root/radiance/ray/src/hd/rhd_glx1.c
Revision: 3.1
Committed: Sat Feb 22 02:07:24 2003 UTC (21 years, 4 months ago) by greg
5 * OpenGL GLX driver for holodeck display.
6 * Based on x11 driver.
7 */
8
9 #include "standard.h"
10
11 #include <GL/glx.h>
12
13 #include "rhd_qtree.h"
14
15 #include "x11icon.h"
16
17 #ifndef RAYQLEN
18 #define RAYQLEN 50000 /* max. rays to queue before flush */
19 #endif
20
21 #ifndef FEQ
22 #define FEQ(a,b) ((a)-(b) <= FTINY && (a)-(b) >= -FTINY)
23 #endif
24
25 #ifndef MAXCONE
26 #define MAXCONE 16 /* number of different cone sizes */
27 #endif
28 #ifndef MAXVERT
29 #define MAXVERT 64 /* maximum number of cone vertices */
30 #endif
31 #ifndef MINVERT
32 #define MINVERT 4 /* minimum number of cone vertices */
33 #endif
34 #ifndef DEPTHFACT
35 #define DEPTHFACT 16. /* multiplier for depth tests */
36 #endif
37
38 #define GAMMA 1.4 /* default gamma correction */
39
40 #define MOVPCT 7 /* percent distance to move /frame */
41 #define MOVDIR(b) ((b)==Button1 ? 1 : (b)==Button2 ? 0 : -1)
42 #define MOVDEG (-5) /* degrees to orbit CW/down /frame */
43 #define MOVORB(s) ((s)&ShiftMask ? 1 : (s)&ControlMask ? -1 : 0)
44
45 #define MINWIDTH 480 /* minimum graphics window width */
46 #define MINHEIGHT 400 /* minimum graphics window height */
47
48 #define VIEWDIST 356 /* assumed viewing distance (mm) */
49
50 #define BORWIDTH 5 /* border width */
51
52 #define ourscreen DefaultScreen(ourdisplay)
53 #define ourroot RootWindow(ourdisplay,ourscreen)
54 #define ourmask (StructureNotifyMask|ExposureMask|KeyPressMask|\
55 ButtonPressMask|ButtonReleaseMask)
56
57 #define levptr(etype) ((etype *)&currentevent)
58
59 struct driver odev; /* global device driver structure */
60
61 char odev_args[64]; /* command arguments */
62
63 static XEvent currentevent; /* current event */
64
65 static int mapped = 0; /* window is mapped? */
66 static unsigned long ourblack=0, ourwhite=~0;
67
68 static Display *ourdisplay = NULL; /* our display */
69 static XVisualInfo *ourvinf; /* our visual information */
70 static Window gwind = 0; /* our graphics window */
71 static GLXContext gctx; /* our GLX context */
72
73 static double pwidth, pheight; /* pixel dimensions (mm) */
74
75 static double curzmax = 1e4; /* current depth upper limit */
76 static double nxtzmax = 0.; /* maximum (finite) depth so far */
77
78 static struct {
79 double rad; /* cone radius */
80 int nverts; /* number of vertices */
81 FVECT *va; /* allocated vertex array */
82 } cone[MAXCONE]; /* precomputed cones for drawing */
83
84 static int inpresflags; /* input result flags */
85
86 static int headlocked = 0; /* lock vertical motion */
87
88 static int resizewindow(), getevent(), getkey(), moveview(),
89 initcones(), freecones(),
90 getmove(), fixwindow(), mytmflags();
91
92
93 dev_open(id) /* initialize X11 driver */
94 char *id;
95 {
96 extern char *getenv();
97 static RGBPRIMS myprims = STDPRIMS;
98 static int atlBest[] = {GLX_RGBA, GLX_RED_SIZE,8,
99 GLX_GREEN_SIZE,8, GLX_BLUE_SIZE,8,
