1 |
/* Copyright (c) 1999 Silicon Graphics, Inc. */ |
2 |
3 |
#ifndef lint |
4 |
static char SCCSid[] = "$SunId$ SGI"; |
5 |
#endif |
6 |
7 |
8 |
* Routines for drawing samples using depth buffer checks. |
9 |
10 |
11 |
#include "standard.h" |
12 |
13 |
#include <GL/glx.h> |
14 |
#include <GL/glu.h> |
15 |
16 |
#include "rhd_odraw.h" |
17 |
18 |
#ifndef DEPTHEPS |
19 |
#define DEPTHEPS 0.02 /* depth epsilon */ |
20 |
#endif |
21 |
#ifndef SAMPSPERBLOCK |
22 |
#define SAMPSPERBLOCK 1024 /* target samples per image block */ |
23 |
#endif |
24 |
#ifndef SFREEFRAC |
25 |
#define SFREEFRAC 0.2 /* fraction to free at a time */ |
26 |
#endif |
27 |
#ifndef REDRAWTHRESH |
28 |
#define REDRAWTHRESH 10240 /* number of samples for dissolve */ |
29 |
#endif |
30 |
#ifndef MAXFAN |
31 |
#define MAXFAN 32 /* maximum arms in a triangle fan */ |
32 |
#endif |
33 |
#ifndef MINFAN |
34 |
#define MINFAN 4 /* minimum arms in a triangle fan */ |
35 |
#endif |
36 |
#ifndef FANSIZE |
37 |
#define FANSIZE 3.5 /* fan sizing factor */ |
38 |
#endif |
39 |
40 |
#define NEWMAP 01 /* need to recompute mapping */ |
41 |
#define NEWRGB 02 /* need to remap RGB values */ |
42 |
#define NEWHIST 04 /* clear histogram as well */ |
43 |
44 |
struct ODview *odView; /* our view list */ |
45 |
int odNViews; /* number of views in our list */ |
46 |
47 |
struct ODsamp odS; /* sample values */ |
48 |
49 |
static int needmapping; /* what needs doing with tone map */ |
50 |
51 |
52 |
#define SAMP32 (32*(2*sizeof(short)+sizeof(union ODfunion)+sizeof(TMbright)+\ |
53 |
6*sizeof(BYTE))+sizeof(int4)) |
54 |
55 |
int |
56 |
odInit(n) /* initialize drawing routines */ |
57 |
int n; |
58 |
59 |
int nbytes, i, j, k, nextsamp, count, blockdiv; |
60 |
int res[2]; |
61 |
62 |
if (odNViews > 0) { /* deallocate view structures */ |
63 |
for (i = odNViews; i--; ) { |
64 |
free((char *)odView[i].bmap); |
65 |
free((char *)odView[i].pmap); |
66 |
if (odView[i].emap != NULL) |
67 |
free((char *)odView[i].emap); |
68 |
69 |
free((char *)odView); |
70 |
odView = NULL; |
71 |
odNViews = 0; |
72 |
73 |
if (n && n != odS.nsamp) { |
74 |
/* round space up to nearest power of 2 */ |
75 |
nbytes = (n+31)/32 * SAMP32; |
76 |
for (i = 1024; nbytes > i-8; i <<= 1) |
77 |
78 |
n = (i-8)/SAMP32 * 32; |
79 |
needmapping = NEWHIST; |
80 |
81 |
if (n != odS.nsamp) { /* (re)allocate sample array */ |
82 |
if (odS.nsamp) |
83 |
free(odS.base); |
84 |
odS.nsamp = 0; |
85 |
if (!n) |
86 |
return(0); |
87 |
88 |
odS.base = (char *)malloc(nbytes); |
89 |
if (odS.base == NULL) |
90 |
return(0); |
91 |
/* assign larger alignment types earlier */ |
92 |
odS.f = (union ODfunion *)odS.base; |
93 |
odS.redraw = (int4 *)(odS.f + n); |
94 |
odS.ip = (short (*)[2])(odS.redraw + n/32); |
