root/radiance/ray/src/hd/rhd_glx2.c
Revision: 3.3
Committed: Fri Nov 5 03:31:37 2004 UTC (20 years, 6 months ago) by greg
Changes since 3.2: +1 -1 lines
State: FILE REMOVED
2 static const char RCSid[] = "$Id: rhd_glx2.c,v 3.2 2003/07/21 22:30:18 schorsch Exp $";
5 * OpenGL GLX driver for holodeck display.
6 * Based on standard GLX driver.
7 */
8
9 #include "standard.h"
10 #include "rhd_sample.h"
11
12 #include <sys/types.h>
13 #include <GL/glx.h>
14 #include <GL/glu.h>
15 #include <X11/extensions/SGIStereo.h>
16 #include <gl/get.h>
17
18 #include "x11icon.h"
19
20 #ifndef RAYQLEN
21 #define RAYQLEN 50000 /* max. rays to queue before flush */
22 #endif
23
24 #ifndef FEQ
25 #define FEQ(a,b) ((a)-(b) <= FTINY && (a)-(b) >= -FTINY)
26 #endif
27
28 #define GAMMA 1.4 /* default gamma correction */
29
30 #define MOVPCT 7 /* percent distance to move /frame */
31 #define MOVDIR(b) ((b)==Button1 ? 1 : (b)==Button2 ? 0 : -1)
32 #define MOVDEG (-5) /* degrees to orbit CW/down /frame */
33 #define MOVORB(s) ((s)&ShiftMask ? 1 : (s)&ControlMask ? -1 : 0)
34
35 #ifndef TARGETFPS
36 #define TARGETFPS 4.0 /* target frames/sec during motion */
37 #endif
38
39 #define MINWIDTH 480 /* minimum stereo window width */
40 #define MINHEIGHT 400 /* minimum stereo window height */
41
42 #define VIEWDIST 356 /* assumed viewing distance (mm) */
43
44 #define BORWIDTH 5 /* border width */
45
46 #define setstereobuf(bid) (glXWaitGL(), \
47 XSGISetStereoBuffer(ourdisplay, gwind, bid), \
48 glXWaitX())
49
50 #define ourscreen DefaultScreen(ourdisplay)
51 #define ourroot RootWindow(ourdisplay,ourscreen)
52 #define ourmask (StructureNotifyMask|ExposureMask|KeyPressMask|\
53 ButtonPressMask|ButtonReleaseMask)
54
55 #define levptr(etype) ((etype *)&currentevent)
56
57 struct driver odev; /* global device driver structure */
58
59 static VIEW vwright; /* right eye view */
60
61 static int rayqleft = 0; /* rays left to queue before flush */
62
63 static XEvent currentevent; /* current event */
64
65 static int mapped = 0; /* window is mapped? */
66 static unsigned long ourblack=0, ourwhite=~0;
67
68 static Display *ourdisplay = NULL; /* our display */
69 static XVisualInfo *ourvinf; /* our visual information */
70 static Window gwind = 0; /* our graphics window */
71 static GLXContext gctx; /* our GLX context */
72
73 static double pwidth, pheight; /* pixel dimensions (mm) */
74
75 static int inpresflags; /* input result flags */
76
77 static int headlocked = 0; /* lock vertical motion */
78
79 static int resizewindow(), getevent(), getkey(), moveview(), eyeview(),
80 wipeclean(), setglpersp(), getmove(), fixwindow(),
81 pushright(), popright(), mytmflags();
82
83 extern time_t time();
84 extern long getmonitor();
85
86
87 dev_open(id) /* initialize GLX driver */
88 char *id;
89 {
90 extern char *getenv();
91 static RGBPRIMS myprims = STDPRIMS;
92 static int atlBest[] = {GLX_RGBA, GLX_RED_SIZE,8,
93 GLX_GREEN_SIZE,8, GLX_BLUE_SIZE,8,
94 GLX_DEPTH_SIZE,15, None};
95 char *ev;
96 double gamval = GAMMA;
97 RGBPRIMP dpri = stdprims;
98 int firstevent, firsterror;
99 XSetWindowAttributes ourwinattr;
100 XWMHints ourxwmhints;
101 XSizeHints oursizhints;
102 /* open display server */
103 ourdisplay = XOpenDisplay(NULL);
104 if (ourdisplay == NULL)