100 GLX_DEPTH_SIZE,15, None};
101 char *ev;
102 double gamval = GAMMA;
103 RGBPRIMP dpri = stdprims;
104 XSetWindowAttributes ourwinattr;
105 XWMHints ourxwmhints;
106 XSizeHints oursizhints;
107 /* set quadtree globals */
108 qtMinNodesiz = 3;
109 qtDepthEps = 0.07;
110 /* open display server */
111 ourdisplay = XOpenDisplay(NULL);
112 if (ourdisplay == NULL)
113 error(USER, "cannot open X-windows; DISPLAY variable set?\n");
114 /* find a usable visual */
115 ourvinf = glXChooseVisual(ourdisplay, ourscreen, atlBest);
116 if (ourvinf == NULL)
117 error(USER, "no suitable visuals available");
118 /* get a context */
119 gctx = glXCreateContext(ourdisplay, ourvinf, NULL, GL_TRUE);
120 /* set gamma and tone mapping */
121 if ((ev = XGetDefault(ourdisplay, "radiance", "gamma")) != NULL
122 || (ev = getenv("DISPLAY_GAMMA")) != NULL)
123 gamval = atof(ev);
124 if ((ev = getenv("DISPLAY_PRIMARIES")) != NULL &&
125 sscanf(ev, "%f %f %f %f %f %f %f %f",
126 &myprims[RED][CIEX],&myprims[RED][CIEY],
127 &myprims[GRN][CIEX],&myprims[GRN][CIEY],
128 &myprims[BLU][CIEX],&myprims[BLU][CIEY],
129 &myprims[WHT][CIEX],&myprims[WHT][CIEY]) >= 6)
130 dpri = myprims;
131 if (tmInit(mytmflags(), dpri, gamval) == NULL)
132 error(SYSTEM, "not enough memory in dev_open");
133 /* open window */
134 ourwinattr.background_pixel = ourblack;
135 ourwinattr.border_pixel = ourblack;
136 ourwinattr.event_mask = ourmask;
137 /* this is stupid */
138 ourwinattr.colormap = XCreateColormap(ourdisplay, ourroot,
139 ourvinf->visual, AllocNone);
140 gwind = XCreateWindow(ourdisplay, ourroot, 0, 0,
141 DisplayWidth(ourdisplay,ourscreen)-2*BORWIDTH,
142 DisplayHeight(ourdisplay,ourscreen)-2*BORWIDTH,
143 BORWIDTH, ourvinf->depth, InputOutput, ourvinf->visual,
144 CWBackPixel|CWBorderPixel|CWColormap|CWEventMask, &ourwinattr);
145 if (gwind == 0)
146 error(SYSTEM, "cannot create window\n");
147 XStoreName(ourdisplay, gwind, id);
148 /* set window manager hints */
149 ourxwmhints.flags = InputHint|IconPixmapHint;
150 ourxwmhints.input = True;
151 ourxwmhints.icon_pixmap = XCreateBitmapFromData(ourdisplay,
152 gwind, x11icon_bits, x11icon_width, x11icon_height);
153 XSetWMHints(ourdisplay, gwind, &ourxwmhints);
154 oursizhints.min_width = MINWIDTH;
155 oursizhints.min_height = MINHEIGHT;
156 oursizhints.flags = PMinSize;
157 XSetNormalHints(ourdisplay, gwind, &oursizhints);
158 /* set GLX context */
159 glXMakeCurrent(ourdisplay, gwind, gctx);
160 glEnable(GL_DEPTH_TEST);
161 glDepthFunc(GL_LEQUAL);
162 glShadeModel(GL_FLAT);
163 glDisable(GL_DITHER);
164 glDisable(GL_CULL_FACE);
165 glMatrixMode(GL_PROJECTION);
166 glOrtho(0., 1., 0., 1., -.01, 1.01);
167 glTranslated(0., 0., -1.01);
168 /* figure out sensible view */
169 pwidth = (double)DisplayWidthMM(ourdisplay, ourscreen) /
170 DisplayWidth(ourdisplay, ourscreen);
171 pheight = (double)DisplayHeightMM(ourdisplay, ourscreen) /
172 DisplayHeight(ourdisplay, ourscreen);
173 copystruct(&odev.v, &stdview);
174 odev.v.type = VT_PER;
