--- ray/src/hd/rhd_glx1.c 2004/03/28 20:33:13 3.4 +++ ray/src/hd/rhd_glx1.c 2021/02/12 00:53:56 3.11 @@ -1,5 +1,5 @@ #ifndef lint -static const char RCSid[] = "$Id: rhd_glx1.c,v 3.4 2004/03/28 20:33:13 schorsch Exp $"; +static const char RCSid[] = "$Id: rhd_glx1.c,v 3.11 2021/02/12 00:53:56 greg Exp $"; #endif /* * OpenGL GLX driver for holodeck display. @@ -21,10 +21,6 @@ static const char RCSid[] = "$Id: rhd_glx1.c,v 3.4 200 #define RAYQLEN 50000 /* max. rays to queue before flush */ #endif -#ifndef FEQ -#define FEQ(a,b) ((a)-(b) <= FTINY && (a)-(b) >= -FTINY) -#endif - #ifndef MAXCONE #define MAXCONE 16 /* number of different cone sizes */ #endif @@ -61,6 +57,8 @@ static const char RCSid[] = "$Id: rhd_glx1.c,v 3.4 200 struct driver odev; /* global device driver structure */ +TMstruct *tmGlobal; /* global tone-mapping structure */ + char odev_args[64]; /* command arguments */ static XEvent currentevent; /* current event */ @@ -102,7 +100,7 @@ static void fixwindow(XExposeEvent *eexp); static void resizewindow(XConfigureEvent *ersz); -extern void +void dev_open( char *id ) @@ -142,7 +140,8 @@ dev_open( &myprims[BLU][CIEX],&myprims[BLU][CIEY], &myprims[WHT][CIEX],&myprims[WHT][CIEY]) >= 6) dpri = myprims; - if (tmInit(mytmflags(), dpri, gamval) == NULL) + tmGlobal = tmInit(mytmflags(), dpri, gamval); + if (tmGlobal == NULL) error(SYSTEM, "not enough memory in dev_open"); /* open window */ ourwinattr.background_pixel = ourblack; @@ -201,7 +200,7 @@ dev_open( } -extern void +void dev_close(void) /* close our display and free resources */ { glXMakeCurrent(ourdisplay, None, NULL); @@ -211,7 +210,7 @@ dev_close(void) /* close our display and free resour XCloseDisplay(ourdisplay); ourdisplay = NULL; qtFreeLeaves(); - tmDone(NULL); + tmDone(tmGlobal); freecones(); odev.v.type = 0; odev.hres = odev.vres = 0; @@ -219,7 +218,7 @@ dev_close(void) /* close our display and free resour } -extern void +void dev_clear(void) /* clear our quadtree */ { qtCompost(100); @@ -228,9 +227,9 @@ dev_clear(void) /* clear our quadtree */ } -extern int +int dev_view( /* assign new driver view */ - register VIEW *nv + VIEW *nv ) { if (nv->type == VT_PAR || /* check view legality */ @@ -247,8 +246,8 @@ dev_view( /* assign new driver view */ return(0); } if (nv != &odev.v) { - if (!FEQ(nv->horiz,odev.v.horiz) || /* resize window? */ - !FEQ(nv->vert,odev.v.vert)) { + if (!FABSEQ(nv->horiz,odev.v.horiz) || /* resize window? */ + !FABSEQ(nv->vert,odev.v.vert)) { int dw = DisplayWidth(ourdisplay,ourscreen); int dh = DisplayHeight(ourdisplay,ourscreen); @@ -281,16 +280,17 @@ dev_view( /* assign new driver view */ } -extern void +void dev_section( /* add octree for geometry rendering */ - char *ofn + char *gfn, + char *pfn ) { /* unimplemented */ } -extern void +void dev_auxcom( /* process an auxiliary command */ char *cmd, char *args @@ -301,7 +301,7 @@ dev_auxcom( /* process an auxiliary command */ } -extern VIEW * +VIEW * dev_auxview( /* return nth auxiliary view */ int n, int hvres[2] @@ -314,7 +314,7 @@ dev_auxview( /* return nth auxiliary view */ } -extern int +int dev_input(void) /* get X11 input */ { inpresflags = 0; @@ -328,7 +328,7 @@ dev_input(void) /* get