105 error(USER, "cannot open X-windows; DISPLAY variable set?\n");
106 switch (XSGIQueryStereoMode(ourdisplay, ourroot)) {
107 case STEREO_TOP:
108 case STEREO_BOTTOM:
109 break;
110 case STEREO_OFF:
111 error(USER,
112 "wrong video mode: run \"/usr/gfx/setmon -n STR_TOP\" first");
113 case X_STEREO_UNSUPPORTED:
114 error(USER, "stereo mode not supported on this screen");
115 default:
116 error(INTERNAL, "unknown stereo mode");
117 }
118 /* find a usable visual */
119 ourvinf = glXChooseVisual(ourdisplay, ourscreen, atlBest);
120 if (ourvinf == NULL)
121 error(USER, "no suitable visuals available");
122 /* get a context */
123 gctx = glXCreateContext(ourdisplay, ourvinf, NULL, GL_TRUE);
124 /* set gamma and tone mapping */
125 if ((ev = XGetDefault(ourdisplay, "radiance", "gamma")) != NULL
126 || (ev = getenv("DISPLAY_GAMMA")) != NULL)
127 gamval = atof(ev);
128 if ((ev = getenv("DISPLAY_PRIMARIES")) != NULL &&
129 sscanf(ev, "%f %f %f %f %f %f %f %f",
130 &myprims[RED][CIEX],&myprims[RED][CIEY],
131 &myprims[GRN][CIEX],&myprims[GRN][CIEY],
132 &myprims[BLU][CIEX],&myprims[BLU][CIEY],
133 &myprims[WHT][CIEX],&myprims[WHT][CIEY]) >= 6)
134 dpri = myprims;
135 if (tmInit(mytmflags(), dpri, gamval) == NULL)
136 error(SYSTEM, "not enough memory in dev_open");
137 /* open window */
138 ourwinattr.background_pixel = ourblack;
139 ourwinattr.border_pixel = ourblack;
140 ourwinattr.event_mask = ourmask;
141 /* this is stupid */
142 ourwinattr.colormap = XCreateColormap(ourdisplay, ourroot,
143 ourvinf->visual, AllocNone);
144 gwind = XCreateWindow(ourdisplay, ourroot, 0, 0,
145 DisplayWidth(ourdisplay,ourscreen)-2*BORWIDTH,
146 (DisplayHeight(ourdisplay,ourscreen)-2*BORWIDTH)/2,
147 BORWIDTH, ourvinf->depth, InputOutput, ourvinf->visual,
148 CWBackPixel|CWBorderPixel|CWColormap|CWEventMask, &ourwinattr);
149 if (gwind == 0)
150 error(SYSTEM, "cannot create window\n");
151 XStoreName(ourdisplay, gwind, id);
152 /* set window manager hints */
153 ourxwmhints.flags = InputHint|IconPixmapHint;
154 ourxwmhints.input = True;
155 ourxwmhints.icon_pixmap = XCreateBitmapFromData(ourdisplay,
156 gwind, x11icon_bits, x11icon_width, x11icon_height);
157 XSetWMHints(ourdisplay, gwind, &ourxwmhints);
158 oursizhints.min_width = MINWIDTH;
159 oursizhints.min_height = MINHEIGHT/2;
160 oursizhints.max_width = DisplayWidth(ourdisplay,ourscreen)-2*BORWIDTH;
161 oursizhints.max_height = (DisplayHeight(ourdisplay,ourscreen) -
162 2*BORWIDTH)/2;
163 oursizhints.flags = PMinSize|PMaxSize;
164 XSetNormalHints(ourdisplay, gwind, &oursizhints);
165 /* set GLX context */
166 glXMakeCurrent(ourdisplay, gwind, gctx);
167 glEnable(GL_DEPTH_TEST);
168 glDepthFunc(GL_LEQUAL);
169 glShadeModel(GL_SMOOTH);
170 glDisable(GL_DITHER);
171 glDisable(GL_CULL_FACE);
172 /* figure out sensible view */
173 pwidth = (double)DisplayWidthMM(ourdisplay, ourscreen) /
174 DisplayWidth(ourdisplay, ourscreen);
175 pheight = 2.0 * (double)DisplayHeightMM(ourdisplay, ourscreen) /
176 DisplayHeight(ourdisplay, ourscreen);
177 odev.v = stdview;
178 odev.v.type = VT_PER;
179 /* map the window */
180 setstereobuf(STEREO_BUFFER_LEFT);
181 XMapWindow(ourdisplay, gwind);
182 dev_input(); /* sets size and view angles */
183 /* allocate our samples */
184 if (!smInit(DisplayWidth(ourdisplay,ourscreen) *