95 |
odS.brt = (TMbright *)(odS.ip + n); |
96 |
odS.chr = (BYTE (*)[3])(odS.brt + n); |
97 |
odS.rgb = (BYTE (*)[3])(odS.chr + n); |
98 |
odS.nsamp = n; |
99 |
100 |
if (!n) |
101 |
return(0); |
102 |
/* allocate view information */ |
103 |
count = 0; /* count pixels */ |
104 |
for (i = 0; dev_auxview(i, res) != NULL; i++) |
105 |
count += res[0]*res[1]; |
106 |
odView = (struct ODview *)malloc(i*sizeof(struct ODview)); |
107 |
if (odView == NULL) |
108 |
return(0); |
109 |
odNViews = i; |
110 |
blockdiv = sqrt(count/(n/SAMPSPERBLOCK)) + 0.5; |
111 |
if (blockdiv < 8) blockdiv = 8; |
112 |
nextsamp = 0; count /= blockdiv*blockdiv; /* # blocks */ |
113 |
while (i--) { /* initialize each view */ |
114 |
dev_auxview(i, res); |
115 |
odView[i].hhi = res[0]; |
116 |
odView[i].hlow = (res[0] + blockdiv/2) / blockdiv; |
117 |
if (odView[i].hlow < 1) odView[i].hlow = 1; |
118 |
odView[i].vhi = res[1]; |
119 |
odView[i].vlow = (res[1] + blockdiv/2) / blockdiv; |
120 |
if (odView[i].vlow < 1) odView[i].vlow = 1; |
121 |
odView[i].emap = NULL; |
122 |
odView[i].dmap = NULL; |
123 |
odView[i].pmap = (int4 *)calloc(FL4NELS(res[0]*res[1]), |
124 |
sizeof(int4)); |
125 |
if (odView[i].pmap == NULL) |
126 |
return(0); |
127 |
j = odView[i].hlow*odView[i].vlow; |
128 |
odView[i].bmap = (struct ODblock *)malloc( |
129 |
j * sizeof(struct ODblock)); |
130 |
if (odView[i].bmap == NULL) |
131 |
return(0); |
132 |
DCHECK(count<=0 | nextsamp>=n, |
133 |
CONSISTENCY, "counter botch in odInit"); |
134 |
if (!i) count = j; |
135 |
odView[i].sfirst = nextsamp; |
136 |
while (j--) { /* initialize blocks & free lists */ |
137 |
odView[i].bmap[j].pthresh = FHUGE; |
138 |
odView[i].bmap[j].first = k = nextsamp; |
139 |
nextsamp += odView[i].bmap[j].nsamp = |
140 |
(n - nextsamp)/count--; |
141 |
odView[i].bmap[j].free = k; |
142 |
while (++k < nextsamp) |
143 |
odS.nextfree(k-1) = k; |
144 |
odS.nextfree(k-1) = ENDFREE; |
145 |
odView[i].bmap[j].nused = 0; |
146 |
147 |
odView[i].snext = nextsamp; |
148 |
odView[i].n2redraw = 0; |
149 |
150 |
CLR4ALL(odS.redraw, odS.nsamp); /* clear redraw flags */ |
151 |
for (i = odS.nsamp; i--; ) { /* clear values */ |
152 |
odS.ip[i][0] = odS.ip[i][1] = -1; |
153 |
odS.brt[i] = TM_NOBRT; |
154 |
155 |
needmapping |= NEWMAP; /* compute new map on update */ |
156 |
return(odS.nsamp); /* return number of samples */ |
157 |
158 |
159 |
#undef SAMP32 |
160 |
161 |
162 |
int |
163 |
sampcmp(s0, s1) /* sample order, descending proximity */ |
164 |
int *s0, *s1; |
165 |
166 |
register double diff = odS.closeness(*s1) - odS.closeness(*s0); |
167 |
168 |
return (diff > FTINY ? 1 : diff < -FTINY ? -1 : 0); |
169 |
170 |
171 |
172 |
int |
173 |