175 /* map the window */
176 XMapWindow(ourdisplay, gwind);
177 dev_input(); /* sets size and view angles */
178 /* allocate our leaf pile */
179 if (!qtAllocLeaves(DisplayWidth(ourdisplay,ourscreen) *
180 DisplayHeight(ourdisplay,ourscreen) * 3 /
181 (qtMinNodesiz*qtMinNodesiz*2)))
182 error(SYSTEM, "insufficient memory for value storage");
183 odev.name = id;
184 odev.ifd = ConnectionNumber(ourdisplay);
185 /* initialize cone array */
186 initcones();
187 }
188
189
190 dev_close() /* close our display and free resources */
191 {
192 glXMakeCurrent(ourdisplay, None, NULL);
193 glXDestroyContext(ourdisplay, gctx);
194 XDestroyWindow(ourdisplay, gwind);
195 gwind = 0;
196 XCloseDisplay(ourdisplay);
197 ourdisplay = NULL;
198 qtFreeLeaves();
199 tmDone(NULL);
200 freecones();
201 odev.v.type = 0;
202 odev.hres = odev.vres = 0;
203 odev.ifd = -1;
204 }
205
206
207 dev_clear() /* clear our quadtree */
208 {
209 qtCompost(100);
210 glClear(GL_DEPTH_BUFFER_BIT);
211 rayqleft = 0; /* hold off update */
212 }
213
214
215 int
216 dev_view(nv) /* assign new driver view */
217 register VIEW *nv;
218 {
219 if (nv->type == VT_PAR || /* check view legality */
220 nv->horiz > 160. || nv->vert > 160.) {
221 error(COMMAND, "illegal view type/angle");
222 nv->type = odev.v.type;
223 nv->horiz = odev.v.horiz;
224 nv->vert = odev.v.vert;
225 return(0);
226 }
227 if (nv->vfore > FTINY) {
228 error(COMMAND, "cannot handle fore clipping");
229 nv->vfore = 0.;
230 return(0);
231 }
232 if (nv != &odev.v) {
233 if (!FEQ(nv->horiz,odev.v.horiz) || /* resize window? */
234 !FEQ(nv->vert,odev.v.vert)) {
235 int dw = DisplayWidth(ourdisplay,ourscreen);
236 int dh = DisplayHeight(ourdisplay,ourscreen);
237
238 dw -= 25; /* for window frame */
239 dh -= 50;
240 odev.hres = 2.*VIEWDIST/pwidth *
241 tan(PI/180./2.*nv->horiz);
242 odev.vres = 2.*VIEWDIST/pheight *
243 tan(PI/180./2.*nv->vert);
244 if (odev.hres > dw) {
245 odev.vres = dw * odev.vres / odev.hres;
246 odev.hres = dw;
247 }
248 if (odev.vres > dh) {
249 odev.hres = dh * odev.hres / odev.vres;
250 odev.vres = dh;
251 }
252 XResizeWindow(ourdisplay, gwind, odev.hres, odev.vres);
253 dev_input(); /* get resize event */
254 }
255 copystruct(&odev.v, nv);
256 }
257 if (nxtzmax > FTINY) {
258 curzmax = nxtzmax;
259 nxtzmax = 0.;
260 }
261 glClear(GL_DEPTH_BUFFER_BIT);
262 qtReplant();
263 return(1);
264 }
265
266
267 dev_section(ofn) /* add octree for geometry rendering */
268 char *ofn;
269 {
270 /* unimplemented */
271 }
272
273
274 dev_auxcom(cmd, args) /* process an auxiliary command */
275 char *cmd, *args;
276 {
277 sprintf(errmsg, "%s: unknown command", cmd);
278 error(COMMAND, errmsg);
279 }
280
281
282 VIEW *
283 dev_auxview(n, hvres) /* return nth auxiliary view */
284 int n;
285 int hvres[2];
286 {
287 if (n)
288 return(NULL);
289 hvres[0] = odev.hres; hvres[1] = odev.vres;
290 return(&odev.v);
291 }
292
293
294 int
295 dev_input() /* get X11 input */
296 {
297 inpresflags = 0;
298
299 do
300 getevent();
301