185 DisplayHeight(ourdisplay,ourscreen) / 10))
186 error(SYSTEM, "insufficient memory for value storage");
187 odev.name = id;
188 odev.ifd = ConnectionNumber(ourdisplay);
189 }
190
191
192 dev_close() /* close our display and free resources */
193 {
194 smInit(0);
195 glXMakeCurrent(ourdisplay, None, NULL);
196 glXDestroyContext(ourdisplay, gctx);
197 XDestroyWindow(ourdisplay, gwind);
198 gwind = 0;
199 XCloseDisplay(ourdisplay);
200 ourdisplay = NULL;
201 tmDone(NULL);
202 odev.v.type = 0;
203 odev.hres = odev.vres = 0;
204 odev.ifd = -1;
205 }
206
207
208 dev_clear() /* clear our representation */
209 {
210 smInit(rsL.maxsamp);
211 wipeclean();
212 rayqleft = 0; /* hold off update */
213 }
214
215
216 int
217 dev_view(nv) /* assign new driver view */
218 register VIEW *nv;
219 {
220 double d;
221
222 if (nv->type != VT_PER || /* check view legality */
223 nv->horiz > 160. || nv->vert > 160.) {
224 error(COMMAND, "illegal view type/angle");
225 nv->type = odev.v.type;
226 nv->horiz = odev.v.horiz;
227 nv->vert = odev.v.vert;
228 return(0);
229 }
230 if (nv != &odev.v) {
231 if (!FEQ(nv->horiz,odev.v.horiz) || /* resize window? */
232 !FEQ(nv->vert,odev.v.vert)) {
233 int dw = DisplayWidth(ourdisplay,ourscreen);
234 int dh = DisplayHeight(ourdisplay,ourscreen)/2;
235
236 dw -= 25; /* for window frame */
237 dh -= 50*2;
238 odev.hres = 2.*VIEWDIST/pwidth *
239 tan(PI/180./2.*nv->horiz);
240 odev.vres = 2.*VIEWDIST/pheight *
241 tan(PI/180./2.*nv->vert);
242 if (odev.hres > dw) {
243 odev.vres = dw * odev.vres / odev.hres;
244 odev.hres = dw;
245 }
246 if (odev.vres > dh) {
247 odev.hres = dh * odev.hres / odev.vres;
248 odev.vres = dh;
249 }
250 XResizeWindow(ourdisplay, gwind, odev.hres, odev.vres);
251 dev_input(); /* get resize event */
252 }
253 odev.v = *nv; /* setview() already called */
254 setglpersp(&odev.v);
255 vwright = *nv;
256 d = eyesepdist / sqrt(nv->hn2);
257 VSUM(vwright.vp, nv->vp, nv->hvec, d);
258 /* setview(&vwright); -- Unnecessary */
259 checkglerr("setting view");
260 }
261 wipeclean();
262 return(1);
263 }
264
265
266 dev_auxcom(cmd, args) /* process an auxiliary command */
267 char *cmd, *args;
268 {
269 sprintf(errmsg, "%s: unknown command", cmd);
270 error(COMMAND, errmsg);
271 }
272
273
274 VIEW *
275 dev_auxview(n, hvres) /* return nth auxiliary view */
276 int n;
277 int hvres[2];
278 {
279 hvres[0] = odev.hres; hvres[1] = odev.vres;
280 if (n == 0)
281 return(&odev.v);
282 if (n == 1)
283 return(&vwright);
284 return(NULL);
285 }
286
287
288 int
289 dev_input() /* get X11 input */
290 {
291 inpresflags = 0;
292
293 do
294 getevent();
295
296 while (XQLength(ourdisplay) > 0);
297
298 return(inpresflags);
299 }
300
301
302 dev_value(c, p, v) /* add a pixel value to our quadtree */
303 COLR c;
304 FVECT p, v;
305 {
306 smNewsamp(c, p, v); /* add to display representation */
307 if (!--rayqleft)
308 dev_flush(); /* flush output */
309 }
310
311
312 int
313 dev_flush() /* flush output */
314 {
315 pushright(); /* update right eye */
316 glClear(GL_DEPTH_BUFFER_BIT);
317 smUpdate(&vwright, 100);
318 popright(); /* update left eye */
319 glClear(GL_DEPTH_BUFFER_BIT);
320 smUpdate(&odev.v, 100);
321 glFlush(); /* flush OGL */
322 checkglerr("flushing display");