odAllocBlockSamp(vn, hh, vh, prox) /* allocate sample from block */ |
174 |
int vn, hh, vh; |
175 |
double prox; |
176 |
177 |
int si[SAMPSPERBLOCK+SAMPSPERBLOCK/4]; |
178 |
int hl, vl; |
179 |
VIEW *vw; |
180 |
FVECT ro, rd; |
181 |
int res[2]; |
182 |
register struct ODblock *bp; |
183 |
register int i, j; |
184 |
/* get block */ |
185 |
hl = hh*odView[vn].hlow/odView[vn].hhi; |
186 |
vl = vh*odView[vn].vlow/odView[vn].vhi; |
187 |
bp = odView[vn].bmap + vl*odView[vn].hlow + hl; |
188 |
if (prox > bp->pthresh) |
189 |
return(-1); /* worse than free list occupants */ |
190 |
/* check for duplicate pixel */ |
191 |
if (CHK4(odView[vn].pmap, vh*odView[vn].hhi + hh)) |
192 |
i = bp->first + bp->nsamp; |
193 |
else |
194 |
i = 0; |
195 |
while (i-- > bp->first) |
196 |
if (hh == odS.ip[i][0] && vh == odS.ip[i][1]) { /* found it! */ |
197 |
/* search free list for it */ |
198 |
if (i == bp->free) |
199 |
break; /* special case */ |
200 |
if (bp->free != ENDFREE) |
201 |
for (j = bp->free; odS.nextfree(j) != ENDFREE; |
202 |
j = odS.nextfree(j)) |
203 |
if (odS.nextfree(j) == i) { |
204 |
odS.nextfree(j) = |
205 |
odS.nextfree(i); |
206 |
bp->nused++; |
207 |
goto gotit; |
208 |
209 |
if (prox >= 0.99*odS.closeness(i)) |
210 |
return(-1); /* previous sample is fine */ |
211 |
goto gotit; |
212 |
213 |
if (bp->free != ENDFREE) { /* allocate from free list */ |
214 |
i = bp->free; |
215 |
if (odS.ip[i][0] >= 0 & odS.ip[i][1] >= 0) |
216 |
CLR4(odView[vn].pmap, odS.ip[i][1]*odView[vn].hhi + |
217 |
odS.ip[i][0]); |
218 |
bp->free = odS.nextfree(i); |
219 |
bp->nused++; |
220 |
goto gotit; |
221 |
222 |
DCHECK(bp->nsamp<=0, CONSISTENCY, |
223 |
"no available samples in odAllocBlockSamp"); |
224 |
DCHECK(bp->nsamp > sizeof(si)/sizeof(si[0]), CONSISTENCY, |
225 |
"too many samples in odAllocBlockSamp"); |
226 |
/* free some samples */ |
227 |
if ((vw = dev_auxview(vn, res)) == NULL) |
228 |
error(CONSISTENCY, "bad view number in odAllocBlockSamp"); |
229 |
for (i = bp->nsamp; i--; ) /* figure out which are worse */ |
230 |
si[i] = bp->first + i; |
231 |
qsort((char *)si, bp->nsamp, sizeof(int), sampcmp); |
232 |
i = bp->nsamp*SFREEFRAC + .5; /* put them into free list */ |
233 |
if (i >= bp->nsamp) i = bp->nsamp-1; /* paranoia */ |
234 |
bp->pthresh = odS.closeness(si[i]); /* new proximity threshold */ |
235 |
while (--i > 0) { |
236 |
odS.nextfree(si[i]) = bp->free; |
237 |
bp->free = si[i]; |
238 |
bp->nused--; |
239 |
240 |
i = si[0]; /* use worst sample */ |
241 |
CLR4(odView[vn].pmap, odS.ip[i][1]*odView[vn].hhi + odS.ip[i][0]); |
242 |
gotit: |
243 |
odS.ip[i][0] = hh; |
244 |
odS.ip[i][1] = vh; |
245 |
odS.closeness(i) = prox; |
246 |
SET4(odView[vn].pmap, vh*odView[vn].hhi + hh); |
247 |