302 while (XQLength(ourdisplay) > 0);
303
304 return(inpresflags);
305 }
306
307
308 int
309 dev_flush() /* flush output */
310 {
311 qtUpdate();
312 glFlush();
313 rayqleft = RAYQLEN;
314 return(XPending(ourdisplay));
315 }
316
317
318 dev_cone(rgb, ip, rad) /* render a cone in view coordinates */
319 BYTE rgb[3];
320 FVECT ip;
321 double rad;
322 {
323 register int ci, j;
324 double apexh, basez;
325 /* is window mapped? */
326 if (!mapped)
327 return;
328 /* compute apex height (0. to 1.) */
329 if (ip[2] > 1e6)
330 apexh = 1. - 1./DEPTHFACT;
331 else {
332 if (ip[2] > nxtzmax)
333 nxtzmax = ip[2];
334 if (ip[2] >= curzmax)
335 apexh = 1. - 1./DEPTHFACT;
336 else
337 apexh = 1. - ip[2]/(curzmax*DEPTHFACT);
338 }
339 rad *= 1.25; /* find conservative cone match */
340 for (ci = 0; ci < MAXCONE-1; ci++)
341 if (cone[ci].rad >= rad)
342 break;
343 /* draw it */
344 glColor3ub(rgb[0], rgb[1], rgb[2]);
345 glBegin(GL_TRIANGLE_FAN);
346 glVertex3d(ip[0], ip[1], apexh); /* start with apex */
347 basez = apexh*cone[ci].va[0][2]; /* base z's all the same */
348 for (j = 0; j < cone[ci].nverts; j++) /* draw each face */
349 glVertex3d(ip[0]+cone[ci].va[j][0], ip[1]+cone[ci].va[j][1],
350 basez);
351 /* connect last to first */
352 glVertex3d(ip[0]+cone[ci].va[0][0], ip[1]+cone[ci].va[0][1], basez);
353 glEnd(); /* all done */
354 }
355
356
357 static int
358 mytmflags() /* figure out tone mapping flags */
359 {
360 extern char *progname;
361 register char *cp, *tail;
362 /* find basic name */
363 for (cp = tail = progname; *cp; cp++)
364 if (*cp == '/')
365 tail = cp+1;
366 for (cp = tail; *cp && *cp != '.'; cp++)
367 ;
368 if (cp-tail == 4 && !strncmp(tail, "glx1", 4))
369 return(TM_F_CAMERA|TM_F_NOSTDERR);
370 if (cp-tail == 5 && !strncmp(tail, "glx1h", 5))
371 return(TM_F_HUMAN|TM_F_NOSTDERR);
372 error(USER, "illegal driver name");
373 }
374
375
376 static
377 initcones() /* initialize cone vertices */
378 {
379 register int i, j;
380 double minrad, d;
381
382 if (cone[0].nverts)
383 freecones();
384 minrad = 2.*qtMinNodesiz/(double)(DisplayWidth(ourdisplay,ourscreen) +
385 DisplayHeight(ourdisplay,ourscreen));
386 for (i = 0; i < MAXCONE; i++) {
387 d = (double)i/(MAXCONE-1); d *= d; /* x^2 distribution */
388 cone[i].rad = minrad + (1.-minrad)*d;
389 cone[i].nverts = MINVERT + 0.5 + (MAXVERT-MINVERT)*d;
390 cone[i].va = (FVECT *)malloc(cone[i].nverts*sizeof(FVECT));
391 if (cone[i].va == NULL)
392 error(SYSTEM, "out of memory in initcones");
393 for (j = cone[i].nverts; j--; ) {
394 d = 2.*PI * (j+.5) / (cone[i].nverts);
395 cone[i].va[j][0] = cos(d) * cone[i].rad;
396 cone[i].va[j][1] = sin(d) * cone[i].rad;
397 cone[i].va[j][2] = 1. - cone[i].rad;
398 }
399 }
400 }
401
402
403 static
404 freecones() /* free cone vertices */
405 {
406 register int i;
407
408 for (i = MAXCONE; i--; )
409 if (cone[i].nverts) {
410 free((void *)cone[i].va);
411 cone[i].va = NULL;
412 cone[i].nverts = 0;
413 }
414 }
415
416
417 static
418 getevent() /* get next event */
