--- ray/src/hd/rhd_odraw.c 1998/12/18 11:55:19 3.1 +++ ray/src/hd/rhd_odraw.c 1998/12/20 20:37:53 3.2 @@ -38,6 +38,7 @@ static char SCCSid[] = "$SunId$ SGI"; #define NEWMAP 01 /* need to recompute mapping */ #define NEWRGB 02 /* need to remap RGB values */ +#define NEWHIST 04 /* clear histogram as well */ struct ODview *odView; /* our view list */ int odNViews; /* number of views in our list */ @@ -73,7 +74,7 @@ int n; for (i = 1024; nbytes > i-8; i <<= 1) ; n = (i-8)/SAMP32 * 32; - needmapping = NEWMAP; + needmapping = NEWHIST; } if (n != odS.nsamp) { /* (re)allocate sample array */ if (odS.nsamp) @@ -125,7 +126,8 @@ int n; DCHECK(count<=0 | nextsamp>=n, CONSISTENCY, "counter botch in odInit"); if (!i) count = j; - while (j--) { + while (j--) { /* initialize blocks & free lists */ + odView[i].bmap[j].pthresh = FHUGE; odView[i].bmap[j].first = k = nextsamp; nextsamp += odView[i].bmap[j].nsamp = (n - nextsamp)/count--; @@ -137,8 +139,11 @@ int n; } } CLR4ALL(odS.redraw, odS.nsamp); /* clear redraw flags */ - for (i = odS.nsamp; i--; ) /* clear values */ + for (i = odS.nsamp; i--; ) { /* clear values */ odS.ip[i][0] = odS.ip[i][1] = -1; + odS.brt[i] = TM_NOBRT; + } + needmapping |= NEWMAP; /* compute new map on update */ return(odS.nsamp); /* return number of samples */ } @@ -156,22 +161,47 @@ int *s0, *s1; int -odAllocBlockSamp(vn, hl, vl) /* allocate sample from block */ -int vn, hl, vl; +odAllocBlockSamp(vn, hh, vh, prox) /* allocate sample from block */ +int vn, hh, vh; +double prox; { int si[SAMPSPERBLOCK+SAMPSPERBLOCK/4]; + int hl, vl; VIEW *vw; FVECT ro, rd; int res[2]; register struct ODblock *bp; - register int i; - + register int i, j; + /* get block */ + hl = hh*odView[vn].hlow/odView[vn].hhi; + vl = vh*odView[vn].vlow/odView[vn].vhi; bp = odView[vn].bmap + vl*odView[vn].hlow + hl; - if (bp->free != ENDFREE) { /* check free list first */ + if (prox > bp->pthresh) + return(-1); /* worse than free list occupants */ + /* check for duplicate pixel */ + for (i = bp->first+bp->nsamp; i-- > bp->first; ) + if (hh == odS.ip[i][0] && vh == odS.ip[i][1]) { /* found it! */ + /* search free list for it */ + if (i == bp->free) + break; /* special case */ + if (bp->free != ENDFREE) + for (j = bp->free; odS.nextfree(j) != ENDFREE; + j = odS.nextfree(j)) + if (odS.nextfree(j) == i) { + odS.nextfree(j) = + odS.nextfree(i); + bp->nused++; + goto gotit; + } + if (prox >= 0.999*odS.closeness(i)) + return(-1); /* previous sample is fine */ + goto gotit; + } + if (bp->free != ENDFREE) { /* allocate from free list */ i = bp->free; bp->free = odS.nextfree(i); bp->nused++; - return(i); + goto gotit; } DCHECK(bp->nsamp<=0, CONSISTENCY, "no available samples in odAllocBlockSamp"); @@ -183,13 +213,20 @@ int vn, hl, vl; for (i = bp->nsamp; i--; ) /* figure out which are worse */ si[i] = bp->first + i; qsort((char *)si, bp->nsamp, sizeof(int), sampcmp); - i = bp->nsamp*SFREEFRAC + .5; /* put them in a list */ + i = bp->nsamp*SFREEFRAC + .5; /* put them into free list */ + if (i >= bp->nsamp) i = bp->nsamp-1; /* paranoia */ + bp->pthresh = odS.closeness(si[i]); /* new proximity threshold */ while (--i > 0) { odS.nextfree(si[i]) = bp->free; bp->free = si[i]; bp->nused--; } - return(si[0]); /* return first free sample */ + i = si[0]; /* use worst sample */ +gotit: + odS.ip[i][0] = hh; + odS.ip[i][1] = vh; + odS.closeness(i) = prox; + return(i); } @@ -198,9 +235,9 @@ COLR c; FVECT d, p; { FVECT disp; - double d0, d1, h, v; + double d0, d1, h, v, prox; register VIEW *vw; - int hl, vl, hh, vh; + int hh, vh; int res[2]; register int i, id; @@ -235,17 +272,15 @@ FVECT d, p; (1.+DEPTHEPS)*d0 < d1)) continue; /* occlusion error */ } - hl = hh*odView[i].hlow/res[0]; - vl = vh*odView[i].vlow/res[1]; - /* may duplicate samples */ - id = odAllocBlockSamp(i, hl, vl); - odS.ip[id][0] = hh; - odS.ip[id][1] = vh; if (p != NULL) { /* compute closeness (sin^2) */ d1 = DOT(disp, d); - odS.closeness(id) = 1. - d1*d1/DOT(disp,disp); + prox = 1. - d1*d1/DOT(disp,disp); } else - odS.closeness(id) = 0.; + prox = 0.; + /* allocate sample */ + id = odAllocBlockSamp(i, hh, vh, prox); + if (id < 0) + continue; /* not good enough */ /* convert color */ tmCvColrs(&odS.brt[id], odS.chr[id], c, 1); if (imm_mode | needmapping) /* if immediate mode */ @@ -257,9 +292,12 @@ FVECT d, p; } -odRemap() /* recompute tone mapping */ +odRemap(newhist) /* recompute tone mapping */ +int newhist; { needmapping |= NEWMAP|NEWRGB; + if (newhist) + needmapping |= NEWHIST; } @@ -303,15 +341,17 @@ GLfloat *dm; int i, j, hmin, hmax, vmin, vmax; register int k, l; - DCHECK(vn<0 | vn>=odNViews, CONSISTENCY, - "bad view number in odDepthMap"); if (dm == NULL) { /* free edge map */ + if (vn<0 | vn>=odNViews) + return; /* too late -- they're gone! */ if (odView[vn].emap != NULL) free((char *)odView[vn].emap); odView[vn].emap = NULL; odView[vn].dmap = NULL; return; } + DCHECK(vn<0 | vn>=odNViews, CONSISTENCY, + "bad view number in odDepthMap"); odView[vn].dmap = dm; /* initialize edge map */ if (odView[vn].emap == NULL) { odView[vn].emap = (int4 *)malloc( @@ -378,7 +418,8 @@ int vn; /* need to do some tone mapping? */ if (needmapping & NEWRGB) { if (needmapping & NEWMAP) { - tmClearHisto(); + if (needmapping & NEWHIST) + tmClearHisto(); if (tmAddHisto(odS.brt,odS.nsamp,1) != TM_E_OK) return; if (tmComputeMapping(0.,0.,0.) != TM_E_OK) @@ -392,8 +433,8 @@ int vn; needmapping = 0; /* reset flag */ } /* draw each block in view */ - for (i = odView[vn].hlow; i--; ) - for (j = odView[vn].vlow; j--; ) { + for (j = odView[vn].vlow; j--; ) + for (i = 0; i < odView[vn].hlow; i++) { /* get block */ bp = odView[vn].bmap + j*odView[vn].hlow + i; /* do quick, conservative flag check */