return(i); |
248 |
249 |
250 |
251 |
odSample(c, d, p) /* add a sample value */ |
252 |
COLR c; |
253 |
FVECT d, p; |
254 |
255 |
FVECT disp; |
256 |
double d0, d1, h, v, prox; |
257 |
register VIEW *vw; |
258 |
int hh, vh; |
259 |
int res[2]; |
260 |
register int i, id; |
261 |
262 |
DCHECK(odS.nsamp<=0, CONSISTENCY, "no samples allocated in odSample"); |
263 |
/* add value to each view */ |
264 |
for (i = 0; (vw = dev_auxview(i, res)) != NULL; i++) { |
265 |
DCHECK(i>=odNViews, CONSISTENCY, "too many views in odSample"); |
266 |
CHECK(vw->type!=VT_PER, INTERNAL, |
267 |
"cannot handle non-perspective views"); |
268 |
if (p != NULL) { /* compute view position */ |
269 |
VSUB(disp, p, vw->vp); |
270 |
d0 = DOT(disp, vw->vdir); |
271 |
if (d0 <= vw->vfore+FTINY) |
272 |
continue; /* too close */ |
273 |
} else { |
274 |
VCOPY(disp, d); |
275 |
276 |
if (d0 <= FTINY) /* behind view */ |
277 |
continue; |
278 |
279 |
h = DOT(disp,vw->hvec)/(d0*vw->hn2) + 0.5 - vw->hoff; |
280 |
if (h < 0. || h >= 1.) |
281 |
continue; /* left or right */ |
282 |
v = DOT(disp,vw->vvec)/(d0*vw->vn2) + 0.5 - vw->voff; |
283 |
if (v < 0. || v >= 1.) |
284 |
continue; /* above or below */ |
285 |
hh = h * res[0]; |
286 |
vh = v * res[1]; |
287 |
if (odView[i].dmap != NULL) { /* check depth */ |
288 |
d1 = odView[i].dmap[vh*res[0] + hh]; |
289 |
if (d1 < 0.99*FHUGE && (d0 > (1.+DEPTHEPS)*d1 || |
290 |
(1.+DEPTHEPS)*d0 < d1)) |
291 |
continue; /* occlusion error */ |
292 |
293 |
if (p != NULL) { /* compute closeness (sin^2) */ |
294 |
d1 = DOT(disp, d); |
295 |
prox = 1. - d1*d1/DOT(disp,disp); |
296 |
} else |
297 |
prox = 0.; |
298 |
/* allocate sample */ |
299 |
id = odAllocBlockSamp(i, hh, vh, prox); |
300 |
if (id < 0) |
301 |
continue; /* not good enough */ |
302 |
/* convert color */ |
303 |
tmCvColrs(&odS.brt[id], odS.chr[id], c, 1); |
304 |
if (imm_mode | needmapping) /* if immediate mode */ |
305 |
needmapping |= NEWRGB; /* map it later */ |
306 |
else /* else map it now */ |
307 |
tmMapPixels(odS.rgb[id], &odS.brt[id], odS.chr[id], 1); |
308 |
SET4(odS.redraw, id); /* mark for redraw */ |
309 |
odView[i].n2redraw++; |
310 |
311 |
312 |
313 |
314 |
odRemap(newhist) /* recompute tone mapping */ |
315 |
int newhist; |
316 |
317 |
needmapping |= NEWMAP|NEWRGB; |
318 |
if (newhist) |
319 |
needmapping |= NEWHIST; |
320 |
321 |
322 |
323 |
odRedrawAll() /* mark all samples for redraw */ |
324 |
325 |
register int i; |
326 |
327 |
if ((needmapping&(NEWMAP|NEWRGB)) == (NEWMAP|NEWRGB)) |
328 |
return; /* will be called later, anyway */ |
329 |
for (i = odS.nsamp; i--; ) |
330 |
if (odS.ip[i][0] >= 0) |
331 |
SET4(odS.redraw, i); |
332 |
/* not right, but not important */ |
333 |
for (i = 0; i < odNViews; i++) |