X11 input */ } -extern int +int dev_flush(void) /* flush output */ { qtUpdate(); @@ -338,14 +338,14 @@ dev_flush(void) /* flush output */ } -extern void +void dev_cone( /* render a cone in view coordinates */ - BYTE rgb[3], + uby8 rgb[3], FVECT ip, double rad ) { - register int ci, j; + int ci, j; double apexh, basez; /* is window mapped? */ if (!mapped) @@ -383,7 +383,7 @@ static int mytmflags(void) /* figure out tone mapping flags */ { extern char *progname; - register char *cp, *tail; + char *cp, *tail; /* find basic name */ for (cp = tail = progname; *cp; cp++) if (*cp == '/') @@ -402,7 +402,7 @@ mytmflags(void) /* figure out tone mapping flags */ static void initcones(void) /* initialize cone vertices */ { - register int i, j; + int i, j; double minrad, d; if (cone[0].nverts) @@ -429,7 +429,7 @@ initcones(void) /* initialize cone vertices */ static void freecones(void) /* free cone vertices */ { - register int i; + int i; for (i = MAXCONE; i--; ) if (cone[i].nverts) { @@ -461,7 +461,14 @@ getevent(void) /* get next event */ getkey(levptr(XKeyPressedEvent)); break; case ButtonPress: - getmove(levptr(XButtonPressedEvent)); + switch (levptr(XButtonPressedEvent)->button) { + case Button4: /* wheel up */ + case Button5: /* wheel down */ + break; + default: + getmove(levptr(XButtonPressedEvent)); + break; + } break; } } @@ -469,7 +476,7 @@ getevent(void) /* get next event */ static void draw3dline( /* draw 3d line in world coordinates */ - register FVECT wp[2] + FVECT wp[2] ) { glVertex3d(wp[0][0], wp[0][1], wp[0][2]); @@ -480,7 +487,7 @@ draw3dline( /* draw 3d line in world coordinates */ static void draw_grids(void) /* draw holodeck section grids */ { - static BYTE gridrgba[4] = {0x0, 0xff, 0xff, 0x00}; + static uby8 gridrgba[4] = {0x0, 0xff, 0xff, 0x00}; double xmin, xmax, ymin, ymax, zmin, zmax; double d; /* can we even do it? */ @@ -534,7 +541,7 @@ moveview( /* move our view */ VIEW nv; FVECT odir, v1; double d; - register int li; + int li; /* start with old view */ nv = odev.v; /* change view direction */ @@ -552,12 +559,11 @@ moveview( /* move our view */ VSUM(nv.vp, qtL.wp[li], odir, -1.); spinvector(nv.vdir, nv.vdir, nv.vup, d); } else if (orb) { /* orbit up/down */ - fcross(v1, odir, nv.vup); - if (normalize(v1) == 0.) + if (geodesic(odir, odir, nv.vup, + d=MOVDEG*PI/180.*orb, GEOD_RAD) == 0.0) return(0); - spinvector(odir, odir, v1, d=MOVDEG*PI/180.*orb); VSUM(nv.vp, qtL.wp[li], odir, -1.); - spinvector(nv.vdir, nv.vdir, v1, d); + geodesic(nv.vdir, nv.vdir, nv.vup, d, GEOD_RAD); } else if (mov) { /* move forward/backward */ d = MOVPCT/100. * mov; VSUM(nv.vp, nv.vp, odir, d); @@ -620,7 +626,7 @@ getmove( /* get view change */ static void getkey( /* get input key */ - register XKeyPressedEvent *ekey + XKeyPressedEvent *ekey ) { int n; @@ -692,7 +698,7 @@ getkey( /* get input key */ static void fixwindow( /* repair damage to window */ - register XExposeEvent *eexp + XExposeEvent *eexp ) { int xmin, xmax, ymin, ymax; @@ -718,7 +724,7 @@ fixwindow( /* repair damage to window */ static void resizewindow( /* resize window */ - register XConfigureEvent *ersz + XConfigureEvent *ersz ) { glViewport(0, 0, ersz->width, ersz->height);
