root/radiance/ray/src/hd/rhd_glx1.c
Revision: 3.8
Committed: Thu Sep 6 00:07:43 2012 UTC (12 years, 8 months ago) by greg
CVS Tags: rad4R2P2, rad5R0, rad4R2, rad4R2P1
Changes since 3.7: +4 -5 lines
# User Rev Content
1 greg 3.1 #ifndef lint
2 greg 3.8 static const char RCSid[] = "$Id: rhd_glx1.c,v 3.7 2011/05/20 02:06:39 greg Exp $";
3 greg 3.1 #endif
4     /*
5     * OpenGL GLX driver for holodeck display.
6     * Based on x11 driver.
7     */
8
9     #include "standard.h"
10
11     #include <GL/glx.h>
12 schorsch 3.3 #include <GL/glu.h>
13 greg 3.1
14 schorsch 3.4 #include "platform.h"
15 greg 3.1 #include "rhd_qtree.h"
16 schorsch 3.3 #include "rhdriver.h"
17     #include "rhdisp.h"
18 greg 3.1 #include "x11icon.h"
19
20     #ifndef RAYQLEN
21     #define RAYQLEN 50000 /* max. rays to queue before flush */
22     #endif
23
24     #ifndef FEQ
25     #define FEQ(a,b) ((a)-(b) <= FTINY && (a)-(b) >= -FTINY)
26     #endif
27
28     #ifndef MAXCONE
29     #define MAXCONE 16 /* number of different cone sizes */
30     #endif
31     #ifndef MAXVERT
32     #define MAXVERT 64 /* maximum number of cone vertices */
33     #endif
34     #ifndef MINVERT
35     #define MINVERT 4 /* minimum number of cone vertices */
36     #endif
37     #ifndef DEPTHFACT
38     #define DEPTHFACT 16. /* multiplier for depth tests */
39     #endif
40
41     #define GAMMA 1.4 /* default gamma correction */
42
43     #define MOVPCT 7 /* percent distance to move /frame */
44     #define MOVDIR(b) ((b)==Button1 ? 1 : (b)==Button2 ? 0 : -1)
45     #define MOVDEG (-5) /* degrees to orbit CW/down /frame */
46     #define MOVORB(s) ((s)&ShiftMask ? 1 : (s)&ControlMask ? -1 : 0)
47
48     #define MINWIDTH 480 /* minimum graphics window width */
49     #define MINHEIGHT 400 /* minimum graphics window height */
50
51     #define VIEWDIST 356 /* assumed viewing distance (mm) */
52
53     #define BORWIDTH 5 /* border width */
54
55     #define ourscreen DefaultScreen(ourdisplay)
56     #define ourroot RootWindow(ourdisplay,ourscreen)
57     #define ourmask (StructureNotifyMask|ExposureMask|KeyPressMask|\
58     ButtonPressMask|ButtonReleaseMask)
59
60     #define levptr(etype) ((etype *)&currentevent)
61
62     struct driver odev; /* global device driver structure */
63
64 greg 3.5 TMstruct *tmGlobal; /* global tone-mapping structure */
65
66 greg 3.1 char odev_args[64]; /* command arguments */
67
68     static XEvent currentevent; /* current event */
69
70     static int mapped = 0; /* window is mapped? */
71     static unsigned long ourblack=0, ourwhite=~0;
72
73     static Display *ourdisplay = NULL; /* our display */
74     static XVisualInfo *ourvinf; /* our visual information */
75     static Window gwind = 0; /* our graphics window */
76     static GLXContext gctx; /* our GLX context */
77
78     static double pwidth, pheight; /* pixel dimensions (mm) */
79
80     static double curzmax = 1e4; /* current depth upper limit */
81     static double nxtzmax = 0.; /* maximum (finite) depth so far */
82
83     static struct {
84     double rad; /* cone radius */
85     int nverts; /* number of vertices */
86     FVECT *va; /* allocated vertex array */
87     } cone[MAXCONE]; /* precomputed cones for drawing */
88
89     static int inpresflags; /* input result flags */
90
91     static int headlocked = 0; /* lock vertical motion */
92
93
94 schorsch 3.3 static int mytmflags(void);
