root/radiance/ray/src/hd/rhd_odraw.c
Fri Oct 5 19:19:16 2018 UTC (6 years, 7 months ago) by greg
Changes since 3.18: +33 -33 lines
Diff to previous 3.18 , to selected 3.11
Fri May 20 02:06:39 2011 UTC (13 years, 11 months ago) by greg
Changes since 3.17: +6 -6 lines
Diff to previous 3.17 , to selected 3.11
Fri Jan 7 20:33:02 2005 UTC (20 years, 4 months ago) by greg
Changes since 3.16: +8 -7 lines
Diff to previous 3.16 , to selected 3.11
Thu Jan 1 11:21:55 2004 UTC (21 years, 4 months ago) by schorsch
Changes since 3.15: +96 -52 lines
Diff to previous 3.15 , to selected 3.11
Ansification and prototypes.
Changes since 3.14: +7 -7 lines
Diff to previous 3.14 , to selected 3.11
Tue Mar 4 05:49:21 2003 UTC (22 years, 2 months ago) by greg
Changes since 3.13: +3 -2 lines
Diff to previous 3.13 , to selected 3.11
Sat Feb 22 02:07:24 2003 UTC (22 years, 2 months ago) by greg
Changes since 3.12: +6 -9 lines
Diff to previous 3.12 , to selected 3.11
Mon Mar 8 17:31:49 1999 UTC (26 years, 2 months ago) by gwlarson
Changes since 3.11: +1 -2 lines
Diff to previous 3.11
Revision 3.11 - (view) (download) (annotate) - [selected]
Tue Dec 29 09:51:07 1998 UTC (26 years, 4 months ago) by gwlarson
Changes since 3.10: +43 -15 lines
Diff to previous 3.10
Thu Dec 24 16:18:45 1998 UTC (26 years, 4 months ago) by gwlarson
Changes since 3.9: +4 -4 lines
Diff to previous 3.9 , to selected 3.11
normalized drawing order in odUpdate()
Thu Dec 24 09:34:20 1998 UTC (26 years, 4 months ago) by gwlarson
Changes since 3.8: +1 -1 lines
Diff to previous 3.8 , to selected 3.11
changed make_arms() to keep arc length (rather than area) constant
Thu Dec 24 08:12:57 1998 UTC (26 years, 4 months ago) by gwlarson
Changes since 3.7: +10 -7 lines
Diff to previous 3.7 , to selected 3.11
fixed minor oversight in blockend()
Wed Dec 23 21:49:43 1998 UTC (26 years, 4 months ago) by gwlarson
Diff to previous 3.6 , to selected 3.11
changed edge clipping to include boundary and avoid black edges
Wed Dec 23 17:42:24 1998 UTC (26 years, 4 months ago) by gwlarson
Changes since 3.5: +39 -16 lines
Diff to previous 3.5 , to selected 3.11
improved edge precheck
added odRedrawAll() routine
Tue Dec 22 17:05:54 1998 UTC (26 years, 4 months ago) by gwlarson
Changes since 3.4: +24 -2 lines
Diff to previous 3.4 , to selected 3.11
Mon Dec 21 14:05:43 1998 UTC (26 years, 4 months ago) by gwlarson
Changes since 3.3: +16 -31 lines
Diff to previous 3.3 , to selected 3.11
made odUpdate() simpler and faster
Mon Dec 21 13:17:00 1998 UTC (26 years, 4 months ago) by gwlarson
Changes since 3.2: +20 -5 lines
Diff to previous 3.2 , to selected 3.11
Sun Dec 20 20:37:53 1998 UTC (26 years, 4 months ago) by gwlarson
Changes since 3.1: +68 -27 lines
Diff to previous 3.1 , to selected 3.11
Fri Dec 18 11:55:19 1998 UTC (26 years, 4 months ago) by gwlarson
Diff to selected 3.11
