--- ray/src/hd/rhd_odraw.c 1998/12/24 09:34:20 3.9 +++ ray/src/hd/rhd_odraw.c 2003/06/20 00:25:49 3.15 @@ -1,16 +1,12 @@ -/* Copyright (c) 1998 Silicon Graphics, Inc. */ - #ifndef lint -static char SCCSid[] = "$SunId$ SGI"; +static const char RCSid[] = "$Id: rhd_odraw.c,v 3.15 2003/06/20 00:25:49 greg Exp $"; #endif - /* * Routines for drawing samples using depth buffer checks. */ #include "standard.h" -#include #include #include @@ -25,6 +21,9 @@ static char SCCSid[] = "$SunId$ SGI"; #ifndef SFREEFRAC #define SFREEFRAC 0.2 /* fraction to free at a time */ #endif +#ifndef REDRAWTHRESH +#define REDRAWTHRESH 10240 /* number of samples for dissolve */ +#endif #ifndef MAXFAN #define MAXFAN 32 /* maximum arms in a triangle fan */ #endif @@ -48,7 +47,7 @@ static int needmapping; /* what needs doing with tone #define SAMP32 (32*(2*sizeof(short)+sizeof(union ODfunion)+sizeof(TMbright)+\ - 6*sizeof(BYTE))+sizeof(int4)) + 6*sizeof(BYTE))+sizeof(int32)) int odInit(n) /* initialize drawing routines */ @@ -59,12 +58,12 @@ int n; if (odNViews > 0) { /* deallocate view structures */ for (i = odNViews; i--; ) { - free((char *)odView[i].bmap); - free((char *)odView[i].pmap); + free((void *)odView[i].bmap); + free((void *)odView[i].pmap); if (odView[i].emap != NULL) - free((char *)odView[i].emap); + free((void *)odView[i].emap); } - free((char *)odView); + free((void *)odView); odView = NULL; odNViews = 0; } @@ -88,7 +87,7 @@ int n; return(0); /* assign larger alignment types earlier */ odS.f = (union ODfunion *)odS.base; - odS.redraw = (int4 *)(odS.f + n); + odS.redraw = (int32 *)(odS.f + n); odS.ip = (short (*)[2])(odS.redraw + n/32); odS.brt = (TMbright *)(odS.ip + n); odS.chr = (BYTE (*)[3])(odS.brt + n); @@ -118,8 +117,8 @@ int n; if (odView[i].vlow < 1) odView[i].vlow = 1; odView[i].emap = NULL; odView[i].dmap = NULL; - odView[i].pmap = (int4 *)calloc(FL4NELS(res[0]*res[1]), - sizeof(int4)); + odView[i].pmap = (int32 *)calloc(FL4NELS(res[0]*res[1]), + sizeof(int32)); if (odView[i].pmap == NULL) return(0); j = odView[i].hlow*odView[i].vlow; @@ -143,6 +142,7 @@ int n; odView[i].bmap[j].nused = 0; } odView[i].snext = nextsamp; + odView[i].n2redraw = 0; } CLR4ALL(odS.redraw, odS.nsamp); /* clear redraw flags */ for (i = odS.nsamp; i--; ) { /* clear values */ @@ -188,7 +188,7 @@ double prox; if (CHK4(odView[vn].pmap, vh*odView[vn].hhi + hh)) i = bp->first + bp->nsamp; else - i = -1; + i = 0; while (i-- > bp->first) if (hh == odS.ip[i][0] && vh == odS.ip[i][1]) { /* found it! */ /* search free list for it */ @@ -203,11 +203,10 @@ double prox; bp->nused++; goto gotit; } - if (prox >= 0.999*odS.closeness(i)) + if (prox >= 0.99*odS.closeness(i)) return(-1); /* previous sample is fine */ goto gotit; } - DCHECK(i>=-1, WARNING, "pixel in presence map not found in block"); if (bp->free != ENDFREE) { /* allocate from free list */ i = bp->free; if (odS.ip[i][0] >= 0 & odS.ip[i][1] >= 0) @@ -298,12 +297,13 @@ FVECT d, p; if (id < 0) continue; /* not good enough */ /* convert color */ - tmCvColrs(&odS.brt[id], odS.chr[id], c, 1); + tmCvColrs(&odS.brt[id], odS.chr[id], (COLR *)c, 1); if (imm_mode | needmapping) /* if immediate mode */ needmapping |= NEWRGB; /* map it later */ else /* else map it