95     static void initcones(void);
96     static void freecones(void);
97     static void getevent(void);
98     static void draw3dline(FVECT wp[2]);
99     static void draw_grids(void);
100     static int moveview(int dx, int dy, int mov, int orb);
101     static void getmove(XButtonPressedEvent *ebut);
102     static void getkey(XKeyPressedEvent *ekey);
103     static void fixwindow(XExposeEvent *eexp);
104     static void resizewindow(XConfigureEvent *ersz);
105
106
107     extern void
108     dev_open(
109     char *id
110     )
111 greg 3.1 {
112     extern char *getenv();
113     static RGBPRIMS myprims = STDPRIMS;
114     static int atlBest[] = {GLX_RGBA, GLX_RED_SIZE,8,
115     GLX_GREEN_SIZE,8, GLX_BLUE_SIZE,8,
116     GLX_DEPTH_SIZE,15, None};
117     char *ev;
118     double gamval = GAMMA;
119     RGBPRIMP dpri = stdprims;
120     XSetWindowAttributes ourwinattr;
121     XWMHints ourxwmhints;
122     XSizeHints oursizhints;
123     /* set quadtree globals */
124     qtMinNodesiz = 3;
125     qtDepthEps = 0.07;
126     /* open display server */
127     ourdisplay = XOpenDisplay(NULL);
128     if (ourdisplay == NULL)
129     error(USER, "cannot open X-windows; DISPLAY variable set?\n");
130     /* find a usable visual */
131     ourvinf = glXChooseVisual(ourdisplay, ourscreen, atlBest);
132     if (ourvinf == NULL)
133     error(USER, "no suitable visuals available");
134     /* get a context */
135     gctx = glXCreateContext(ourdisplay, ourvinf, NULL, GL_TRUE);
136     /* set gamma and tone mapping */
137     if ((ev = XGetDefault(ourdisplay, "radiance", "gamma")) != NULL
138     || (ev = getenv("DISPLAY_GAMMA")) != NULL)
139     gamval = atof(ev);
140     if ((ev = getenv("DISPLAY_PRIMARIES")) != NULL &&
141     sscanf(ev, "%f %f %f %f %f %f %f %f",
142     &myprims[RED][CIEX],&myprims[RED][CIEY],
143     &myprims[GRN][CIEX],&myprims[GRN][CIEY],
144     &myprims[BLU][CIEX],&myprims[BLU][CIEY],
145     &myprims[WHT][CIEX],&myprims[WHT][CIEY]) >= 6)
146     dpri = myprims;
147 greg 3.5 tmGlobal = tmInit(mytmflags(), dpri, gamval);
148     if (tmGlobal == NULL)
149 greg 3.1 error(SYSTEM, "not enough memory in dev_open");
150     /* open window */
151     ourwinattr.background_pixel = ourblack;
152     ourwinattr.border_pixel = ourblack;
153     ourwinattr.event_mask = ourmask;
154     /* this is stupid */
155     ourwinattr.colormap = XCreateColormap(ourdisplay, ourroot,
156     ourvinf->visual, AllocNone);
157     gwind = XCreateWindow(ourdisplay, ourroot, 0, 0,
158     DisplayWidth(ourdisplay,ourscreen)-2*BORWIDTH,
159     DisplayHeight(ourdisplay,ourscreen)-2*BORWIDTH,
160     BORWIDTH, ourvinf->depth, InputOutput, ourvinf->visual,
161     CWBackPixel|CWBorderPixel|CWColormap|CWEventMask, &ourwinattr);
162     if (gwind == 0)
163     error(SYSTEM, "cannot create window\n");
164     XStoreName(ourdisplay, gwind, id);
165     /* set window manager hints */
166     ourxwmhints.flags = InputHint|IconPixmapHint;
167     ourxwmhints.input = True;
168     ourxwmhints.icon_pixmap = XCreateBitmapFromData(ourdisplay,
169     gwind, x11icon_bits, x11icon_width, x11icon_height);
170     XSetWMHints(ourdisplay, gwind, &ourxwmhints);
171     oursizhints.min_width = MINWIDTH;
172     oursizhints.min_height = MINHEIGHT;
173     oursizhints.flags = PMinSize;
174     XSetNormalHints(ourdisplay, gwind, &oursizhints);
175     /* set GLX context */
176     glXMakeCurrent(ourdisplay, gwind, gctx);
