--- ray/src/hd/rhd_glx1.c 2003/07/21 22:30:18 3.2 +++ ray/src/hd/rhd_glx1.c 2006/06/07 17:52:04 3.6 @@ -1,5 +1,5 @@ #ifndef lint -static const char RCSid[] = "$Id: rhd_glx1.c,v 3.2 2003/07/21 22:30:18 schorsch Exp $"; +static const char RCSid[] = "$Id: rhd_glx1.c,v 3.6 2006/06/07 17:52:04 schorsch Exp $"; #endif /* * OpenGL GLX driver for holodeck display. @@ -9,9 +9,12 @@ static const char RCSid[] = "$Id: rhd_glx1.c,v 3.2 200 #include "standard.h" #include +#include +#include "platform.h" #include "rhd_qtree.h" - +#include "rhdriver.h" +#include "rhdisp.h" #include "x11icon.h" #ifndef RAYQLEN @@ -58,6 +61,8 @@ static const char RCSid[] = "$Id: rhd_glx1.c,v 3.2 200 struct driver odev; /* global device driver structure */ +TMstruct *tmGlobal; /* global tone-mapping structure */ + char odev_args[64]; /* command arguments */ static XEvent currentevent; /* current event */ @@ -85,13 +90,24 @@ static int inpresflags; /* input result flags */ static int headlocked = 0; /* lock vertical motion */ -static int resizewindow(), getevent(), getkey(), moveview(), - initcones(), freecones(), - getmove(), fixwindow(), mytmflags(); +static int mytmflags(void); +static void initcones(void); +static void freecones(void); +static void getevent(void); +static void draw3dline(FVECT wp[2]); +static void draw_grids(void); +static int moveview(int dx, int dy, int mov, int orb); +static void getmove(XButtonPressedEvent *ebut); +static void getkey(XKeyPressedEvent *ekey); +static void fixwindow(XExposeEvent *eexp); +static void resizewindow(XConfigureEvent *ersz); -dev_open(id) /* initialize X11 driver */ -char *id; + +extern void +dev_open( + char *id +) { extern char *getenv(); static RGBPRIMS myprims = STDPRIMS; @@ -128,7 +144,8 @@ char *id; &myprims[BLU][CIEX],&myprims[BLU][CIEY], &myprims[WHT][CIEX],&myprims[WHT][CIEY]) >= 6) dpri = myprims; - if (tmInit(mytmflags(), dpri, gamval) == NULL) + tmGlobal = tmInit(mytmflags(), dpri, gamval); + if (tmGlobal == NULL) error(SYSTEM, "not enough memory in dev_open"); /* open window */ ourwinattr.background_pixel = ourblack; @@ -187,7 +204,8 @@ char *id; } -dev_close() /* close our display and free resources */ +extern void +dev_close(void) /* close our display and free resources */ { glXMakeCurrent(ourdisplay, None, NULL); glXDestroyContext(ourdisplay, gctx); @@ -196,7 +214,7 @@ dev_close() /* close our display and free resources XCloseDisplay(ourdisplay); ourdisplay = NULL; qtFreeLeaves(); - tmDone(NULL); + tmDone(tmGlobal); freecones(); odev.v.type = 0; odev.hres = odev.vres = 0; @@ -204,7 +222,8 @@ dev_close() /* close our display and free resources } -dev_clear() /* clear our quadtree */ +extern void +dev_clear(void) /* clear our quadtree */ { qtCompost(100); glClear(GL_DEPTH_BUFFER_BIT); @@ -212,9 +231,10 @@ dev_clear() /* clear our quadtree */ } -int -dev_view(nv) /* assign new driver view */ -register VIEW *nv; +extern int +dev_view( /* assign new driver view */ + register VIEW *nv +) { if (nv->type == VT_PAR || /* check view legality */ nv->horiz > 160. || nv->vert > 160.) { @@ -264,25 +284,32 @@ register VIEW *nv; } -dev_section(ofn) /* add octree for geometry rendering */ -char *ofn; +extern void +dev_section( /* add octree for geometry rendering */ + char *gfn, + char *pfn +) { /* unimplemented */ } -dev_auxcom(cmd, args) /* process an auxiliary command */ -char *cmd, *args; +extern void +dev_auxcom( /* process an auxiliary command */ + char *cmd, + char *args +) { sprintf(errmsg, "%s: unknown command", cmd); error(COMMAND, errmsg); } -VIEW * -dev_auxview(n, hvres) /* return nth auxiliary view */ -int n; -int hvres[2]; +extern VIEW * +dev_auxview( /* return