323 rayqleft = RAYQLEN;
324 return(XPending(ourdisplay)); /* flush X11 and return # pending */
325 }
326
327
328 checkglerr(where) /* check for GL or GLU error */
329 char *where;
330 {
331 register GLenum errcode;
332
333 while ((errcode = glGetError()) != GL_NO_ERROR) {
334 sprintf(errmsg, "OpenGL error %s: %s",
335 where, gluErrorString(errcode));
336 error(WARNING, errmsg);
337 }
338 }
339
340
341 static
342 pushright() /* push on right view */
343 {
344 double d;
345
346 setstereobuf(STEREO_BUFFER_RIGHT);
347 glMatrixMode(GL_MODELVIEW);
348 glPushMatrix();
349 d = -eyesepdist / sqrt(odev.v.hn2);
350 glTranslated(d*odev.v.hvec[0], d*odev.v.hvec[1], d*odev.v.hvec[2]);
351 }
352
353
354 static
355 popright() /* pop off right view */
356 {
357 glMatrixMode(GL_MODELVIEW);
358 glPopMatrix();
359 setstereobuf(STEREO_BUFFER_LEFT);
360 }
361
362
363 static int
364 mytmflags() /* figure out tone mapping flags */
365 {
366 extern char *progname;
367 register char *cp, *tail;
368 /* find basic name */
369 for (cp = tail = progname; *cp; cp++)
370 if (*cp == '/')
371 tail = cp+1;
372 for (cp = tail; *cp && *cp != '.'; cp++)
373 ;
374 if (cp-tail == 3 && !strncmp(tail, "glx2", 3))
375 return(TM_F_CAMERA|TM_F_NOSTDERR);
376 if (cp-tail == 4 && !strncmp(tail, "glx2h", 4))
377 return(TM_F_HUMAN|TM_F_NOSTDERR);
378 error(USER, "illegal driver name");
379 }
380
381
382 static
383 getevent() /* get next event */
384 {
385 XNextEvent(ourdisplay, levptr(XEvent));
386 switch (levptr(XEvent)->type) {
387 case ConfigureNotify:
388 resizewindow(levptr(XConfigureEvent));
389 break;
390 case UnmapNotify:
391 mapped = 0;
392 break;
393 case MapNotify:
394 mapped = 1;
395 break;
396 case Expose:
397 fixwindow(levptr(XExposeEvent));
398 break;
399 case KeyPress:
400 getkey(levptr(XKeyPressedEvent));
401 break;
402 case ButtonPress:
403 getmove(levptr(XButtonPressedEvent));
404 break;
405 }
406 }
407
408
409 static
410 draw3dline(wp) /* draw 3d line in world coordinates */
411 register FVECT wp[2];
412 {
413 glVertex3d(wp[0][0], wp[0][1], wp[0][2]);
414 glVertex3d(wp[1][0], wp[1][1], wp[1][2]);
415 }
416
417
418 static
419 draw_grids() /* draw holodeck section grids */
420 {
421 static BYTE gridrgba[4] = {0x0, 0xff, 0xff, 0x00};
422
423 if (!mapped)
424 return;
425 glColor4ub(gridrgba[0], gridrgba[1], gridrgba[2], gridrgba[3]);
426 glBegin(GL_LINES); /* draw each grid line */
427 gridlines(draw3dline);
428 glEnd();
429 }
430
431
432 static
433 moveview(dx, dy, mov, orb) /* move our view */
434 int dx, dy, mov, orb;
435 {
436 VIEW nv;
437 FVECT odir, v1;
438 double d;
439 register int li;
440 /* start with old view */
441 nv = odev.v;
442 /* change view direction */
443 if (viewray(v1, odir, &odev.v,
444 (dx+.5)/odev.hres, (dy+.5)/odev.vres) < -FTINY)
445 return(0); /* outside view */
446 if (mov | orb) {
447 if ((li = smFindsamp(v1, odir)) < 0)
448 return(0); /* not on window */
449 VSUM(odir, rsL.wp[li], nv.vp, -1.);
450 } else
451 VCOPY(nv.vdir, odir);
452 if (orb && mov) { /* orbit left/right */
453 spinvector(odir, odir, nv.vup, d=MOVDEG*PI/180.*mov);
454 VSUM(nv.vp, rsL.wp[li], odir, -1.);
455 spinvector(nv.vdir, nv.vdir, nv.vup, d);
456 } else if (orb) { /* orbit up/down */
457 fcross(v1, odir, nv.vup);
458 if (normalize(v1) == 0.)
