--- ray/src/hd/rhd_odraw.c 1998/12/23 21:49:43 3.7 +++ ray/src/hd/rhd_odraw.c 2003/02/22 02:07:24 3.13 @@ -1,16 +1,12 @@ -/* Copyright (c) 1998 Silicon Graphics, Inc. */ - #ifndef lint -static char SCCSid[] = "$SunId$ SGI"; +static const char RCSid[] = "$Id: rhd_odraw.c,v 3.13 2003/02/22 02:07:24 greg Exp $"; #endif - /* * Routines for drawing samples using depth buffer checks. */ #include "standard.h" -#include #include #include @@ -25,6 +21,9 @@ static char SCCSid[] = "$SunId$ SGI"; #ifndef SFREEFRAC #define SFREEFRAC 0.2 /* fraction to free at a time */ #endif +#ifndef REDRAWTHRESH +#define REDRAWTHRESH 10240 /* number of samples for dissolve */ +#endif #ifndef MAXFAN #define MAXFAN 32 /* maximum arms in a triangle fan */ #endif @@ -59,12 +58,12 @@ int n; if (odNViews > 0) { /* deallocate view structures */ for (i = odNViews; i--; ) { - free((char *)odView[i].bmap); - free((char *)odView[i].pmap); + free((void *)odView[i].bmap); + free((void *)odView[i].pmap); if (odView[i].emap != NULL) - free((char *)odView[i].emap); + free((void *)odView[i].emap); } - free((char *)odView); + free((void *)odView); odView = NULL; odNViews = 0; } @@ -143,6 +142,7 @@ int n; odView[i].bmap[j].nused = 0; } odView[i].snext = nextsamp; + odView[i].n2redraw = 0; } CLR4ALL(odS.redraw, odS.nsamp); /* clear redraw flags */ for (i = odS.nsamp; i--; ) { /* clear values */ @@ -188,7 +188,7 @@ double prox; if (CHK4(odView[vn].pmap, vh*odView[vn].hhi + hh)) i = bp->first + bp->nsamp; else - i = -1; + i = 0; while (i-- > bp->first) if (hh == odS.ip[i][0] && vh == odS.ip[i][1]) { /* found it! */ /* search free list for it */ @@ -203,11 +203,10 @@ double prox; bp->nused++; goto gotit; } - if (prox >= 0.999*odS.closeness(i)) + if (prox >= 0.99*odS.closeness(i)) return(-1); /* previous sample is fine */ goto gotit; } - DCHECK(i>=-1, WARNING, "pixel in presence map not found in block"); if (bp->free != ENDFREE) { /* allocate from free list */ i = bp->free; if (odS.ip[i][0] >= 0 & odS.ip[i][1] >= 0) @@ -304,6 +303,7 @@ FVECT d, p; else /* else map it now */ tmMapPixels(odS.rgb[id], &odS.brt[id], odS.chr[id], 1); SET4(odS.redraw, id); /* mark for redraw */ + odView[i].n2redraw++; } } @@ -326,6 +326,9 @@ odRedrawAll() /* mark all samples for redraw */ for (i = odS.nsamp; i--; ) if (odS.ip[i][0] >= 0) SET4(odS.redraw, i); + /* not right, but not important */ + for (i = 0; i < odNViews; i++) + odView[i].n2redraw = odView[i].snext - odView[i].sfirst; } @@ -355,8 +358,10 @@ int vn, hmin, vmin, hmax, vmax; for (j = vmin; j <= vmax; j++) { bp = odView[vn].bmap + j*odView[vn].hlow + i; for (k = bp->nsamp; k--; ) - if (odS.ip[bp->first+k][0] >= 0) + if (odS.ip[bp->first+k][0] >= 0) { SET4(odS.redraw, bp->first+k); + odView[vn].n2redraw++; + } } } @@ -373,7 +378,7 @@ GLfloat *dm; if (vn<0 | vn>=odNViews) return; /* too late -- they're gone! */ if (odView[vn].emap != NULL) - free((char *)odView[vn].emap); + free((void *)odView[vn].emap); odView[vn].emap = NULL; odView[vn].dmap = NULL; return; @@ -437,7 +442,9 @@ GLfloat *dm; odUpdate(vn) /* update this view */ int vn; { - register int i, j; + static short primes[] = {9431,6803,4177,2659,1609,887,587,251,47,1}; + int myprime; + register int i, n; DCHECK(vn<0 | vn>=odNViews, CONSISTENCY, "bad view number in odUpdate"); @@ -458,33 +465,51 @@ int vn; return; needmapping &= ~NEWRGB; } - /* this code segment was too slow */ -#if 0 - for (i = odView[vn].sfirst; i < odView[vn].snext; i++) + if (odView[vn].n2redraw <= 0) + return; +#if REDRAWTHRESH + if (odView[vn].n2redraw < REDRAWTHRESH) + goto quickdraw; + /* pick a good prime step size */ + n = odView[vn].snext - odView[vn].sfirst; + for (i = 0; primes[i]<<5 >= n; i++) + ; + while ((myprime = primes[i++]) > 1) + if (n % myprime) + break; + /* dissolve in new samples */ + for (i = odView[vn].sfirst; n-- > 0; i += myprime) { + if (i >= odView[vn].snext) + i -= odView[vn].snext - odView[vn].sfirst; if (CHK4(odS.redraw, i)) { odDrawSamp(vn, i); CLR4(odS.redraw, i); } -#else - /* redraw samples at each end */ - for (i = odView[vn].sfirst; i < odView[vn].sfirst+31; i++) + } + odView[vn].n2redraw = 0; + return; +quickdraw: /* quicker sparse flag checking */ +#endif + /* redraw samples at end */ + for (i = odView[vn].snext-31; i < odView[vn].snext; i++) if (CHK4(odS.redraw, i)) { odDrawSamp(vn, i); CLR4(odS.redraw, i); } - for (i = odView[vn].snext-31; i < odView[vn].snext; i++) + /* faster flag checks in middle */ + for (n = odView[vn].snext>>5; n-- > (odView[vn].sfirst+0x1f)>>5; ) + for (i = 0; odS.redraw[n]; i++) /* skips faster */ + if (odS.redraw[n] & 1L<>5; j-- > (odView[vn].sfirst+0x1f)>>5; ) - for (i = 0; odS.redraw[j]; i++) /* skips faster */ - if (odS.redraw[j] & 1L< 1, CONSISTENCY, "super-unary size in make_arms"); - na = MAXFAN*sz*sz + 0.5; /* keep area constant */ + na = MAXFAN*sz + 0.5; /* keep arc length constant */ if (na < MINFAN) na = MINFAN; hrad = FANSIZE*sz*vp->hhi/vp->hlow; vrad = FANSIZE*sz*vp->vhi/vp->vlow; @@ -628,10 +653,12 @@ blockedge(vp, bi0, bi1) /* check for edge between bl register struct ODview *vp; register int bi0, bi1; { + if (bi1 == bi0) + return(0); /* same block */ if (bi1 < 0) return(1); /* end off view */ if (CHK4(vp->emap, bi1)) - return(1); /* end has edges */ + return(1); /* end block has edges */ if (bi1 == bi0+1 || bi1 == bi0-1 || bi1 == bi0+vp->hlow || bi1 == bi0-vp->hlow) return(0); /* end in adjacent block -- no edges */