419 {
420 XNextEvent(ourdisplay, levptr(XEvent));
421 switch (levptr(XEvent)->type) {
422 case ConfigureNotify:
423 resizewindow(levptr(XConfigureEvent));
424 break;
425 case UnmapNotify:
426 mapped = 0;
427 break;
428 case MapNotify:
429 mapped = 1;
430 break;
431 case Expose:
432 fixwindow(levptr(XExposeEvent));
433 break;
434 case KeyPress:
435 getkey(levptr(XKeyPressedEvent));
436 break;
437 case ButtonPress:
438 getmove(levptr(XButtonPressedEvent));
439 break;
440 }
441 }
442
443
444 static
445 draw3dline(wp) /* draw 3d line in world coordinates */
446 register FVECT wp[2];
447 {
448 glVertex3d(wp[0][0], wp[0][1], wp[0][2]);
449 glVertex3d(wp[1][0], wp[1][1], wp[1][2]);
450 }
451
452
453 static
454 draw_grids() /* draw holodeck section grids */
455 {
456 static BYTE gridrgba[4] = {0x0, 0xff, 0xff, 0x00};
457 double xmin, xmax, ymin, ymax, zmin, zmax;
458 double d, cx, sx, crad;
459 FVECT vx, vy;
460 register int i, j;
461 /* can we even do it? */
462 if (!mapped || odev.v.type != VT_PER)
463 return;
464 /* compute view frustum */
465 if (normalize(odev.v.vdir) == 0.0)
466 return;
467 zmin = 0.01;
468 zmax = 10000.;
469 if (odev.v.vfore > FTINY)
470 zmin = odev.v.vfore;
471 if (odev.v.vaft > FTINY)
472 zmax = odev.v.vaft;
473 xmax = zmin * tan(PI/180./2. * odev.v.horiz);
474 xmin = -xmax;
475 d = odev.v.hoff * (xmax - xmin);
476 xmin += d; xmax += d;
477 ymax = zmin * tan(PI/180./2. * odev.v.vert);
478 ymin = -ymax;
479 d = odev.v.voff * (ymax - ymin);
480 ymin += d; ymax += d;
481 /* set view matrix */
482 glMatrixMode(GL_PROJECTION);
483 glPushMatrix();
484 glLoadIdentity();
485 glFrustum(xmin, xmax, ymin, ymax, zmin, zmax);
486 gluLookAt(odev.v.vp[0], odev.v.vp[1], odev.v.vp[2],
487 odev.v.vp[0] + odev.v.vdir[0],
488 odev.v.vp[1] + odev.v.vdir[1],
489 odev.v.vp[2] + odev.v.vdir[2],
490 odev.v.vup[0], odev.v.vup[1], odev.v.vup[2]);
491 glDisable(GL_DEPTH_TEST); /* write no depth values */
492 glColor4ub(gridrgba[0], gridrgba[1], gridrgba[2], gridrgba[3]);
493 glBegin(GL_LINES); /* draw each grid line */
494 gridlines(draw3dline);
495 glEnd();
496 glEnable(GL_DEPTH_TEST); /* restore rendering params */
497 glPopMatrix();
498 }
499
500
501 static
502 moveview(dx, dy, mov, orb) /* move our view */
503 int dx, dy, mov, orb;
504 {
505 VIEW nv;
506 FVECT odir, v1;
507 double d;
508 register int li;
509 /* start with old view */
510 copystruct(&nv, &odev.v);
511 /* change view direction */
512 if (mov | orb) {
513 if ((li = qtFindLeaf(dx, dy)) < 0)
514 return(0); /* not on window */
515 VSUM(odir, qtL.wp[li], nv.vp, -1.);
516 } else {
517 if (viewray(nv.vp, nv.vdir, &odev.v,
518 (dx+.5)/odev.hres, (dy+.5)/odev.vres) < -FTINY)
519 return(0); /* outside view */
520 }
521 if (orb && mov) { /* orbit left/right */
522 spinvector(odir, odir, nv.vup, d=MOVDEG*PI/180.*mov);
523 VSUM(nv.vp, qtL.wp[li], odir, -1.);
524 spinvector(nv.vdir, nv.vdir, nv.vup, d);
525 } else if (orb) { /* orbit up/down */
526 fcross(v1, odir, nv.vup);
527 if (normalize(v1) == 0.)