459 return(0);
460 spinvector(odir, odir, v1, d=MOVDEG*PI/180.*orb);
461 VSUM(nv.vp, rsL.wp[li], odir, -1.);
462 spinvector(nv.vdir, nv.vdir, v1, d);
463 } else if (mov) { /* move forward/backward */
464 d = MOVPCT/100. * mov;
465 VSUM(nv.vp, nv.vp, odir, d);
466 }
467 if (!mov ^ !orb && headlocked) { /* restore head height */
468 VSUM(v1, odev.v.vp, nv.vp, -1.);
469 d = DOT(v1, odev.v.vup);
470 VSUM(nv.vp, nv.vp, odev.v.vup, d);
471 }
472 if (setview(&nv) != NULL)
473 return(0); /* illegal view */
474 dev_view(&nv);
475 inpresflags |= DFL(DC_SETVIEW);
476 return(1);
477 }
478
479
480 static
481 getmove(ebut) /* get view change */
482 XButtonPressedEvent *ebut;
483 {
484 int movdir = MOVDIR(ebut->button);
485 int movorb = MOVORB(ebut->state);
486 int qlevel = 100;
487 time_t lasttime, thistime;
488 int nframes;
489 Window rootw, childw;
490 int rootx, rooty, wx, wy;
491 unsigned int statemask;
492
493 XNoOp(ourdisplay);
494
495 lasttime = time(0); nframes = 0;
496 while (!XCheckMaskEvent(ourdisplay,
497 ButtonReleaseMask, levptr(XEvent))) {
498
499 if (!XQueryPointer(ourdisplay, gwind, &rootw, &childw,
500 &rootx, &rooty, &wx, &wy, &statemask))
501 break; /* on another screen */
502
503 if (!moveview(wx, odev.vres-1-wy, movdir, movorb)) {
504 sleep(1);
505 lasttime++;
506 continue;
507 }
508 pushright();
509 draw_grids();
510 smUpdate(&vwright, qlevel);
511 popright();
512 draw_grids();
513 smUpdate(&odev.v, qlevel);
514 glFlush();
515 checkglerr("moving view");
516 nframes++;
517 thistime = time(0);
518 if (thistime - lasttime >= 3 ||
519 nframes > (int)(3*3*TARGETFPS)) {
520 qlevel = thistime<=lasttime ? 1000 :
521 (int)((double)nframes/(thistime-lasttime)
522 / TARGETFPS * qlevel + 0.5);
523 lasttime = thistime; nframes = 0;
524 if (qlevel > 100) {
525 if (qlevel > 300) { /* put on the brakes */
526 sleep(1);
527 lasttime++;
528 }
529 qlevel = 100;
530 } else if (qlevel < 1)
531 qlevel = 1;
532 }
533 }
534 if (!(inpresflags & DFL(DC_SETVIEW))) { /* do final motion */
535 movdir = MOVDIR(levptr(XButtonReleasedEvent)->button);
536 wx = levptr(XButtonReleasedEvent)->x;
537 wy = levptr(XButtonReleasedEvent)->y;
538 moveview(wx, odev.vres-1-wy, movdir, movorb);
539 }
540 }
541
542
543 static
544 setglpersp(vp) /* set perspective view in GL */
545 register VIEW *vp;
546 {
547 double d, xmin, xmax, ymin, ymax, zmin, zmax;
548
549 zmin = 0.1;
550 zmax = 1000.;
551 if (odev.v.vfore > FTINY)
552 zmin = odev.v.vfore;
553 if (odev.v.vaft > FTINY)
554 zmax = odev.v.vaft;
555 xmax = zmin * tan(PI/180./2. * odev.v.horiz);
556 xmin = -xmax;
557 d = odev.v.hoff * (xmax - xmin);
558 xmin += d; xmax += d;
559 ymax = zmin * tan(PI/180./2. * odev.v.vert);
560 ymin = -ymax;
561 d = odev.v.voff * (ymax - ymin);
562 ymin += d; ymax += d;
563 /* set view matrix */
564 glMatrixMode(GL_PROJECTION);
565 glLoadIdentity();
566 glFrustum(xmin, xmax, ymin, ymax, zmin, zmax);
567 gluLookAt(odev.v.vp[0], odev.v.vp[1], odev.v.vp[2],