334 |
odView[i].n2redraw = odView[i].snext - odView[i].sfirst; |
335 |
336 |
337 |
338 |
odRedraw(vn, hmin, vmin, hmax, vmax) /* redraw view region */ |
339 |
int vn, hmin, vmin, hmax, vmax; |
340 |
341 |
int i, j; |
342 |
343 |
register int k; |
344 |
345 |
if (vn<0 | vn>=odNViews) |
346 |
return; |
347 |
/* check view limits */ |
348 |
if (hmin < 0) hmin = 0; |
349 |
if (hmax >= odView[vn].hhi) hmax = odView[vn].hhi-1; |
350 |
if (vmin < 0) vmin = 0; |
351 |
if (vmax >= odView[vn].vhi) vmax = odView[vn].vhi-1; |
352 |
if (hmax <= hmin | vmax <= vmin) |
353 |
return; |
354 |
/* convert to low resolution */ |
355 |
hmin = hmin * odView[vn].hlow / odView[vn].hhi; |
356 |
hmax = hmax * odView[vn].hlow / odView[vn].hhi; |
357 |
vmin = vmin * odView[vn].vlow / odView[vn].vhi; |
358 |
vmax = vmax * odView[vn].vlow / odView[vn].vhi; |
359 |
/* mark block samples for redraw, inclusive */ |
360 |
for (i = hmin; i <= hmax; i++) |
361 |
for (j = vmin; j <= vmax; j++) { |
362 |
bp = odView[vn].bmap + j*odView[vn].hlow + i; |
363 |
for (k = bp->nsamp; k--; ) |
364 |
if (odS.ip[bp->first+k][0] >= 0) { |
365 |
SET4(odS.redraw, bp->first+k); |
366 |
odView[vn].n2redraw++; |
367 |
368 |
369 |
370 |
371 |
372 |
odDepthMap(vn, dm) /* assign depth map for view */ |
373 |
int vn; |
374 |
GLfloat *dm; |
375 |
376 |
double d0, d1; |
377 |
int i, j, hmin, hmax, vmin, vmax; |
378 |
register int k, l; |
379 |
380 |
if (dm == NULL) { /* free edge map */ |
381 |
382 |
return; /* too late -- they're gone! */ |
383 |
if (odView[vn].emap != NULL) |
384 |
free((char *)odView[vn].emap); |
385 |
odView[vn].emap = NULL; |
386 |
odView[vn].dmap = NULL; |
387 |
return; |
388 |
389 |
DCHECK(vn<0 | vn>=odNViews, CONSISTENCY, |
390 |
"bad view number in odDepthMap"); |
391 |
odView[vn].dmap = dm; /* initialize edge map */ |
392 |
if (odView[vn].emap == NULL) { |
393 |
odView[vn].emap = (int4 *)malloc( |
394 |
FL4NELS(odView[vn].hlow*odView[vn].vlow)*sizeof(int4)); |
395 |
if (odView[vn].emap == NULL) |
396 |
error(SYSTEM, "out of memory in odDepthMap"); |
397 |
398 |
CLR4ALL(odView[vn].emap, odView[vn].hlow*odView[vn].vlow); |
399 |
/* compute edge map */ |
400 |
vmin = odView[vn].vhi; /* enter loopsville */ |
401 |
for (j = odView[vn].vlow; j--; ) { |
402 |
vmax = vmin; |
403 |
vmin = j*odView[vn].vhi/odView[vn].vlow; |
404 |
hmin = odView[vn].hhi; |
405 |
for (i = odView[vn].hlow; i--; ) { |
406 |
hmax = hmin; |
407 |
hmin = i*odView[vn].hhi/odView[vn].hlow; |
408 |
for (l = vmin; l < vmax; l++) { /* vertical edges */ |
409 |
d1 = dm[l*odView[vn].hhi+hmin]; |
410 |
for (k = hmin+1; k < hmax; k++) { |
411 |
d0 = d1; |
412 |
d1 = dm[l*odView[vn].hhi+k]; |
413 |
if (d0 > (1.+DEPTHEPS)*d1 || |
414 |
