last to first */ |
703 |
glEnd(); |
704 |