177     glEnable(GL_DEPTH_TEST);
178     glDepthFunc(GL_LEQUAL);
179     glShadeModel(GL_FLAT);
180     glDisable(GL_DITHER);
181     glDisable(GL_CULL_FACE);
182     glMatrixMode(GL_PROJECTION);
183     glOrtho(0., 1., 0., 1., -.01, 1.01);
184     glTranslated(0., 0., -1.01);
185     /* figure out sensible view */
186     pwidth = (double)DisplayWidthMM(ourdisplay, ourscreen) /
187     DisplayWidth(ourdisplay, ourscreen);
188     pheight = (double)DisplayHeightMM(ourdisplay, ourscreen) /
189     DisplayHeight(ourdisplay, ourscreen);
190 schorsch 3.2 odev.v = stdview;
191 greg 3.1 odev.v.type = VT_PER;
192     /* map the window */
193     XMapWindow(ourdisplay, gwind);
194     dev_input(); /* sets size and view angles */
195     /* allocate our leaf pile */
196     if (!qtAllocLeaves(DisplayWidth(ourdisplay,ourscreen) *
197     DisplayHeight(ourdisplay,ourscreen) * 3 /
198     (qtMinNodesiz*qtMinNodesiz*2)))
199     error(SYSTEM, "insufficient memory for value storage");
200     odev.name = id;
201     odev.ifd = ConnectionNumber(ourdisplay);
202     /* initialize cone array */
203     initcones();
204     }
205
206
207 schorsch 3.3 extern void
208     dev_close(void) /* close our display and free resources */
209 greg 3.1 {
210     glXMakeCurrent(ourdisplay, None, NULL);
211     glXDestroyContext(ourdisplay, gctx);
212     XDestroyWindow(ourdisplay, gwind);
213     gwind = 0;
214     XCloseDisplay(ourdisplay);
215     ourdisplay = NULL;
216     qtFreeLeaves();
217 greg 3.5 tmDone(tmGlobal);
218 greg 3.1 freecones();
219     odev.v.type = 0;
220     odev.hres = odev.vres = 0;
221     odev.ifd = -1;
222     }
223
224
225 schorsch 3.3 extern void
226     dev_clear(void) /* clear our quadtree */
227 greg 3.1 {
228     qtCompost(100);
229     glClear(GL_DEPTH_BUFFER_BIT);
230     rayqleft = 0; /* hold off update */
231     }
232
233
234 schorsch 3.3 extern int
235     dev_view( /* assign new driver view */
236     register VIEW *nv
237     )
238 greg 3.1 {
239     if (nv->type == VT_PAR || /* check view legality */
240     nv->horiz > 160. || nv->vert > 160.) {
241     error(COMMAND, "illegal view type/angle");
242     nv->type = odev.v.type;
243     nv->horiz = odev.v.horiz;
244     nv->vert = odev.v.vert;
245     return(0);
246     }
247     if (nv->vfore > FTINY) {
248     error(COMMAND, "cannot handle fore clipping");
249     nv->vfore = 0.;
250     return(0);
251     }
252     if (nv != &odev.v) {
253     if (!FEQ(nv->horiz,odev.v.horiz) || /* resize window? */
254     !FEQ(nv->vert,odev.v.vert)) {
255     int dw = DisplayWidth(ourdisplay,ourscreen);
256     int dh = DisplayHeight(ourdisplay,ourscreen);
257
258     dw -= 25; /* for window frame */
259     dh -= 50;
260     odev.hres = 2.*VIEWDIST/pwidth *
261     tan(PI/180./2.*nv->horiz);
262     odev.vres = 2.*VIEWDIST/pheight *
263     tan(PI/180./2.*nv->vert);
264     if (odev.hres > dw) {
265     odev.vres = dw * odev.vres / odev.hres;
266     odev.hres = dw;
267     }
268     if (odev.vres > dh) {
269     odev.hres = dh * odev.hres / odev.vres;
270     odev.vres = dh;
271     }
272     XResizeWindow(ourdisplay, gwind, odev.hres, odev.vres);
273     dev_input(); /* get resize event */
274     }
275 schorsch 3.2 odev.v = *nv;
276 greg 3.1 }
277     if (nxtzmax > FTINY) {
278     curzmax = nxtzmax;
279     nxtzmax = 0.;
280     }
281     glClear(GL_DEPTH_BUFFER_BIT);
282     qtReplant();