(1.+DEPTHEPS)*d0 < d1) { |
415 |
SET4(odView[vn].emap, |
416 |
j*odView[vn].hlow + i); |
417 |
break; |
418 |
419 |
420 |
if (k < hmax) |
421 |
break; |
422 |
423 |
if (l < vmax) |
424 |
continue; |
425 |
for (k = hmin; k < hmax; k++) { /* horizontal edges */ |
426 |
d1 = dm[vmin*odView[vn].hhi+k]; |
427 |
for (l = vmin+1; l < vmax; l++) { |
428 |
d0 = d1; |
429 |
430 |
431 |
432 |
433 |
434 |
break; |
435 |
436 |
437 |
if (l < vmax) |
438 |
break; |
439 |
440 |
441 |
442 |
443 |
444 |
445 |
odUpdate(vn) /* update this view */ |
446 |
int vn; |
447 |
448 |
static short primes[] = {9431,6803,4177,2659,1609,887,587,251,47,1}; |
449 |
int myprime; |
450 |
register int i, n; |
451 |
452 |
453 |
"bad view number in odUpdate"); |
454 |
/* need to do some tone mapping? */ |
455 |
if (needmapping & NEWRGB) { |
456 |
if (needmapping & NEWMAP) { |
457 |
if (needmapping & NEWHIST) |
458 |
tmClearHisto(); |
459 |
needmapping &= ~NEWHIST; |
460 |
if (tmAddHisto(odS.brt,odS.nsamp,1) != TM_E_OK) |
461 |
return; |
462 |
if (tmComputeMapping(0.,0.,0.) != TM_E_OK) |
463 |
return; |
464 |
needmapping &= ~NEWMAP; |
465 |
odRedrawAll(); /* redraw everything */ |
466 |
467 |
if (tmMapPixels(odS.rgb,odS.brt,odS.chr,odS.nsamp) != TM_E_OK) |
468 |
return; |
469 |
needmapping &= ~NEWRGB; |
470 |
471 |
if (odView[vn].n2redraw <= 0) |
472 |
return; |
473 |
#if REDRAWTHRESH |
474 |
if (odView[vn].n2redraw < REDRAWTHRESH) |
475 |
goto quickdraw; |
476 |
/* pick a good prime step size */ |
477 |
n = odView[vn].snext - odView[vn].sfirst; |
478 |
for (i = 0; primes[i]<<5 >= n; i++) |
479 |
480 |
while ((myprime = primes[i++]) > 1) |
481 |
if (n % myprime) |
482 |
break; |
483 |
/* dissolve in new samples */ |
484 |
for (i = odView[vn].sfirst; n-- > 0; i += myprime) { |
485 |
if (i >= odView[vn].snext) |
486 |
i -= odView[vn].snext - odView[vn].sfirst; |
487 |
if (CHK4(odS.redraw, i)) { |
488 |
odDrawSamp(vn, i); |
489 |
CLR4(odS.redraw, i); |
490 |
491 |
492 |
odView[vn].n2redraw = 0; |
493 |
return; |
494 |
quickdraw: /* quicker sparse flag checking */ |
495 |
#endif |
496 |
/* redraw samples at end */ |
497 |
for (i = odView[vn].snext-31; i < odView[vn].snext; i++) |
498 |
499 |
500 |
501 |
502 |
/* faster flag checks in middle */ |
503 |
for (n = odView[vn].snext>>5; n-- > (odView[vn].sfirst+0x1f)>>5; ) |
504 |
for (i = 0; odS.redraw[n]; i++) /* skips faster */ |
505 |
if (odS.redraw[n] & 1L<<i) { |
506 |
odDrawSamp(vn, (n<<5)+i); |
507 |
odS.redraw[n] &= ~(1L<<i); |
508 |
509 |
/* redraw samples at beginning */ |
510 |
for (i = odView[vn].sfirst; i < odView[vn].sfirst+31; i++) |
511 |
512 |
513 |
514 |
515 |
516 |
517 |
518 |
519 |
/* this turned out to be unnecessary */ |
520 |
#if 0 |
521 |
static |
522 |