nth auxiliary view */ + int n, + int hvres[2] +) { if (n) return(NULL); @@ -291,8 +318,8 @@ int hvres[2]; } -int -dev_input() /* get X11 input */ +extern int +dev_input(void) /* get X11 input */ { inpresflags = 0; @@ -305,8 +332,8 @@ dev_input() /* get X11 input */ } -int -dev_flush() /* flush output */ +extern int +dev_flush(void) /* flush output */ { qtUpdate(); glFlush(); @@ -315,10 +342,12 @@ dev_flush() /* flush output */ } -dev_cone(rgb, ip, rad) /* render a cone in view coordinates */ -BYTE rgb[3]; -FVECT ip; -double rad; +extern void +dev_cone( /* render a cone in view coordinates */ + BYTE rgb[3], + FVECT ip, + double rad +) { register int ci, j; double apexh, basez; @@ -355,7 +384,7 @@ double rad; static int -mytmflags() /* figure out tone mapping flags */ +mytmflags(void) /* figure out tone mapping flags */ { extern char *progname; register char *cp, *tail; @@ -370,11 +399,12 @@ mytmflags() /* figure out tone mapping flags */ if (cp-tail == 5 && !strncmp(tail, "glx1h", 5)) return(TM_F_HUMAN|TM_F_NOSTDERR); error(USER, "illegal driver name"); + return -1; /* pro forma return */ } -static -initcones() /* initialize cone vertices */ +static void +initcones(void) /* initialize cone vertices */ { register int i, j; double minrad, d; @@ -400,8 +430,8 @@ initcones() /* initialize cone vertices */ } -static -freecones() /* free cone vertices */ +static void +freecones(void) /* free cone vertices */ { register int i; @@ -414,8 +444,8 @@ freecones() /* free cone vertices */ } -static -getevent() /* get next event */ +static void +getevent(void) /* get next event */ { XNextEvent(ourdisplay, levptr(XEvent)); switch (levptr(XEvent)->type) { @@ -441,23 +471,22 @@ getevent() /* get next event */ } -static -draw3dline(wp) /* draw 3d line in world coordinates */ -register FVECT wp[2]; +static void +draw3dline( /* draw 3d line in world coordinates */ + register FVECT wp[2] +) { glVertex3d(wp[0][0], wp[0][1], wp[0][2]); glVertex3d(wp[1][0], wp[1][1], wp[1][2]); } -static -draw_grids() /* draw holodeck section grids */ +static void +draw_grids(void) /* draw holodeck section grids */ { static BYTE gridrgba[4] = {0x0, 0xff, 0xff, 0x00}; double xmin, xmax, ymin, ymax, zmin, zmax; - double d, cx, sx, crad; - FVECT vx, vy; - register int i, j; + double d; /* can we even do it? */ if (!mapped || odev.v.type != VT_PER) return; @@ -498,9 +527,13 @@ draw_grids() /* draw holodeck section grids */ } -static -moveview(dx, dy, mov, orb) /* move our view */ -int dx, dy, mov, orb; +static int +moveview( /* move our view */ + int dx, + int dy, + int mov, + int orb +) { VIEW nv; FVECT odir, v1; @@ -546,9 +579,10 @@ int dx, dy, mov, orb; } -static -getmove(ebut) /* get view change */ -XButtonPressedEvent *ebut; +static void +getmove( /* get view change */ + XButtonPressedEvent *ebut +) { int movdir = MOVDIR(ebut->button); int movorb = MOVORB(ebut->state); @@ -588,9 +622,10 @@ XButtonPressedEvent *ebut; } -static -getkey(ekey) /* get input key */ -register XKeyPressedEvent *ekey; +static void +getkey( /* get input key */ + register XKeyPressedEvent *ekey +) { int n; char buf[8]; @@ -659,9 +694,10 @@ register XKeyPressedEvent *ekey; } -static -fixwindow(eexp) /* repair damage to window */ -register XExposeEvent *eexp; +static void +fixwindow( /* repair damage to window */ + register XExposeEvent *eexp +) { int xmin, xmax, ymin, ymax; @@ -684,9 +720,10 @@ register XExposeEvent *eexp; } -static -resizewindow(ersz) /* resize window */ -register XConfigureEvent *ersz; +static void +resizewindow( /* resize window */ + register XConfigureEvent *ersz +) { glViewport(0, 0, ersz->width, ersz->height);