283     return(1);
284     }
285
286
287 schorsch 3.3 extern void
288     dev_section( /* add octree for geometry rendering */
289 schorsch 3.6 char *gfn,
290     char *pfn
291 schorsch 3.3 )
292 greg 3.1 {
293     /* unimplemented */
294     }
295
296
297 schorsch 3.3 extern void
298     dev_auxcom( /* process an auxiliary command */
299     char *cmd,
300     char *args
301     )
302 greg 3.1 {
303     sprintf(errmsg, "%s: unknown command", cmd);
304     error(COMMAND, errmsg);
305     }
306
307
308 schorsch 3.3 extern VIEW *
309     dev_auxview( /* return nth auxiliary view */
310     int n,
311     int hvres[2]
312     )
313 greg 3.1 {
314     if (n)
315     return(NULL);
316     hvres[0] = odev.hres; hvres[1] = odev.vres;
317     return(&odev.v);
318     }
319
320
321 schorsch 3.3 extern int
322     dev_input(void) /* get X11 input */
323 greg 3.1 {
324     inpresflags = 0;
325
326     do
327     getevent();
328
329     while (XQLength(ourdisplay) > 0);
330
331     return(inpresflags);
332     }
333
334
335 schorsch 3.3 extern int
336     dev_flush(void) /* flush output */
337 greg 3.1 {
338     qtUpdate();
339     glFlush();
340     rayqleft = RAYQLEN;
341     return(XPending(ourdisplay));
342     }
343
344
345 schorsch 3.3 extern void
346     dev_cone( /* render a cone in view coordinates */
347 greg 3.7 uby8 rgb[3],
348 schorsch 3.3 FVECT ip,
349     double rad
350     )
351 greg 3.1 {
352     register int ci, j;
353     double apexh, basez;
354     /* is window mapped? */
355     if (!mapped)
356     return;
357     /* compute apex height (0. to 1.) */
358     if (ip[2] > 1e6)
359     apexh = 1. - 1./DEPTHFACT;
360     else {
361     if (ip[2] > nxtzmax)
362     nxtzmax = ip[2];
363     if (ip[2] >= curzmax)
364     apexh = 1. - 1./DEPTHFACT;
365     else
366     apexh = 1. - ip[2]/(curzmax*DEPTHFACT);
367     }
368     rad *= 1.25; /* find conservative cone match */
369     for (ci = 0; ci < MAXCONE-1; ci++)
370     if (cone[ci].rad >= rad)
371     break;
372     /* draw it */
373     glColor3ub(rgb[0], rgb[1], rgb[2]);
374     glBegin(GL_TRIANGLE_FAN);
375     glVertex3d(ip[0], ip[1], apexh); /* start with apex */
376     basez = apexh*cone[ci].va[0][2]; /* base z's all the same */
377     for (j = 0; j < cone[ci].nverts; j++) /* draw each face */
378     glVertex3d(ip[0]+cone[ci].va[j][0], ip[1]+cone[ci].va[j][1],
379     basez);
380     /* connect last to first */
381     glVertex3d(ip[0]+cone[ci].va[0][0], ip[1]+cone[ci].va[0][1], basez);
382     glEnd(); /* all done */
383     }
384
385
386     static int
387 schorsch 3.3 mytmflags(void) /* figure out tone mapping flags */
388 greg 3.1 {
389     extern char *progname;
390     register char *cp, *tail;
391     /* find basic name */
392     for (cp = tail = progname; *cp; cp++)
393     if (*cp == '/')
394     tail = cp+1;
395     for (cp = tail; *cp && *cp != '.'; cp++)
396     ;
397     if (cp-tail == 4 && !strncmp(tail, "glx1", 4))
398     return(TM_F_CAMERA|TM_F_NOSTDERR);
399     if (cp-tail == 5 && !strncmp(tail, "glx1h", 5))
400     return(TM_F_HUMAN|TM_F_NOSTDERR);
401     error(USER, "illegal driver name");
402 schorsch 3.3 return -1; /* pro forma return */
403 greg 3.1 }
404
405
406 schorsch 3.3 static void
407     initcones(void) /* initialize cone vertices */
408 greg 3.1 {
409     register int i, j;
410     double minrad, d;
411
412     if (cone[0].nverts)
413     freecones();