528 return(0);
529 spinvector(odir, odir, v1, d=MOVDEG*PI/180.*orb);
530 VSUM(nv.vp, qtL.wp[li], odir, -1.);
531 spinvector(nv.vdir, nv.vdir, v1, d);
532 } else if (mov) { /* move forward/backward */
533 d = MOVPCT/100. * mov;
534 VSUM(nv.vp, nv.vp, odir, d);
535 }
536 if (!mov ^ !orb && headlocked) { /* restore head height */
537 VSUM(v1, odev.v.vp, nv.vp, -1.);
538 d = DOT(v1, odev.v.vup);
539 VSUM(nv.vp, nv.vp, odev.v.vup, d);
540 }
541 if (setview(&nv) != NULL)
542 return(0); /* illegal view */
543 dev_view(&nv);
544 inpresflags |= DFL(DC_SETVIEW);
545 return(1);
546 }
547
548
549 static
550 getmove(ebut) /* get view change */
551 XButtonPressedEvent *ebut;
552 {
553 int movdir = MOVDIR(ebut->button);
554 int movorb = MOVORB(ebut->state);
555 int oldnodesiz = qtMinNodesiz;
556 Window rootw, childw;
557 int rootx, rooty, wx, wy;
558 unsigned int statemask;
559
560 qtMinNodesiz = 24; /* accelerate update rate */
561 XNoOp(ourdisplay);
562
563 while (!XCheckMaskEvent(ourdisplay,
564 ButtonReleaseMask, levptr(XEvent))) {
565
566 if (!XQueryPointer(ourdisplay, gwind, &rootw, &childw,
567 &rootx, &rooty, &wx, &wy, &statemask))
568 break; /* on another screen */
569
570 if (!moveview(wx, odev.vres-1-wy, movdir, movorb)) {
571 sleep(1);
572 continue;
573 }
574 glClear(GL_COLOR_BUFFER_BIT);
575 qtUpdate();
576 draw_grids();
577 glFlush();
578 }
579 if (!(inpresflags & DFL(DC_SETVIEW))) { /* do final motion */
580 movdir = MOVDIR(levptr(XButtonReleasedEvent)->button);
581 wx = levptr(XButtonReleasedEvent)->x;
582 wy = levptr(XButtonReleasedEvent)->y;
583 moveview(wx, odev.vres-1-wy, movdir, movorb);
584 }
585 dev_flush();
586
587 qtMinNodesiz = oldnodesiz; /* restore quadtree resolution */
588 }
589
590
591 static
592 getkey(ekey) /* get input key */
593 register XKeyPressedEvent *ekey;
594 {
595 int n;
596 char buf[8];
597
598 n = XLookupString(ekey, buf, sizeof(buf), NULL, NULL);
599 if (n != 1)
600 return;
601 switch (buf[0]) {
602 case 'h': /* turn on height motion lock */
603 headlocked = 1;
604 return;
605 case 'H': /* turn off height motion lock */
606 headlocked = 0;
607 return;
608 case 'l': /* retrieve last view */
609 inpresflags |= DFL(DC_LASTVIEW);
610 return;
611 case 'p': /* pause computation */
612 inpresflags |= DFL(DC_PAUSE);
613 return;
614 case 'v': /* spit out view */
615 inpresflags |= DFL(DC_GETVIEW);
616 return;
617 case '\n':
618 case '\r': /* resume computation */
619 inpresflags |= DFL(DC_RESUME);