clip_end(p, o, vp) /* clip line segment to view */ |
523 |
GLshort p[3]; |
524 |
short o[2]; |
525 |
register struct ODview *vp; |
526 |
527 |
if (p[0] < 0) { |
528 |
p[1] = -o[0]*(p[1]-o[1])/(p[0]-o[0]) + o[1]; |
529 |
p[2] = -o[0]*p[2]/(p[0]-o[0]); |
530 |
p[0] = 0; |
531 |
} else if (p[0] >= vp->hhi) { |
532 |
p[1] = (vp->hhi-1-o[0])*(p[1]-o[1])/(p[0]-o[0]) + o[1]; |
533 |
p[2] = (vp->hhi-1-o[0])*p[2]/(p[0]-o[0]); |
534 |
p[0] = vp->hhi-1; |
535 |
536 |
if (p[1] < 0) { |
537 |
p[0] = -o[1]*(p[0]-o[0])/(p[1]-o[1]) + o[0]; |
538 |
p[2] = -o[1]*p[2]/(p[1]-o[1]); |
539 |
p[1] = 0; |
540 |
} else if (p[1] >= vp->vhi) { |
541 |
p[0] = (vp->vhi-1-o[1])*(p[0]-o[0])/(p[1]-o[1]) + o[0]; |
542 |
p[2] = (vp->vhi-1-o[1])*p[2]/(p[1]-o[1]); |
543 |
p[1] = vp->vhi-1; |
544 |
545 |
546 |
#endif |
547 |
548 |
549 |
static int |
550 |
make_arms(ar, cp, vp, sz) /* make arms for triangle fan */ |
551 |
GLshort ar[MAXFAN][3]; |
552 |
short cp[2]; |
553 |
554 |
double sz; |
555 |
556 |
int na, dv; |
557 |
double hrad, vrad, phi; |
558 |
register int i; |
559 |
560 |
DCHECK(sz > 1, CONSISTENCY, "super-unary size in make_arms"); |
561 |
na = MAXFAN*sz + 0.5; /* keep arc length constant */ |
562 |
if (na < MINFAN) na = MINFAN; |
563 |
hrad = FANSIZE*sz*vp->hhi/vp->hlow; |
564 |
vrad = FANSIZE*sz*vp->vhi/vp->vlow; |
565 |
if (hrad*vrad < 2.25) |
566 |
hrad = vrad = 1.5; |
567 |
dv = OMAXDEPTH*sz + 0.5; |
568 |
for (i = 0; i < na; i++) { |
569 |
phi = (2.*PI)*i/na; |
570 |
ar[i][0] = cp[0] + tcos(phi)*hrad + 0.5; |
571 |
ar[i][1] = cp[1] + tsin(phi)*vrad + 0.5; |
572 |
ar[i][2] = dv; |
573 |
/* clip_end(ar[i], cp, vp); */ |
574 |
575 |
return(na); |
576 |
577 |
578 |
579 |
static int |
580 |
depthchange(vp, x0, y0, x1, y1) /* check depth discontinuity */ |
581 |
582 |
int x0, y0, x1, y1; |
583 |
584 |
register double d0, d1; |
585 |
586 |
DCHECK(x0<0 | x0>=vp->hhi | y0<0 | y0>=vp->vhi, |
587 |
CONSISTENCY, "coordinates off view in depthchange"); |
588 |
589 |
if (x1<0 | x1>=vp->hhi | y1<0 | y1>=vp->vhi) |
590 |
return(1); |
591 |
592 |
d0 = vp->dmap[y0*vp->hhi + x0]; |
593 |
d1 = vp->dmap[y1*vp->hhi + x1]; |
594 |
595 |
return((1.+DEPTHEPS)*d0 < d1 || d0 > (1.+DEPTHEPS)*d1); |
596 |
597 |
598 |
599 |
static |
600 |
clip_edge(p, o, vp) /* clip line segment to depth edge */ |
601 |
GLshort p[3]; |
602 |
short o[2]; |
603 |
604 |
605 |
int x, y, xstep, ystep, rise, rise2, run, run2, n; |
606 |
607 |
DCHECK(vp->dmap==NULL, CONSISTENCY, |
608 |
"clip_edge called with no depth map"); |
609 |
x = o[0]; y = o[1]; |
610 |
run = p[0] - x; |
611 |
xstep = run > 0 ? 1 : -1; |
612 |
run *= xstep; |
613 |
rise = p[1] - y; |
614 |
ystep = rise > 0 ? 1 : -1; |
615 |
rise *= ystep; |
616 |
rise2 = run2 = 0; |
617 |