414     minrad = 2.*qtMinNodesiz/(double)(DisplayWidth(ourdisplay,ourscreen) +
415     DisplayHeight(ourdisplay,ourscreen));
416     for (i = 0; i < MAXCONE; i++) {
417     d = (double)i/(MAXCONE-1); d *= d; /* x^2 distribution */
418     cone[i].rad = minrad + (1.-minrad)*d;
419     cone[i].nverts = MINVERT + 0.5 + (MAXVERT-MINVERT)*d;
420     cone[i].va = (FVECT *)malloc(cone[i].nverts*sizeof(FVECT));
421     if (cone[i].va == NULL)
422     error(SYSTEM, "out of memory in initcones");
423     for (j = cone[i].nverts; j--; ) {
424     d = 2.*PI * (j+.5) / (cone[i].nverts);
425     cone[i].va[j][0] = cos(d) * cone[i].rad;
426     cone[i].va[j][1] = sin(d) * cone[i].rad;
427     cone[i].va[j][2] = 1. - cone[i].rad;
428     }
429     }
430     }
431
432
433 schorsch 3.3 static void
434     freecones(void) /* free cone vertices */
435 greg 3.1 {
436     register int i;
437
438     for (i = MAXCONE; i--; )
439     if (cone[i].nverts) {
440     free((void *)cone[i].va);
441     cone[i].va = NULL;
442     cone[i].nverts = 0;
443     }
444     }
445
446
447 schorsch 3.3 static void
448     getevent(void) /* get next event */
449 greg 3.1 {
450     XNextEvent(ourdisplay, levptr(XEvent));
451     switch (levptr(XEvent)->type) {
452     case ConfigureNotify:
453     resizewindow(levptr(XConfigureEvent));
454     break;
455     case UnmapNotify:
456     mapped = 0;
457     break;
458     case MapNotify:
459     mapped = 1;
460     break;
461     case Expose:
462     fixwindow(levptr(XExposeEvent));
463     break;
464     case KeyPress:
465     getkey(levptr(XKeyPressedEvent));
466     break;
467     case ButtonPress:
468     getmove(levptr(XButtonPressedEvent));
469     break;
470     }
471     }
472
473
474 schorsch 3.3 static void
475     draw3dline( /* draw 3d line in world coordinates */
476     register FVECT wp[2]
477     )
478 greg 3.1 {
479     glVertex3d(wp[0][0], wp[0][1], wp[0][2]);
480     glVertex3d(wp[1][0], wp[1][1], wp[1][2]);
481     }
482
483
484 schorsch 3.3 static void
485     draw_grids(void) /* draw holodeck section grids */
486 greg 3.1 {
487 greg 3.7 static uby8 gridrgba[4] = {0x0, 0xff, 0xff, 0x00};
488 greg 3.1 double xmin, xmax, ymin, ymax, zmin, zmax;
489 schorsch 3.3 double d;
490 greg 3.1 /* can we even do it? */
491     if (!mapped || odev.v.type != VT_PER)
492     return;
493     /* compute view frustum */
494     if (normalize(odev.v.vdir) == 0.0)
495     return;
496     zmin = 0.01;
497     zmax = 10000.;
498     if (odev.v.vfore > FTINY)
499     zmin = odev.v.vfore;
500     if (odev.v.vaft > FTINY)
501     zmax = odev.v.vaft;
502     xmax = zmin * tan(PI/180./2. * odev.v.horiz);
503     xmin = -xmax;
504     d = odev.v.hoff * (xmax - xmin);
505     xmin += d; xmax += d;
506     ymax = zmin * tan(PI/180./2. * odev.v.vert);
507     ymin = -ymax;
508     d = odev.v.voff * (ymax - ymin);
509     ymin += d; ymax += d;
510     /* set view matrix */
511     glMatrixMode(GL_PROJECTION);
512     glPushMatrix();
513     glLoadIdentity();
514     glFrustum(xmin, xmax, ymin, ymax, zmin, zmax);
515     gluLookAt(odev.v.vp[0], odev.v.vp[1], odev.v.vp[2],
516     odev.v.vp[0] + odev.v.vdir[0],
517     odev.v.vp[1] + odev.v.vdir[1],
518     odev.v.vp[2] + odev.v.vdir[2],
519     odev.v.vup[0], odev.v.vup[1], odev.v.vup[2]);
520     glDisable(GL_DEPTH_TEST); /* write no depth values */
521     glColor4ub(gridrgba[0], gridrgba[1], gridrgba[2], gridrgba[3]);