568 odev.v.vp[0] + odev.v.vdir[0],
569 odev.v.vp[1] + odev.v.vdir[1],
570 odev.v.vp[2] + odev.v.vdir[2],
571 odev.v.vup[0], odev.v.vup[1], odev.v.vup[2]);
572 }
573
574
575 wipeclean() /* prepare for redraw */
576 {
577 setstereobuf(STEREO_BUFFER_RIGHT);
578 glClear(GL_DEPTH_BUFFER_BIT);
579 setstereobuf(STEREO_BUFFER_LEFT);
580 glClear(GL_DEPTH_BUFFER_BIT);
581 smClean();
582 }
583
584
585 static
586 getkey(ekey) /* get input key */
587 register XKeyPressedEvent *ekey;
588 {
589 int n;
590 char buf[8];
591
592 n = XLookupString(ekey, buf, sizeof(buf), NULL, NULL);
593 if (n != 1)
594 return;
595 switch (buf[0]) {
596 case 'h': /* turn on height motion lock */
597 headlocked = 1;
598 return;
599 case 'H': /* turn off height motion lock */
600 headlocked = 0;
601 return;
602 case 'l': /* retrieve last view */
603 inpresflags |= DFL(DC_LASTVIEW);
604 return;
605 case 'p': /* pause computation */
606 inpresflags |= DFL(DC_PAUSE);
607 return;
608 case 'v': /* spit out view */
609 inpresflags |= DFL(DC_GETVIEW);
610 return;
611 case '\n':
612 case '\r': /* resume computation */
613 inpresflags |= DFL(DC_RESUME);
614 return;
615 case CTRL('R'): /* redraw screen */
616 wipeclean();
617 return;
618 case CTRL('L'): /* refresh from server */
619 if (inpresflags & DFL(DC_REDRAW))
620 return;
621 eyeview(VWRIGHT);
622 glClear(GL_COLOR_BUFFER_BIT | GL_DEPTH_BUFFER_BIT);
623 draw_grids();
624 eyeview(VWLEFT);
625 glClear(GL_COLOR_BUFFER_BIT | GL_DEPTH_BUFFER_BIT);
626 draw_grids();
627 glFlush();
628 smInit(rsL.maxsamp); /* get rid of old values */
629 inpresflags |= DFL(DC_REDRAW); /* resend values from server */
630 rayqleft = 0; /* hold off update */
631 return;
632 case 'K': /* kill rtrace process(es) */
633 inpresflags |= DFL(DC_KILL);
634 break;
635 case 'R': /* restart rtrace */
636 inpresflags |= DFL(DC_RESTART);
637 break;
638 case 'C': /* clobber holodeck */
639 inpresflags |= DFL(DC_CLOBBER);
640 break;
641 case 'q': /* quit the program */
642 inpresflags |= DFL(DC_QUIT);
643 return;
644 default:
645 XBell(ourdisplay, 0);
646 return;
647 }
648 }
649
650
651 static
652 fixwindow(eexp) /* repair damage to window */
653 register XExposeEvent *eexp;
654 {
655 if (odev.hres == 0 | odev.vres == 0) { /* first exposure */
656 resizewindow((XConfigureEvent *)eexp);
657 return;
658 }
659 if (eexp->count) /* wait for final exposure */
660 return;
661 wipeclean(); /* clear depth */
662 }
663
664
665 static
666 resizewindow(ersz) /* resize window */
667 register XConfigureEvent *ersz;
668 {
669 /* glViewport(0, 0, ersz->width, ersz->height); */
670
671 if (ersz->width == odev.hres && ersz->height == odev.vres)
672 return;
673
674 odev.hres = ersz->width;
675 odev.vres = ersz->height;
676
677 odev.v.horiz = 2.*180./PI * atan(0.5/VIEWDIST*pwidth*odev.hres);
678 odev.v.vert = 2.*180./PI * atan(0.5/VIEWDIST*pheight*odev.vres);
679
680 inpresflags |= DFL(DC_SETVIEW);
681 }