620 return;
621 case CTRL('R'): /* redraw screen */
622 if (nxtzmax > FTINY) {
623 curzmax = nxtzmax;
624 nxtzmax = 0.;
625 }
626 glClear(GL_DEPTH_BUFFER_BIT);
627 qtRedraw(0, 0, odev.hres, odev.vres);
628 return;
629 case CTRL('L'): /* refresh from server */
630 if (inpresflags & DFL(DC_REDRAW))
631 return;
632 if (nxtzmax > FTINY) {
633 curzmax = nxtzmax;
634 nxtzmax = 0.;
635 }
636 glClear(GL_COLOR_BUFFER_BIT | GL_DEPTH_BUFFER_BIT);
637 draw_grids();
638 glFlush();
639 qtCompost(100); /* get rid of old values */
640 inpresflags |= DFL(DC_REDRAW); /* resend values from server */
641 rayqleft = 0; /* hold off update */
642 return;
643 case 'K': /* kill rtrace process(es) */
644 inpresflags |= DFL(DC_KILL);
645 break;
646 case 'R': /* restart rtrace */
647 inpresflags |= DFL(DC_RESTART);
648 break;
649 case 'C': /* clobber holodeck */
650 inpresflags |= DFL(DC_CLOBBER);
651 break;
652 case 'q': /* quit the program */
653 inpresflags |= DFL(DC_QUIT);
654 return;
655 default:
656 XBell(ourdisplay, 0);
657 return;
658 }
659 }
660
661
662 static
663 fixwindow(eexp) /* repair damage to window */
664 register XExposeEvent *eexp;
665 {
666 int xmin, xmax, ymin, ymax;
667
668 if (odev.hres == 0 || odev.vres == 0) /* first exposure */
669 resizewindow((XConfigureEvent *)eexp);
670 xmin = eexp->x; xmax = eexp->x + eexp->width;
671 ymin = odev.vres - eexp->y - eexp->height; ymax = odev.vres - eexp->y;
672 /* clear portion of depth */
673 glColorMask(GL_FALSE, GL_FALSE, GL_FALSE, GL_FALSE);
674 glDepthFunc(GL_ALWAYS);
675 glBegin(GL_POLYGON);
676 glVertex3d((double)xmin/odev.hres, (double)ymin/odev.vres, 0.);
677 glVertex3d((double)xmax/odev.hres, (double)ymin/odev.vres, 0.);
678 glVertex3d((double)xmax/odev.hres, (double)ymax/odev.vres, 0.);
679 glVertex3d((double)xmin/odev.hres, (double)ymax/odev.vres, 0.);
680 glEnd();
681 glColorMask(GL_TRUE, GL_TRUE, GL_TRUE, GL_TRUE);
682 glDepthFunc(GL_LEQUAL);
683 qtRedraw(xmin, ymin, xmax, ymax);
684 }
685
686
687 static
688 resizewindow(ersz) /* resize window */
689 register XConfigureEvent *ersz;
690 {
691 glViewport(0, 0, ersz->width, ersz->height);
692
693 if (ersz->width == odev.hres && ersz->height == odev.vres)
694 return;
695
696 odev.hres = ersz->width;
697 odev.vres = ersz->height;
698
699 odev.v.horiz = 2.*180./PI * atan(0.5/VIEWDIST*pwidth*odev.hres);
700 odev.v.vert = 2.*180./PI * atan(0.5/VIEWDIST*pheight*odev.vres);
701
702 inpresflags |= DFL(DC_SETVIEW);
703 }