522     glBegin(GL_LINES); /* draw each grid line */
523     gridlines(draw3dline);
524     glEnd();
525     glEnable(GL_DEPTH_TEST); /* restore rendering params */
526     glPopMatrix();
527     }
528
529
530 schorsch 3.3 static int
531     moveview( /* move our view */
532     int dx,
533     int dy,
534     int mov,
535     int orb
536     )
537 greg 3.1 {
538     VIEW nv;
539     FVECT odir, v1;
540     double d;
541     register int li;
542     /* start with old view */
543 schorsch 3.2 nv = odev.v;
544 greg 3.1 /* change view direction */
545     if (mov | orb) {
546     if ((li = qtFindLeaf(dx, dy)) < 0)
547     return(0); /* not on window */
548     VSUM(odir, qtL.wp[li], nv.vp, -1.);
549     } else {
550     if (viewray(nv.vp, nv.vdir, &odev.v,
551     (dx+.5)/odev.hres, (dy+.5)/odev.vres) < -FTINY)
552     return(0); /* outside view */
553     }
554     if (orb && mov) { /* orbit left/right */
555     spinvector(odir, odir, nv.vup, d=MOVDEG*PI/180.*mov);
556     VSUM(nv.vp, qtL.wp[li], odir, -1.);
557     spinvector(nv.vdir, nv.vdir, nv.vup, d);
558     } else if (orb) { /* orbit up/down */
559 greg 3.8 if (geodesic(odir, odir, nv.vup,
560     d=MOVDEG*PI/180.*orb, GEOD_RAD) == 0.0)
561 greg 3.1 return(0);
562     VSUM(nv.vp, qtL.wp[li], odir, -1.);
563 greg 3.8 geodesic(nv.vdir, nv.vdir, nv.vup, d, GEOD_RAD);
564 greg 3.1 } else if (mov) { /* move forward/backward */
565     d = MOVPCT/100. * mov;
566     VSUM(nv.vp, nv.vp, odir, d);
567     }
568     if (!mov ^ !orb && headlocked) { /* restore head height */
569     VSUM(v1, odev.v.vp, nv.vp, -1.);
570     d = DOT(v1, odev.v.vup);
571     VSUM(nv.vp, nv.vp, odev.v.vup, d);
572     }
573     if (setview(&nv) != NULL)
574     return(0); /* illegal view */
575     dev_view(&nv);
576     inpresflags |= DFL(DC_SETVIEW);
577     return(1);
578     }
579
580
581 schorsch 3.3 static void
582     getmove( /* get view change */
583     XButtonPressedEvent *ebut
584     )
585 greg 3.1 {
586     int movdir = MOVDIR(ebut->button);
587     int movorb = MOVORB(ebut->state);
588     int oldnodesiz = qtMinNodesiz;
589     Window rootw, childw;
590     int rootx, rooty, wx, wy;
591     unsigned int statemask;
592
593     qtMinNodesiz = 24; /* accelerate update rate */
594     XNoOp(ourdisplay);
595
596     while (!XCheckMaskEvent(ourdisplay,
597     ButtonReleaseMask, levptr(XEvent))) {
598
599     if (!XQueryPointer(ourdisplay, gwind, &rootw, &childw,
600     &rootx, &rooty, &wx, &wy, &statemask))
601     break; /* on another screen */
602
603     if (!moveview(wx, odev.vres-1-wy, movdir, movorb)) {
604     sleep(1);
605     continue;
606     }
607     glClear(GL_COLOR_BUFFER_BIT);
608     qtUpdate();
609     draw_grids();
610     glFlush();
611     }
612     if (!(inpresflags & DFL(DC_SETVIEW))) { /* do final motion */
613     movdir = MOVDIR(levptr(XButtonReleasedEvent)->button);
614     wx = levptr(XButtonReleasedEvent)->x;
615     wy = levptr(XButtonReleasedEvent)->y;
616     moveview(wx, odev.vres-1-wy, movdir, movorb);
617     }
618     dev_flush();
619
620     qtMinNodesiz = oldnodesiz; /* restore quadtree resolution */
621     }
622
623
624 schorsch 3.3 static void
625     getkey( /* get input key */
626     register XKeyPressedEvent *ekey
627     )
628 greg 3.1 {
629     int n;
630     char buf[8];
631
632     n = XLookupString(ekey, buf, sizeof(buf), NULL, NULL);
633     if (n != 1)