if (rise > run) rise2 = 1; |
618 |
else run2 = 1; |
619 |
n = rise + run; |
620 |
while (n--) /* run out arm, checking depth */ |
621 |
if (run2 > rise2) { |
622 |
x += xstep; |
623 |
rise2 += rise; |
624 |
if (depthchange(vp, x-xstep, y, x, y)) |
625 |
break; |
626 |
} else { |
627 |
y += ystep; |
628 |
run2 += run; |
629 |
if (depthchange(vp, x, y-ystep, x, y)) |
630 |
break; |
631 |
632 |
if (n < 0) /* found something? */ |
633 |
return; |
634 |
if (run > rise) |
635 |
p[2] = (x - o[0])*p[2]/(p[0] - o[0]); |
636 |
else |
637 |
p[2] = (y - o[1])*p[2]/(p[1] - o[1]); |
638 |
p[0] = x; |
639 |
p[1] = y; |
640 |
641 |
642 |
643 |
static int |
644 |
getblock(vp, h, v) /* get block index */ |
645 |
646 |
register int h, v; |
647 |
648 |
if (h<0 | h>=vp->hhi | v<0 | v>=vp->vhi) |
649 |
return(-1); |
650 |
return(h*vp->hlow/vp->hhi + v*vp->vlow/vp->vhi*vp->hlow); |
651 |
652 |
653 |
654 |
static int |
655 |
blockedge(vp, bi0, bi1) /* check for edge between blocks? */ |
656 |
657 |
register int bi0, bi1; |
658 |
659 |
if (bi1 == bi0) |
660 |
return(0); /* same block */ |
661 |
if (bi1 < 0) |
662 |
return(1); /* end off view */ |
663 |
if (CHK4(vp->emap, bi1)) |
664 |
return(1); /* end block has edges */ |
665 |
if (bi1 == bi0+1 || bi1 == bi0-1 || |
666 |
bi1 == bi0+vp->hlow || bi1 == bi0-vp->hlow) |
667 |
return(0); /* end in adjacent block -- no edges */ |
668 |
return(1); /* conservative for rarer case */ |
669 |
670 |
671 |
672 |
odDrawSamp(vn, id) /* draw view sample */ |
673 |
int vn; |
674 |
register int id; |
675 |
676 |
GLshort arm[MAXFAN][3]; |
677 |
int narms, blockindex; |
678 |
679 |
double size; |
680 |
int home_edges; |
681 |
register int i; |
682 |
683 |
vp = odView + vn; |
684 |
blockindex = getblock(vp, odS.ip[id][0], odS.ip[id][1]); |
685 |
DCHECK(blockindex<0, CONSISTENCY, "bad sample handed to odDrawSamp"); |
686 |
DCHECK(vp->bmap[blockindex].nused <= 0, |
687 |
CONSISTENCY, "bad in-use count in odDrawSamp"); |
688 |
/* create triangle fan */ |
689 |
size = 1./sqrt((double)vp->bmap[blockindex].nused); |
690 |
narms = make_arms(arm, odS.ip[id], vp, size); |
691 |
if (vp->emap != NULL) { /* check for edge collisions */ |
692 |
home_edges = CHK4(vp->emap, blockindex); |
693 |
for (i = 0; i < narms; i++) |
694 |
if (home_edges || blockedge(vp, blockindex, |
695 |
getblock(vp, arm[i][0], arm[i][1]))) |
696 |
clip_edge(arm[i], odS.ip[id], vp); |
697 |
698 |
/* draw triangle fan */ |
699 |
glColor3ub(odS.rgb[id][0], odS.rgb[id][1], odS.rgb[id][2]); |
700 |
glBegin(GL_TRIANGLE_FAN); |
701 |
glVertex3s((GLshort)odS.ip[id][0], (GLshort)odS.ip[id][1], (GLshort)0); |
702 |
703 |
glVertex3sv(arm[i]); |
704 |
glVertex3sv(arm[0]); /* connect last to first */ |
705 |
glEnd(); |
706 |