now */ tmMapPixels(odS.rgb[id], &odS.brt[id], odS.chr[id], 1); SET4(odS.redraw, id); /* mark for redraw */ + odView[i].n2redraw++; } } @@ -326,6 +326,9 @@ odRedrawAll() /* mark all samples for redraw */ for (i = odS.nsamp; i--; ) if (odS.ip[i][0] >= 0) SET4(odS.redraw, i); + /* not right, but not important */ + for (i = 0; i < odNViews; i++) + odView[i].n2redraw = odView[i].snext - odView[i].sfirst; } @@ -355,8 +358,10 @@ int vn, hmin, vmin, hmax, vmax; for (j = vmin; j <= vmax; j++) { bp = odView[vn].bmap + j*odView[vn].hlow + i; for (k = bp->nsamp; k--; ) - if (odS.ip[bp->first+k][0] >= 0) + if (odS.ip[bp->first+k][0] >= 0) { SET4(odS.redraw, bp->first+k); + odView[vn].n2redraw++; + } } } @@ -373,7 +378,7 @@ GLfloat *dm; if (vn<0 | vn>=odNViews) return; /* too late -- they're gone! */ if (odView[vn].emap != NULL) - free((char *)odView[vn].emap); + free((void *)odView[vn].emap); odView[vn].emap = NULL; odView[vn].dmap = NULL; return; @@ -382,8 +387,8 @@ GLfloat *dm; "bad view number in odDepthMap"); odView[vn].dmap = dm; /* initialize edge map */ if (odView[vn].emap == NULL) { - odView[vn].emap = (int4 *)malloc( - FL4NELS(odView[vn].hlow*odView[vn].vlow)*sizeof(int4)); + odView[vn].emap = (int32 *)malloc( + FL4NELS(odView[vn].hlow*odView[vn].vlow)*sizeof(int32)); if (odView[vn].emap == NULL) error(SYSTEM, "out of memory in odDepthMap"); } @@ -437,7 +442,9 @@ GLfloat *dm; odUpdate(vn) /* update this view */ int vn; { - register int i, j; + static short primes[] = {9431,6803,4177,2659,1609,887,587,251,47,1}; + int myprime; + register int i, n; DCHECK(vn<0 | vn>=odNViews, CONSISTENCY, "bad view number in odUpdate"); @@ -454,38 +461,56 @@ int vn; needmapping &= ~NEWMAP; odRedrawAll(); /* redraw everything */ } - if (tmMapPixels(odS.rgb,odS.brt,odS.chr,odS.nsamp) != TM_E_OK) + if (tmMapPixels((BYTE *)(odS.rgb), odS.brt, + (BYTE *)(odS.chr), odS.nsamp) != TM_E_OK) return; needmapping &= ~NEWRGB; } - /* this code segment was too slow */ -#if 0 - for (i = odView[vn].sfirst; i < odView[vn].snext; i++) + if (odView[vn].n2redraw <= 0) + return; +#if REDRAWTHRESH + if (odView[vn].n2redraw < REDRAWTHRESH) + goto quickdraw; + /* pick a good prime step size */ + n = odView[vn].snext - odView[vn].sfirst; + for (i = 0; primes[i]<<5 >= n; i++) + ; + while ((myprime = primes[i++]) > 1) + if (n % myprime) + break; + /* dissolve in new samples */ + for (i = odView[vn].sfirst; n-- > 0; i += myprime) { + if (i >= odView[vn].snext) + i -= odView[vn].snext - odView[vn].sfirst; if (CHK4(odS.redraw, i)) { odDrawSamp(vn, i); CLR4(odS.redraw, i); } -#else - /* redraw samples at beginning */ - for (i = odView[vn].sfirst; i < odView[vn].sfirst+31; i++) + } + odView[vn].n2redraw = 0; + return; +quickdraw: /* quicker sparse flag checking */ +#endif + /* redraw samples at end */ + for (i = odView[vn].snext-31; i < odView[vn].snext; i++) if (CHK4(odS.redraw, i)) { odDrawSamp(vn, i); CLR4(odS.redraw, i); } /* faster flag checks in middle */ - for (j = odView[vn].snext>>5; j-- > (odView[vn].sfirst+0x1f)>>5; ) - for (i = 0; odS.redraw[j]; i++) /* skips faster */ - if (odS.redraw[j] & 1L<>5; n-- > (odView[vn].sfirst+0x1f)>>5; ) + for (i = 0; odS.redraw[n]; i++) /* skips faster */ + if (odS.redraw[n] & 1L<