634     return;
635     switch (buf[0]) {
636     case 'h': /* turn on height motion lock */
637     headlocked = 1;
638     return;
639     case 'H': /* turn off height motion lock */
640     headlocked = 0;
641     return;
642     case 'l': /* retrieve last view */
643     inpresflags |= DFL(DC_LASTVIEW);
644     return;
645     case 'p': /* pause computation */
646     inpresflags |= DFL(DC_PAUSE);
647     return;
648     case 'v': /* spit out view */
649     inpresflags |= DFL(DC_GETVIEW);
650     return;
651     case '\n':
652     case '\r': /* resume computation */
653     inpresflags |= DFL(DC_RESUME);
654     return;
655     case CTRL('R'): /* redraw screen */
656     if (nxtzmax > FTINY) {
657     curzmax = nxtzmax;
658     nxtzmax = 0.;
659     }
660     glClear(GL_DEPTH_BUFFER_BIT);
661     qtRedraw(0, 0, odev.hres, odev.vres);
662     return;
663     case CTRL('L'): /* refresh from server */
664     if (inpresflags & DFL(DC_REDRAW))
665     return;
666     if (nxtzmax > FTINY) {
667     curzmax = nxtzmax;
668     nxtzmax = 0.;
669     }
670     glClear(GL_COLOR_BUFFER_BIT | GL_DEPTH_BUFFER_BIT);
671     draw_grids();
672     glFlush();
673     qtCompost(100); /* get rid of old values */
674     inpresflags |= DFL(DC_REDRAW); /* resend values from server */
675     rayqleft = 0; /* hold off update */
676     return;
677     case 'K': /* kill rtrace process(es) */
678     inpresflags |= DFL(DC_KILL);
679     break;
680     case 'R': /* restart rtrace */
681     inpresflags |= DFL(DC_RESTART);
682     break;
683     case 'C': /* clobber holodeck */
684     inpresflags |= DFL(DC_CLOBBER);
685     break;
686     case 'q': /* quit the program */
687     inpresflags |= DFL(DC_QUIT);
688     return;
689     default:
690     XBell(ourdisplay, 0);
691     return;
692     }
693     }
694
695
696 schorsch 3.3 static void
697     fixwindow( /* repair damage to window */
698     register XExposeEvent *eexp
699     )
700 greg 3.1 {
701     int xmin, xmax, ymin, ymax;
702
703     if (odev.hres == 0 || odev.vres == 0) /* first exposure */
704     resizewindow((XConfigureEvent *)eexp);
705     xmin = eexp->x; xmax = eexp->x + eexp->width;
706     ymin = odev.vres - eexp->y - eexp->height; ymax = odev.vres - eexp->y;
707     /* clear portion of depth */
708     glColorMask(GL_FALSE, GL_FALSE, GL_FALSE, GL_FALSE);
709     glDepthFunc(GL_ALWAYS);
710     glBegin(GL_POLYGON);
711     glVertex3d((double)xmin/odev.hres, (double)ymin/odev.vres, 0.);
712     glVertex3d((double)xmax/odev.hres, (double)ymin/odev.vres, 0.);
713     glVertex3d((double)xmax/odev.hres, (double)ymax/odev.vres, 0.);
714     glVertex3d((double)xmin/odev.hres, (double)ymax/odev.vres, 0.);
715     glEnd();
716     glColorMask(GL_TRUE, GL_TRUE, GL_TRUE, GL_TRUE);
717     glDepthFunc(GL_LEQUAL);
718     qtRedraw(xmin, ymin, xmax, ymax);
719     }
720
721
722 schorsch 3.3 static void
723     resizewindow( /* resize window */
724     register XConfigureEvent *ersz
725     )
726 greg 3.1 {
727     glViewport(0, 0, ersz->width, ersz->height);
728
729     if (ersz->width == odev.hres && ersz->height == odev.vres)
730     return;
731
732     odev.hres = ersz->width;
733     odev.vres = ersz->height;
734
735     odev.v.horiz = 2.*180./PI * atan(0.5/VIEWDIST*pwidth*odev.hres);
736     odev.v.vert = 2.*180./PI * atan(0.5/VIEWDIST*pheight*odev.vres);
737
738     inpresflags |= DFL(DC_SETVIEW);
739     }
